Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
If you don’t care for dark mode, you can change the 2nd to last line to
      background: rgb(255, 255, 255);
Can someone explain to me how the primary_info and secondary_info works on Entity cards?
For instance I have a card that has a motion sensor on it… I’d like the battery % to show up on the card also. I’ve tried a couple things but just get errors…
I see you can use ā€˜state’ on either but can I or should I also specify an entity for that?
I’m getting errors and ui won’t load when I try this… perhaps I’m just not understanding how it’s supposed to work.
Thank you!
- type: horizontal-stack
            cards:
              - type: custom:mushroom-entity-card
                entity: binary_sensor.front_room_motion_occupancy
                icon: mdi:account
                style: |
                  ha-card {
                    background-color: rgba(255, 255, 255, .1);
I had no doubt that you come up with a solution! Thank you that much!
No, you can’t customize an entity-card like you plan. You have to use a template card and then you can put a template in the secondary line.
Aunt Edith says: No, my code wasn’t right.
this can not be right…
You’re right, had this in a non-functional test card.
Backgroung fan icon is moving with fan. It looks weird.
I’m going to have to do this. Makes more sense to light up the card rather than showing a bulb when a light is on like I currently do. Nice work!
I like this alot, even better if the smaller icons like the motion etc could be pushed up higher to be along side the room/temperature. Great work however!
Thank you so much for your code - I did get it to work with a lightbulb, but I could not get it to work with my door lock.
For background info my Schlage lock is connected via my ring alarm(via zwave) using the ring-mqtt add-on, I’m not sure if that makes any difference here. But I did get this all to work - look at my reply to Boostin4HP - I put my code there as well.
It might help if you come across the same issue of it not working when you receive your hub.
This worked perfectly for me - Thank you Boostin4HP - this will add about 10lbs of boost to your ride for good will :slight_smile:
For everyone else here is the code for my Mushroom template card to get the door lock icon changing color based on state as well as icon and the wording to change based on state as well.
type: custom:mushroom-template-card
primary: Front Door Lock
secondary: |-
  {% set state=states(entity) %}
  {% if state=='locked' %}
  Locked
  {% elif state=='unlocked' %}
  Unlocked
  {% else %}
  Error
  {% endif %}
icon: |-
  mdi:lock
  mdi:lock-open-alert
  {% else %}
  mdi:alert
  {% endif %}
layout: vertical
entity: lock.front_door_lock
tap_action:
  action: toggle
icon_color: |-
  green
  red
  {% else %}
  grey
  {% endif %}
Thank you both image969 (James) and Boostin4HP for the help here, it is greatly appreciated and have these items working perfectly.
Actually used the same method for my Garage door connected via MyQ as well:
primary: Garage Door
secondary: |-
  {% if state=='closed' %}
  Closed
  {% elif state=='open' %}
  Open
  {% else %}
  Error
  {% endif %}
icon: |-
  mdi:garage-variant
  mdi:garage-open-variant-alert
  {% else %}
  mdi:alert
  {% endif %}
layout: vertical
entity: cover.garage_door
icon_color: |-
  green
  red
  {% else %}
  grey
  {% endif %}
tap_action:
  action: toggle
Hope this helps others as well.
Just wanted to share what I have right now.
I parted ways with conditional chips so the chips beneath the room cards will stay at there position and are only visible if…
…windows are open.
…shades are open.
…appliances are running.
…fan is running.
…vacuum is cleaning.
…music or tv is playing.
ezgif.com-gif-maker
And yes, washing machine and dryer are wobbling. :slight_smile:
I have several testing cards that need to be integrated somewhere and I believe this will be a neverending story.
That’s sexy :slight_smile: is it possible to use the wobling also in a Chips card ? Can you please share the wobling part ? :slight_smile:
That is a chips card. :slight_smile:
        type: custom:mushroom-chips-card
        chips:
          - type: template
            entity: input_select.washing_machine_state
            icon: |-
              {% if is_state('input_select.washing_machine_state', 'washing') %}
                hue:room-laundry
              {% else %}
              {% endif %}
            icon_color: green
            card_mod: null
            style: |
              @keyframes wobbling {
                0% {
                  transform: rotate(-5deg);
                100% {
                  transform: rotate(5deg);
              ha-card {
                --chip-box-shadow: 0px 0px;
                animation: wobbling 1s linear infinite alternate;
                {% if states('input_select.washing_machine_state') == 'washing' %}
                 animation-duration: 0.1s;
                {%- else -%}
                {%- endif %}
        alignment: center
Would you mind sharing the code for your room buttons. I like that they show what is active in a room in 1 overview. Thnx
your cams all have the same resolution?
Of course. Here’s the one for my bedroom as is has a temperature sensor, 3 windows, shades and a media player.
The icon and content template are a bit complicated but I wanted to show which windows are open because it gets damn hot in there if I don’t close the right windows at the wright time.
type: custom:vertical-stack-in-card
cards:
    primary: BEDROOM
    secondary: ''
    icon: |-
      {% if is_state('light.BEDROOM', 'on') %}
        mdi:bed-king
      {% elif is_state('light.BEDROOM', 'off') %}
        mdi:bed-king
      {% elif is_state('light.BEDROOM', 'unavailable') %}
        mdi:lightbulb-question
      {% else %}
      {% endif %}
    entity: light.BEDROOM
    icon_color: |-
        amber
        disabled
        disabled
      {% else %}
      {% endif %}
    fill_container: false
    multiline_secondary: true
    tap_action:
      action: navigate
      navigation_path: /lovelace-mobile/BEDROOM
    hold_action:
      action: toggle
    double_tap_action:
      action: none
  - square: false
    columns: 4
    type: grid
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            icon: null
            double_tap_action:
              action: none
            content: '{{ states(''sensor.temperature_BEDROOM'') | float }}°C'
            entity: sensor.temperature_BEDROOM
            tap_action:
              action: more-info
            hold_action:
              action: none
            card_mod: null
            style: |
              ha-card {
        alignment: center
        chips:
          - type: template
            double_tap_action:
              action: none
            entity: null
            icon: >-
              {% if is_state('binary_sensor.fenster_l_BEDROOM', 'on') and
              is_state('binary_sensor.fenster_r_BEDROOM', 'on') and
              is_state('binary_sensor.fenster_s_BEDROOM', 'on') %}
                phu:panel-glass-door-open
              {% elif is_state('binary_sensor.fenster_l_BEDROOM', 'on') and
              is_state('binary_sensor.fenster_r_BEDROOM', 'on') %}
              {% elif is_state('binary_sensor.fenster_r_BEDROOM', 'on') and
              {% elif is_state('binary_sensor.fenster_l_BEDROOM', 'on') %}
              {% elif is_state('binary_sensor.fenster_r_BEDROOM', 'on') %}
              {% elif is_state('binary_sensor.fenster_S_BEDROOM', 'on') %}
              {% else %}
                none
              {% endif %}
            icon_color: red
            tap_action:
              action: none
            hold_action:
              action: none
            content: >-
                all
                LR
                LS
                RS
                L
                R
                S
              {% else %}
              {% endif %}
            card_mod: null
            style: |
              ha-card {
        alignment: center
        chips:
          - type: template
            entity: cover.sonnenschutz_BEDROOM
            icon: >-
              {%- set jalousie = state_attr('cover.sonnenschutz_BEDROOM',
              'current_position') | int %} {% if jalousie >= 2 %}
                mdi:blinds-open
              {% else %}
              {% endif %}
            icon_color: yellow
            double_tap_action:
              action: none
            tap_action:
              action: more-info
            hold_action:
              action: none
            card_mod: null
            style: |
              ha-card {
        alignment: center
        chips:
          - type: template
            entity: media_player.BEDROOM
            icon: |-
              {% if is_state('media_player.BEDROOM', 'playing') %}
                 mdi:music
              {% else %}
              {% endif %}
            icon_color: |-
                 #d8a159
              {% else %}
              {% endif %}
            double_tap_action:
              action: none
            tap_action:
              action: more-info
            hold_action:
              action: none
            card_mod: null
            style: |
              ha-card {
        alignment: center
At this rate you may as well put your entire lovelace.yaml on github and just point people there. LOL
No, I just changed the aspect ratio on some.
Is there a reason why I can’t toggle two switches with one click?
entities:
  - entity: switch.privacy_mode_g3_vardagsrummet
  - entity: switch.privacy_mode_g3_hallen
tap_action:
  action: toggle
With one entity it works fine? Am I doing it wrong or is it a limitation in Mushroom?
