Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
@tamirbunny Itā€™s the current temperature in the state, not the target temperature because target temperature is shown in the temperature control button.
@benchr @tmen79
HVAC mode and HVAC action are two different things.
The HVAC mode is the mode of your thermostat : heat, cool, auto, etcā€¦ The icon is colored according to this mode.
The HVAC action is what your thermostat currently do. And it can be idle. The badge is displayed according to this action : heating = red, cooling = blue, idle = no badge.
For example :
  • if your thermostat is in heat mode and the target temperature is below current temperature, the heater will be on, so the HVAC action will be heating.
  • if your thermostat is in heat mode and the target temperature is above current temperature, the heater will be on, so the HVAC action will be idle.
Thanks, I understand.
For some reason it doesnā€™t show any temperature, even though the information is available in the stateā€¦
Iā€™m not sure why this is. Is there a workaround? maybe with a template?
Ok I got it now. Some devices do not show hvac_action instead they have hvac_modes. You have to create template sensor to display and use hvac modes.
My configuration sample is as follows :
    sensors:
      kaira_ac:
        value_template: "{{ states('climate.146235046506144_climate') }}"
Your thermostat is probably showing heat in the state tab. With this template sensor you can now display hvac modes in your cards or where ever you use it. Just add the above configuration to your config settings (configuration.yaml or sensor.yaml) @tmen79
Hello
I like a lot your cards.
Is posible in the person card use filters when use the icon type the entity picture for the states home or not home???
Something like this:
state_filter:
home: grayscale(0%)
not_home: grayscale(100%)
How can I do it if itā€™s posible??? Iā€™m new here.
Thanks in advance and sorry for my English.
Love the new Climate Card. Iā€™ve already replaced the Simple Thermostat Card in the popup for my electric smoker. So clean! Love It!
For some reason, Iā€™m not seeing the new Climate card pop up when I search for mush* after updating to 2.1.1? Anyone else seeing this issue?
Here you go. This is my combo Mushroom Mini-Media-Player card:
Mushroom Alexa Mini Media Player - Standby
type: custom:stack-in-card
cards:
  - type: custom:mushroom-media-player-card
    entity: media_player.office_echo
    icon: si:amazonalexa
    use_media_artwork: false
    fill_container: false
    use_media_info: true
    show_volume_level: false
    media_controls:
      - previous
      - play_pause_stop
      - next
    collapsible_controls: true
    tap_action:
      action: toggle
    card_mod:
      style: |
        ha-card {
          padding-bottom: 0px !important;
  - entity: media_player.office_echo
    hide:
      icon: true
      runtime: true
      source: true
      power: true
      state_label: true
      volume: true
      info: true
      progress: true
      controls: true
    more_info: false
    tts:
      platform: alexa
    type: custom:mini-media-player
    toggle_power: false
    group: true
    card_mod:
      style: |
        ha-card {
          padding: 10px 8px 8px !important;
card_mod:
  style: |
    ha-card {
      {% if not is_state('media_player.office_echo', 'standby') %}
        background: rgba(var(--rgb-card-background-color), 0.5) url( '{{ state_attr( "media_player.office_echo", "entity_picture" ) }}' ) center no-repeat;
        background-size: cover;
        background-blend-mode: overlay;
      {% endif %}
Can we color the text in secondary information in a template card?
I would just like ā€œLOWā€ to be in red.
{% if is_state("binary_sensor.water_fountain_water_level", "on") %}
      Water level LOW
{% elif is_state("binary_sensor.water_fountain_water_level", "off") %}
      Water level ok
{% endif %}
You could do something with card-mod, but a cleaner approach IMO would to be to utilize the icon color and badges.
perfect. I didnt see the badge, as my heaters were not firing. once i updated the temp, its working nicely. thanks
spa
Thank you! That helps me a lot. Got it working now.
trying to get this working but struggling
i have a custom button card the code is
          - type: custom:button-card
              <ha-icon icon="mdi:shield-lock-outline"></ha-icon>WEATHER
            tap_action:
              !include popup/weather.yaml
            template: footer
so when you tap/click the weather button the card should pop up but it doesnt, on click does nothing when using this code
type: vertical-stackcards:
  - type: custom:mushroom-chips-card
    chips:
      - type: menu
      - type: weather
        entity: weather.lille
        show_conditions: true
        show_temperature: true
      - type: entity
        entity: light.kitchen_lights
        icon_color: orange
        icon: mdi:ceiling-light
      - type: entity
        entity: alarm_control_panel.alarm_panel_1
        icon_color: blue-grey
        icon: mdi:shield-half-full
  - type: grid
    cards:
      - type: custom:mushroom-person-card
        entity: person.anne_therese
        use_entity_picture: true
        vertical: true
        entity: device_tracker.demo_paulus
        vertical: true
      - type: custom:mushroom-entity-card
        entity: binary_sensor.updater
        vertical: true
    square: false
    columns: 3
  - type: grid
    title: Lights
    cards:
      - type: custom:mushroom-light-card
        icon: mdi:ceiling-light-multiple
        show_brightness_control: true
        entity: light.bed_light
        icon: mdi:lamps
        show_color_temp_control: true
    columns: 2
    square: false
  - type: grid
    title: Devices
    cards:
      - type: custom:mushroom-fan-card
        entity: fan.living_room_fan
        show_percentage_control: true
        show_oscillate_control: true
      - type: custom:mushroom-alarm-control-panel-card
        states:
          - armed_home
          - armed_away
        entity: switch.ac
        icon: mdi:light-switch
        entity: sensor.power_consumption
        icon_color: purple
        icon: mdi:transmission-tower
    columns: 2
    square: false
but when i use this code works fineā€¦
action: fire-dom-event
browser_mod:
  command: popup
  title: Weather
  style:
    hui-vertical-stack-card:
      $hui-entities-card$ : |
        #states {
          padding-top: 0.5em;
          padding-bottom: 0em;
  card:
    cards:
      - type: custom:weather-card
        entity: weather.openweathermap
        icons: "/local/icons/"
        current: true
        details: false
        forecast: true
        hourly_forecast: false
        number_of_forecasts: 5
any ideas on what the problem maybe?
ok i think i got it working
Now when i tap ā€œvelux buttonā€ i get a popup with the following
The code im using is
browser_mod:
  command: popup
  title: Velux Windows & Blinds
  style:
        #states {
          padding-top: 0.5em;
  card:
    cards:
        entity: cover.velux_window_3
        fullscreen: true
        show_position_control: true
        show_buttons_control: true
        actionsInARow: 3
        sliderService: cover.set_cover_position
        entity: cover.velux_window_2
        fullscreen: true
        actionsInARow: 3
        fullscreen: true
        actionsInARow: 3
How do i add to the above screenshot sliders / position / etc so the buttons are more functional ?
Does someone know if this can be done with a mushroom card?
On the right you see me doing animation with custom button card. With the mushroom on the left I have no idea to get this effect. Feature request or am I already able to do it with mushroom cards?
Code for custom button card: Redirecting...
Iā€™m trying to get the Chips cards to work with the swipe-card in a specific way.
Basically I have a couple of chips on the top of my dashboard with (mostly) counters: numbers of doors open, windows open, covers open, etc. These chips are conditional to only show when count > 0.
firefox_tj3RzIPn3H
Issue is that when a lot of Chips are shown, they drop down to the next line, which is not aesthetically pleasing.
To remedy this, I wrapped the whole horizontal stack of Chips in a swipe-card and this works well: instead of dropping to the next line, the chips continue ā€˜off-screenā€™ and can be seen when swiping to the left. The issue here is however that when I release the container, it snaps back to the start. I would like it to keep the position where it is released. Similar to how itā€™s shown here: https://swiperjs.com/demos (right below ā€™ Premium Swiper templates & plugins from UI Initiative).
Does anyone know what parameters of the swipe card to use in order to achieve this?
This is the current YAML:
type: custom:swipe-card
parameters:
  width: 1000
cards:
  - type: horizontal-stack
    cards:
        chips:
          - type: menu
          - type: alarm-control-panel
            entity: alarm_control_panel.ha_alarm
            content_info: name
            tap_action:
              browser_mod:
                command: popup
                deviceID: this
                title: Alarm
                card:
                  layout: vertical
                  states:
                    - armed_away
          - type: conditional
            conditions:
              - entity: sensor.count_lights_on
                state_not: '0'
            chip:
              type: entity
              icon_color: amber
              icon: mdi:lightbulb
              tap_action:
                action: navigate
                navigation_path: lampen
          - type: conditional
            conditions:
              - entity: sensor.count_active_climate
                state_not: '0'
            chip:
              type: entity
              icon_color: deep-orange
              icon: mdi:radiator
              tap_action:
                action: navigate
                navigation_path: verwarming
          - type: conditional
            conditions:
              - entity: sensor.count_windows_open
                state_not: '0'
            chip:
              type: entity
              icon_color: red
              icon: mdi:window-open-variant
              tap_action:
                action: navigate
                navigation_path: ramen
          - type: conditional
            conditions:
              - entity: sensor.count_doors_open
                state_not: '0'
            chip:
              type: entity
              icon_color: green
              icon: mdi:door-open
              tap_action:
                action: navigate
                navigation_path: deuren
          - type: conditional
            conditions:
              - entity: sensor.count_covers_down
                state_not: '0'
            chip:
              type: entity
              icon_color: purple
              icon: mdi:window-shutter
              tap_action:
                action: navigate
                navigation_path: zonneschermen
          - type: conditional
            conditions:
              - entity: sensor.count_fans_on
                state_not: '0'
            chip:
              type: entity
              icon_color: lime
              icon: mdi:fan
              tap_action:
                action: navigate
                navigation_path: ventilatie
          - type: conditional
            conditions:
              - entity: sensor.count_media_active
                state_not: '0'
            chip:
              type: entity
              icon_color: indigo
              icon: mdi:cast-connected
              tap_action:
                action: navigate
                navigation_path: mediaspelers
          - type: conditional
            conditions:
              - entity: sensor.count_motion_detected
                state_not: '0'
            chip:
              type: entity
              icon_color: light-blue
              icon: mdi:motion-sensor
              tap_action:
                action: navigate
                navigation_path: beweging
        alignment: start
Hi @piitaya
First of all many thanks for all your hard work on the Mushroom cards. Itā€™s absolutely fabulous.
Would it be a good idea to also show an ā€œidle badgeā€ in the above example when the HVAC action is idle? In that case you always know that the entity has a HVAC action and the actual state of the action.
Climate entities without HVAC action will just show the colored icon without the use of badges as there is no HVAC Action available. For example the icon will be colored red when itā€™s actually heating but there will be no badge (as there is no HVAC action).
So this means this would be the same visual apperance as a climate entity where the HVAC mode is heat and the HVAC action is idle. Which means itā€™s actually not heating.
Could this be used for Amazon polly? I canā€™t seem to get it to work replacing alexa with the service below.
tts.amazon_polly_say
amazon_polly_say
I did it with cover :wink:
dropdown
    cards:
      - type: custom:layout-card
        layout_type: grid
        layout:
          grid-template-rows: 25px
          grid-template-areas: |
            "entity menu"
        cards:
          - type: custom:mushroom-cover-card
            entity: cover.volet_amis_prop
            fill_container: true
            show_buttons_control: false
            icon_type: entity-picture
            view_layout:
              grid-area: entity
              grid-column-start: 1
              grid-column-end: 3
            alignment: end
            view_layout:
              grid-area: menu
            card_mod:
              style: |
                ha-card {
                  background-color: transparent !important;
                  margin-top: 10px;
                  margin-right: 5px;
                  text-align: right;
                  box-shadow: none !important;
            chips:
              - type: entity
                entity: input_select.mode_volet_amis
Thanks. But not sure how I would make that work. I donā€™t know how to get to the media source select to use it.
Hi all - really stoked to see the update land recently that included mushroom climate cards, theyā€™re very aesthetically pleasing!
I was previously using ā€˜simple-thermostatā€™ card to control our home climate system and I much prefer the look of the mushroom card.
Iā€™m missing a few functionality pieces that I liked from my old setup, and wondering if thereā€™s a way to include these.
My A/C includes state attributes for the temperature in-duct and the target zone for climate control. The system uses one A/C unit and variable zones control target temperatures in each room. Is there a way to include these state attributes in the secondary information, or alternatively, to support templates?
The other feature is support for fan speeds (ideally collapsible when the system is on/off).
Have attached lovelace screenshots of simple-thermostat and mushroom cards.
