I have many sensors for which the icon and the color are defined in the customize_glob.yaml file.
It would be nice if the icon and the color defined in this file are used in the chip card without having to use the template option (avoid duplication/replication).
Anyway to have use_entity_picture: true in the light card? I see it is an option with entity card and its super cool to have all my own pictures with the amount of control offering from your card.
Not sure if you ever got this working, but I ended up using a markdown card with card_mod to make font adjustments.
Hopefully, it’ll be an option with Mushroom down the road.
Has anyone achieved an ‘include’ card?
ie - I have set up a mobile view in KIOSK mode and every single one on my pages utilizes a shared or similar chips navigation header.
So if I have 20 linked pages of information, each has the same top menu. However currently they need to be individually edited.
Is there a way to ‘include’ one header file that can be shared over multiple pages and only edited it in one place?
Of course you know better (since you wrote it ) but it is still the shortest and straight forward code I saw around here in this regard and I am still ‘studying’ it. so though to point to it for common benefit.
Has anyone here been able to set the color for the icon and slider on the mushroom cover card? I have tried this, using the theme, but can’t seem to get it to work. It keeps displaying with the blue color instead of the mushroom brown color that I prefer to use.
The Mushroom theme is ‘under’ the normal theme. It only changes the corners to be round or square etc.
If you want the Mushroom theme to be powerful, make your own theme and put all of the mushroom variables in it.
So start with this in your theme: as stated ‘Build you own’.
It is still depending on the basic theme, but you get the feeling…
