The answer is yes if we use
Iāll need a day to get there. Late for me CST
UPDATEā¦got it working. Will walk you through adjusting your theme tomorrow.
In my case itās looks like this:
- type: horizontal-stack
cards:
- type: custom:vertical-stack-in-card
cards:
- type: custom:mushroom-person-card
entity: person.p1
icon_type: entity-picture
primary_info: state
secondary_info: false
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: sensor.p1
use_entity_picture: false
card_mod:
style: |
ha-card {
border: none
alignment: center
cards:
entity: person.p2
primary_info: state
chips:
- type: entity
entity: sensor.p2
card_mod:
style: |
ha-card {
border: none
alignment: center
cards:
entity: person.p3
primary_info: state
see the difference? is_state
vs is_states
. is_states
doesnt exist.
sorry but i havenāt code for green icon cardā¦ itās only an image take from web
Morning all - first post
I am building out a Climate card and trying to customise the Icon based on state. Several forums laterā¦ I am struggling with the icon section (removing this and the card works) - the Icon on the card is blank.
I have checked the states available (heat and āoffā) via the development tools - any help really apricated
type: custom:mushroom-climate-card
entity: climate.controller_boiler
hvac_modes: []
collapsible_controls: true
show_temperature_control: false
layout: horizontal
icon_type: icon
secondary_info: state
tap_action:
action: toggle
**icon: |-**
** {% set vbl=state('climate.controller_boiler') %}**
** {% if vbl=='heat' %}**
** icon: mdi:fire**
** {% elif vbl=='off' %}**
** icon: mdi:fire-off **
** {% endif %}**
card_mod: null
style: |
ha-card {
height: 200px !important;
width: 200px;
mushroom-state-info$: |
.container {
--card-secondary-font-size: 10px;
--card-primary-font-size: 12px;
mushroom-climate-temperature-control$:
mushroom-input-number$: |
.value {
font-size: 30px; }
try:
icon: |-
mdi:fire
mdi:fire-off
{% endif %}
If no one has answered by tomorrow, Iāll reach out. Done for tonight or in my case this morning
Hi!
Anyone knows, if exists the way to modify the cover-card to add a custom button inline with the others or change the actual behaviour of the up/down buttons to call another service (for example, set_cover_position) ??
Okā¦ will be waiting for your guidance
Thank you
Thanks for the super quick response - unfortunately same behaviour:
(Icon just goes blank light orange).
The following works in the developer tools template
icon:|-
{% if is_state('climate.controller_boiler','heat') %}
icon: mdi:fire
{% else %}
icon: mdi:fire-off
{% endif %}
Result type: string
icon: |-
icon: mdi:fire-off
That doesnt work for a non-template card.
@careyjack-boop you will need card mod to control the the icon based on state.
so like this (replace entities with your own):
entity: climate.office_heating
hvac_modes: []
layout: horizontal
icon_type: icon
tap_action:
action: toggle
card_mod:
style:
.container {
.value {
font-size: 30px;
ha-card {
width: 200px;
ha-state-icon {
{% if is_state(config.entity,'heat') %}
--card-mod-icon: mdi:fire;
color: rgb(var(--rgb-deep-orange)) !important;
{% else %}
--card-mod-icon: mdi:fire-off;
color: rgb(var(--rgb-disabled));
{% endif %}
mushroom-shape-icon {
--shape-color: rgba(var(--rgb-deep-orange), 0.2) !important;
{% else %}
--shape-color: rgba(var(--rgb-disabled), 0.2) !important;
{% endif %}
i added that the icon becomes grey if the heating is off.
type: custom:mushroom-template-card
primary: ''
secondary: '{{states(''sensor.soggiorno_humidity'')}} %'
entity: sensor.soggiorno_humidity
icon: mdi:thermometer
icon_color: 'blue'
layout: vertical
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--icon-size: 3rem;
outline: solid 0.5rem ;
outline-offset: -0.99rem;
outline-color: rgba(255,255,255,0.1);
background:
radial-gradient(var(--card-background-color)63%, transparent 65%),
conic-gradient(rgb(var(--rgb-blue)) {{ states('sensor.soggiorno_humidity') }}% 0%, transparent 10%, rgba(var(--rgb-white),0.01) 0% 100%);
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
ha-card {
width: auto;
--spacing: 8px;
padding-bottom: calc(var(--spacing) * 1.618) !important;
background-color
box-shadow: var(--ha-card-box-shadow) !important;
border-radius: calc(var(--ha-card-border-radius, 12px) * 2) !important;
margin-left: auto;
margin-right: auto;
transition: all 0s;
something like thisā¦ but not totally satisfied
Thanks againā¦ bit word blind
Is it possible to blink (on/off) the badge icon?
I want to use a badge icon to indicate warm water is being used in the house. So, for example:
Yes. have the badge appear based on the state of your sensors. then if it is being shown play this animation when both hot and cold is on.
mushroom-badge-icon {
{% if states('binary_sensor.water_hot_and_cold') == 'on' %}
animation: blink-animation 1s steps(5, start) infinite;
{% endif %}
@keyframes blink-animation {
to {visibility: hidden;}
it would go anywhere under or before your icon really:
icon: mdi:washing-machine
icon_color: >-
{% if is_state("switch.washing_machine", "on") %} amber {% else %} grey {%
endif %}
primary: Laundry
layout: vertical
secondary: >-
{% if is_state("switch.washing_machine", "off") %} Off {% else %} {{
states("sensor.washing_machine_washer_job_state") }} {% endif %}
entity: switch.washing_machine
tap_action:
action: more-info
card_mod:
style: |
ha-state-icon {
{% if is_states('switch.washing_machine', 'on') %}
animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
transform-origin: 50% 110%;
{% else %}
{% endif %}
@keyframes shake {
0%, 100% { transform: translate(0, 0) rotate(0); }
20% { transform: translate(0.4px, -0.4px) rotate(-4deg); }
40% { transform: translate(-0.4px, 0.4px) rotate(4deg); }
60% { transform: translate(0.4px, 0.4px) rotate(-4deg); }
80% { transform: translate(-0.4px, -0.4px) rotate(4deg); }
@keyframes drum {
50% { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
{% endif %}
Hello all,
Iām trying to get change my dashboard a little bit. I would like the gap/distance at the title a little bit smaller but canāt get it changed.
Tried making an own theme based on the mushroom and change this at my theme *.yaml :
mush-title-padding: 12px 12px 6px
mush-title-spacing: 6px
Nothing changedā¦ Other changes to this file are visible on my theme.
Tried to ad this code to the Auto Entities Card Configuration Iām using.
card_mod:
style: |
ha-card {
--mush-title-padding: 12px 12px 6px;
--mush-title-spacing: 6px;
But this didnāt change anything eitherā¦
Can someone maybe help me? Thanks!
Nice work,
please add icon_tap_action: to custom:mushroom-template-card
tap_action:
action: navigate
navigation_path: /lovelace/
icon_tap_action:
** action: toggle**
double_tap_action:
action: none
hold_action:
action: none
Are you using the standard Mushroom Shadow theme with no edits?
Yes original with no edits
Ok create a new file named mushroom-square-shadow2.yaml
in the same folder as the original theme file.
Add the following to the new file. Execute Home Assistant Frontend: Reload themes in the Developer tools and the log out and log back in. Choose the new theme.
Mushroom Square Shadow2:
card-mod-theme: Mushroom Square Shadow2
card-mod-card: |
ha-card {
border: none !important;
background-color: none !important;
--card-secondary-line-height: 9px !important;
--card-secondary-font-size: 9px !important;
ha-card-box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.16)
ha-card-border-width: 0
mush-icon-border-radius: 6px
mush-control-border-radius: 6px
ha-card-border-radius: 6px
modes:
light: {}
dark: {}
**You have to create the new theme, because the original Mushroom Themes get overwritten with updates.
Results
