Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
I don’t get it but that worked perfectly! Thank You Cookie Monster! :cookie::cookie::cookie:
Either one works if that’s affecting the font size of both chip cards. Thank you.
I’ve tried to research how to do things like this myself, but keep coming up empty handed. W3 schools explains the concepts with syntax for direct CSS, but often doesn’t translate for use in these Jinja-based dashboards. Do you recommend a resource for understanding things like the use of div, $, ., etc?
Also, why doesn’t your syntax require card_mod:?
Thanks again!
I should be using card_mod:. It is not required but is recommended and apparently provides better performance.
@rhysb Gotcha. Any recommendations for learning Jinja-style CSS?
I tried the syntax you provided. It works for the chip card in the first stack-in-card, but not the rest in the vertical stack. What changes should I make to get that to apply to the entire vertical stack with 4 stack-in-cards containing a mix of mushroom-chips-card, markdown cards, and mushroom-template-card ?
EDIT: I’ve inspected the elements (CTRL-SHIFT-I) to extract this hierarchy:
div #all columns
  div #first column
    hui-vertical-stack-card #THIS IS THE STACK IN THE SCREENSHOT ABOVE
      shadow-root
        div #root
          stack-in-card
            shadow-root
              ha-card #custom-stack-in-card
                shadow-root
                div
                    shadow-root
                      div #root
                        mushroom-chips-card
                          shadow-root
                            ha-card #custom-mushroom-chips-card
                              shadow-root
                              div
                                mushroom-weather-chip
                                  shadow-root
                                    mushroom-chip
Using that, I’m trying to reverse your syntax to understand it a little more. From this, it looks like the $ is used any place there’s a shadow-root. If I basically used that same approach, would I be able to start at the lowest div in the hierarchy that contains all of the elements I would want to effect (e.g. all the way up to the column or columns level div)?
Just sitting in a boring Teams meeting so I tinkered around with backgrounds a bit.
Office and bathroom lights are off:
Office light on, bathroom off:
Office off, bathroom on:
Both on:
Mod for the template card alone:
        card_mod: null
        style: |
          ha-card {
            background: var(--card-background-color) url('/local/Icons/area_arbeitszimmer.jpg' )
            no-repeat center 0px;
            background-size: cover;
            background-blend-mode: overlay;
            background-color: rgba(var(--rgb-card-background-color),
              {% if is_state('light.arbeitszimmer', 'on') %}
                0.2
              {% elif is_state('light.arbeitszimmer', 'off') %}
                0.7
              {% endif %});
            position: relative;
            background-position: center;
            background-repeat: no-repeat;
full code:
cards:
  - type: custom:vertical-stack-in-card
    cards:
        icon: disabled
        entity: light.arbeitszimmer
        icon_color: disabled
        hold_action:
          action: toggle
        card_mod: null
        style: |
          ha-card {
                0.2
                0.7
              {% endif %});
            position: relative;
      - square: false
        columns: 4
        type: grid
        cards:
          - type: custom:mushroom-chips-card
            chips:
              - type: template
                content: '{{ states(''sensor.temperature_arbeitszimmer'') | float }}°C'
                entity: sensor.temperature_arbeitszimmer
                tap_action:
                  action: more-info
                card_mod: null
                style: |
                  ha-card {
                    --chip-box-shadow: 0px 0px;
            alignment: center
            chips:
              - type: template
                entity: binary_sensor.fenster_l_arbeitszimmer
                icon: >-
                  {% if is_state('binary_sensor.fenster_l_arbeitszimmer', 'on')
                    mdi:window-open
                  {% else %}
                  {% endif %}
                icon_color: red
                card_mod: null
                style: |
                  ha-card {
            alignment: center
            chips:
              - type: template
                icon: |-
                  {% if is_state('fan.arbeitszimmer', 'on') %}
                    mdi:fan
                  {% else %}
                  {% endif %}
                icon_color: |-
                  {% if is_state_attr('fan.arbeitszimmer', 'preset_mode',
                  'Normal')%}
                    blue
                  {% elif is_state_attr('fan.arbeitszimmer', 'preset_mode',
                  'Nature')%}
                    green
                  {% else %}
                    disabled
                  {% endif %}
                tap_action:
                  action: more-info
                entity: fan.arbeitszimmer
                card_mod: null
                style: |
                  @keyframes rotation {
                    0% {
                      transform: rotate(0deg);
                    100% {
                      transform: rotate(360deg);
                  ha-card {
                    animation: rotation linear infinite;
                    {% if states('fan.arbeitszimmer') == 'on' %}
                     animation-duration: 3s;
                    {%- else -%}
                    {%- endif %}
            alignment: center
            chips:
              - type: template
                entity: media_player.arbeitszimmer
                icon: |-
                  {% if is_state('media_player.arbeitszimmer', 'playing') %}
                     mdi:music
                  {% else %}
                  {% endif %}
                icon_color: |-
                     #d8a159
                  {% else %}
                  {% endif %}
                tap_action:
                  action: more-info
                card_mod: null
                style: |
                  ha-card {
            alignment: center
    cards:
        icon: disbabled
        entity: light.badezimmer
        tap_action:
          action: navigate
          navigation_path: /lovelace-mobile/badezimmer
        hold_action:
          action: toggle
        card_mod: null
        style: |
          ha-card {
            background: var(--card-background-color) url('/local/Icons/area_badezimmer.jpg' )
              {% if is_state('light.badezimmer', 'on') %}
                0.2
              {% elif is_state('light.badezimmer', 'off') %}
                0.7
              {% endif %});
            position: relative;
      - square: false
        columns: 4
        type: grid
        cards:
            chips:
              - type: template
                icon: null
                entity: sensor.temperature_badezimmer
                content: '{{ states(''sensor.temperature_badezimmer'') | float }}°C'
                tap_action:
                  action: more-info
                card_mod: null
                style: |
                  ha-card {
            alignment: center
            chips:
              - type: template
                entity: binary_sensor.fenster_l_badezimmer
                icon: |-
                  {% if is_state('binary_sensor.fenster_l_badezimmer', 'on') %}
                    mdi:window-open
                  {% else %}
                  {% endif %}
                icon_color: red
                card_mod: null
                style: |
                  ha-card {
            alignment: center
            chips:
              - type: template
                card_mod: null
                style: |
                  ha-card {
            alignment: center
            chips:
              - type: template
                entity: media_player.bad
                icon: |-
                  {% if is_state('media_player.bad', 'playing') %}
                     mdi:music
                  {% else %}
                  {% endif %}
                icon_color: |-
                     #d8a159
                  {% else %}
                  {% endif %}
                tap_action:
                  action: more-info
                card_mod: null
                style: |
                  ha-card {
            alignment: center
I’m not smart enough to hide the icon shadow totally but…
Hi @dunner
How do I put this little icons on the cards?
I’m struggling to do that.
try this to remove the shadow:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 0;
Thanks, but won’t work because these are not chips. I mean the template card icon shadow that you can see if you zoom in.
do you mean the black-ish background around the icons under the room picture?
Nope, I mean the icon shadow/background of the template card.
mushroom-shape-icon { --shape-color: none !important; }
Nope, no luck.
strange. worked fine for me.
Nevermind, stupid-me had still an icon color to find it in the code details that of course prevented your code from functioning…
Thanks for keeping up!
No one? :roll_eyes: Hopefully just a small error from my side but can’t figure it out.
Probably just a limitation as in the normal button card.
Possible solution: put them in a switch group and toggle that entity.
Second option: put both in a script and call that via service and template.
Do you mind sharing the code?
I’m trying to put the icons to show the entities states, like you did.
Which part? The room card?
You can’t toggle 2 entities like that. You need to create a group with those 2 entities in it then toggle the group.
As I already said in an intermediate posting, I later discovered that the best way for this fine tuning are Mushroom Themes. They allow you to control many aspects of the Mushroom Cards.
If you already have a theme in place, you can simply add the relevant mushroom variables to your theme and redefine their values. I.e. one of my own themes is call “AnJoWi Light Theme” and I simply added some mushroom vars to its YAML file:
AnJoWi Light Theme:
  # my existing theme settings
  primary-color: rgb(26, 115, 232)
  # my new mushroom settings:
  mush-spacing: 5px  # was: 12px, i.e. space between Icon+Name and Slider
  mush-card-primary-font-size: 18px  # was: 14px
  mush-card-primary-font-weight: normal  # was: bold
And today I found that in conjunction with card-mod 3 of Thomas Lovén it is even possible to add these mushroom theme vars to individual mushroom cards!
To do this you must install card-mod 3 and then add the theme vars to your mushroom card’s yaml definition like this:
type: custom:mushroom-light-card
entity: light.kitchen
card_mod:
  style: |
    :host {
      height: 90px;
      --mush-icon-size: 52px;
      --mush-icon-symbol-size: 0.8em;
      --mush-spacing:5px;
This is really VERY helpful.
