Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Don’t know what i’m doing wrong, but can’t succeed to remove the circle around the icon in the chip-area.
Also possible to remove the divider between the main card and the chip card?
Any help/advise ?
type: custom:stack-in-card
cards:
    primary: Woonkamer
    secondary: >-
      {{ states('sensor.toon_room_temp') }} °C    {{
      states('sensor.bedroom_j_temperature_humidity') }} %
      {{ states('sensor.tpl_television') }}
    icon: fapro:couch
    entity: light.livingroom_led_television
    tap_action:
      action: navigate
      navigation_path: /dashboard-mushroom/woonkamer
    hold_action:
      action: navigate
      navigation_path: /dashboard-mushroom/tvgids
    icon_color: '{{ state( ''on'') else ''disabled'' }}'
    fill_container: true
    layout: horizontal
    multiline_secondary: true
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0);
          --mush-icon-size: 76px;
          height: 80px;
          margin-left: -18px !important;
  - type: custom:mushroom-chips-card
    chips:
      - type: conditional
        conditions:
          - entity: binary_sensor.livingroom_motion_occupancy
            state: 'on'
        chip:
          type: template
          icon_color: red
          icon: mdi:walk
          card_mod:
            style: |
              ha-card {
                animation: blink 1s linear infinite;
              @keyframes blink {
                50% {opacity: 0;}
      - type: conditional
        conditions:
          - entity: light.livingroom_led_television
            state: 'on'
        chip:
          type: template
          icon_color: green
          icon: mdi:led-strip-variant
          tap_action:
            action: more-info
            browser_mod:
              command: popup
              deviceID: null
              title: null
              card:
                type: custom:mod-card
                style: |
                  ha-card {
                    padding-right: 45px;
                    padding-left: 45px;
                    padding-bottom: 45px;
                    box-shadow: none;
      - type: conditional
        conditions:
            state: 'off'
        chip:
          type: template
          icon_color: red
          icon: mdi:led-strip-variant-off
          tap_action:
            action: more-info
            browser_mod:
              command: popup
              deviceID: null
              title: null
              card:
                style: |
                  ha-card {
                    padding-left: 45px;
                    box-shadow: none;
    alignment: end
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 0;
          box-shadow: none;
card_mod:
  style: |
    ha-card {
      box-shadow: none;
      height: 120px;
      {% if is_state('light.livingroom_led_television', 'on') %}
         background: rgba({{ states('sensor.tpl_television_led') }}, 0.15);
      {% endif %}
many thanks for your help. your code works.
Why can’t you tab/focus mushroom cards?
In the theme yaml you are using
I wouldn’t suggest using it though, it messes with other elements. I ended up removing it.
Edit:
This seems to work better (using card_mod):
Theme Name:
  card-mod-theme: "Theme Name"
  card-mod-card-yaml: |
      ha-state-icon {
        line-height: 0;
Be warned I have no idea what this will do to other cards. It would affect anything that uses ha-state-icon. I would wait for a fix from piitaya.
Thanks for the heads up! Wasnt sure where to add it in exactly. Wont do it now, but good to know for future that its under card mod.
it work in card via:
card_mod:
  style: |
    mushroom-shape-icon {
        line-height: 0.1rem;
Thanks, yes ive done that for now. Will change it back once fixed :slight_smile:
edit:
    card_mod:
      style: |
        :host {
          height: 80px;
          border-widht: 0px;
        ha-card {
          border-width: 0px;
and about circle:
edit:
    card_mod:
      style: |
        ha-card {
          --chip-spacing: 0;
          --chip-border-width:0px;
00
Hey all, haven’t been here in a while.
Anyone else experiencing broken animations after the core update on iOS companion app?
Saw there was an update to fix this bĆ«t it didn’t.
Hi all,
Can somebody help me with some code.
I want to have my fan icon spin in the chip header, i already got it running in a normal card but can’t get it working in the chip header.
At this moment i got the following code (fan is a static icon now), so what code do i have to put in to get the fan icon spinning with the state when it’s on and when it’s off no spinning :slight_smile:
- type: template
    double_tap_action:
      action: none
    entity: light.fan
    icon: mdi:fan
This is the code that i use in template card and it works great.
type: custom:mushroom-template-card
icon: mdi:fan
entity: light.fan
tap_action:
  action: toggle
icon_color: '{{ ''green'' if is_state(''light.fan'', ''on'') else ''grey'' }}'
primary: Ventilator
secondary: '{{ states(entity) | title }}'
hold_action:
  action: none
double_tap_action:
  action: none
card_mod:
  style: |
        {% if is_state('light.fan','on') %}
        --icon-animation: spin 1s linear infinite;
        @keyframes shake {
          0%, 100% { transform: translate(0, 0) rotate(0); }
          20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
          40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
          60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
          80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
        @keyframes drum {
          50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
        {% else %}
        {% endif %}
Thank you.
Put your code as preformatted text please
same here, on browser
 reading back the posts but bit difficult to filter out the right code
Ok got it to work on browser (chrome) but not iOS! or companion app.
Step1: replace “ha-icon” with “ha-state-icon”
Step 2: delete “mushroom-shape-icon$:”
Step 3: Make sure style is like this: “style: |”
Tha got it to work on chrome on pc but not on iOS!
@rhysb They broke it. Any ideas how to get animations to work on safari again?
Yes done it :slight_smile:
Here’s the vertical Door Lock Card.
cards:
    primary: Laundry Door
    secondary: >-
      {% if is_state('lock.door_lock','unlocked') and
      is_state('binary_sensor.laundry_door_sensor_access_control_window_door_is_open','on')
        Open and Unlocked
      {% elif
        Door Open
      {% elif is_state('lock.door_lock','unlocked') %}
        Unlocked
      {% else %}
        Locked
      {% endif%}
    icon: >-
        mdi:door-open
      {% elif
        mdi:door-open
        mdi:lock-open
      {% else %}
        mdi:lock
      {% endif%}
    icon_color: >-
      {% if is_state('lock.door_lock','locked') and
      is_state('binary_sensor.laundry_door_sensor_access_control_window_door_is_open','off')
        green
      {% else %}
        red
      {% endif%}
    badge_icon: |-
      {% set bl = states('sensor.laundry_door_sensor_battery_level') | int %}
      {% if bl < 10 %} mdi:battery-outline
      {% elif bl < 20 %} mdi:battery-10
      {% elif bl < 30 %} mdi:battery-20
      {% elif bl < 40 %} mdi:battery-30
      {% elif bl < 50 %} mdi:battery-40
      {% elif bl < 60 %} mdi:battery-50
      {% elif bl < 70 %} mdi:battery-60
      {% elif bl < 80 %} mdi:battery-70
      {% elif bl < 90 %} mdi:battery-80
      {% elif bl < 100 %} mdi:battery-90
      {% elif bl == 100 %} mdi:battery
      {% else %} mdi:battery-unknown
      {% endif %}
    badge_color: |-
      {% if bl < 10 %} red
      {% elif bl < 20 %} red
      {% elif bl < 30 %} red
      {% elif bl < 40 %} orange
      {% elif bl < 50 %} orange
      {% elif bl < 60 %} green
      {% elif bl < 70 %} green
      {% elif bl < 80 %} green
      {% elif bl < 90 %} green
      {% elif bl < 100 %} green
      {% elif bl == 100 %} green
      {% else %} disabled
      {% endif %}
    tap_action:
      action: none
    card_mod:
      style: |
        mushroom-badge-icon {
          left: -3px;
  - type: grid
    square: false
    columns: 2
    cards:
        primary: ''
        secondary: ''
        icon: mdi:lock-smart
        badge_icon: |-
          {% set bl = states('sensor.door_lock_battery_level') | int %}
          {% endif %}
        badge_color: |-
          {% else %} disabled
          {% endif %}
        tap_action:
          action: navigate
          navigation_path: keypad-laundry_room
        card_mod:
          style: |
              left: -3px;
            ha-card {
              margin-top: -12px;
              --icon-border-radius: 12px;
              --icon-color: #e1e1e1 !important;
      - type: custom:mushroom-lock-card
        entity: lock.door_lock
        primary_info: none
        secondary_info: none
        icon_type: none
        card_mod:
          style: |
            ha-card {
              margin-top: -12px;
              margin-left: -52px;
card_mod:
  style: |
    ha-card {
      is_state('binary_sensor.laundry_door_sensor_access_control_window_door_is_open','off') %}
          background: rgba(101,170,91,0.2);
      {% else %}
          background: rgba(226,84,66,0.2);
      {% endif %}
Not sure what you’re taking about with the Raptor Door Locks, here’s my current Raptor page.
Thanks a lot!
Thought i tried everything, but didn’t thought about this option.
This worked for some. THANK YOU :slightly_smiling_face:
What about the below when there are shapes? any advice?
        entity: switch.pool_filter_pump
        primary: Filter
        icon: none
        icon_color: ''
        badge_color: ''
        card_mod:
          style:
            mushroom-shape-icon$: |
              ha-icon {
                {{'--icon-animation: spin 0.5s linear infinite reverse;' if is_state(config.entity, 'on') }}
                border-radius: 50%;
                {{'border: 8px dotted rgb(var(--rgb-red));' if is_state(config.entity, 'on') else 'border: 8px dotted rgb(var(--rgb-disabled));'}}
              .shape {
                {{'border: 4px dashed rgb(var(--rgb-green));' if is_state(config.entity, 'on') else 'border: 4px dashed rgb(var(--rgb-disabled));'}}
                {{'--shape-animation: spin 2s linear infinite;' if is_state(config.entity, 'on') }}
                --shape-color: none;
                --icon-symbol-size: 5px;
                --icon-size: 34px;
Try like this. i think the animation is working as intended, but not 100% sure as i dont know what it is supposed to look like :slight_smile:
  primary: Filter
  icon: none
  icon_color: ''
  badge_color: ''
  card_mod:
    style:
        .shape {
          --icon-size: 34px;
        ha-state-icon {
          border-radius: 50%;
EDIT: Fixed it. realised that there were 2 different animated elements and only 1 was working. works as intended i think now :slight_smile:
read the great post series about animation from rhysb
Everything’s there
How did you position the blue icon near “Salon” ?
