Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Sorry, the background-image should have had a url
card_mod:
  style: |
    {% if states( ‘switch.radiator_slaapkamer_1_4’, 'on') %}
       ha-state-icon::after {
         content: "";
         position: absolute;
         top: -11%;
         right: -11%;
         display: flex;
         justify-content: center;
         align-items: center;
         width: 15px;
         height: 15px;
         border-radius: 50%;
         position: absolute;
         background-repeat: no-repeat;
         background-image: url("/local/animated/fire-red.png") !important;
         background-position: top;
         background-size: cover;
         {%else%}
         {%endif%}
Maybe realy stupid question but where do i have to store this image? I tried to upload this image to /local/image/fire-red.png (and of course used this path in the code) path but then i see no image :D… Are there any restrictions regarding the resolution / image format etc.?
I create a folder for all my images and then reference that folder in the url. With HACS installed, local is actually the www folder.
mine is called animated. It has my pics and SVGs
I’ll put together the code for both the bade and the card mod shape.
This should get you pointed in the right direction and remember you may need to clear your browser history for the changes to take affect,
type: custom:mushroom-template-card
primary: Kim en Jos
secondary: '{{ states(''sensor.basement_sensor'') }} °C'
icon: mdi:bed-king-outline
entity: light.pc_lights
badge_color: |-
  {% if is_state('light.pc_lights', 'on') %}
    red
  {% endif %}
icon_color: |-
    orange
  {% endif %}
hold_action:
  action: toggle
tap_action:
  action: navigate
  navigation_path: /kim-en-jos/home
layout: vertical
badge_icon: |-
    mdi:fire
  {% endif %}
card_mod:
  style: |
    {% if is_state( 'light.pc_lights', 'on') %}
         content: "";
         position: absolute;
         top: 80%;
         right: 30%;
         display: flex;
         width: 15px;
         height: 15px;
         border-radius: 50%;
         position: absolute;
         background-image: url("/local/animated/fire.png") !important;
         {%else%}
         {%endif%}
Such good advice to local host any icons you use! I dont recommend using a link to a webpage :slight_smile:
Just for anyone in the future the use of a stylesheet is also fine as the stylesheet ends up being downloaded to your local storage anyway.
Agreed!! Appreciate the stylesheet comment, overall it’s the way to go if you do a lot of customization :clap:
is there any news on this? does anyone have any info? Sorry, I’m new and trying to learn
Folks, please help to rewrite the icon animation (stopped working after update of Mushroom cards):
type: horizontal-stack
cards:
    tap_action:
      action: more-info
    double_tap_action:
      action: call-service
      service: input_boolean.toggle
        entity_id: input_boolean.swimpoolactive
    entity: switch.5
    layout: vertical
    secondary: S-HeatPump
    icon: mdi:fan
    icon_color: |-
      {% if is_state('switch.5', 'on') %}
        deep-purple
      {% else %}
        teal
      {% endif %}
    card_mod:
      style:
          ha-card {
            {{'--secondary-text-color: yellow;' if is_state('input_boolean.swimpoolactive', 'on')}}
        mushroom-shape-icon$: |
          ha-icon {
            {{'--icon-animation: spin 1s linear infinite;' if is_state(config.entity, 'on')}}
I assume something must be changed in t
his part:
          ha-icon {
Look at my replies in this topic. I have linked to the new animations many many times :slight_smile:
I’ve tried proposed solutions, the animation didn’t work.
Did figure this out? I’ve tried stack-in-card, but it didn’t give the same look unfortunately.
did you though?
then just add your if statement, either like this:
{% if is_state(config.entity, 'on') %}
{% endif %}
or like this:
{{'animation: spin 1s linear infinite;' if is_state(config.entity, 'on')}}
And if that still doesnt work then you either.
  1. Dont have card mod installed.
  2. Dont have card mod correctly installed.
Thanks! Now it works!
Hello together,
I try to use a common defined color for the icon, like “–error-color”. This is working e.g. for custom:mushroom-cover-card but I cannot get this running for custom:mushroom-template-card, even I use the same code. Can somebody help me please?!
Many thanks!
My code so far…
    entity: sensor.hausbefeuchtung
    icon: |
      {% if is_state(config.entity, 'Aus') %}
        mdi:air-humidifier-off
      {% elif is_state(config.entity, 'Leer') %}
        mdi:water-off-outline
      {% else %}
        mdi:air-humidifier
      {% endif %}
    primary: '{{ state_attr(config.entity, ''friendly_name'') }}'
    secondary: '{{ states(config.entity) }}'
    tap_action:
      action: more-info
    double_tap_action:
      action: toggle
    icon_color: |
        var(--error-color)
        red
      {% else %}
        blue
      {% endif %}
    card_mod:
      style:
          .shape {
            background: none !important;
What color are you getting when using var(--error-color) ?
I may have missed it, but -error-color doesn’t appear to be defined in the source code in a manner that can be used in the way you coded it. I added the following line to the javascript and was able to usevar(--rgb-error) in the template card.
    --rgb-error: var(--mush-rgb-error, var(--rgb-purple));
icon: |
  {% else %}
    mdi:air-humidifier
  {% endif %}
tap_action:
  action: more-info
double_tap_action:
  action: toggle
icon_color: |
        var(--rgb-error)
        red
      {% else %}
        blue
      {% endif %}
card_mod:
  style:
      .shape {
Hoping the masterminds here can help resolve an issue.
Upgraded to 2023.11 (yes I’m not on 2023.12) from 2023.9, and now my mushroom cards have all gone and gotten a black raised background, others have a border?!
They’ve gone from this:
To this:
How do I get rid of that horrific background and raised shadow thing and the borders that is going on?!
Appreciate the assist.
can you please post your code?
If you are using Card Mod, ensure you are using card_mod: and not just style: |
should look something like this…
card_mod:
  style: |
Here you go:
type: custom:vertical-stack-in-card
cards:
  - type: custom:vertical-stack-in-card
    cards:
      - type: custom:layout-card
        layout_type: custom:grid-layout
        layout:
          grid-template-columns: 123px auto
          grid-template-rows: auto
          margin: 0 auto;
          padding: 5px 2px;
        cards:
          - type: custom:mushroom-chips-card
            chips:
              - type: template
                entity: light.bathroom_light
                icon: mdi:lightbulb
                icon_color: |-
                  {% set state = states(entity) %}
                  {% if state == 'on' %}
                   white
                  {% else %}
                   grey
                  {% endif %}
                tap_action:
                  action: more-info
                card_mod: null
                style: |
                  ha-card {
                    --chip-box-shadow: none;
                    --chip-background: none;
                    --chip-padding: 0 0 0 10px;
              - type: template
                entity: switch.adaptive_lighting_bathroom
                icon: |-
                   mdi:lightbulb-auto
                  {% else %}
                   mdi:lightbulb-auto-outline
                  {% endif %}
                icon_color: |-
                   orange
                  {% else %}
                   grey
                  {% endif %}
                tap_action:
                  action: toggle
                card_mod: null
                style: |
                  ha-card {
                    --chip-spacing: 0px;
                    --chip-padding: 0 15px 0 10px;
              - type: template
                entity: switch.adaptive_lighting_sleep_mode_bathroom
                icon: mdi:theme-light-dark
                icon_color: |-
                   orange
                  {% else %}
                   grey
                  {% endif %}
                tap_action:
                  action: toggle
                card_mod: null
                style: |
                  ha-card {
                    --chip-padding: 0;
            card_mod:
              style: |
                ha-card {
                  background-color: rgba(0, 0, 0, 0.6) !important;
                  border-radius: var(--ha-card-border-radius, 12px) !important;
                  --chip-spacing: 0;
            chips:
              - type: template
                content: >-
                  {{ states(entity) | float }} {{ state_attr(entity,
                  "unit_of_measurement") }}
                entity: sensor.bathroom_sensor_temperature
                icon: mdi:thermometer
                tap_action:
                  action: more-info
                icon_color: |-
                  {% set state=states(entity)|float(0) %}
                  {% if state >= 21 %}
                  red
                  {% elif state >= 19 %}
                  orange
                  {% elif state < 19 %}
                  blue
                  {% else %}
                  grey
                  {% endif %}
                style: |
                  ha-card {
                    --chip-padding: 0 10px;
              - type: template
                content: >-
                  {{ states(entity) }}{{ state_attr(entity,
                entity: sensor.bathroom_sensor_humidity
                icon: mdi:water
                icon_color: blue
                tap_action:
                  action: none
                hold_action:
                  action: none
                style: |
                  ha-card {
                    --chip-padding: 0 10px 0 0px;
              - type: template
                content: >-
                  {{ states(entity) }} {{ state_attr(entity,
                entity: sensor.bathroom_sensor_pressure
                icon: mdi:gauge
                icon_color: grey
                tap_action:
                  action: none
                style: |
                  ha-card {
            card_mod:
              style: |
                ha-card {
                  background-color: rgba(0, 0, 0, 0.7) !important;
                  --chip-spacing: 0;
        cards:
            primary: Bathroom
            icon: mdi:shower-head
            fill_container: true
            tap_action:
              action: navigate
              navigation_path: bathroom
            hold_action:
              action: none
            icon_color: blue
            card_mod:
              style: |
                ha-card {
                  background: none;
                  padding: 10px 16px !important;
            layout:
              grid-template-columns: 65% auto
              margin: 0 0 0 5px;
              padding: 5px
            cards:
                chips:
                  - type: template
                    entity: sensor.washing_machine_current_consumption
                    content: |-
                      {% set state = states(entity) | float(0) %}
                      {% if state > 0 %}
                       Running
                      {% endif %}
                    icon: mdi:washing-machine
                    icon_color: |-
                      {% set state = states(entity)|float(0) %}
                      {% if state > 0 %}
                       blue
                      {% elif state == 'unavailable' %}
                       grey
                      {% else %}
                       white
                      {% endif %}
                    tap_action:
                      action: navigate
                      navigation_path: laundry
                    card_mod: null
                    style: |
                      ha-card {
                  - type: template
                    entity: sensor.dryer_current_consumption
                    content: |-
                      {% if state > 0 %}
                       Running
                      {% endif %}
                    icon: mdi:tumble-dryer
                    icon_color: |-
                      {% if state > 0 %}
                       red
                       grey
                      {% else %}
                       white
                      {% endif %}
                    tap_action:
                      action: navigate
                    card_mod: null
                    style: |
                      ha-card {
                        --chip-padding: 0 15px 0;
                card_mod:
                  style: |
                    ha-card {
                      --chip-spacing: 0;
                chips: null
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
              box-shadow: none;
              position: relative;
              bottom: -100px;
              border-radius: 0;
            :host {
              --mush-card-primary-font-size: 1.2rem;
    card_mod:
      style: |
        ha-card {
          min-height: 275px;
          background: var(--card-background-color) url('/local/backgrounds/bathroom-small.jpg');
          no-repeat center 0px;
          position: relative;
          background-position: center;
          border-radius: 15px 15px 0 0;
Appreciate you looking at this :slight_smile:
Let’s see what this does for you and go from there…
cards:
    layout:
      margin: 0 auto;
      padding: 5px 2px;
    cards:
        chips:
          - type: template
            icon: mdi:lightbulb
            icon_color: |-
               white
              {% else %}
               grey
              {% endif %}
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
          - type: template
            icon: |-
               mdi:lightbulb-auto
              {% else %}
              {% endif %}
            icon_color: |-
               orange
              {% else %}
               grey
              {% endif %}
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
          - type: template
            icon_color: |-
               orange
              {% else %}
               grey
              {% endif %}
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
                  --chip-padding: 0;
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
        chips:
          - type: template
            content: >-
            tap_action:
              action: more-info
            icon_color: |-
              red
              orange
              blue
              {% else %}
              grey
              {% endif %}
            card_mod:
              style: |
                ha-card {
          - type: template
            content: >-
              {{ states(entity) }}{{ state_attr(entity, "unit_of_measurement")
            icon: mdi:water
            icon_color: blue
            tap_action:
              action: none
            hold_action:
              action: none
            card_mod:
              style: |
                ha-card {
          - type: template
            content: >-
              {{ states(entity) }} {{ state_attr(entity, "unit_of_measurement")
            icon: mdi:gauge
            icon_color: grey
            tap_action:
              action: none
            card_mod:
              style: |
                ha-card {
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    cards:
        primary: Bathroom
        tap_action:
          action: navigate
        hold_action:
          action: none
        icon_color: blue
        card_mod:
          style: |
            ha-card {
              background: none;
        layout:
          margin: 0 0 0 5px;
          padding: 5px
        cards:
            chips:
              - type: template
                content: |-
                  {% if state > 0 %}
                   Running
                  {% endif %}
                icon_color: |-
                  {% if state > 0 %}
                   blue
                   grey
                  {% else %}
                   white
                  {% endif %}
                tap_action:
                  action: navigate
                card_mod:
                  style: |
                    ha-card {
              - type: template
                content: |-
                  {% if state > 0 %}
                   Running
                  {% endif %}
                icon_color: |-
                  {% if state > 0 %}
                   red
                   grey
                  {% else %}
                   white
                  {% endif %}
                tap_action:
                  action: navigate
                card_mod:
                  style: |
                    ha-card {
            card_mod:
              style: |
                ha-card {
                  --chip-spacing: 0;
    card_mod:
      style: |
        ha-card {
          --chip-spacing: 0;
          box-shadow: none;
          position: relative;
          bottom: -100px;
          border-radius: 0;
        :host {
card_mod:
  style: |
    ha-card {
      min-height: 275px;
      position: relative;
