It don’t think it’s possible with Mushroom because we want to keep it simple to use. For custom usage, I think minimalist is better or maybe you can use browser_mod.
I absolutely love this. Switched my whole mobile dashboard to it today. Would it be possible to have the chips create equal space between them and center the group (instead of being locked to the left edge)?
You can just use the grid card to display multiple entities per line. There is no option for now to hide the slider when off. Doing this would result a height change when the state entity change and I don’t thing it’s a good idea to do this.
We plan to add inline controls to add the control on the left instead of bottom.
Hey @piitaya I keep getting the following error when I try to add the repo as Lovelace: "Repository structure for v0.0.2 is not compliant"
Any idea what may be causing this?
I already had the following in my config file so I did not change it since it seemed the same as your instructions:
Mushroom : contain all the cards available in HACS
Mushroom Themes : contains themes to improve Mushroom experience (rounded border radius). It’s not available on HACS. I just wait the approval.
I think you tried to install the theme avec a lovelace component. Just search for Mushroom in HACS. After that, you can add Mushroom Theme as custom repository (category theme) if you want but it’s optional.
Thank you Paul. I already had Mushroom installed through HACS. Chose Lovelace instead of Theme when adding your theme as a custom repo
Since you are so responsive, lol, how do I get the chips card to display the current weather with the temperature? I have a chip that only shows a sun. I would like to see the temp, for example, and I couldn’t find examples of what it should be. I have tried using https://ui-lovelace-minimalist.netlify.app/codegen/example but I cannot get it to show the weather properly.
Any idea how I get the weather chip to show other parameters?
thank you so much for replying so quickly.
Thought I would post my current UI built on Mushroom, Im so impressed with these cards as a simple and fast way to make a beautiful UI for HA. I had been using custom button cards for a long time and find the yaml tedious and slow and I never really got what I wanted. In a day I made this interface for my phone and Im very happy with it. My only requests would be a Climate card and to be able to set the state to a different entity from the entity the card is using.
Hi @HelL5toKe.
I’m working on a similar setup and have 3 questions I’m currently facing:
How do you resize and position the buttons in your TV remote view?
What do you do, so you don’t have to re-do the header with the chips in every view?
How did you make the hamburger menu button in the home view?
