jimmyeao
(Jimmy White)
June 26, 2022, 12:57pm
1486
How does one add a person picture to a template card?
I have this that greets me:
{% set time = now().hour %}
{% if (time >= 18) %}
Good Evening, {{user}}!
{% elif (time >= 12) %}
Good Afternoon, {{user}}!
{% elif (time >= 5) %}
Good Morning, {{user}}!
{% else %}
Hello, {{user}}!
{% endif %}
(James Scialdone)
June 26, 2022, 3:11pm
1489
I donāt understand what Iām missing. I opened up a Brand New template card and I copied in your code exactly the way it is and everything works but it gives an error when it comes to the badge icon. Is there something else I need installs for badges to work?
KTibow
(Kendell R)
June 26, 2022, 3:12pm
1490
What error is it? Could you send a screenshot?
I havenāt used theme variables for anything yet, so Iām a bit lost. How can I use the variables in the template cards?
Hereās an example of a template card I have:
icon_color: |-
{% if is_state('input_boolean.example_mode', 'on') %}
red
{% else %}
#bdbdbd
{% endif %}
I would like to use the theme variables like mush-rgb-red and mush-rgb-disabled . More generally, I am trying to solve the issue explained in Github Issue #196 . Basically, Iām trying to match the ādisabledā color of a template card to the one of a entity card, on both light and dark mushroom themes. Does anyone actually have a working config?
Is there a way to set a variable template wide and use it in multiple fields afterwards, eg both primary and secondary fields?
rhysb
(Rhys)
June 27, 2022, 1:33am
1493
There is a specific ādisabledā color for this purpose. Light theme it is #bdbdbd , while dark theme it is #6f6f6f .
berkans
(Berkan Sezer)
June 27, 2022, 1:34am
1494
Can we do that with battery card you shared ?
rhysb
(Rhys)
June 27, 2022, 1:37am
1495
What are you wanting to do?
rhysb
(Rhys)
June 27, 2022, 1:43am
1496
Do you have Card Mod installed? While Mushroom cards do not require it, if you want to modify the CSS you will need Card Mod.
berkans
(Berkan Sezer)
June 27, 2022, 1:48am
1497
This is the color icon card you just shared a few messages before. Can the icons in this card be like this :
rhysb
(Rhys)
June 27, 2022, 1:54am
1498
Yes, just replace the code for icon_color with ādisabledā
rhysb
(Rhys)
June 27, 2022, 1:58am
1499
Mushroom doesnāt require any other cards but if you want to modify or combine cards you do. Combining cards you will need Stack-In-Card plus whatever card you are wanting to combine/stack with. Modifying CSS (Styles) you will need Card-Mod.
i thought card-mod was only applied if you prefix stlyes with card-mod
ie
card-mod:
styles: ...
where as the examples provided here do not have the card-mod prefix
rhysb
(Rhys)
June 27, 2022, 2:13am
1501
Just styles: is legacy syntax and still works. Correct syntax is as below:
card_mod:
styles:
Both require card_mod
rhysb
(Rhys)
June 27, 2022, 2:21am
1502
To further explain this, āredā is mush-rgb-red and ādisabledā is mush-rgb-disabled.
rhysb
(Rhys)
June 27, 2022, 3:48am
1503
It is because you are overlaying one card over another. You could change the layering order with z-index, but it starts getting awfully messy.
Hi there.
Is there a way to include something? I want the same list of chips in a row as kind of a navigation on every view without editing all the views when doing a change.
I tried it with an include like this - !include ā¦/includes/navigation.yaml but an yaml exception occurs when saving the raw configuration. Can I temporarly use the yaml mode for mushroom? Or how do you solve this?
Thank you for any kind of help
Stuartie
(Stuart)
June 27, 2022, 9:58am
1505
Yeah I can see how that can start to get quite messy. I did fiddle around with z-index and managed to get what I wanted, I donāt plan to add anymore to this card so hopefully itāll stay tidy enough like this.
type: custom:stack-in-card
cards:
primary: Living Room
secondary: '{{ states(''sensor.thermostat_1_current_temperature'') }} Ā°C'
icon: mdi:sofa
entity: light.living_room_lights
icon_color: |-
{% if is_state('light.living_room_lights', 'on') %}
orange
{% endif %}
hold_action:
action: toggle
tap_action:
action: navigate
navigation_path: livingroom
badge_icon: |-
{% if is_state('sensor.count_living_room_lights_on', '0') %}
{% elif is_state('sensor.count_living_room_lights_on', '1') %}
mdi:numeric-1
{% elif is_state('sensor.count_living_room_lights_on', '2') %}
mdi:numeric-2
{% elif is_state('sensor.count_living_room_lights_on', '3') %}
mdi:numeric-3
{% elif is_state('sensor.count_living_room_lights_on', '4') %}
mdi:numeric-4
{% elif is_state('sensor.count_living_room_lights_on', '5') %}
mdi:numeric-5
{% elif is_state('sensor.count_living_room_lights_on', '6') %}
mdi:numeric-6
{% elif is_state('sensor.count_living_room_lights_on', '7') %}
mdi:numeric-7
{% elif is_state('sensor.count_living_room_lights_on', '8') %}
mdi:numeric-8
{% elif is_state('sensor.count_living_room_lights_on', '9') %}
mdi:numeric-9
{% else %}
mdi:numeric-9-plus
{% endif %}
badge_color: orange
fill_container: true
layout: horizontal
multiline_secondary: false
card_mod:
style: |
:host {
z-index: 1;
- type: custom:mushroom-chips-card
chips:
- type: conditional
conditions:
- entity: binary_sensor.living_room_motion_sensor_occupancy
state: 'on'
chip:
type: template
icon_color: green
icon: mdi:window-open-variant
- type: conditional
conditions:
- entity: binary_sensor.living_room_window
state: 'on'
chip:
type: template
icon_color: red
icon: mdi:motion-sensor
alignment: end
card_mod:
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0;
top: -36px;
z-index: 0;
card_mod:
style: |
ha-card {
height: 66px;
Thanks for your help!
piitaya
(Paul)
June 27, 2022, 10:10am
1506
You can change it using theme variables : https://github.com/piitaya/lovelace-mushroom-themes
mush-rgb-yellow: 255, 235, 59
mush-rgb-state-cover-open: var(--mush-rgb-yellow)
rhysb
(Rhys)
June 27, 2022, 11:09am
1507
Here is another combo card with an entities drop-down that may be useful. I wanted something that would still work as a half width card on my phone.
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: auto 33px
margin: '-4px -4px -8px -4px;'
cards:
primary: Amplifiers
secondary: |-
{% if is_state(entity, 'on') %}
{{ states('sensor.lounge_amp_front_power') | round(0) +
states('sensor.lounge_amp_center_power') | round(0) +
states('sensor.lounge_amp_left_surround_power') | round(0) +
states('sensor.lounge_amp_right_surround_power') | round(0) }} W
{% else %}
Off
{% endif %}
icon: mdi:audio-video
entity: group.lounge_amps
icon_color: '{{ ''blue'' if is_state(entity, ''on'') else ''disabled'' }}'
fill_container: false
card_mod:
style: |
ha-card {
background: none;
--ha-card-box-shadow: 0px;
entity: input_boolean.amps_dropdown
primary: ''
secondary: ''
icon: >-
{{ 'mdi:chevron-up' if is_state(entity, 'on') else 'mdi:chevron-down'
icon_color: disabled
hold_action:
action: none
card_mod:
style: |
ha-card {
align-items: flex-end;
background: none;
mushroom-shape-icon {
--shape-color: none !important;
- type: conditional
conditions:
- entity: input_boolean.amps_dropdown
state: 'on'
card:
type: entities
entities:
- entity: switch.lounge_amp_front
secondary_info: null
- entity: switch.lounge_amp_center
- entity: switch.lounge_amp_left_surround
- entity: switch.lounge_amp_right_surround
state_color: true
show_header_toggle: false
card_mod:
style: |
ha-card {
box-shadow: none !important;
--paper-item-icon-active-color: #2196f3;
--paper-item-icon-color: #6f6f6f;
