Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Yes. you can only have one | per line. currently you have 2 if i strip out the rest:
card_mod:
  style: |
    mushroom-state-info$: |
      .primary:before {
        content: '1st line';
      .primary {
        display: flex;
        flex-direction: column;
      .primary:after {
        content: '3rd line';
You see how that is different from what i showed you? i have no | after style:
card_mod:
  style:
      .primary:before {
      .primary {
        display: flex;
      .primary:after {
if you need to combine style: | with other entries that use | you need to use .: | it is explained as well in the guide in my profile in the first post.
so to fix your code do this:
Code using CSS Pseudo Elements
type: custom:mushroom-cover-card
entity: cover.office_blinds
show_buttons_control: true
show_tilt_position_control: false
show_position_control: false
icon_type: icon
fill_container: true
tap_action:
  action: none
hold_action:
  action: none
double_tap_action:
  action: none
layout: vertical
secondary_info: none
primary_info: name
card_mod:
  style:
      .primary:before {
      .primary {
        display: flex;
      .primary:after {
      ha-state-icon {
        {% if is_state(config.entity, 'opening') %}
          --card-mod-icon: mdi:arrow-up-box
        {% elif is_state(config.entity, 'closing') %}
          --card-mod-icon: mdi:arrow-down-box
        {% elif state_attr(config.entity, 'current_position') == 100 %}
          color: rgba(255,255,255);
          --card-mod-icon: fapro:shutter1;
        {% elif state_attr(config.entity, 'current_position') > 50 %}
          color: rgba(193,193,193);
          --card-mod-icon: fapro:shutter2;
        {% elif state_attr(config.entity, 'current_position') > 0 %}
          color: rgba(131,131,131);
          --card-mod-icon: fapro:shutter3;
        {% else %}
          color: rgba(100,100,100);
          --card-mod-icon: fapro:shutter4;
        {% endif %}
      ha-card {
        --card-primary-font-size: 18px;
        --card-primary-font-weight: normal;
      mushroom-shape-icon {
        --shape-color: none !important;
        --shape-color-disabled: transparent !important;
        --icon-symbol-size: 100px;
      mushroom-state-item {
        padding-top: 20px;
        --spacing: 20px;
        margin-bottom: 10px;
to give some examples:
This is allowed.
card_mod:
  style: |
    element {
This is allowed.
card_mod:
  style:
    element$: |
      element2 {
This is NOT allowed.
card_mod:
  style: |
    element$: |
      element2 {
This is allowed.
card_mod:
  style:
    element$: |
      element2 {
      element3 {
This is allowed (because both | are on the same indentation).
card_mod:
  style:
    element$: |
      element2 {
    element3$: |
      element4 {
Thank you, a lot, for the very good help and sorry for my missing skills.
At the moment this failure appears when changing as suggested:
Why didnt you just copy the exact code i gave you?
you have wrong indentation at your ha-state-icon section.
you have:
 ha-state-icon {
i showed:
  ha-state-icon {
Indentation problem of the following I guessā€¦
Noticed it too late (please see above).
Iā€™m sorry, Iā€™m not very trainedā€¦
No need to apologise my friend. just curious. does it work now? :slight_smile:
Perfect :slight_smile: Thank you!!
I also like this Card and combinaded it with my normal Room Card which is added with a conditional card to open and close the Room. Still just Playing around with it.
As my Card getting really long with many Entities, is there an easy way to add ā€œvariablesā€ so i can just Change the Entity and not the whole code for many rooms ?
For your use case i would recommend looking into the decluttering card. Its a bit complex, but helps with exactly what you want. Yaml anchors dont actually save well.
Almostā€¦:)))))))
If you need some help, post the latest code please so we can continue on that. I went through all 8500 posts yesterday and got a bit confused on what was the latest lol.
@dimitri.landerloos, @rhysb and @ArenaCloser made my todo list insanely large with all the good posts in here lol. And now you as well @Mattia2399 :joy:
At least i am fully up to date now in the beautiful stuff that I could do and try to finish my WIP dashboard.
I created a topic for my configuration: Adaptive Mushroom (excuse the cross-posting). For questions, comments or suggestions, feel free to reach out. If you use my adaptive layout, Iā€™d love to see your resulting dashboard there!
Love the new screens @ArenaCloser , especially the rick roller. Working with the layout since last week, but still running into some errors. E.g. the mobile footer isnā€™t sticky on my side. Didnā€™t look at this yet though, but will post it to your github when found.
Just wanted to throw in my 2Ā¢.
Animated the Purifier Icon from @rhysb and updated by @dimitri.landerloos based on the entityā€™s fan speed.
Not sure if this has been posted before (forgive me for not reading all 8500+ posts) but figured it might help someone. The idea came from the mushroom-fan-card animation.
I simply changed the animation: air 1s infinite; line to animation: air {{ 25 / (state_attr(config.entity , 'percentage')) }}s infinite;.
Hereā€™s the card in full, with an updated power state badge:
type: custom:mushroom-template-card
primary: Purifier
layout: vertical
entity: fan.air_purifier
icon: mdi:air-purifier
icon_color: '{{ ''cyan'' if is_state(entity, ''on'') else ''disabled'' }} '
tap_action:
  action: more-info
hold_action:
  action: toggle
badge_icon: mdi:power
badge_color: '{{ ''#3CB371'' if is_state(entity, ''on'') else ''#DAA520'' }} '
card_mod:
  style: |
    ha-state-icon {
      {% if is_state(config.entity, 'on') %}
      {% else %}
      {% endif %}
    @keyframes air {
      0%, 100% { clip-path: inset(0 0 0 0); }
      25% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 98% 32%, 63% 42%, 65% 58%, 100% 43%); }
      75% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 100% 44%, 64% 61%, 64% 73%, 100% 72%); }
      50% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 78% 38%, 64% 43%, 64% 72%, 100% 73%); }
Hey there,
iā€™m just getting started with dashboards and mushroom cards, but i already fail on simple things.I want to have a dashboard for my phone in the end with rows in it and quite narrow buttons. But i canā€™t find the right syntax to change font size and icon size to make it fit better. Especially the two cover cards. Iā€™ve tried tinkering with ā€œcard_modā€ but nothing changes. seems like i just donā€™t get the syntax right. Is there any example or documentation where i can check this? Greatly appreciate any help!
Thanks!
type: custom:layout-card
layout_type: grid
layout:
  grid-template-columns: 15% 15% 70%
  grid-template-rows: 25% 25% 25% 25%
  grid-template-areas: |
    "a a1 a2"
    "a a3 a4"
    "b b1 b2"
    "b b3 b4"
cards:
  - type: picture
    image: https://demo.home-assistant.io/stub_config/t-shirt-promo.png
    view_layout:
      grid-area: a
  - type: custom:mushroom-cover-card
    entity: cover.rollo_buro_did
    primary_info: state
    view_layout:
      grid-area: a2
    show_position_control: true
    show_buttons_control: false
    icon_type: none
    primary_info: none
    view_layout:
      grid-area: a4
  - type: button
    show_icon: true
    show_name: false
    tap_action:
      action: toggle
    entity: switch.burod_pm_sperren
    show_state: true
    view_layout:
      grid-area: a3
  - type: custom:mushroom-light-card
    entity: light.licht_kg_burod
    view_layout:
      grid-area: a1
Try This one: edit card ā†’ open code editor ā†’ paste this code in:
type: vertical-stack
cards:
 - type: horizontal-stack
    cards:
        entity: light.duo
        show_brightness_control: true
        icon: mdi:lightbulb-fluorescent-tube
Note: change entity to your entity name.
Hi All, Im trying to get a binary sensor(motion sensor) to change colour based on state (motion/no motion) any ideas where im going wrong?
primary: Kitchen Motion
secondary: ā€˜ā€™
icon: mdi:motion-sensor
layout: vertical
icon_color: >-
{% if is_state(ā€˜binary_sensor.kitchen_motion_310fcd24_ias_zoneā€™, ā€˜Trueā€™) %} green {% else %} black {% endif %}
multiline_secondary: false
fill_container: false
Try:
secondary: ''
layout: vertical
icon_color: >
  {{ 'green' if is_state('binary_sensor.kitchen_motion_310fcd24_ias_zone', 'on') else 'black' }}
Can you share me energy cards code please?
Thank you
