Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
On the phone screen unfortunately it breaks. My CSS skills are obviously not enough to fix it.
We will make a deal, you help me find out how to get this work consistently when accessing HA remotely and ill help with the CSS. Ill take a look when i am back from work :wink:
Sure, Iā€™d be happy to help =)
would love to see the code for this aswellā€¦if you want to share it
Hello everybody
@dimitri.landerloos why i can change the style with .: |
type: grid
cards:
  - type: custom:mushroom-cover-card
    entity: cover.shellyswitch25_68c63afa44ed
    show_position_control: true
    show_buttons_control: true
    card_mod:
      style:
        mushroom-cover-position-control$: |
          mushroom-slider {
          {% if states ('cover.shellyswitch25_68c63afa44ed') == 'open'%}
            --slider-bg-color: #89DF83!important;
          {% else %}
            --slider-bg-color: ##FF483F!important;
          {% endif %}
       ha-card {
        border-style: none;
Capture dā€™eĢcran 2023-12-15 aĢ€ 23.11.24
I maybe mistaken, but I donā€™t believe border-style is an option. You can remove the border with: " --ha-card-border-width: 0px"
In addition ā€œ.: |ā€ needs to line up with ā€œmushroom-cover-position-control$: |ā€
type: grid
cards:
    card_mod:
      style:
          mushroom-slider {
          {% else %}
          {% endif %}
         ha-card {
          --ha-card-border-width: 0px;
Didnā€™t work, i think iā€™m doing wrong using .: , or bad indendation, i donā€™t know
Wrong indentation of .: |.
border style does exist, but is only used to define the type of border not whether or not to apply. So border-style: solid; or border-style: dotted;.
Just using border: 1px solid green; is shorthand for seperate border entries, border-style, border-width, border-color.
Border is set in the theme, so most of the time you need to override it with a !important;
type: grid
cards:
    card_mod:
      style:
          mushroom-slider {
          {% else %}
          {% endif %}
         ha-card {
           border: none !important;
That is great to know!
Didnā€™t work @dimitri.landerloos
I also want to change the width, but nothing changeā€¦
Did you copy what i sent directly?
SmartSelect_20231215_230504_Home Assistant
You can change the amount of columns in a grid, and grid makes cards square by default so you will likely want to disable that.
type: grid
columns: 2
square: false
cards:
    entity: cover.office_blinds
    card_mod:
      style:
          mushroom-slider {
          {% else %}
          {% endif %}
         ha-card {
The indentation is very important, now itā€™s worked :+1:
@dimitri.landerloos I would be grateful if you can help me accomplish the following:
I have a mushroom template card and would like to add another word under the word ā€œNoonā€ like in the picture:
Or below the time will work too.
Here is the code:
  type: custom:mushroom-template-card
  primary: Noon
  secondary: |
    {{ states('sensor.dhuhr_prayer_time') }}
  tap_action:
    action: more-info
  entity: sensor.current_prayer
  icon: mdi:weather-sunny
  icon_color: '#FFC107'
  layout: vertical
  card_mod:
    style:
        ha-card {
          /* Set size and spacing of button */
          {% if states('sensor.current_prayer') == 'Dhuhr' %}
            border: 1px outset green; /* Example border color */
            background: rgba(70, 130, 180, 0.5) !important;
          {% else %}
            background: rgba(0, 224, 56, 0.1) !important;
          {% endif %}
          width: 300px;
          --spacing: 8px;
          padding-bottom: calc(var(--spacing) * 1.718) !important;
          margin-bottom: 5px;
          /* Styling of button */
          box-shadow: var(--ha-card-box-shadow) !important;
          border-radius: calc(var(--ha-card-border-radius, 15px) * 1 ) !important;
          /* Center button */
          margin-left: auto;
          margin-right: auto;
          transition: all 0s;
        /* Add subtle color on hover */
        ha-card:hover {
          background: rgba(255, 235, 59, 0.5) !important; /* Soft amber on hover with reduced opacity */
          border-color: orange; /* Orange border on hover */
        ha-state-icon {
            animation: spin 2s linear infinite;
          {% endif %}
        @keyframes spin {
          0% {transform: rotate(0deg);}
      mushroom-state-info$: |
        .container {
          --secondary-text-color: rgba(13, 71, 161, 0.9);  /* A soft amber for a warm contrast */
Add this line span.secondary { white-space: pre; word-break: break-word ; }to your mushroom-state-info$: |
it will look like this:
          span.secondary {
              white-space: pre;
              word-break: break-word;
          .container {
The entire card for secondary:
primary: Noon
secondary: |
    {{ states('sensor.sun_next_noon') }}
    Additional Line
tap_action:
    action: more-info
entity: sensor.sun_next_dawn
layout: vertical
card_mod:
    style:
        ha-card {
          {% if states('sensor.sun_next_dawn') == 'Dhuhr' %}
          {% else %}
          {% endif %}
          width: 300px;
          --spacing: 8px;
          margin-bottom: 5px;
          /* Center button */
          margin-left: auto;
          margin-right: auto;
          transition: all 0s;
        ha-card:hover {
        ha-state-icon {
          {% endif %}
        @keyframes spin {
          span.secondary {
              white-space: pre;
          .container {
The entire card for primary:
primary: |
  Noon
  Additional Line
secondary: |
tap_action:
  action: more-info
layout: vertical
card_mod:
  style:
      ha-card {
        {% else %}
        {% endif %}
        width: 300px;
        --spacing: 8px;
        margin-bottom: 5px;
        /* Center button */
        margin-left: auto;
        margin-right: auto;
        transition: all 0s;
      ha-card:hover {
      ha-state-icon {
        {% endif %}
      @keyframes spin {
      span.primary {
          white-space: pre;
      .container {
Thank you very much. I really appreciate your time and efforts. It worked the way I want. One more request if it s possible: If I could make the font of the ā€œAdditional Lineā€ as big as the primary one with the same color while leaving the font the color of the time intact!. Thank you again!
I would suggest using additional info in the primary: section with this code to match the color and font-height if this what you are trying to achieveā€¦
primary: |
  Noon
  Additional Line
secondary: |
tap_action:
  action: more-info
layout: vertical
card_mod:
  style:
      ha-card {
        {% else %}
        {% endif %}
        width: 300px;
        --spacing: 8px;
        margin-bottom: 5px;
        /* Center button */
        margin-left: auto;
        margin-right: auto;
        transition: all 0s;
      ha-card:hover {
      ha-state-icon {
        {% endif %}
      @keyframes spin {
      span.primary {
          white-space: pre;
      .container {
Wow! That s exactly how I wanted. Thank you very much and I am very thankful to you for your time and patience! Thank you again!
Happy to helpā€¦Iā€™m in the process of teaching myself to program CSS and your question sparked my curiousity!
Thank you very much. Any resources you can recommend for a newbie to start learning ?
Here is my roku remote hope people like it.
Might need a bit of tweaking due to the way I have set up mine.
Needs the following
  • conditional cards
  • simple icons
  • mini-media player
  • bubble card
donā€™t forget to create an input helper.
I used tv_section for mine
EDIT: I cantā€™t fit the whole code here, but let me know if you want the other sections
home
type: conditional
conditions:
  - condition: state
    entity: input_select.tv_section
    state: home
card:
  type: custom:layout-card
  layout_type: custom:grid-layout
  cards:
      icon: mdi:power
      fill_container: true
      layout: vertical
      tap_action:
        action: toggle
      card_mod:
        style:
          mushroom-shape-icon$: |
            .shape {
             --icon-size: 60px !important;
             --icon-color:var(--black);
             --shape-color: none !important;
               background-color:transparent !important;
            ha-card {
             background: var(--red) !important;
              max-height:125px !important;
              max-width:130px !important;
      icon: mdi:chevron-up
      layout: vertical
      tap_action:
        action: call-service
        service: remote.send_command
          entity_id: remote.roku
          command: up
      card_mod:
        style:
            .shape {
             --icon-size: 70px !important;
             --icon-color:var(--white);
            ha-card {
             background: var(--contrast4) !important;
      icon: mdi:home
      layout: vertical
      tap_action:
          command: home
      card_mod:
        style:
            .shape {
            ha-card {
             background: var(--blue) !important;
      icon: mdi:chevron-left
      layout: vertical
      tap_action:
          command: left
      card_mod:
        style:
            .shape {
            ha-card {
      icon: mdi:checkbox-blank-circle-outline
      tap_action:
          command: select
      layout: vertical
      card_mod:
        style:
            .shape {
            ha-card {
      icon: mdi:chevron-right
      layout: vertical
      tap_action:
          command: right
      card_mod:
        style:
            .shape {
            ha-card {
      icon: mdi:undo-variant
      tap_action:
          command: back
      layout: vertical
      card_mod:
        style:
            .shape {
            ha-card {
      icon: mdi:chevron-down
      layout: vertical
      tap_action:
          command: down
      card_mod:
        style:
            .shape {
            ha-card {
      icon: mdi:asterisk
      layout: vertical
      tap_action:
          command: info
      card_mod:
        style:
            .shape {
            ha-card {
      icon: mdi:volume-mute
      layout: vertical
      tap_action:
          command: volume_mute
      card_mod:
        style:
            .shape {
            ha-card {
             background: var(--contrast7) !important;
      primary: ''
      icon: mdi:volume-minus
      layout: vertical
      tap_action:
          command: volume_down
      card_mod:
        style:
            .shape {
            ha-card {
      icon: mdi:volume-plus
      layout: vertical
      tap_action:
          command: volume_up
      card_mod:
        style:
            .shape {
            ha-card {
  layout:
    grid-template-columns: 105px 105px 105px
    grid-template-rows: auto
    grid-template-areas: |
      "header header header"
      "main main2 main3"
media
type: conditional
conditions:
  - condition: state
    state: play
card:
  cards:
      layout: vertical
      primary: Volume Down
      tap_action:
      card_mod:
        style:
            .shape {
               margin-top:-10px;
               left: -50%;
               justify-content: flex-start !important;
            .primary {
              font-family: Montserrat;
              font-size: 1.04em !important;
              --primary-text-color: var(--contrast40);
              text-align:start;
              margin-top:-20px;
              font-weight:500 !important;
              white-space: initial !important;
              z-index:1;
            ha-card {
              max-height:90px !important;
              max-width:140px !important;
      layout: vertical
      primary: Volume Up
      tap_action:
          command: volume_up
      card_mod:
        style:
            .shape {
               margin-top:-10px;
               left: -65%;
            .primary {
              text-align:start;
              margin-top:-20px;
              font-weight:300 !important;
              z-index:1;
            ha-card {
              max-width:160px !important;
      icon: mdi:play-pause
      layout: vertical
      primary: Play\Pause
      tap_action:
          command: play
      card_mod:
        style:
            .shape {
               margin-top:-10px;
               left: -50%;
            .primary {
              --primary-text-color: var(--black);
              text-align:start;
              margin-top:-15px;
              z-index:1;
            ha-card {
             background: var(--green) !important;
              max-height:180px !important;
    - type: vertical-stack
      cards:
          icon: mdi:arrow-up-drop-circle-outline
          layout: vertical
          primary: Channel Up
          tap_action:
              command: channel_up
          card_mod:
            style:
                .shape {
                   margin-top:-10px;
                   left: -65%;
                .primary {
                  text-align:start;
                  margin-top:-15px;
                  z-index:1;
                ha-card {
          icon: mdi:arrow-down-drop-circle-outline
          layout: vertical
          primary: Channel Down
          tap_action:
              command: channel_up
          card_mod:
            style:
                .shape {
                   margin-top:-10px;
                   left: -65%;
                .primary {
                  text-align:start;
                  margin-top:-15px;
                  z-index:1;
                ha-card {
      icon: mdi:skip-previous
      layout: vertical
      primary: Previous
      tap_action:
          command: reverse
      card_mod:
        style:
            .shape {
               margin-top:-10px;
               left: -50%;
            .primary {
              text-align:start;
              margin-top:-15px;
              z-index:1;
            ha-card {
      icon: mdi:skip-next
      layout: vertical
      primary: Next
      tap_action:
          command: forward
      card_mod:
        style:
            .shape {
               margin-top:-10px;
               left: -70%;
            .primary {
              text-align:start;
              margin-top:-15px;
              z-index:1;
            ha-card {
      secondary: ''
  layout:
    grid-template-columns: 150px 180px
      "main main"
footer
layout_type: custom:masonry-layout
cards:
  - type: custom:mini-media-player
    noPadding: true
    hide:
      volume: true
      power: true
      prev: true
      next: true
      source: true
      runtime: true
      runtime_remaining: true
      controls: false
      mute: false
    entity: media_player.roku
    info: short
    source: icon
    artwork: material
    volume_stateless: false
    group: true
    card_mod:
      style: |
        :host{
            font-family: "Montserrat";
            font-weight:700;
            max-width: 420px;
        .mmp__bg, .mmp__player, .mmp__container {
            border-radius: 10px 10px 0px 0px !important;
            -webkit-transform: translateZ(0);
        .entity__info__name{
            color: var(--contrast0) !important;
            font-weight: 400 !important;
            font-size: 15px !important;
        ha-card.--has-artwork .cover{
  - type: custom:stack-in-card
    mode: horizontal
    card_mod:
      style:
          ha-card {
             border-radius:  0 0 10px 10px;
             padding:0px !important;
             background: var(--contrast1);
             max-width: 420px;
    cards:
      - type: custom:layout-card
        layout:
          grid-template-columns: 25% 25% 25% 25%
        cards:
            icon: mdi:home-outline
            layout: vertical
            tap_action:
              service: input_select.select_option
                entity_id: input_select.tv_section
                option: home
            card_mod:
              style:
                  .shape {
                   --icon-color: var(--contrast15);
                   --icon-size: 45px !important;
                  ha-card {
                    background: none;
            icon: mdi:play-circle-outline
            layout: vertical
            tap_action:
                option: play
            card_mod:
              style:
                  .shape {
                  ha-card {
                    background: none;
            icon: mdi:format-list-numbered
            layout: vertical
            tap_action:
                option: input
            card_mod:
              style:
                  .shape {
                  ha-card {
                    background: none;
            icon: mdi:star
            layout: vertical
            tap_action:
                option: favorites
            card_mod:
              style:
                  .shape {
                  ha-card {
                    background: none;
layout:
  card_margin: 0px
