Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
You are the best
I’ve been following this post since I started HS, just wanted to say you go above and beyond to help people in this community.
I’ve learnt so much from your examples and its so much appreciated.
EDIT:
that goes for dimitri.landerloos aswell
Hello friend, the background is still present in two modes… I can’t get rid of it, please watch the video
Анимация23
type: custom:mushroom-template-card
icon: mdi:fire
entity: climate.otoplenie_zal
icon_color: |
  {{ 'red' if is_state(config.entity, 'heat') else 'disabled' }}
tap_action:
  action: more-info
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: none !important;
      {% if state_attr(config.entity, 'hvac_action') ==
      'heating'  %}
      ha-state-icon {
        animation: fire 3.5s infinite;
        transform-origin: 50% 85%;
        ha-card {
          background: none;
          box-shadow: none;
          margin-left: -0px !important;
          margin-right: 0px !important;
          margin-bottom: 0px !important;
          #width: 75%;
      @keyframes fire {
        0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      {% endif %}
Also, if you will add | int behind your badge temperature, it will rounded to full number
          ha-card:after {
                    content: "{{ states('sensor.openweathermap_forecast_temperature') |int }}";
                    position: absolute;
                    display: flex;
                    justify-content: center;
                    align-items: center;
                    background: rgb(var(--rgb-orange));
                    color: rgb(var(--rgb-black));
                    font-weight: 900;
                    border-radius: 50%;
                    top: -6px;
                    right: -5px;
                    width: 20px;
                    height: 20px;
                    font-size: 15px;
                    z-index: 1;
Misunderstood what you meant by the background. Thought you meant the shape background. I’ll take a look, should be an easy fix!
I’m using the Mushroom Climate Card and would like to have the default changed from showing the Modes to showing the set temperate, what code is needed to swap the default?
This will fix it
icon: mdi:fire
icon_color: |
tap_action:
  action: more-info
card_mod:
  style:
      .shape {
      ha-state-icon {
      'heating'  %}
      {% endif %} }
      ha-card {
          box-shadow: none;
          width: 75%;
      @keyframes fire {
Thank you for the kind words!!
The work and knowledge @dimitri.landerloos has shared has been the foundation I initially based my education and knowledge on. His contributions have led to the continued success of this community.
Did you just snag a picture or do you have code associate with the card?
Cool!!! Thanks a lot!!! this code works perfect!
Just needed a small formatting change. Happy to assist!!!
This is custom:flower-card.
I tried to recreate a similar card using mushroom, but my knowledge of CSS is not enough
Is the forked module or the original no longer working ?
No GitHub - Olen/lovelace-flower-card: Lovelace Flower Card to match the custom plant integration is working well! I just want to have this design for the other cards. The main thing- how to move the circle out of the card?
Its definitely possible, I’ll just need a day or so to design the card.
is it possible to do the same, only with the custom:mushroom-chips-card (template)?
Depends on what you are putting in the body of the card. The post only showed a pic in the left top corner
It’s probably some minor mistake, but I can’t figure it out without our EXPERTS LiQuid and Dmitri. My fan light not animated when I turn light on
type: custom:stack-in-card
mode: vertical
card_mod:
  style: |-
    ha-card {
      {% if states('light.living_fan') == 'on' %}
      box-shadow: 0px 0px 5px 5px #CBC3E3 !important;
      {% else %}
      box-shadow: 5px 10px 5px -3px rgba(0,0,0,0.75);
      {% endif %}
      {% if is_state('light.living_fan', 'on') %}
      background: rgba(255, 152, 0, 0.1) !important;
      {% endif %}
cards:
  - type: custom:mushroom-fan-card
    entity: fan.living_fan
    show_percentage_control: true
    show_oscillate_control: true
    tap_action:
      action: toggle
    hold_action:
      action: none
    double_tap_action:
      action: none
    icon: mdi:fan
    icon_color: |
      {{ '#00bcd4' if is_state(config.entity, 'on') else 'blue' }}
    card_mod:
      style:
          .shape {
          ha-state-icon {
              animation:
              {% set pwr = states(config.entity) %}
              {% set perc = state_attr(config.entity,'percentage')|int %}
              {% set spd = 'rotation infinite linear' %}
              {% if ( pwr == 'off') %} 0s {{spd}}
              {% elif (perc <= 17 and pwr == 'on') %} 2.5s {{spd}}
              {% elif (perc <= 34 and pwr == 'on') %}  2s {{spd}}
              {% elif (perc <= 51 and pwr == 'on') %}  1.5s {{spd}}
              {% elif (perc <= 67 and pwr == 'on') %}  1s {{spd}}
              {% elif (perc <= 84 and pwr == 'on') %}  .75s {{spd}}
              {% elif (perc <= 100 and pwr == 'on') %}  .5s {{spd}}
              {% endif %};
              @keyframes rotation {
              0% {transform: rotate(0deg);}
              100% {transform: rotate(360deg);} }
          ha-card {
                  border: none;
                  background: none;
    layout: null
  - type: custom:mushroom-light-card
    entity: light.living_fan
    icon: mdi:ceiling-fan-light
    use_light_color: true
    show_brightness_control: true
    tap_action:
      action: toggle
    hold_action:
      action: none
    double_tap_action:
      action: none
    layout: null
    card_mod:
      style:
          .shape {
            ha-state-icon {
              animation: {{ 'illumination 2s infinite' if is_state('light.living_fan', 'on') }};
            @keyframes illumination {
              0%, 100% { clip-path: inset(0 0 0 0); }
              95% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
Thank you
No, that was a question about this code
entity: fan.ventilation_pwm_fan1
tap_action:
  action: toggle
icon: mdi:fan
icon_color: |
  {{ 'blue' if is_state(config.entity, 'on') else 'grey' }}
card_mod:
  style:
      .shape {
      ha-state-icon {
          {% if (perc <= 17 and pwr == 'on') %} animation: rotation 2.5s linear infinite
          {% elif (perc <= 34 and pwr == 'on') %} animation: rotation 2s linear infinite
          {% elif (perc <= 51 and pwr == 'on') %} animation: rotation 1.5s linear infinite
          {% elif (perc <= 67 and pwr == 'on') %} animation: rotation 1s linear infinite
          {% elif (perc <= 84 and pwr == 'on') %} animation: rotation .75s linear infinite
          {% elif (perc <= 100 and pwr == 'on') %} animation: rotation .5s linear infinite
          {%- else  %} animation: rotation 0s linear infinite
          {% endif %};
        ha-card {
          background: none;
          box-shadow: none;
          #width: 75%;
          100% {transform: rotate(-360deg);
Hey
Can someone help, to Card mod an Image instead of an Icon?
I Want that the picture is near the middle and Not as Here shown on top?
Do Not know how…
Hope someone can help here :blush:
Thank you!
