Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Take a look at the guide in my profile.
Here is another simple solution:
    mushroom-state-info$: |
      .primary:after {
        content: 'Test';
        display: flex;
        flex-direction: column;
You can then write whatever you want where it says 'Test'
If you want it under secondary instead just replace .primary { with .secondary {
For my education, is there a benefit to this method vs white-space/word-break method?
Small benefit is that you can use it on the secondary of any card. Not just the template card where you can write text.
The white-space word-break solution doesnt work if you cant change the text.
.+ learning how to use pseudo elements (:after, :before) is a useful skill to have as you can use it for more than just text (as you know from your Hue colored icons).
That makes sense. Mostly you have to use the template card for total customization, but on occasion I do use the standard cards and that would help. Definitely an intriguing subject for me. You have a ton of knowledge!
and yes :after & :before is extremely useful. Just started some new styling with :after & :before in .shape and ha-state-icon based off some of your older posts.
Which card do you use for temperature?
if you are talking about mushroom cards only. the one most applicable would probably just be the standard entity card.
Thank you very much @dimitri.landerloos for another solution for the issue I was facing. I appreciate your time and your efforts. Thank you!
Can ā€œTestā€ be in different color even if it s in the same section primary?
Sure. Just add color:
      .primary:after {
        content: 'Test';
        display: flex;
        color: red;
Of course you can use any color you want.
yes of course. I can send you the whole code of my chips at the top of my dashboard
  - theme: Backend-selected
    title: Dashboard
    path: dashboard
    icon: mdi:home
    type: custom:layout-card
    layout_type: custom:horizontal-layout
    layout:
      width: 360
      max_cols: 2
    badges: []
    cards:
      - type: custom:layout-card
        layout_type: custom:vertical-layout
        layout: null
        cards:
          - type: custom:mushroom-chips-card
            chips:
              - type: menu
              - type: weather
                entity: weather.casa_ventura
                show_conditions: false
                show_temperature: true
                double_tap_action:
                  action: none
                tap_action:
                  action: none
                hold_action:
                  action: none
              - type: template
                entity: sensor.assorbimento_casa
                double_tap_action:
                  action: none
                tap_action:
                  action: navigate
                  navigation_path: energia
                hold_action:
                  action: none
                icon: mdi:home-lightning-bolt-outline
                icon_color: ''
                content: '{{ int(states("sensor.assorbimento_casa")) }} W'
              - type: conditional
                conditions:
                  - entity: cover.gruppo_cover_all
                    state: open
                chip:
                  type: template
                  double_tap_action:
                    action: none
                  icon: mdi:window-shutter-alert
                  icon_color: ''
                  hold_action:
                    action: toggle
                  tap_action:
                    action: navigate
                    navigation_path: tapparelle
                  content: '{{ states("sensor.number_cover_open") }}'
              - type: conditional
                conditions:
                  - entity: binary_sensor.contact_cancelletto_contact
                    state: 'on'
                chip:
                  type: template
                  icon: mdi:door-open
                  icon_color: '#D70D0D'
                  tap_action:
                    action: navigate
                    navigation_path: telecamere
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
                  card_mod:
                    style: |
                      ha-card {
                        --ha-card-border-width: 0;
                        animation: {% if is_state('binary_sensor.contact_cancelletto_contact', 'on') %} blink 1s linear infinite;
                                  {% else %} none
                                  {% endif %}
                      @keyframes blink {
                        50% {opacity: 0.2;}
              - type: conditional
                conditions:
                  - entity: binary_sensor.contact_portone_contact
                    state: 'on'
                chip:
                  type: template
                  icon: mdi:gate-alert
                  tap_action:
                    action: navigate
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
                  card_mod:
                    style: |
                      ha-card {
                        animation: {% if is_state('binary_sensor.contact_portone_contact', 'on') %} blink 1s linear infinite;
                                  {% else %} none
                                  {% endif %}
                      @keyframes blink {
                        50% {opacity: 0.2;}
              - type: conditional
                conditions:
                  - entity: light.gruppo_luci_interno
                    state: 'on'
                chip:
                  type: template
                  icon: mdi:lightbulb
                  icon_color: amber
                  content: '{{ states("sensor.number_indoor_lights_on") }}'
                  tap_action:
                    action: navigate
                    navigation_path: luci-interne
                  hold_action:
                    action: toggle
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                  - entity: light.gruppo_luci_esterno
                    state: 'on'
                chip:
                  type: template
                  icon_color: amber
                  icon: mdi:coach-lamp-variant
                  tap_action:
                    action: navigate
                    navigation_path: luci-esterne
                  hold_action:
                    action: toggle
                  content: '{{ states("sensor.number_outdoor_lights_on") }}'
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                  - entity: switch.gruppo_termosifoni_all
                    state: 'on'
                chip:
                  type: template
                  icon_color: red
                  icon: mdi:radiator
                  tap_action:
                    action: toggle
                  hold_action:
                    action: none
                  content: '{{ states("sensor.number_heater_on") }}'
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                  - entity: climate.group_all
                    state_not: 'off'
                chip:
                  type: template
                  tap_action:
                    action: navigate
                    navigation_path: condizionatori
                  hold_action:
                    action: toggle
                  double_tap_action:
                    action: none
                  icon: mdi:fan
                  icon_color: blue-grey
                  content: '{{ states("sensor.number_climate_on") }}'
            card_mod:
              style:
                mushroom-conditional-chip:nth-child(11):
                  mushroom-template-chip$: |
                    ha-state-icon {
                      animation: rotation 1s linear infinite;
                    @keyframes rotation {
                      0% { transform: rotate(0deg); }
                      100% { transform: rotate(360deg); }
                  :host {
                    --ha-card-background: rgba(var(--rgb-primary-text-color), 0.025);
                  ha-card {
                    --chip-spacing: 2px;
Fantastic! Thank you very much!
Its set to nth-child(11) but there are only 10 chips total.
So change to reflect the chip that you want to apply it to.
SmartSelect_20231216_172442_Home Assistant
layout: null
cards:
    chips:
      - type: menu
      - type: weather
        double_tap_action:
          action: none
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        double_tap_action:
          action: none
        tap_action:
          action: navigate
        hold_action:
          action: none
        icon_color: ''
      - type: conditional
        conditions:
            state: open
        chip:
          type: template
          double_tap_action:
            action: none
          icon_color: ''
          hold_action:
            action: toggle
          tap_action:
            action: navigate
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon: mdi:door-open
          tap_action:
            action: navigate
          hold_action:
            action: none
          double_tap_action:
            action: none
          card_mod:
            style: |
              ha-card {
                          {% else %} none
                          {% endif %}
              @keyframes blink {
                50% {opacity: 0.2;}
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          tap_action:
            action: navigate
          hold_action:
            action: none
          double_tap_action:
            action: none
          card_mod:
            style: |
              ha-card {
                          {% else %} none
                          {% endif %}
              @keyframes blink {
                50% {opacity: 0.2;}
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon: mdi:lightbulb
          icon_color: amber
          tap_action:
            action: navigate
          hold_action:
            action: toggle
          double_tap_action:
            action: none
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon_color: amber
          tap_action:
            action: navigate
          hold_action:
            action: toggle
          double_tap_action:
            action: none
      - type: conditional
        conditions:
            state: 'on'
        chip:
          type: template
          icon_color: red
          icon: mdi:radiator
          tap_action:
            action: toggle
          hold_action:
            action: none
          double_tap_action:
            action: none
      - type: conditional
        conditions:
            state_not: 'off'
        chip:
          type: template
          tap_action:
            action: navigate
          hold_action:
            action: toggle
          double_tap_action:
            action: none
          icon: mdi:fan
    card_mod:
      style:
        mushroom-conditional-chip:nth-child(10):
            ha-state-icon {
          :host {
          ha-card {
iā€™cant understand why but it doesnā€™t work in my dashboardā€¦ I can attach more code if it can helpā€¦
    title: Dashboard
    path: dashboard
    icon: mdi:home
    layout:
      width: 360
      max_cols: 2
    badges: []
    cards:
        layout: null
        cards:
            chips:
              - type: menu
              - type: weather
                double_tap_action:
                  action: none
                tap_action:
                  action: none
                hold_action:
                  action: none
              - type: template
                double_tap_action:
                  action: none
                tap_action:
                  action: navigate
                hold_action:
                  action: none
                icon_color: ''
              - type: conditional
                conditions:
                    state: open
                chip:
                  type: template
                  double_tap_action:
                    action: none
                  icon_color: ''
                  hold_action:
                    action: toggle
                  tap_action:
                    action: navigate
              - type: conditional
                conditions:
                    state: 'on'
                chip:
                  type: template
                  icon: mdi:door-open
                  tap_action:
                    action: navigate
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
                  card_mod:
                    style: |
                      ha-card {
                                  {% else %} none
                                  {% endif %}
                      @keyframes blink {
                        50% {opacity: 0.2;}
              - type: conditional
                conditions:
                    state: 'on'
                chip:
                  type: template
                  tap_action:
                    action: navigate
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
                  card_mod:
                    style: |
                      ha-card {
                                  {% else %} none
                                  {% endif %}
                      @keyframes blink {
                        50% {opacity: 0.2;}
              - type: conditional
                conditions:
                    state: 'on'
                chip:
                  type: template
                  icon: mdi:lightbulb
                  icon_color: amber
                  tap_action:
                    action: navigate
                  hold_action:
                    action: toggle
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                chip:
                  type: template
                  icon_color: amber
                  tap_action:
                    action: navigate
                  hold_action:
                    action: toggle
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state: 'on'
                chip:
                  type: template
                  icon_color: red
                  icon: mdi:radiator
                  tap_action:
                    action: toggle
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
              - type: conditional
                conditions:
                    state_not: 'off'
                chip:
                  type: template
                  tap_action:
                    action: navigate
                  hold_action:
                    action: toggle
                  double_tap_action:
                    action: none
                  icon: mdi:fan
            card_mod:
              style:
                    ha-state-icon {
                  :host {
                  ha-card {
          - type: conditional
            conditions:
              - entity: input_boolean.qualcuno_ha_suonato
                state: 'on'
            card:
              type: custom:mushroom-template-card
              primary: Qualcuno ha suonato al citofono!
              secondary: Clicca per vedere le telecamere!
              icon: mdi:bell-alert
              icon_color: white
              tap_action:
                action: navigate
                navigation_path: camere-citofono
              hold_action:
                action: none
              double_tap_action:
                action: none
              multiline_secondary: false
              card_mod:
                style: |
                  mushroom-shape-icon { --shape-color: none !important; }
                  ha-card {
                    --card-primary-font-weight: bold;
                    --card-secondary-font-weight: bold;
                    --card-primary-font-size: 19px;
                    --card-secondary-font-size: 14px;
                  ha-card {
                      --primary-text-color: rgba(254,249,244,255)
                  ha-card {
                      --secondary-text-color: rgba(254,249,244,255)
                  ha-card {
                      background: rgba(233,14,20,255);
                      --chip-box-shadow: none;
                    :host {
                      --mush-icon-size: 60px;
          - type: custom:mushroom-title-card
            title: |
              {% if now().hour < 5 %}
              Buona notte
              {% elif now().hour < 12 %}
              Buongiorno
              {% elif now().hour < 18 %}
              Buon pomeriggio
              {% else %}
              Buonasera
              {% endif %}
            subtitle: |-
              benvenuto a casa, sono le {{
                states('sensor.time') }}
            alignment: start
  1. Have you tried a different browser to see if it works?
  2. Can you try the same code not applied to a conditional chip? Some browsers have issues with animations in conditional chips. For example can you try this:
Conditional Chip
chips:
  - type: conditional
    conditions:
        state_not: 'off'
    chip:
      type: template
      icon: mdi:fan
card_mod:
  style:
    mushroom-conditional-chip:nth-child(1):
        ha-state-icon {
      :host {
      ha-card {
VS this:
Template Chip
chips:
  - type: template
    icon: mdi:fan
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
    :host {
    ha-card {
Do both work or only one, or do neither work?
How do i get rid of the drop down chevron and add hidden chip that only show when on? Needing some help.
Here is the code
type: custom:stack-in-card
cards:
  - type: picture-entity
    image: local/images/Livingroom.jpg
    entity: light.living_room
    show_state: false
    show_name: false
    camera_view: auto
    aspect_ratio: '3'
    tap_action:
      action: navigate
      navigation_path: /home-living-room
    hold_action:
      action: toggle
    theme: Mushroom
  - type: custom:gap-card
    height: 2
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: auto 33px
      margin: '-4px -4px -8px -4px;'
    cards:
        primary: Family Room
        secondary: null
        icon: mdi:lightbulb-group
        icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''grey'' }}'
        tap_action:
          action: none
        fill_container: false
        card_mod:
          style: |
            ha-card {
              background: none;
              --ha-card-box-shadow: 0px;
        entity: input_boolean.mushroom_familyroom_card
        icon: >-
          {{ 'mdi:chevron-up' if is_state(entity, 'on') else 'mdi:chevron-down'
        icon_color: black
        hold_action:
          action: none
        card_mod:
          style: |
            ha-card {
              align-items: flex-end;
              background: none;
  - type: conditional
    conditions:
      - entity: input_boolean.mushroom_familyroom_card
        state: 'on'
    card:
      cards:
          primary: Ceiling Fan Lights
          secondary: null
          entity: light.wiz_lights
          icon: mdi:ceiling-fan-light
          tap_action:
            action: toggle
          card_mod:
            style:
                .container {
                  display: table !important;
                .secondary {
                  display: table-cell;
                  text-align: right;
                  width: 100%;
                  font-size: 14px !important;
                  font-weight: bold !important;
                  color: var(--primary-text-color) !important;
                ha-card:after {
                  content: '';
                  border-bottom: solid 2px rgba(var(--rgb-disabled), 0.2);
                  margin: 12px 0px -12px;
          primary: Floor Accents
          secondary: null
          entity: light.accent_lights
          icon: mdi:light-flood-up
          tap_action:
            action: toggle
          card_mod:
            style:
                .container {
                .secondary {
                  text-align: right;
                  width: 100%;
                ha-card:after {
                  content: '';
          primary: Porch Light
          secondary: null
          entity: light.front_outside_light
          icon: mdi:lightbulb
          tap_action:
            action: toggle
          card_mod:
            style:
                .container {
                .secondary {
                  text-align: right;
                  width: 100%;
                ha-card:after {
                  content: '';
      card_mod:
        style: |
          ha-card {
            background: none;
            box-shadow: none;
Something like this? (Swap entities for your own.)
cards:
    entity: light.lounge_lights
    show_state: false
    show_name: false
    camera_view: auto
    aspect_ratio: '3'
    tap_action:
      action: navigate
    hold_action:
      action: toggle
    theme: Mushroom
    height: 2
    layout:
      grid-template-columns: auto auto
    cards:
        secondary: null
        tap_action:
          action: none
        card_mod:
          style: |
            ha-card {
              background: none;
        alignment: end
        chips:
          - type: conditional
            conditions:
              - entity: light.lounge_corner_lamp
                state_not: 'off'
            chip:
              type: light
          - type: conditional
            conditions:
              - entity: light.lounge_main_light
                state_not: 'off'
            chip:
              type: light
        card_mod:
          style: |
            ha-card {
              position: relative;
              top: 20%;
i fix it!! both worked, but the problem was not there. the problem was these line at the top of my code.
        layout: null
        cards:
removing these line chips worked, but I have to edit all my dashboard, because there are many elements under this layout cardā€¦
Iā€™m sorry, may I ask why my card_mod cannot be used in Mushroom?
No need to apologize. Can you post the full code formatted correctly please?
Check out this post (section 11) to see how to do that :slight_smile:
# An example of what correctly formatted code blocks will look like.
type: custom:example
entity: switch.example
cards:
  - type: custom:test
    entity: light.test
    icon: mdi:test-tube
    icon_color: green
card_mod:
  style: |
    ha-card {
      test: 1px red solid;
Means you are using the custom layout card. Cant tell you much more than that the layout card is used to achieve more complex layouts.
