Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
QQā€¦this card looks niceā€¦curiousā€¦wha sort of helper & code did you use for the dropdown? I have been trying to do this on my setup, but cannot figure out how to do it?
May I ask how were you able to use the numbers card for a sensor percentage? Can i see your code?
Itā€™s a toggle helper. Just create a new helper under Settings > Devices & services and select Toggle.
Itā€™s just an input_boolean. Clicking the icon just toggles the boolean. Then the extra info is just under a conditional card referenced to that boolean.
I added some padding to the chip card. I would suggest the use of two icons, one for open blinds and one for closed. In addition, you can set a different color icon based on the status of the blinds.
Closed -tilt is 0
Open -tilt is 44
type: custom:stack-in-card
mode: horizontal
cards:
  - type: custom:stack-in-card
    cards:
        primary: Quarto Brinquedos
        secondary: >-
          states('sensor.sala_sala_sala_unknown_03_00_00_01_14_a4_temperature')
          | round(0) }} Ā°C
        icon: mdi:unicorn-variant
        entity: light.toys_room_tx_ultimate_toys_room_tx_ultimate_l1
        tap_action:
          action: navigate
          navigation_path: quarto_brinquedos
        hold_action:
          action: toggle
        icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
        fill_container: true
        layout: horizontal
        multiline_secondary: false
        card_mod:
          style: |
            :host([dark-mode]) {
              background: rgba(var(--rgb-primary-background-color), 0.2);
            :host {
              background: rgba(var(--rgb-primary-text-color), 0.025);
              --mush-icon-size: 76px;
              height: 60px;
              margin-left: -20px !important;
            ha-card {
              border-width: 0px;
              box-shadow: 0px 0px;
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            entity: cover.quarto_brinquedos_390_0_391
            icon: |
             {%- set jalousie = state_attr('cover.sonnenschutz_BEDROOM',
              'current_position') | int %} {% if jalousie >= 2 %}
                mdi:window-shutter-open
              {% else %}
                mdi:window-shutter
              {% endif %}
            icon_color: |
                 green
               {% else %}
                 yellow
               {% endif %}
            card_mod:
              style: |
                ha-card:after {
                  content: "{{state_attr('cover.quarto_brinquedos_390_0_391','current_tilt_position') }}";
                  position: absolute;
                  display: flex;
                  justify-content: center;
                  align-items: center;
                  background: rgb(var(--rgb-orange));
                  color: var(--card-background-color);
                  font-weight: bolder;
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-border-width: 0px;
              --chip-box-shadow: none;
              --chip-background: none;
              padding: 0px 10px 0px 0px;
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% if is_state('light.toys_room_tx_ultimate_toys_room_tx_ultimate_l1', 'on') %}
             background: rgba(255, 152, 0, 0.1);
          {% endif %}
Thanks a lot it worked!
If I wanted to animate the large icon, for example when sensor.aeg_roupa_appliancestate is different than IDLE, icon mdi:washing-machine will wiggle like this code:
cards:
    icon: mdi:washing-machine
    icon_color: orange
    primary: 'Washing Machine #2'
    card_mod:
      style: |
          ha-state-icon {
            animation: shake 400ms ease-in-out infinite;
            transform-origin: 50% 58%;
            clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
          @keyframes shake {
            0%, 100% { transform: translate(0, 0) rotate(0); }
            20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
            40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
            60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
            80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
    icon_color: blue
    card_mod:
      style:
        mushroom-shape-icon$: |
          .shape {
            background: none !important;
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: spin 1s linear infinite;
            clip-path: circle(21.7% at 50% 58%);
card_mod:
  style: |
    ha-card {
      height: 66px;
But this in the previous card.
Would that be too difficult?
Thanks.
Like this?
mode: horizontal
cards:
    cards:
        secondary: >-
          | round(0) }} Ā°C
        tap_action:
          action: navigate
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: >
            :host {
              height: 60px;
            ha-card {
              border-width: 0px;
            {% if is_state('sensor.aeg_roupa_appliancestate', 'on') %}
            ha-state-icon {
             @keyframes shake {
               {% endif %}
        chips:
          - type: template
            icon: |
               {% else %}
                 mdi:window-shutter
               {% endif %}
            icon_color: |
                 green
               {% else %}
                 yellow
               {% endif %}
            card_mod:
              style: |
                ha-card:after {
                  position: absolute;
                  display: flex;
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% endif %}
This one I cannot get it to work, even when I change
to
{% if is_state('sensor.aeg_roupa_appliancestate', 'off') %}
or
{% if is_state('sensor.aeg_roupa_appliancestate', 'iddle') %}
The icon do not animate.
But thanks anyway for helping!
I tested with my own entities and it works
mode: horizontal
cards:
    cards:
        secondary: |
          {{states('sensor.sala_sala_sala_unknown_03_00_00_01_14_a4_temperature')
          | round(0) }} Ā°C
        tap_action:
          action: navigate
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: >
            :host {
              height: 60px;
            ha-card {
              border-width: 0px;
            {% if states('sensor.aeg_roupa_appliancestate') == 'off' or states('sensor.aeg_roupa_appliancestate') ==
            'on' %}
            ha-state-icon {
             @keyframes shake {
             {%else %}
             {% endif %}
        chips:
          - type: template
            icon: |
               {% else %}
                 mdi:window-shutter
               {% endif %}
            icon_color: |
                 green
               {% else %}
                 yellow
               {% endif %}
            card_mod:
              style: |
                ha-card:after {
                  position: absolute;
                  display: flex;
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% endif %}
Test this basic card if that doesnā€™t work
mode: horizontal
cards:
    cards:
        secondary: |
          | round(0) }} Ā°C
        tap_action:
          action: navigate
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: |
             ha-state-icon {
             @keyframes shake {
Is it possible to replicate this person card with mushroom and card-mod? As you can see in the pic, the badge icon has a cutout when it meets the entity icon. Thanks
The simpler one worked, but the inside of the icon disappeared :confused:
GravaĆ§Ć£o do ecrĆ£ 2024-02-11, Ć s 12.22.15
Please post the code for those two cards combined
This are not combined, they are single cards that Iā€™m using to test.
The two cards that will be combined to the laundry and living room will be these, but I want to animate the ā€˜Lavandariaā€™ icon when the machine is working :wink:
mode: horizontal
cards:
    cards:
        primary: Lavandaria
        entity: null
        tap_action:
          action: navigate
          navigation_path: lavandaria
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: |
            :host {
              height: 60px;
            ha-card {
              border-width: 0px;
        chips:
          - type: template
            entity: cover.lavandaria_janela_lavandaria_17
            icon: >
              {%- set jalousie =
              state_attr('cover.lavandaria_janela_lavandaria_17',
               {% else %}
                 mdi:window-shutter
               {% endif %}
            icon_color: >
              {%- set jalousie =
                 blue
               {% else %}
                 grey
               {% endif %}
            card_mod:
              style: |
                ha-card:after {
                  content: "{{state_attr('cover.lavandaria_janela_lavandaria_17','current_tilt_position') }}";
                  position: absolute;
                  display: flex;
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% if is_state('light.NENHUMA', 'on') %}
          {% endif %}
    cards:
        primary: Sala de estar
        secondary: >-
          | round(0) }} Ā°C
        icon: mdi:sofa
        entity: light.escritorio_tras_interruptor_1
        tap_action:
          action: navigate
          navigation_path: sala-de-estar
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: |
            :host {
              height: 60px;
            ha-card {
              border-width: 0px;
        chips:
          - type: template
            entity: cover.sala_portas_sala_varanda_15
            icon: |
              {%- set jalousie = state_attr('cover.sala_portas_sala_varanda_15',
               {% else %}
                 mdi:window-shutter
               {% endif %}
            icon_color: |
                 blue
               {% else %}
                 grey
               {% endif %}
            card_mod:
              style: |
                ha-card:after {
                  content: "{{state_attr('cover.sala_portas_sala_varanda_15','current_tilt_position') }}";
                  position: absolute;
                  display: flex;
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% if is_state('light.escritorio_tras_interruptor_1', 'on') %}
          {% endif %}
card_mod:
  style: |
    ha-card {
      border-width: 0px;
Yes like this or similar
type: custom:mushroom-person-card
entity: person.jay673
card_mod:
  style: |
    mushroom-badge-icon {
      --badge-icon-size: 0px;
      --badge-size: 15px;
       outline: 3px solid white;
       border-radius:50%;
Iā€™ll get back to you later today if no one answers you :slight_smile:
Great, thank you!
Guys, can make the chip card animate?
I tried something like this but to no avail:
          chips:
            - type: template
              entity: binary_sensor.toilet_presence
              content_info: none
              icon: mdi:human
              icon_color: |-
                {% if is_state('binary_sensor.toilet_presence', 'on') %}
                  amber
                {% else %}
                  #44739e
                {% endif %}
              card_mod:
                style: |
                    animation: blink 1s linear infinite;
                  @keyframes blink {
                    50% {opacity: 0;}
upd: oh sorry, I see I had used badgeā€¦
I see where the problem is, the animated washing machine have two cards stacked, the orange and the blue are two cardsā€¦
I got it working on the small card, with this code, but I only want it to animate when sensor.aeg_roupa_appliancestate is not idle, now its animated all the time, because it donā€™t have the conditional.
mode: horizontal
cards:
    cards:
        secondary: >
          | round(0) }} Ā°C
        tap_action:
          action: navigate
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: |
            ha-state-icon {
            @keyframes shake {
        icon_color: blue
        card_mod:
          style:
              .shape {
              ha-card {
                width: 66px;
                top: -66px;
              ha-state-icon {
    card_mod:
      style: |
        ha-card {
          height: 66px;
EDIT: I managed to put in the big icon also, but the blue part I donā€™t know how to resize it. In all off them I need the condition
icons
Code for the last buttons:
mode: horizontal
cards:
    cards:
        primary: Lavandaria
        entity: null
        tap_action:
          action: navigate
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: |
            :host {
              height: 60px;
            ha-card {
              border-width: 0px;
            ha-state-icon {
            @keyframes shake {
        icon_color: blue
        card_mod:
          style:
              .shape {
              ha-card {
                top: -62px;
                border-width: 0px;
              ha-state-icon {
        chips:
          - type: template
            icon: >
              {%- set jalousie =
               {% else %}
                 mdi:window-shutter
               {% endif %}
            icon_color: >
              {%- set jalousie =
                 blue
               {% else %}
                 grey
               {% endif %}
            card_mod:
              style: |
                ha-card:after {
                  position: absolute;
                  display: flex;
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% endif %}
    cards:
        secondary: >-
          | round(0) }} Ā°C
        icon: mdi:sofa
        tap_action:
          action: navigate
        hold_action:
          action: toggle
        layout: horizontal
        card_mod:
          style: |
            :host {
              height: 60px;
            ha-card {
              border-width: 0px;
        chips:
          - type: template
            icon: |
               {% else %}
                 mdi:window-shutter
               {% endif %}
            icon_color: |
                 blue
               {% else %}
                 grey
               {% endif %}
            card_mod:
              style: |
                ha-card:after {
                  position: absolute;
                  display: flex;
                  border-radius: 50%;
                  top: -5px;
                  right: -5px;
                  width: 16px;
                  height: 16px;
                  font-size: 11px;
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-spacing: 0;
    card_mod:
      style: |
        ha-card {
          height: 102px;
          border-width: 0px;
          {% endif %}
card_mod:
  style: |
    ha-card {
      border-width: 0px;
Hope you can give me a hand here, my knowledge is not so great, I try and do what I can. :wink:
Can anyone give me a hint if there is a way to make my crafts appear the same on both the desktop (expected option) and the mobile app (not expected option)?
Desktop:
App:
          primary: Airwick
          icon: mdi:spray
          icon_color:  |-
            {% if is_state('switch.toilet_airwick_valve', 'on') %}
              red
            {% else %}
              teal
            {% endif %}
          layout: vertical
          entity: switch.toilet_airwick_valve
          card_mod:
            style: |
                ha-card {
                  border: none !important;
                ha-card:after {
                  content: "{{ states('counter.toilet_airwick_total') }}";
                  position: absolute;
                  display: flex;
                  border-radius: 50%;
                  top: +10px;
                  right: +45px;
                  width: 21px;
                  height: 21px;
                  font-size: 11px;
                :host {
                  --icon-size: 64px !important;
                  perspective: 900px;
                ha-card:active {
                  transform: rotateX(25deg);
                  transform-origin: center bottom;
                  transition: 0s;
                mushroom-shape-icon {
                  --shape-color: none !important;
                  --shape-color-disabled: none !important;}
