Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 2)
Iā€™ll tackle it this evening.
Have you reloaded or reinstalled Mushroom to see if that resolves the issue?
It scares me to reinstall it. I have so many years invested with coding. I would hate for something to go wrong. But I do update it when thereā€™s one available so thatā€™s kind of like reloading it isnā€™t it?
Just make a backup and download it to your PC prior to the redownloading. Youā€™ll be surprised how little redownloading or even uninstalling an reinstalling HACS programs affects your setup.
With the assistance I give folks, I am constantly adding and removing HACS modules.
If it makes you that uncomfortable, then donā€™t do it. I donā€™t have another resolution beyond that.
It works!!! My friend, you just canā€™t imagine how much you helped me!!! I couldnā€™t find the answer anywhere! I am very grateful to you!!!
Happy to assist! I made an adjustment in the code. I had the fan going in reverse. -360 vs `360ā€™
Please look at my problem, I donā€™t have the skill to solve this problem myselfā€¦
thank you so much for your help
Your template logic is looking for an ON or OFF state when it needs to point at the hvac_action atrribute of the entity.
For example:
icon_color: |
  {{ 'red' if state_attr('climate.otoplenie_zal', 'hvac_action') ==
    'heating' else ' disabled' }}
Full card
type: custom:mushroom-template-card
icon: mdi:fire
entity: climate.otoplenie_zal
icon_color: |
  {{ 'red' if state_attr(config.entity, 'hvac_action') ==
tap_action:
  action: more-info
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: none !important;
      {% if state_attr(config.entity, 'hvac_action') ==
      'heating'  %}
      ha-state-icon {
        animation: fire 3.5s infinite;
        transform-origin: 50% 85%;
        ha-card {
          background: none;
          box-shadow: none;
          margin-left: -0px !important;
          margin-right: 0px !important;
          margin-bottom: 0px !important;
          #width: 75%;
      @keyframes fire {
        0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      {% endif %}
Thanks friend, but the problem is still thereā€¦ The on and off states have the same icon appearance, it only turns on when there is direct heating. You can somehow make the state look like this:
  1. off - gray icon
  2. The thermostat is turned on - the icon lights up red but without animation
  3. The thermostat starts heating - the icon lights up red and the animation begins.
Point 2 doesnā€™t work nowā€¦
Thank you in advance!!!
Your thermostat has two states from what I see, heat and off. Let start with icon color first.
Does this fix that issue?
icon_color: |
     {{ 'red' if is_state(config.entity, 'heat') else 'disabled' }}
The rest of the code should work correctly. The animation will start when hvac_action is heating
Oh yes, the animation started working exactly when it was needed!!!
Just a problem with the background appearedā€¦ The icon should be without a background, but the background appears in the off state and in the idle state. It is necessary that there is no background in all modes.
Post the card code with your updates please. The background it my tests worked correctly.
icon: mdi:fire
icon_color: |
tap_action:
  action: more-info
card_mod:
  style:
      .shape {
      'heating'  %}
      ha-state-icon {
        ha-card {
          background: none;
          box-shadow: none;
          #width: 75%;
      @keyframes fire {
      {% endif %}
I am not seeing a background no matter what state the thermostat with the posted code.
If you put the code in separate card, do you see a background?
@president75 This is all animations working as requested. With so many animations, I am starting to see some lag.
With the code you had been working with the refresh animation wasnā€™t very visible. I added blue to show it was working.
Is there a specific color youā€™d like to have inside the TV?
chrome-capture-2024-3-28 (1)
Untitled
my code
primary: QuaĢ£t 2
entity: switch.sonoff_1000cf9431
icon: mdi:fan
icon_color: red
fill_container: false
tap_action:
  action: more-info
hold_action:
  action: none
double_tap_action:
  action: none
secondary: ''
layout: vertical
card_mod:
  style: |
    ha-card {
    border: none !important;
    padding: 2px 0px 0px 0px !important;
Can you help me, thank you
This should do it :smile:
primary: QuaĢ£t 2
icon: mdi:fan
icon_color: red
tap_action:
  action: more-info
hold_action:
  action: none
double_tap_action:
  action: none
secondary: ''
layout: vertical
card_mod:
  style:
    mushroom-state-info$: |
      .container {
       margin-top: -12px !important;
     ha-card {
Thank you so much Cooled.
Thatā€™s fine.
Iā€™ll take care of the colors.
Here is the code with my devices. Button card throws errors when entities arenā€™t present.
type: custom:button-card
icon: mdi:sofa
entity: light.pc_lights
show_state: false
show_label: true
label: |
    return Math.round(states['sensor.basement_sensor'].state) + "Ā°C" + "&nbsp&nbsp" + Math.round(states['sensor.basement_sensor'].state) + " %";
tap_action:
  action: navigate
  navigation_path: '#soggiorno'
custom_fields:
  btn:
    card:
      type: custom:mushroom-chips-card
      chips:
        - type: template
          tap_action:
            action: none
          icon: |
            {% if is_state(entity, 'on') %}
              mdi:lightbulb-on
            {% else %}
              mdi:lightbulb-outline
            {% endif %}
          icon_color: |
              black
            {% else %}
              white
            {% endif %}
        - type: template
          tap_action:
            action: none
          entity: switch.kitchen_lights
          icon: |
              mdi:power-socket-eu
            {% else %}
              mdi:power-socket-eu
            {% endif %}
          icon_color: |
              red
            {% else %}
              white
            {% endif %}
      card_mod:
        style:
          mushroom-template-chip:nth-child(1)$:
            mushroom-chip$: |
              ha-card:after {
                    content: "{{ states('sensor.basement_sensor') }}";
                    position: absolute;
                    display: flex;
                    justify-content: center;
                    align-items: center;
                    background: rgb(var(--rgb-orange));
                    color: rgb(var(--rgb-black));
                    font-weight: 900;
                    border-radius: 50%;
                    top: -6px;
                    right: -5px;
                    width: 20px;
                    height: 20px;
                    font-size: 8px;
                    z-index: 1;
              ha-card {
                --chip-background: {{'rgba(235, 204, 52, 1)' if is_state('light.pc_lights', 'on') else 'rgba(199, 239, 207, 0.3)' }};
                animation: {{ 'ping 2s ease-out infinite' if is_state('light.pc_lights', 'on') }};
                padding: 5px !important;
                border-radius: 100px !important;
                --chip-icon-size: 34px;
                --chip-height: 40px;
                width: var(--chip-height) !important;
              @keyframes ping {
                0% {
                  box-shadow: 0 0 5px 1px rgba(var(--rgb-amber), 1);
                100% {
                  box-shadow: 0 0 5px 10px rgba(var(--rgb-amber), 0);
              ha-card:active {
                transform: translateY(1.5px);
                transition: 0s;
                box-shadow: 0 0.5px 2px 0 rgba(0, 0, 0, 0.16);
              ha-state-icon {
                animation: {{ 'illumination 2s infinite' if is_state('light.pc_spot', 'on') }};
              @keyframes illumination {
                0%, 100% { clip-path: inset(0 0 0 0); }
                95% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
          mushroom-template-chip:nth-child(2)$:
            mushroom-chip$: |
              ha-card:after {
                    position: absolute;
                    display: flex;
                    font-weight: 900;
                    border-radius: 50%;
                    top: -6px;
                    right: -5px;
                    width: 20px;
                    height: 20px;
                    font-size: 8px;
                    z-index: 1;
              ha-card {
                --chip-background: {{'rgba(140, 199, 161, 1)' if is_state('switch.kitchen_lights', 'on') else 'rgba(140, 199, 161, 0.3)' }};
                animation: {{ 'ping 2s ease-out infinite' if is_state('switch.kitchen_lights', 'on') }};
                --chip-icon-size: 30px;
              @keyframes ping {
                0% {
                100% {
              ha-card:active {
                transition: 0s;
              ha-state-icon {
                {% if is_state('switch.kitchen_lights', 'on') %}
                animation: tilt 4s steps(1) infinite, blink 4s infinite;
                transform-origin: 50% 92%;
                {% else %}
                {% endif %}
              @keyframes tilt {
                0%, 100% { transform: rotate(0deg); }
                33% { transform: rotate(8deg); }
                66% { transform: rotate(-8deg); }
              @keyframes blink {
                0%, 20%, 30%, 45%, 55%, 70%, 80%, 100% { clip-path: inset(0 0 0 0); }
                25% { clip-path: polygon(0 0, 100% 0, 100% 53%, 25% 52%, 24% 77%, 75% 77%, 76% 52%, 100% 52%, 100% 100%, 0 100%); }
                50%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 51% 54%, 51% 76%, 76% 77%, 75% 53%, 100% 52%, 100% 100%, 0 100%); }
                75%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 24% 53%, 24% 77%, 47% 77%, 47% 52%, 100% 52%, 100% 100%, 0 100%); }
  btn1:
    card:
      chips:
        - type: template
          tap_action:
            action: none
          entity: climate.living_room
          icon: |
            {% if (states["climate.living_room"].attributes["hvac_action"] ==
            "heating") %}
              mdi:fire
            {% else %}
              mdi:thermostat
            {% endif %}
          icon_color: |
            "heating") %}
              black
            {% else %}
              white
            {% endif %}
        - type: template
          tap_action:
            action: none
          entity: media_player.tv
          icon: |
              mdi:television
            {% else %}
              mdi:television
            {% endif %}
          icon_color: |
              blue
            {% else %}
              white
            {% endif %}
      card_mod:
        style:
            mushroom-chip$: |
              ha-card {
                --chip-background: {{'rgba(186, 233, 234, 1)' if (states["climate.living_room"].attributes["hvac_action"] == "heating") else 'rgba(186, 233, 234, 0.3)' }};
                animation: {{ 'ping 2s ease-out infinite' if (states["climate.living_room"].attributes["hvac_action"] == "heating") }};
              @keyframes ping {
                0% {
                100% {
              ha-card:active {
                transition: 0s;
              ha-state-icon {
                {% if (states["climate.living_room"].attributes["hvac_action"] == "heating") %}
                animation: fire 1.5s infinite;
                {% else %}
                {% endif %}
              @keyframes fire {
            mushroom-chip$: |
              ha-card {
                --chip-background: {{ 'rgba(199, 239, 207, 0.8)' if is_state('media_player.tv', 'on') else 'rgba(199, 239, 207, 0.3)' }};
                animation: {{ 'ping 2s ease-out infinite' if is_state('media_player.tv', 'on') }};
              @keyframes ping {
                0% {
                  box-shadow: 0 0 5px 1px rgba(199, 239, 207, 1);
                100% {
                  box-shadow: 0 0 5px 10px rgba(199, 239, 207, 0);
              ha-card:active {
                transition: 0s;
              ha-state-icon {
               {% if is_state('light.pc_lights', 'on') %}
               animation: tube-on 1s linear, flicker 1s linear 1s infinite alternate;
               {% else %}
               animation: tube-off 2s linear forwards;
              {% endif %}
              @keyframes tube-off {
              1%, 15% { transform: scale(1, 0.2); }
              40%  { transform: scale(0.2); opacity: 1; }
              100%  { transform: scale(0.2); opacity: 0; }
              @keyframes tube-on {
              5%  { transform: scale(1, 0.2); opacity: 0.3; }
              15%  { transform: scale(1); opacity: 0.4; }
              100%  { transform: scale(1); opacity: 1; }
              @keyframes flicker {
              0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%,
              95.98%, 96.98%, 97.98%, 98.98%, 100% { opacity: 0.6; }
              32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% {
              opacity: 1; }
              ha-state-icon:before {
              content: "";
              position: absolute;
              width: 50%;
              height: 30%;
              margin: 6%;
              top: 25%;
              animation: refresh 300ms linear infinite;
              {% endif %}
              @keyframes refresh {
              0% { background: linear-gradient(180deg, rgba(0,0 ,255, 1) 0%,
              transparent 50%, transparent 100%); }
              25% { background: linear-gradient(180deg, transparent 0%,
              rgba(0,0 ,255, 1) 25%, transparent
              100%); }
              50% { background: linear-gradient(180deg, transparent 0%,
              rgba(0,0 ,255, 1) 50%, transparent
              100%); }
              75% { background: linear-gradient(180deg, transparent 0%,
              rgba(0,0 ,255, 1) 75%, transparent
              100%); }
              100% { background: linear-gradient(180deg, transparent 0%,
              transparent 50%, rgba(0,0 ,255, 1)
              100%); }
styles:
  grid:
    - grid-template-areas: '"n btn btn1" "l btn btn1" "i btn btn1"'
    - grid-template-columns: 1fr min-content min-content
    - grid-template-rows: min-content min-content 1fr
  img_cell:
    - justify-content: center
    - position: absolute
    - width: 80px
    - height: 80px
    - left: 0
    - bottom: 0
    - margin: 0 0 -25px -25px
    - background: '#72F3CD'
    - border-radius: 200px
  icon:
    - width: 35px
    - color: black
    - opacity: '0.6'
    - margin: 0 0 18px 15px
  card:
    - padding: 10px 20px 10px 10px
    - border: solid 2px rgba(114, 243, 205, 1)
  custom_fields:
    btn:
      - justify-content: end
      - align-self: start
    btn1:
      - align-self: start
  name:
    - justify-self: start
    - align-self: start
    - font-size: 18px
    - font-weight: 500
    - color: '#72F3CD'
    - margin-bottom: 5px
  label:
    - align-self: start
    - font-size: 16px
    - font-weight: 500
    - margin-bottom: 50px
    - color: '#fff'
