Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
its still on the left for me:
what i am doing wrong? :thinking:
Code
type: custom:mushroom-template-card
entity: ''
primary_info: none
secondary_info: none
icon: mdi:test-tube
card_mod:
  style: |
    mushroom-shape-icon {
      --shape-color: none !important;
    ha-card {
      width: 100px;
      height: 40px !important;
      background: none;
      border: 1 !important;
      box-shadow: none !important;
      transition: 1s;
    ha-card:hover {
      background: red !important;
    mushroom-state-item {
      display: grid;
      justify-items: center !important;
Nothing wrong. but sorry i just assumed you meant you wanted to center the contents of the card not the card itself on the view.
easiest way to center a single card would be to just add margin. but i think what you want is each card centered neatly inside of the grid card. without starting to use something like the mod card its really difficult to try and do, so i would just replicate the buttons like this with sizing them right:
type: grid
square: false
cards:
    primary: null
    secondary: null
    icon: mdi:home
    card_mod:
      style: |
        ha-card {
          width: 120px;
          transition: 1s;
          border-radius: 10px !important;
          background: rgba(var(--rgb-disabled), 0.2) !important;
          left: 8px;
        ha-card:hover {
          display: grid;
    primary: null
    secondary: null
    icon: mdi:home
    card_mod:
      style: |
        ha-card {
          width: 120px;
          transition: 1s;
          left: 4px;
        ha-card:hover {
          display: grid;
    primary: null
    secondary: null
    icon: mdi:home
    card_mod:
      style: |
        ha-card {
          width: 120px;
          transition: 1s;
        ha-card:hover {
          display: grid;
i tried it and it looked good:
but when i viewed it from mobile things got messy (even when i used % instead of px):
wouldnt it be better to style the icon-shape as a button instead of the ha-card?
actually probably better to just use Chips instead. then you can set the chip container to justify content and they will work on different screen sizes :slight_smile:
type: custom:stack-in-card
cards:
    primary: ''
    secondary: ''
    icon: mdi:home
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        icon: mdi:arrow-up
        card_mod:
          style: |
            ha-card {
              width: 118px !important;
              transition: 1s;
            ha-card:hover {
      - type: template
        icon: mdi:square
        card_mod:
          style: |
            ha-card {
              transition: 1s;
            ha-card:hover {
      - type: template
        icon: mdi:arrow-down
        card_mod:
          style: |
            ha-card {
              transition: 1s;
            ha-card:hover {
    alignment: justify
    card_mod:
      style:
        mushroom-template-chip:nth-child(1)$:
          mushroom-chip$: |
            ha-card {
              display: grid !important;
        mushroom-template-chip:nth-child(2)$:
          mushroom-chip$: |
            ha-card {
        mushroom-template-chip:nth-child(3)$:
          mushroom-chip$: |
            ha-card {
          ha-card {
            padding: 0px 10px 10px 10px
thanks, but somehow it looks different at my side and spacing is very strange.
will this even work on different screen sizes if the ha-card with and height is defined as pixels? :thinking:
You are right. i was just saying that using the chip card as a base will ensure it works on all screen sizes. but you still need to figure out how to size the width chips themselves dynamically. the height being set shouldnt matter at all.
i found that this code works courtesy of @eMeF
Code
cards:
    primary: ''
    secondary: ''
    icon: mdi:home
    chips:
      - type: template
        icon: mdi:arrow-up
        card_mod:
          style: |
            ha-card {
              justify-content: center;
              transition: 1s;
            ha-card:hover {
      - type: template
        icon: mdi:square
        card_mod:
          style: |
            ha-card {
              transition: 1s;
            ha-card:hover {
      - type: template
        card_mod:
          style: |
            ha-card {
              transition: 1s;
            ha-card:hover {
    alignment: justify
    card_mod:
      style: |
        mushroom-template-chip {
          width: 100%;
        div.chip-container {
          justify-content: space-evenly;
          flex-wrap: nowrap;
        ha-card {
          margin: 0px 12px 12px;
          --chip-spacing: 12px !important;
Hello!
I have just updated to the latest version. But now my navigation bar is up top instead of at the bottom.
Can someone help me with what I should write in the theme file to move it back down again?
first thing i would do is see if there is a card-mod update for you to install as well. install it, then clear your browser/apps cache and see if that helps :slight_smile:
The first card you got there looks really nice with that black information bar. Can you share your code? :slight_smile:
Is there a way to adjust the spaxing between primary and secondary information of a template card uaing card_mod? Thanks in advance and best regards
in my guide:
doesnt tell you exactly what you want, but you could always just do:
    card_mod:
      style:
        mushroom-state-info$: |
          .container {
            gap: 20px;
I just wanted to pass on a big thanks to Dimitri and Rhys for their numerous examples and code. I decided to redesign my entire dashboard and have made good progress so far on the homepage. Still a long way to go but I’m happy. Room cards change picture based on light status so if lights are off it will show picture of room with lights off.
I will when I have some spare time. Writing a manual takes hours. But with the manual you can easily configure the dashboard to your needs.
Nice can you share how did you do your welcome card with chips please?
First, Lovely mushroom card! Bravo!
Second, Is there a way to change the dimming method on the light cards?
Instead of adjusting immediately while sliding, sending the adjust only after you release the slider. Like the others.
I notice that some dimmers prefer that.
Thanks!
Nice card, mind sharing the code?
Hey guys!
It might be a stupid question, however, I think I am facing some slow respond to taps on the mushroom cards. I do feel there is one second or smth like that of a delay when I click on a switch/light/any-actionable thing. Is it only me?
I tried searching the thread but didnt find anything similar? Anyone aware of how I can reduce this ‘delay’?
I’m trying to create a card with my temperature and humidity sensors. I try to put a title on the card, by using the area_name of the area where my sensor is :
type: vertical-stack
cards:
  - type: custom:mushroom-title-card
    title: {{ area_name('Temp_Hum_1') }}
  - type: horizontal-stack
    cards:
        primary: Température
        icon: mdi:home-thermometer-outline
        secondary: '{{ states.sensor.temp_hum_1_temperature.state_with_unit }}'
        primary: Humidité
        secondary: '{{ states.sensor.temp_hum_1_humidity.state_with_unit }}'
Unfortunately, it’s not working : I’ve got no title :
Capture d’écran du 2023-10-15 23-55-58
An idea how to sort it out ?
I was previously using a birthday card on my dashboard. This card showed only one person’s birthday. For a long time, I wanted to design a card where I could visually see the upcoming birthdays of several people at the same time. I was able to do this with the list calendar events feature that comes in Home Assistant 2023.9 ​​version.
This card currently lists 4 people who have birthdays in the coming days. The cards also work in a dynamic structure and shows the time left until the birthday. When the birthday is over, it renews itself and moves on to the next person’s birthday card. I will also put a button on the cards so that it will activate an automation that will give me an extra reminder. By the way, the card shows only 4 people, but this number can be increased if desired. As far as I know, there is no card or integration that visually displays birthdays on the Home assistant. I will also use these cards in the tablet interface that can be controlled with Alexa, which I will build in the coming weeks.
Similarly, I created a card to follow football matches.
Its just a combination of different stack in cards.
Here’s the code.
cards:
  - type: custom:layout-card
    layout_type: masonry
    layout: {}
    cards:
        chips:
          - type: template
            entity: alarm_control_panel.yale_smart_alarm
            content_info: none
            icon: >-
              {{ 'mdi:shield-off' if
              is_state('alarm_control_panel.yale_smart_alarm', 'disarmed') else
              'mdi:shield-check' }}
            icon_color: >-
              {{ 'red' if is_state('alarm_control_panel.yale_smart_alarm',
              'disarmed') else 'green' }}
          - type: template
            entity: lock.front_door
            icon: >-
              {{ 'mdi:lock' if is_state('lock.front_door', 'locked') else
              'mdi:lock-open-variant' }}
            icon_color: '{{ ''green'' if is_state(''lock.front_door'', ''locked'') else ''red'' }}'
            content: null
            hold_action:
              action: call-service
              service: lock.unlock
                code: 'XXXX'
                entity_id: lock.front_door
            tap_action:
              action: more-info
          - type: spacer
          - type: weather
            entity: weather.winshields_way
            show_conditions: true
            show_temperature: true
        title: |-
          {% set time = now().hour %}
          {% if (time >= 18) %}
           Good Evening, {{user}}!
          {% elif (time >= 12) %}
           Good Afternoon, {{user}}!
          {% elif (time >= 5) %}
           Good Morning, {{user}}!
          {% else %}
           Hello, {{user}}
          {% endif %}
        subtitle: ''
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
              background: none;
              border-radius: 0px;
              margin-left: auto;
              margin-right: auto;
              margin-bottom: -25px;
              margin-top: -25px;
        cards:
          - type: custom:stack-in-card
            cards:
                primary: >-
                  {{ states('person.greg').replace('not_home',
                  'Away').title() }}
                hold_action:
                  action: toggle
                tap_action:
                  action: navigate
                  navigation_path: /home-v2/hallway
                fill_container: true
                layout: vertical
                multiline_secondary: false
                card_mod:
                  style:
                      .primary {
                        text-shadow: 1px 0px 2px black;
                        --card-primary-font-weight: 400;
                        --primary-text-color: white;
                        --card-primary-font-size: 12px;
                        #align-items: end;
                        margin-top: 70px;
                        inline-size: 75px;
                        margin-left: auto;
                        text-transform: capitalize;
                        text-align: left;
                        text-indent: 7px;
                      .secondary {
                        --card-secondary-font-size: 13px;
                          text-shadow: 0px 0px 5px black;
                        --secondary-text-color: white;
                        --card-secondary-font-weight: 350;
                          margin-top: -5px;
                          margin-left: -35px;
                      :host {
                      {% if is_state('person.greg', 'home') %}
                        background: url('/local/images/persons/greg.JPG') center;
                        background-size: contain;
                        background-position-y: -30px;
                        #filter: grayscale(70%);
                        #background-color: rgba(var(--rgb-card-background-color), 0.0);
                      {%- else -%}
                        #background-blend-mode: overlay;
                        filter: grayscale(100%);
                      {% endif %}
                        --mush-icon-size: 0px;
                        height: 200px;
                        margin-left: -15px !important;
                        margin-top: -70px !important;
                        --shape-color: rgba(var(--rgb-{{ 'orange' if is_state('light.hallway_lamp', 'on') else 'disabled' }}), 0.4) !important;
            card_mod:
              style: |
                ha-card {
                  height: 75px;
                  width: 75px;
                  border-radius: 7.5px;
                  margin-left: auto;
                  margin-right: auto;
            cards:
                primary: >-
                  {{ states('person.sarah').replace('not_home',
                  'Away').title() }}
                hold_action:
                  action: toggle
                tap_action:
                  action: navigate
                layout: vertical
                card_mod:
                  style:
                      .primary {
                        #align-items: end;
                        margin-top: 70px;
                        inline-size: 75px;
                        margin-left: auto;
                        text-align: left;
                        text-indent: 7px;
                      .secondary {
                          margin-top: -5px;
                          margin-left: -35px;
                      :host {
                      {% if is_state('person.sarah', 'home') %}
                        background: url('/local/images/persons/sarah.JPG') center;
                      {%- else -%}
                      {% endif %}
                        height: 200px;
            card_mod:
              style: |
                ha-card {
                  height: 75px;
                  width: 75px;
                  margin-left: auto;
                  margin-right: auto;
            cards:
                primary: >-
                  {{ states('person.cameron').replace('not_home',
                  'Away').title() }}
                hold_action:
                  action: toggle
                tap_action:
                  action: navigate
                layout: vertical
                card_mod:
                  style:
                      .primary {
                        #align-items: end;
                        margin-top: 70px;
                        inline-size: 75px;
                        margin-left: auto;
                        text-align: left;
                        text-indent: 7px;
                      .secondary {
                          margin-top: -5px;
                          margin-left: -35px;
                      :host {
                      {% if is_state('person.cameron', 'home') %}
                        background: url('/local/images/persons/cameron.JPG') center;
                        background-position-y: -20px;
                      {%- else -%}
                      {% endif %}
                        height: 200px;
            card_mod:
              style: |
                ha-card {
                  height: 75px;
                  width: 75px;
                  margin-left: auto;
                  margin-right: auto;
            cards:
                primary: >-
                  {{ states('person.rhys').replace('not_home',
                  'Away').title() }}
                hold_action:
                  action: toggle
                tap_action:
                  action: navigate
                layout: vertical
                card_mod:
                  style:
                      .primary {
                        #align-items: end;
                        margin-top: 70px;
                        inline-size: 75px;
                        margin-left: auto;
                        text-align: left;
                        text-indent: 7px;
                      .secondary {
                          margin-top: -5px;
                          margin-left: -35px;
                      :host {
                      {% if is_state('person.rhys', 'home') %}
                        background: url('/local/images/persons/rhys.JPG') center;
                      {%- else -%}
                      {% endif %}
                        height: 200px;
            card_mod:
              style: |
                ha-card {
                  height: 75px;
                  width: 75px;
                  margin-left: auto;
                  margin-right: auto;
        cards:
            layout_type: horizontal
            layout: {}
            cards:
                chips:
                  - type: menu
                  - type: back
                  - type: alarm-control-panel
                    content_info: none
                  - type: template
                    icon: >-
                      else 'mdi:lock-open' }}
                    icon_color: >-
                      {{ 'green' if is_state('lock.front_door', 'locked') else
                      'red' }}
                    content: null
                    tap_action:
                      action: more-info
                  - type: conditional
                    conditions:
                      - entity: light.all_lights
                        state: 'on'
                    chip:
                      type: template
                      icon: mdi:lightbulb
                      content: >-
                        {{ expand(states.light.all_lights) | selectattr(
                        'state', 'eq', 'on') | list | count }}
                      tap_action:
                        action: more-info
                      icon_color: grey
                  - type: conditional
                    conditions:
                      - entity: media_player.livingroomtv
                        state: 'on'
                    chip:
                      type: template
                      icon_color: grey
                      icon: mdi:cast
                      content: |-
                        {{ expand(states.media_player.all_media_players)
                         | rejectattr( 'state', 'in', ['idle'])
                         | rejectattr( 'state', 'in', ['standby'])
                         | rejectattr( 'state', 'in', ['off'])
                         | rejectattr( 'state', 'in', ['paused'])
                         | list | count }}
                      tap_action:
                        action: more-info
                      entity: media_player.all_media_players
                  - type: conditional
                    conditions:
                      - entity: binary_sensor.garage
                        state: 'on'
                    chip:
                      type: template
                      icon_color: grey
                      icon: mdi:garage-open
                      tap_action:
                        action: more-info
        card_mod:
          style: |
            ha-card {
              #padding: 0px;
              box-shadow: none;
              border-radius: none;
              background-color: white;
              margin-left: auto;
              margins-right: auto;
              border: none;
card_mod:
  style: |
    ha-card {
      padding: 2px;
      background: rgba(var(--rgb-primary-text-color), 0.00);
      box-shadow: 1px;
      border-radius: 15px;
