Just upgraded to 3.0.3 after waiting a while for the ha-icon thing to be clear. I have looked at all the examples provided here but cannot seem to get everything working.
I have a person card popup (from @rhysb ) with an animated icon for my phones battery level. With the ha-icon not working, I tried to restore the animation. I can get that to work, but in the process I somehow wreck the circle shape around the icon. Or I somehow lose the ha-card background removal. Getting all to work seems impossible
Can someone please help me out?
type: custom:mushroom-template-card
primary: '{{ states(entity) }}%'
secondary: >
{{ 'Laden' if is_state('binary_sensor.oneplus_9pro_maarten_is_charging', 'on'
) else 'Ontladen' }}
icon: |
{% set battery_level = (states(entity) | int / 10) | round(0) | int * 10 %}
{% if battery_level == 100 %}
mdi:battery
{% elif battery_level > 0 %}
mdi:battery-{{ battery_level }}
{% else %}
mdi:battery-alert-variant-outline
{% endif %}
icon_color: |-
{% set battery_level = states(entity) | int %}
{% if battery_level > 90 %}
green
{% elif battery_level > 60 %}
light-green
{% elif battery_level > 50 %}
lime
{% elif battery_level > 40 %}
yellow
{% elif battery_level > 30 %}
amber
{% elif battery_level > 20 %}
orange
{% elif battery_level > 10 %}
deep-orange
{% else %}
red
{% endif %}
entity: sensor.oneplus_9pro_maarten_battery_level
layout: vertical
badge_icon: |-
{% if is_state('binary_sensor.oneplus_9pro_maarten_is_charging', 'on') %}
mdi:lightning-bolt
{% elif states(entity) | int < 10 %}
mdi:exclamation-thick
{% endif %}
badge_color: '{{ ''red'' if states(entity) | int < 10 else ''light-blue'' }}'
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style:
mushroom-shape-icon$: |
.shape {
/* Radial progress bar */
background: radial-gradient(var(--card-background-color) 60%,
transparent calc(60% + 1px)),
conic-gradient(var(--icon-color) {{ states(config.entity) }}% 0%,
var(--card-background-color) 0% 100%);
.shape:after {
/* Add back icon shape */
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: var(--icon-border-radius);
background: var(--shape-color);
ha-icon {
/* Icon charging animation */
{{ '--icon-animation: charge 3s linear infinite;' if is_state('binary_sensor.maarten_phone_is_charging', 'on') }}
@keyframes charge {
0%, 80% { clip-path: inset(0 0 0 0); }
10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
ha-card {
/* Remove default card styling */
--ha-card-background: none;
--ha-card-box-shadow: none;
--ha-card-border-width: 0;
/* Center card on row */
width: fit-content;
margin: auto;
/* Make card non-responsive to select and pointer */
user-select: none;
pointer-events: none;
