GTunney
(G Tunney)
October 16, 2023, 7:49am
8411
Thanks, sure here is the code for a room tile.
type: custom:stack-in-card
cards:
primary: Hallway
secondary: >-
{{ states('sensor.sonoff_a44001d0c1_temperature') | round (1) }}°C - {{
states('sensor.sonoff_a44001d0c1_humidity') | round (0) }}%
icon: none
entity: light.hallway_lamp
hold_action:
action: toggle
tap_action:
action: navigate
navigation_path: /home-v2/hallway
icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
fill_container: true
layout: horizontal
multiline_secondary: false
card_mod:
style:
mushroom-state-info$: |
.primary {
text-shadow: 0px 0px 5px black;
--card-primary-font-weight: 400;
--primary-text-color: white;
--card-primary-font-size: 20px;
align-items: end;
margin-top: 170px;
inline-size: 180px;
.secondary {
--card-secondary-font-size: 13px;
--secondary-text-color: white;
--card-secondary-font-weight: 350;
margin-top: -4px;
:host {
{% if is_state('light.hallway_lamp', 'on') %}
background: url('/local/images/areas/hallway.PNG') center;
background-size: cover;
background-blend-mode: overlay;
#filter: grayscale(70%);
background-color: rgba(var(--rgb-card-background-color), 0.0);
{% else %}
background: url('/local/images/areas/hallwayoff.jpeg') center;
{% endif %}
--mush-icon-size: 0px;
height: 220px;
margin-left: -15px !important;
margin-top: -70px !important;
mushroom-shape-icon {
--shape-color: rgba(var(--rgb-{{ 'orange' if is_state('light.hallway_lamp', 'on') else 'disabled' }}), 0.4) !important;
- type: custom:mushroom-chips-card
chips:
- type: conditional
conditions:
- entity: binary_sensor.front_door
state: 'on'
chip:
type: template
icon_color: red
icon: mdi:door-open
tap_action:
action: more-info
hold_action:
action: none
- type: conditional
conditions:
- entity: lock.front_door
state: unlocked
chip:
type: template
icon_color: red
icon: mdi:lock-open-variant
tap_action:
action: more-info
hold_action:
action: none
- type: template
icon: >-
{{ 'mdi:lightbulb' if is_state('light.hallway_lamp', 'on') else
'mdi:lightbulb-outline' }}
icon_color: '{{ ''orange'' if is_state(''light.hallway_lamp'', ''on'') else ''grey'' }}'
content: >-
{{ expand(states.light.hallway_lamp) | selectattr( 'state', 'eq',
'on') | list | count }}
tap_action:
action: call-service
service: light.toggle
area_id: hallway
hold_action:
action: more-info
alignment: end
card_mod:
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: -15px;
margin-top: -4px;
card_mod:
style: |
ha-card {
height: 180px;
width: 180px;
margin-left: auto;
margin-right: auto;
#box-shadow: 0 0 20px rgba(245, 173, 66, 0.5);
#border-radius: 10px;
#background: rgba(245, 173, 66, 0.3); {% endif %}
ketoha
(Ketoha)
October 16, 2023, 8:50am
8412
I am experiencing an issue with styling the mushroom-chips-card
using card-mod
. Iâm trying to achieve two things:
Set a background style for the entire card.
Apply an animation to a specific state icon.
Hereâs the working animation code I have:
card_mod:
style:
mushroom-template-chip:nth-child(3)$: |
ha-state-icon {
{{ 'animation: eureka 1.8s infinite;' if is_state('switch.0x540f57fffed36109_l2', 'on') }}
When I try to incorporate the background styling:
card_mod:
style: |
.chip-container {
background-color: #1c1c1c;
padding-top: 10px;
padding-left: 10px;
mushroom-template-chip:nth-child(3) ha-state-icon {
{{ 'animation: eureka 1.8s infinite;' if is_state('switch.0x540f57fffed36109_l2', 'on') else '' }}
The issue arises where the card background styling works, but the animation does not.
If I bypass card-mod
and directly use:
style: |
.chip-container {
padding-top: 10px;
padding-left: 10px;
The background styling works perfectly, but I need the animations provided by card-mod
Any guidance or solutions would be greatly appreciated!
What does this code do when you put it in the template editor:
This should work, but i didnt see your keyframes anywhere, so just put them where i have put the placeholder.
card_mod:
style:
ha-state-icon {
{{ 'animation: eureka 1.8s infinite;' if is_state('switch.office_screens', 'on') else '' }}
@keyframes eureka {
0% { transform: rotate(0deg); }
100% { transform: rotate(360deg); }
.chip-container {
padding-top: 10px;
padding-left: 10px;
Greg.o
(Greg)
October 16, 2023, 5:15pm
8415
However, Temp_Hum_1
is in a room : âChambre Parentaleâ :
Hi, please can you share the code for this card?
You would need to actually type in the full entity id which is what i am trying to get you to realise when putting it in the template editor.
if it doesnt work in the template editor it wont work in a card. best to always check there first.
but essentially i assume that your Temp_Hum_1
is a regular sensor. so the ID is probably sensor.temp_hum_1
, but i would double check what the id actually is.
Greg.o
(Greg)
October 16, 2023, 9:03pm
8418
Thx a lot for your help.
I now have an area_name :
But, it doesnât work for the title of a card :
look at your secondary in the template card you have:
secondary: '{{states.sensor.temp_hum_1_temperature}}'
see what you are missing in your title?
around your template.
when you then do that you also need to do:
title: '{{area_name(''sensor.temp_hum_1_temperature'')}}'
as otherwise the internal quotes are just single quotes with outside single quotes (which doesnt work).
can also do this instead:
title: "{{area_name('sensor.temp_hum_1_temperature')}}"
or even this:
title: |-
Greg.o
(Greg)
October 16, 2023, 9:19pm
8420
Thank you a lot for your patience and your explanations !! Off course, it works now !!
Here is the correct code :
type: vertical-stack
cards:
- type: custom:mushroom-title-card
title: '{{ area_name(''sensor.temp_hum_1_temperature'') }}'
- type: horizontal-stack
cards:
primary: Température
icon: mdi:home-thermometer-outline
secondary: '{{ states.sensor.temp_hum_1_temperature.state_with_unit }}'
primary: Humidité
secondary: '{{ states.sensor.temp_hum_1_humidity.state_with_unit }}'
Edit: got it. But feel free to educate me on how
behaves.
Thx!
- type: custom:mushroom-select-card
entity: input_select.ir_command_ac2_temp
secondary_info: last-updated
icon_type: none
card_mod:
style:
mushroom-select-option-control$:
mushroom-select$: |
.mdc-select__anchor{
background: blue !important
.mdc-select__selected-text {
color: white !important;
.container {
--primary-text-color: green;
--secondary-text-color: orange;
ha-card {
background-color: red;
Newbie assistance neededâŠ
Trying to combine multiple styling components but am obviously wrong with the syntax
(no errors returned but only the first styling component works; background-color).
They work individually though.
Iâve checked the guide but couldnât figure it out.
what am I missing?
Thank you!
secondary_info: none
icon_type: none
card_mod:
style: |
ha-card {
mushroom-select$: |
.container {
weado
October 17, 2023, 9:11am
8422
Maybe I donât read something, but my mushroom animation doesnât work . I just copy/paste your code, install card-mod plugin via HACS but itâs doesnât work⊠for example with the basic fan animation :
Look at my post with updated animations. How animations are applied changed months ago.
Hi @rhysb ,
i have made a general mushroom - card-mod styling guide that i have posted here . i have linked to your resource on animations from it because it is great. however since it was made a few things have changed with the way that animations are applied and we get a bunch of questions regarding it right now because people want to use your animations. so i hope you dont mind that i have gone through and updated each of your animations below and will be posting them as a reply here.
i will âŠ
This explains how these symbols work
Here is an explanation of how these symbols work.
$ is used when we want to access the shadow-root of an object. like this here:
[image]
the .shape is within the shadow-root of mushroom-shape-icon so to access it and modify it, we would write this:
[image]
card_mod:
style:
mushroom-shape-icon$: |
.shape {
background: red !important;
you cant just write this, as this wont access the element through the shadow root.
[image]
card_mod:
style: |
.shape {
âŠ
LRDC
(LRDC)
October 17, 2023, 11:10am
8425
Does anybody know how to minimize the delay between clicking the up or down arrow on a mushroom number card and the actual update of the input number value ? Iâve already tried to lower the values of âmush-slider-tresholdâ and âmush-input-number-debounceâ with card-mod and in my theme but the delay of approximately 2 seconds wonât change.
Iâm trying to use custom:mushroom-select-card as an overlay to a custom:button-card.
Essentially, I just want the select-option part to be visible once the card is clicked, the rest should be transparent.
Iâm pretty close to the result (see code below) but two issues remain:
1- can the âbottom barâ be hidden / made transparent?
2- is it possible to custom size the clickable zone so it covers the full card (see gray zone when cursor hovers the card)? Iâve tried changing the font size hoping it would expand the zone but it doesnât.
type: custom:layout-card
layout_type: grid
layout:
grid-template-columns: 25% 25% 25% 25%
grid-template-areas: |
"A1 A2 A3 A4"
cards:
view_layout:
grid-area: A1
cards:
- type: custom:button-card
entity: input_select.ir_command_ac2_mode
show_state: true
show_entity_picture: true
entity_picture: \local\!MYDATA\WEATHER\temperature2.png
styles:
card:
- font-size: 2rem
- font-weight: bold
icon:
- height: 4rem
- width: 4rem
view_layout:
grid-area: A1
cards:
icon_type: none
card_mod:
style:
mushroom-select$: |
background: none !important
color: transparent !important;
.mdc-select__dropdown-icon {
fill: transparent !important;
ha-card {
background: none;
I dont normally just figure out the answer for people, but i liked the use case so here you go!
layout_type: grid
layout:
"A1 A2 A3 A4"
cards:
view_layout:
grid-area: A1
cards:
entity: input_select.bedroom_fan_direction
show_state: true
styles:
card:
- font-size: 2rem
- font-weight: bold
icon:
- height: 4rem
- width: 4rem
view_layout:
grid-area: A1
cards:
icon_type: none
card_mod:
style:
mushroom-select$: |
background: none !important;
border-radius: 20px !important;
.mdc-line-ripple::before {
border-bottom-width: 0px !important;
.mdc-line-ripple::after {
.mdc-select {
position: absolute !important;
width: 100% !important;
--select-height: 97px;
top: 0%;
right: 0%;
ha-card {
background: none;
i had to set the position to absolute for the dropdown, so it may not work well in grids. but since its already in a layout card, perhaps it will, who knows!
removes the line before you clicked.
removes the blue line from after you have clicked.
Amazing. Thanks for the extra mile. Glad you like the use case =)
This will be a great building block for my dashboard. Thank you!
Just to improve my search skills, was this documented in your guide or elsewhere?
Not really. i have a section for the selection value in the select card in my guide. but it doesnt mention removing the line.
Person Card Sections are split:
Main Icon Styling
You can style the main icon like this:
Change the icon type/mdi.
[image]
card_mod:
style: |
ha-state-icon {
--card-mod-icon: mdi:mushroom;
Change the icon color.
[image]
card_mod:
style: |
ha-state-icon {
color: orange;
Change icon size.
[image]
card_mod:
style: |
ha-state-icon {
--icon-symbol-size: 40px;
Rotate Icon.
[image]
card_mod:
style: |
ha-state-icon {
rotate:âŠ
Select Card is in the same post as the person card.
then go to the selection value sections of this post.
i did answer the question regarding the line removal recently here:
card_mod:
style:
mushroom-select$: |
background: white !important;
border-radius: 12px !important;
fill: red !important
so perhaps i will update my guide to include it
weemaba999
(Bart Weemaels)
October 17, 2023, 5:50pm
8431
Hi all,
Iâm using mushroom-entity-buttons to highlight which rooms my vacuum should clean. I had the intention that every button would light up when I press it, but unfortunately they all light up when I press only one.
Is it possible because they all refer to the same script (but with different parameters) ?
Does anyone have a clue how to change that ?
Hereâs my code:
cards:
- type: custom:mushroom-entity-card
tap_action:
service: script.jarvis_room_cleaner
service_data:
room: bartjessie
entity: script.jarvis_room_cleaner
icon_height: 30px
icon: mdi:bed-king-outline
layout: vertical
tap_action:
service_data:
room: joosarne
icon_height: 30px
icon: mdi:bed-queen-outline
layout: vertical
tap_action:
service_data:
room: bentjesse
icon_height: 30px
icon: mdi:bed-single-outline
layout: vertical
cards:
tap_action:
service_data:
room: hallway
icon_height: 30px
icon: mdi:hanger
layout: vertical
tap_action:
service_data:
room: berging
icon_height: 30px
layout: vertical
icon: mdi:vacuum-outline
tap_action:
service_data:
room: kitchen
icon_height: 30px
icon: mdi:silverware-fork-knife
layout: vertical
columns: 4
square: false
Thanks a lot in advance !
Kr,
Bart
