Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Guys, as far as I understand, itā€™s impossible to make only the icon rotate without the main text?
          primary: Fan
          icon: mdi:fan
          icon_color: teal
          layout: vertical
          entity: light.bathroom_dimmer_fan
          card_mod:
            style: |
                ha-card {
                  border: none !important;
                  box-shadow: 0px 0px;
                  animation: rotation linear infinite;
                  {% if states('light.bathroom_dimmer_fan') == 'on' %}
                  animation-duration: 2s;
                  {%- else -%}
                  {%- endif %}
                @keyframes rotation {
                  0% {
                    transform: rotate(0deg);
                  100% {
                    transform: rotate(360deg);
Look at the updated animations that i have linked to many many times in this thread.
No you definitely can.
          primary: Fan
          icon: mdi:fan
          icon_color: teal
          layout: vertical
          card_mod:
            style: |
                ha-card {
                ha-state-icon {
                  {%- else -%}
                  {%- endif %}
                  0% {transform: rotate(0deg);}
                  100% {transform: rotate(360deg);}
Oh, thanks homie :+1: It seemed to me that I had already tried everything, including the examples hereā€¦ apparently I missed it. :man_facepalming:
This is a known issue - but not a bug. Itā€™s go to do with a clearing the cache.
I used this fix and all is good now.
Try this.
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 65px auto 15px
      margin: '-4px -4px -8px -4px;'
    cards:
        entity: sensor.air_filter_days_remaining
        icon: mdi:air-filter
        icon_color: |
          {% set filter_days = states(entity) | int %}
          {% if filter_days < 11 %}
            red
          {% elif filter_days < 41 %}
            orange
          {% else %}
            green
          {% endif %}
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              background: none;
              --ha-card-box-shadow: 0px;
      - type: custom:bar-card
        height: 42px
        min: '0'
        max: '120'
        entity_row: true
        severity:
          - color: green
            to: 90
          - color: orange
            to: 39
          - color: red
            to: 9
        positions:
          icon: 'off'
          indicator: 'off'
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              padding: 12px;
              margin-left: 12px;
              --bar-card-border-radius: 12px;
            bar-card-value {
              margin: 12px;
              font-size: 12px;
              font-weight: bolder;
            bar-card-name {
              margin: 12px;
              font-size: 12px;
            bar-card-backgroundbar {
              opacity: 0.2;
              filter: brightness(1);
        entity: input_boolean.furnace_filter_dropdown
        icon: mdi:chevron-down
        icon_color: disabled
        hold_action:
          action: none
        card_mod:
          style: |
            ha-state-icon {
              transition: transform 0.14s !important;
              {{ 'transform: rotate(-180deg);' if is_state(config.entity, 'on') }}
            ha-card {
              border-width: 0px;
              align-items: flex-end;
              background: none;
              padding-left: 20px!important;
            mushroom-shape-icon {
              --shape-color: None !important;
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: custom:mushroom-entity-card
        entity: input_datetime.air_filter_last_replaced
        icon: mdi:calendar
        layout: vertical
        primary: state
        secondary: Date Replaced
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        layout: vertical
        primary_info: state
        secondary_info: name
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        entity: input_number.air_filter_threshold
        icon: mdi:calendar-edit
        layout: vertical
        primary_info: state
        tap_action:
          action: none
        hold_action:
          action: more-info
        double_tap_action:
          action: none
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        primary: Reset
        secondary: ''
        icon: mdi:refresh
        layout: vertical
        tap_action:
          action: none
        hold_action:
          action: call-service
          service: script.reset_air_filter_date_to_today
          data: {}
          target: {}
        double_tap_action:
          action: none
        card_mod:
          style: |
            ha-card {
              border-width: 0px;
              width: 130px;
              margin-left: auto;
              margin-right: auto;
    card_mod:
      style: |
        ha-card {
          border-width: 0px;
          margin-top: -14px;
card_mod:
  style: |
    ha-card {
      {{ 'height: 66px;' if is_state('input_boolean.furnace_filter_dropdown', 'off') }}
Right, thank you! Resetting frontend cache in companion app under debugging section did the trick. Now itā€™s back to normal.
hey guys,
i got a row of 4 chips and iĀ“m trying to color the background of the different chips based on the state of an entity using card_mod. however i donĀ“t get it working.
anyone knows whatĀ“s wrong?
type: custom:mushroom-chips-card
chips:
  - type: template
    icon: mdi:numeric-1
    content: 'OFF'
    entity: input_text.test
  - type: template
    icon: mdi:numeric-2
    content: PV
  - type: template
    icon: mdi:numeric-3
    content: MINPV
  - type: template
    icon: mdi:numeric-4
    content: MAX
card_mod:
  style: |
    ha-card {
      {% if is_state(config.entity, 'off') %}
        --chip-background: red;
      {% else %}
      {% if is_state(config.entity, 'PV') %}
      {% else %}
      {% if is_state(config.entity, 'MINPV') %}
      {% else %}
      {% if is_state(config.entity, 'MAX') %}
      {% else %}
      {% endif %}
Hi there.
I am setting up some Climate Cards. I activated a few HVAC modes and the buttons appear on the card, but there are no icons.
2024-02-10 08_29_15-Castle Taylor-Morgan ā€“ Home Assistant
Have I missed a step in the settings? :thinking:
Here is my codeā€¦
type: custom:mushroom-climate-card
entity: climate.thunderbox_hq
hvac_modes:
  - heat
  - auto
  - 'off'
tap_action:
  action: more-info
show_temperature_control: false
layout: horizontal
Thanks in advance for the help! :smiling_face_with_three_hearts:
SOLUTION: Fixed in the latest update! :duck:
The short answerā€¦ Let me know if you need additional help adding your logic.
chips:
  - type: template
    icon: mdi:numeric-1
    content: 'OFF'
  - type: template
    icon: mdi:numeric-2
    content: PV
  - type: template
    icon: mdi:numeric-3
    content: MINPV
  - type: template
    icon: mdi:numeric-4
    content: MAX
card_mod:
  style: |
    .chip-container *:nth-child(1) {
      --chip-background: yellow !important;
    .chip-container *:nth-child(2) {
      --chip-background: red !important;
    .chip-container *:nth-child(3) {
      --chip-background: green !important;
    .chip-container *:nth-child(4) {
      --chip-background: blue !important;
card_mod:
  style: |
       {% if is_state('light.pc_lights', 'on') %}
        --chip-background: red !important;;
       {% else %}
        --chip-background: grey !important;
      {% endif %}
that worked. thank you :slight_smile:
just to understand it if i run in something like that again: i have to do it for every nth-child, itĀ“s not possible to use something like {% if is_state(config.entity, 'off') %}? would simplyfy the code
I think this is what you are looking for. Simplified :grinning:
mode: vertical
cards:
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        content: PV
        icon: mdi:numeric-1
      - type: template
        icon: mdi:numeric-2
        content: MINPV
      - type: template
        icon: mdi:numeric-3
        content: MAX
      - type: template
        icon: mdi:power
        content: 'Off'
    card_mod:
      style:
          {% set mode =  states('light.pc_lights') %}
          ha-card {
             padding: 10px  !important;
             --chip-height: 40px !important;
          .chip-container * {
            --color: rgb(var(--rgb-primary-text-color)) !important;
            {% if mode == "PV" %} 1
            {% elif mode == "MINPV" %} 2
            {% elif mode == "MAX" %} 3
            {% elif mode == "off" %} 4
            {% endif %}
My entity was used. Will highlight the state base on the state of input_text.test
youĀ“re awesome. thanks!
okā€¦I donā€™t have an input.boolean fieldā€¦where does that get created? Is that a helper action, if so, how should it be created? Sorry for the noob questionsā€¦just trying to wrap my head around this mush card setup (which is beautiful)
Guys, please tell me, can the counter entity be added as badge to mushroom-template-card?
Yes, you will need to create that under Settings > Devices & services > Helpers > + CREATE HELPER > Toggle
Hello, I need some help please.
Iā€™m trying to change my mushroom dashboard, but I donā€™t know how to do 3 things and Iā€™m seeking for some help.
On the left button, I have this window cover in the chips card that is a venetian blind, and it have the up/down position and the tilt position 0-100.
I want the up/down position to be represented by the icon, and the tilt position by the badge, knowing that the entity is cover.quarto_brinquedos_390_0_391 how can I do that?
The last thing is that I need to move the chips a little to the left so I can see all the badge.
Hope anyone can help me please.
Entity attributes:
current_position: 0
current_tilt_position: 0
device_class: blind
friendly_name: Janela Brinquedos
supported_features: 255
Code for the first button:
mode: horizontal
cards:
    cards:
        primary: Quarto Brinquedos
        secondary: >-
          states('sensor.sala_sala_sala_unknown_03_00_00_01_14_a4_temperature')
          | round(0) }} Ā°C
        icon: mdi:unicorn-variant
        entity: light.toys_room_tx_ultimate_toys_room_tx_ultimate_l1
        tap_action:
          action: navigate
          navigation_path: quarto_brinquedos
        hold_action:
          action: toggle
        icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
        fill_container: true
        layout: horizontal
        multiline_secondary: false
        card_mod:
          style: |
            :host([dark-mode]) {
              background: rgba(var(--rgb-primary-background-color), 0.2);
            :host {
              background: rgba(var(--rgb-primary-text-color), 0.025);
              --mush-icon-size: 76px;
              height: 60px;
              margin-left: -20px !important;
            ha-card {
              border-width: 0px;
        chips:
          - type: template
            entity: cover.quarto_brinquedos_390_0_391
            icon: mdi:window-shutter
            icon_color: blue
            card_mod:
              style: |
                ha-card:after {
                  content: "{{ expand(states.light.luzes_entrada) | selectattr( 'state', 'eq', 'on') | list | count }}";
                  position: absolute;
                  display: flex;
                  justify-content: center;
                  align-items: center;
                  background: rgb(var(--rgb-orange));
                  color: var(--card-background-color);
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-border-width: 0px;
              --chip-box-shadow: none;
              --chip-background: none;
              --chip-spacing: 0;
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% if is_state('light.toys_room_tx_ultimate_toys_room_tx_ultimate_l1', 'on') %}
             background: rgba(255, 152, 0, 0.1);
          {% endif %}
I guess I didnā€™t clarify myselfā€¦what is the code that I need to put in my YAML to use the input_boolean in this card example?
No YAML code needed. Just the helper itself. Itā€™s only function is to hide/un-hide the additional info.
What helper option do I need to choose for this? My google fu didnā€™t turn up much
