beurdy
February 2, 2024, 7:58am
9928
Soā¦ almost everything worksā¦ Exept for the animation:
type: custom:mushroom-template-card
icon: mdi:washing-machine
icon_color: >-
{% if is_state("switch.washing_machine", "on") %} amber {% else %} grey {%
endif %}
primary: Laundry
layout: vertical
secondary: >-
{% if is_state("switch.washing_machine", "off") %} Off {% else %} {{
states("sensor.washing_machine_washer_job_state") }} {% endif %}
entity: switch.washing_machine
tap_action:
action: more-info
card_mod:
style: |
ha-state-icon {
{% if is_states('switch.washing_machine', 'on') %}
animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
transform-origin: 50% 110%;
{% else %}
{% endif %}
@keyframes shake {
0%, 100% { transform: translate(0, 0) rotate(0); }
20% { transform: translate(0.4px, -0.4px) rotate(-4deg); }
40% { transform: translate(-0.4px, 0.4px) rotate(4deg); }
60% { transform: translate(0.4px, 0.4px) rotate(-4deg); }
80% { transform: translate(-0.4px, -0.4px) rotate(4deg); }
@keyframes drum {
50% { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
If I remove the if-statement for the animation, the animation does work. Butā¦ the same if-statement does work for the icon-color. What am I missing?
Hi guys, anyone can suggest me why the code for the mushroom-shape-icon is not applied ?
secondary: >-
{{ states('sensor.cucina_temperature') |round(1)| replace
(".",",")}} Ā°C
icon: mdi:home-thermometer-outline
layout: vertical
entity: sensor.corridoio_temperature_2
icon_color: |
{% if states['switch.shellyplug_s_80646f81bd30'].state == 'on' %}
amber
{%- else -%}
brown
{% endif %}
tap_action:
action: toggle
card_mod:
style: |-
ha-card {
/* Set size and spacing of button */
width: 58px;
--spacing: 8px;
padding-bottom: calc(var(--spacing) * 1.618) !important;
/* Styling of button */
background: var(--card-background-color) !important;
box-shadow: var(--ha-card-box-shadow) !important;
border-radius: calc(var(--ha-card-border-radius, 12px) * 2) !important;
/* Center button */
margin-left: auto;
margin-right: auto;
transition: all 0s;
mushroom-shape-icon$: |
.shape {
background: radial-gradient(var(--card-background-color) 66%, transparent 0%), conic-gradient(rgb(var(--rgb-green)) {{ states('sensor.pixel_6a_battery_level') }}% 0%, var(--card-background-color) 0% 100%);
--icon-size: 66px
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
I donāt use themes, but let me see if that is a possibility with Mushroom. The JavaScript controls what you can adjust via a theme.
andreadannibale:
.shape {
--icon-size: 66px
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
this code isnāt applied
andreadannibale:
--icon-size: 66px
add a ;
here --icon-size: 66px;
thanks but not workingā¦ It seems there is a conflict between the code portion ha-card and the code portion mushroom-shape-iconā¦ because if I apply them separately, both work.
Working on cleaning up your code.
the entity is correctā¦ the card is shown correctly but the style with card mod works partially
Letās start with this in a separate test card and make the appropriate adjustments if you are good with that?
secondary: '{{ states(''sensor.cucina_temperature'') |round(1)| replace (".",",")}} Ā°C '
layout: vertical
icon_color: >
{{ 'amber' if is_state('switch.shellyplug_s_80646f81bd30', 'on') else 'brown'
tap_action:
action: toggle
card_mod:
style:
.shape {
--icon-size: 66px;
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
ha-card {
width: 58px;
--spacing: 8px;
margin-left: auto;
margin-right: auto;
transition: all 0s;
The shape after background code looks off to me, but I need a little help understanding what you want.
primary: ''
secondary: '{{states(''sensor.soggiorno_humidity'')}} %'
entity: sensor.soggiorno_humidity
icon: mdi:thermometer
icon_color: blue
layout: vertical
card_mod:
style:
.shape {
background: radial-gradient(var(--card-background-color) 66%, transparent 0%), conic-gradient(rgb(var(--rgb-green)) {{ states('sensor.soggiorno_humidity') }}% 0%, var(--card-background-color) 0% 100%);
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
This works correctā¦ but if i try to add style to ha-cardā¦ the shape donāt work
Your brackets ;
need adjusted in. I added red background to ensure you know when itās working
primary: ''
icon_color: blue
layout: vertical
card_mod:
style:
.shape {
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
ha-card {
width: 58px;
--spacing: 8px;
background: red !important;
margin-left: auto;
margin-right: auto;
transition: all 0s;
LiQuid_cOOled:
primary: ''
icon_color: blue
layout: vertical
card_mod:
style:
.shape {
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
ha-card {
width: 58px;
--spacing: 8px;
margin-left: auto;
margin-right: auto;
transition: all 0s;
thank you, this worked!!!
Happy to assist!! I like your icon concept
Faecon
(Jo)
February 2, 2024, 8:52am
9942
The position is ok
i changed it in font-weight : bold; and added font-size: 12 ;
But it looks like this is not working
Font weight is only going to affect the 4, the + and - are icons.
type: custom:numberbox-card
entity: input_number.test
icon: false
picture: false
border: false
card_mod:
style: |
ha-card {
color: lime;
.cur-num{
font-weight: 900 !important;
color: red;
.cur-box {
padding-top: 20px !important;
primary: ''
icon_color: blue
layout: vertical
card_mod:
style:
.shape {
background: radial-gradient(var(--card-background-color) 60%, transparent 65%), conic-gradient(rgb(var(--rgb-blue)) {{ states('sensor.soggiorno_humidity') }}% 22%, var(--card-background-color) 0% 100%);
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
ha-card {
width: 88px;
--spacing: 8px;
margin-left: auto;
margin-right: auto;
transition: all 0s;
now i have this:
can i work to reach this(?):
look at the margin of borderā¦ get by conic-gradientā¦but how to get margin from shape ?
Can you post your current code for the green icon?
Bully89
(Bas)
February 2, 2024, 9:15am
9946
Good morning, Iām trying to figure out how to skip the background on the chip card and have searched the forum/thread for an answer, can across some previous topics but none of the solution seems to work.
Did anybody manage to do this? Tried several things:
styles:
img_cell:
- background: '#FFFFFF'
card:
- background: none and or '#FFFFFF' or var(--contrast1)
card_mod:
style: |
:host([type='menu']) .chip {
background: none !important;
etcā¦ Of course with the correct indentation
Thanks!
Please post your code corerctly. See #11
Before we beginā¦
This forum is not a helpdesk
The people here donāt work for Home Assistant, thatās an open source project. We are volunteering our free time to help others. Not all topics may get an answer, never mind one that helps you solve your problem.
[image]
This also isnāt a general home automation forum, this is a forum for Home Assistant and things related to it. Any question about Home Assistant, and about using things with Home Assistant, is welcome here. We canāt help you with eā¦
