Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
I found this post in part1 and I would like to transform it a litte bit.
I want to make it working for my shutters. left Icon for toggle and then th other buttons for fixed positions like sunprotection or something. How looks the code?! Cant get it working :frowning:
4f0ebc6ed136129149177143b1d81331ae91aa4c
This should address this issue.
type: custom:mushroom-template-card
entity: fan.ventilation_pwm_fan1
secondary: >
  {% if states(config.entity) == 'on' %}
   {{state_attr(config.entity, 'percentage')}}%
    Off
tap_action:
  action: toggle
icon: mdi:fan
layout: vertical
icon_color: |
  {{ '#00bcd4' if is_state(config.entity, 'on') else 'grey' }}
primary: Fan
fill_container: false
multiline_secondary: false
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
      ha-state-icon {
          {% set pwr = states(config.entity) %}
          {% set perc = state_attr(config.entity,'percentage')|int %}
          {% if (perc <= 17 and pwr == 'on') %} animation: rotation 2.5s linear infinite
          {% elif (perc <= 34 and pwr == 'on') %} animation: rotation 2s linear infinite
          {% elif (perc <= 51 and pwr == 'on') %} animation: rotation 1.5s linear infinite
          {% elif (perc <= 67 and pwr == 'on') %} animation: rotation 1s linear infinite
          {% elif (perc <= 84 and pwr == 'on') %} animation: rotation .75s linear infinite
          {% elif (perc <= 100 and pwr == 'on') %} animation: rotation .5s linear infinite
          {%- else  %} animation: rotation 0s linear infinite
          {% endif %};
        ha-card {
          box-shadow: none;
          margin-left: -0px !important;
          margin-right: 0px !important;
          margin-bottom: 0px !important;
          #width: 75%;
          @keyframes rotation {
          0% {transform: rotate(0deg);}
          100% {transform: rotate(360deg);
You can use a negative margin with margin: -20px 0px 0px 0px in the layout card.
type: custom:layout-card
    layout_type: grid
    layout:
      width: 100%
      grid-template-columns: 45% 35% 20%
      grid-template-rows: auto
    cards:
Perfect!!! Thank you very much!!!
I might need to start again, but a while ago I found a really slick and compact room card which I copied the code from and forgot about until now.
None of the entities / icons are displaying at the bottom, is there something obvious I’m missing here? (I’m a coding newb)
type: custom:vertical-stack-in-card
style: |
  ha-card {
    margin-left: 6px;
    margin-right: -2px;
    border-radius: 14px 5px 5px 5px !important;
    margin-bottom: -4px !important;
    border-color: rgb(0,0,0,0.05);
    border-width: 2px;
cards:
    entity: group.lights_all_livingroom
    icon: phu:rooms-living
    badge_icon: >
      {% if is_state(config.entity,'on') %} mdi:numeric-{{
      states('group.lights_all_livingroom') }} {% endif %}
    badge_color: transparent
    icon_color: '{{ ''orange'' if is_state(config.entity,''on'') }}'
    primary: Living Room
    tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.sequence
            - service: input_select.select_option
                entity_id: input_select.xlivingdropdown
                option: none
            - service: browser_mod.navigate
                path: /lovelace/livingroom
    hold_action:
      action: call-service
      service: mqtt.publish
      service_data:
        topic: zigbee2mqtt/Living Room/set
        payload_template: |
          {% if is_state('light.living','on') %}
            {{ "off" }}
            {{ "on" }}
    double_tap_action:
      action: toggle
    card_mod:
      style: |
        ha-card:active mushroom-shape-icon {
            display: flex;
            animation: clip 2.5s;
            background-color: var(--amber-color);
            transition: all 2s;
          border-radius: 50px;
        mushroom-badge-icon {
          --main-color: rgba(var(--rgb-amber),0.5) !important;
          --icon-color: rgba(var(--rgb-red),0.5) !important;
          border-radius: 50px !important;
          margin-right: -5px;
          box-shadow: 0.5px 0.5px 0.5px 0.5px var(--grey-color);
        @keyframes clip {
          0% { box-shadow: 0 0 1px 1px var(--yellow-color) inset; }
          50% { box-shadow: 0 0 5px 15px transparent inset; }
          51% { box-shadow: 0 0 1px 1px var(--amber-color); }
          100% { box-shadow: 0 0 5px 15px transparent; }
        :host { border-width: 0px !important;
        mushroom-card {
          box-shadow: 1px 1px 1px rgb(0,0,0,0.0);
        mushroom-state-info {
        align-self: end !important;
        text-shadow: 1px 1px 1px rgb(125,125,125,0.1);
        margin-top: -12px;
        ha-card {
          --card-primary-font-size: 1.4em;
          --card-primary-font-weight: 400;
          {{ 'background: linear-gradient(0deg, rgba(0,0,0,0) 0%, rgba(255,255,0,0.1) 100%);' if is_state(config.entity, 'on') }}
          --icon-size: 1.7em !important;
          --icon-symbol-size: 1.3em !important;
          --badge-icon-size: 1.4em;
          padding-bottom: 0 !important;
          align-text: end;
  - type: entities
    entities:
      - type: custom:paper-buttons-row
        extra_styles: |
          @keyframes clip {
                50% { clip-path: polygon(0 0, 55% 0, 100% 100%, 0 100%); }
          @keyframes flash {
              20% { opacity: 0.5 ;}
              100% { opacity: 1 ;}
        buttons:
          - entity: sensor.living_room_temperature
              {% if is_state('sensor.living_room_temperature','unavailable') %}
              {{ "00°c" }}{% else %}{{ states('sensor.living_room_temperature')
              | round }}°c{% endif %}
            icon: false
            styles:
              button:
                font-size: 13px
                font-weight: 600
                margin: 0em -0.5px 0em -0.4em
                align-text: left
                padding-left: 0px
              name:
                color: rgb(125,125,125,0.8)
            state_styles:
              unavailable:
                name:
                  color: rgb(0,0,0,0)
            tap_action: none
            hold_action: none
            double_tap_action: none
          - entity: media_player.samsung_q70
            icon: mdi:television-classic-off
            styles:
              icon:
                color: rgb(125,125,125,0.3)
                '--mdc-icon-size': 20px
                margin: 0px -0.5px
                padding: 0px
            state_styles:
              'off':
                icon:
              'on':
                icon:
                  color: orange
            state_icons:
              'on': mdi:television-classic
            tap_action:
              service_data:
                      option: media
            hold_action: none
          - entity: media_player.pioneer
            icon: mdi:audio-video-off
            styles:
              icon:
                margin: 0px -0.5px
                padding: 0px
            state_styles:
              'off':
                icon:
              'on':
                icon:
                  color: orange
            state_icons:
              'on': mdi:audio-video
            tap_action:
              service_data:
                      option: media
            hold_action: none
          - entity: binary_sensor.motion_sensor_home_security_motion_detection_4
            icon: mdi:circle
            styles:
              icon:
                margin: 0px -0.5px
                padding: 0px
                animation: >-
                  {% if is_state('binary_sensor.delay_motion_living','on') and
                  is_state('binary_sensor.living_motion_group','on') %} clip 2s
                  linear infinite {% endif %}
            state_styles:
              'on':
                icon:
                  color: orange
              'off':
                icon:
            state_icons:
              'off': mdi:motion-sensor-off
              'on': mdi:motion-sensor
            tap_action:
              service_data:
                      option: secure
            hold_action: none
          - entity: binary_sensor.delay_door_living
            icon: |
              {% if is_state('binary_sensor.living_door_door_open','on') %}
                mdi:door-open
                mdi:door-closed
            styles:
              icon:
                margin: 0px -0.5px
                padding: 0px
                animation: >-
                  {% if is_state('binary_sensor.delay_door_living','on') and
                  is_state('binary_sensor.living_door_door_open','on') %} flash
                  2s linear infinite {% endif %}
            state_styles:
              'off':
                icon:
              'on':
                icon:
                  color: orange
            tap_action:
              service_data:
                      option: secure
            hold_action: none
          - entity: light.living_lights_smart
            icon: mdi:lightbulb-question-outline
            styles:
              button:
                padding-right: 0em
                margin-right: 0em
              icon:
                padding: 0em
                margin: 0px -0.4em 0px -0.5px
            state_styles:
              'off':
                icon:
              'on':
                icon:
                  color: orange
            state_icons:
              'on': mdi:lightbulb
              'off': mdi:lightbulb-outline
            tap_action:
              service_data:
                      option: lights
            hold_action: none
        styles:
          justify-content: space-between
          margin-top: '-1.2em'
          margin-bottom: '-1.1em'
          padding-left: 0em
          padding-right: 0em
          margin-left: 0em
          margin-right: 0em
    style: 'ha-card {background: none; !important;}'
I have wrote a post on Sticky Floating Navigation Menu - All Devices - Mushroom Chips Card if anyone is interested.
I thought this would be a good place to post a link to my complete code.
To start let’ add card_mod: here
card_mod:
 style: |
   ha-card {
If one of the device is no longer available in you system or has been renamed none of the devices will appear.
I was able to get them to appear, but all main entities were required.
Can someone please tell me, if this collapsable card can be made strictly in mushroom?
Expander card is super flakey, and no CARD-MOD seems to work with it. I have tried literally everything. The onlhy thing I need to do is change the little arrow from blue to white. For some reason it shows up white b default on browser, but it is blue on my iphone. The only card that’s ever done that
So I would love to make it all in mushroom
type: custom:expander-card
title: ''
cards:
  - square: false
    type: grid
    cards:
      - type: custom:button-card
        icon: mdi:power
        color: gray
        tap_action:
          action: navigate
          navigation_path: media
        double_tap_action:
          service: script.tv
        hold_action:
          service: script.switch
        theme: mushroom
        styles:
          card:
            - color: gray
            - background-color: RGB(45,45,45)
          name:
            - font-size: 0.8em
            - white-space: normal
          icon:
            - width: 30px
            - height: 40px
          label:
            - font-size: 0.7em
        icon: mdi:fan-speed-1
        color: gray
        tap_action:
          action: navigate
        double_tap_action:
          service: script.tv
        hold_action:
        theme: mushroom
        styles:
          card:
            - color: gray
          name:
            - font-size: 0.8em
          icon:
            - width: 30px
            - height: 40px
          label:
            - font-size: 0.7em
        icon: mdi:fan-speed-2
        color: gray
        tap_action:
          action: navigate
        double_tap_action:
          service: script.tv
        hold_action:
        theme: mushroom
        styles:
          card:
            - color: gray
          name:
            - font-size: 0.8em
          icon:
            - width: 30px
            - height: 40px
          label:
            - font-size: 0.7em
        icon: mdi:fan-speed-3
        color: gray
        tap_action:
          action: navigate
        double_tap_action:
          service: script.tv
        hold_action:
        theme: mushroom
        styles:
          card:
            - color: gray
          name:
            - font-size: 0.8em
          icon:
            - width: 30px
            - height: 40px
          label:
            - font-size: 0.7em
    columns: 4
title-card:
  type: custom:mushroom-light-card
  entity: light.alaynabelle_lights
  icon: mdi:lamp
  use_light_color: true
  show_brightness_control: true
  show_color_temp_control: true
  show_color_control: true
  double_tap_action:
    action: more-info
  card_mod:
    style: |
      ha-card {
        border: 0px !important;
        --ha-card-box-shadow: none;
gap: 0em
padding: em
child-padding: 1em
title-card-padding: ''
title-card-button-overlay: true
overlay-margin: 1.1em
card_mod:
  style: |
    ha-card {
My take on a Fan Card.
There is a dark mode too :slight_smile:
FanCard
So for the last 20 days I have been working for a tablet version of Home Assistant. It’s still a wip but have almost finished %80 of it My main goal is to use tablets as an informative device rather then controlling the house. But of course dashboard will also contain extensive controls. My main goal was to create an interface useful to inform people with animations. Here are some examples from my project.
I learnd much with both tutorials, but now I am on my limit :slight_smile:
I’m sure, that I red, that it is possible to set the tap_action, but I can’t find it.
I try to seperate the card like:
tap_action:
Icon: toggle
card: more_info
It is a litte more Homekit like
Can you post your current card code?
sorry… here is the code:
    icon: mdi:lightbulb-on
    icon_color: |-
        teal
        grey
    primary: LED-Stripe
    layout: horizontal
    hold_action:
      action: more_info
    double_tap_action:
      action: none
    tap_action:
      action: toggle
    entity: light.kueche_lightstripe
    card_mod:
      style:
        mushroom-shape-icon: |
          ha-state-icon {
            animation: {{ 'illumination 2s infinite' if is_state(config.entity, 'on') else 'none' }}
          @keyframes illumination {
           0%, 100% { clip-path: inset(0 0 0 0); }
           80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
toggle and more_info is working, but only on the complete card
more-info is correct not more_info That is your issue
not really. I would like to seperate the tap_action between card & Icon.
If i tap the icon turn the light on/off (toogle), but if I tap on the card show me more information like brightness and color-controll.
Oh, That’s a lot clearer. Let me see what I can do. We can just merge two cards into one with template cards. I’ll put together an example.
Try this out…
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 1fr 3fr
      margin: 0px 0px 0px 0px
    cards:
        icon_color: |-
           teal
          grey
        tap_action:
          action: toggle
        card_mod:
          style:
              ha-state-icon {
              ha-card {
               border: none;
        primary: LED-Stripe
        tap_action:
          action: more-info
        card_mod:
          style: |
            ha-card {
             border: none;
             left: -30px;
             top: 10px;
So fast a working solution?! Very nice. Thanks.
A little problem is now, that i can’t have two cards next to each other:
grafik
First row is standard, second is your code.
Layout-card is a good option. I will try with this a litte :slight_smile:
We can make it fit. I’ll adjust and post the code. I alsakso need to adjust for your colors
type: horizontal-stack
cards:
  - type: custom:stack-in-card
    cards:
        layout:
          grid-template-columns: 0.2fr 1fr
        cards:
            color_type: icon
            color: var(--button-card-light-color)
            icon_color: |-
               {{ '#%02x%02x%02x' % state_attr(entity, 'rgb_color') }}
              grey
            tap_action:
              action: toggle
            card_mod:
              style:
                  ha-state-icon {
                  ha-card {
                   border: none;
                   background: transparent !important;
            primary: LED-Stripe
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                 border: none;
                 left: 0px;
                 top: 10px;
    cards:
        layout:
        cards:
            color_type: icon
            icon_color: |-
              grey
            tap_action:
              action: toggle
            card_mod:
              style:
                  ha-state-icon {
                  ha-card {
                   border: none;
            primary: LED-Stripe
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                 border: none;
                 left: 0px;
                 top: 10px;
this works, but can I make it easier?
I use a horizontal-stack to make it a little more lookalike to my view. Now I have only to adjust the hight of this “stack” and maybe make the right tap part a little bigger.
grafik
looks nice :slight_smile:
The adjustment of brackground color is only to make it “transparent” All other comes from ios-Theme i’m using
edit:
another simple thing I need for an other entity: How can I remove the Background / circle of the Icon?
