Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 2)
try
background: rgba(0,0,0,0);
Iā€™ve organized my entities into separate cards for each room. Some rooms have too many entities to fit on a single card. Is there a way for these entities to automatically cycle through within their respective cards?
you could add a drop down list of entities that donā€™t fit on your card
this happens, borders appear
will quote what I said before.
itā€™s not adding border: none because you havenā€™t added the ha-card correctly.
if you follow the forum guidelines and post your code with `` and not as a screenshot I could help you more
Still no change reflected in the browser after clearing cache and using the suggested value background: rgba(0,0,0,0);. Do I be on a version of mushroom before 3.6.2 for this to work??
When editing the ha-card DOM element directly in Chromeā€™s dev tools, I can set the background color as expected - so I am confident that ha-card is the element I want to target, however, I am almost certainly messing up element targeting in the yaml.
Based on the screenshot and if I understand the docs correctly, ha-card is in the shadow-root of mushroom-cover-card therefore, I should be using the following yaml configuration:
type: custom:mushroom-cover-card
entity: cover.garage_doors
card_mod:
  style:
    mushroom-cover-card$: |
      ha-card {
        background: rgba(0,0,0,0) !important;
the issue wouldnā€™t be mushroom it would be card_mod if anything.
can you try this.
this is my working title card
type: custom:mushroom-template-card
primary: 'r e m i n d e r s '
icon: ''
secondary: 'a l a r m s '
icon_color: blue
card_mod:
  style: |
    ha-card {
        --card-primary-font-size: 1.5rem;
        --card-secondary-color: var(--purple-color);
        border: 1px;
        box-shadow: none;
        margin-top: 1.5rem;
In your example, are you editing the yaml in the code editor for the card? When I copy paste your configuration into a brand new mushroom-template-card I still do not see any of the style changes reflected in the UI despite multiple reloads and cache clears.
I would suggest making a new post or ask for assistance in the card_mod thread.
sounds like you have an issue with that. abit out of scope for this mushroom thread.
Do you see a red background with this code?
If not have you reloaded card_mod?
Is card_mod working on other cards?
entity: cover.your_device
card_mod:
  style: |
      ha-card {
        background: red !important;
If not, please follow Frostyā€™s advice and open up a new thread for this specific issue.
Apologies for wasting everyoneā€™s time. My specific issue? I didnā€™t have card-mod installed :man_facepalming:
More common than you might expect, dont feel too bad :slight_smile:
Hi, how do I add this swing option to the mushroom climate card?
For me, it is only available in the more info panel.
KeĢpernyoĢ‹fotoĢ 2024-07-03 - 17.28.31
Good morning everybody,
I need a bit help from the experts :slight_smile:
With the new HA update, my custom cards got ā€œbiggerā€ and the css broke a bit.
I am not sure if this is a mushroom issue or HA issue - am I the only one?
This is the code for one card:
type: custom:stack-in-card
cards:
    primary: Haus
    secondary: >-
      {{ states('sensor.haus_temperatur_mischung') | replace (".",",")}} Ā°C ā€¢ {{
      states('sensor.haus_feuchtigkeit_mischung') }} %
    icon: mdi:home
    entity: light.zentral_haus_licht_helper
    tap_action:
      action: navigate
      navigation_path: haus
    hold_action:
      action: more-info
    icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0,2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 76px;
          height: 66px;
          margin-left: -18px !important;
  - type: custom:mushroom-chips-card
    chips:
      - type: conditional
        conditions:
          - entity: binary_sensor.zentral_haus_bewegung_prasenz_helper
            state: 'on'
        chip:
          type: template
          icon_color: red
          tap_action:
            action: more-info
          entity: sensor.zentral_haus_bewegung_prasenz
          card_mod:
            style: |
              ha-card {
                animation: blink 1s linear infinite;
              @keyframes blink {
                50% {opacity: 0;}
          icon: mdi:motion-sensor
      - type: conditional
        conditions:
          - entity: binary_sensor.zentral_haus_fenster_helper
            state: 'on'
        chip:
          type: template
          icon_color: red
          tap_action:
            action: more-info
          entity: sensor.zentral_haus_offene_fenster
          icon: mdi:window-open
          card_mod:
            style: |
              ha-card {
              @keyframes blink {
                50% {opacity: 0;}
      - type: conditional
        conditions:
          - entity: binary_sensor.zentral_haus_turen_helper
            state: 'on'
        chip:
          type: template
          icon_color: red
          tap_action:
            action: more-info
          entity: sensor.zentral_haus_offene_turen
          icon: mdi:door-open
          card_mod:
            style: |
              ha-card {
              @keyframes blink {
                50% {opacity: 0;}
      - type: conditional
        conditions:
          - entity: binary_sensor.zentral_haus_tore_helper
            state: 'on'
        chip:
          type: template
          icon_color: red
          tap_action:
            action: more-info
          entity: sensor.zentral_haus_offene_tore
          icon: mdi:gate-open
          card_mod:
            style: |
              ha-card {
              @keyframes blink {
                50% {opacity: 0;}
      - type: conditional
        conditions:
          - entity: input_boolean.briefkasten
            state: 'on'
        chip:
          type: template
          icon_color: red
          tap_action:
            action: more-info
          card_mod:
            style: |
              ha-card {
              @keyframes blink {
                50% {opacity: 0;}
          icon: mdi:mailbox-open
      - type: template
        icon_color: '{{ ''#f1c232'' if is_state(entity, ''on'') else ''off'' ''#5353ec''}}'
        icon: mdi:sleep-off
        tap_action:
          action: more-info
        entity: switch.wach_schlafen
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 0;
Cards
Besides that, maybe the experts have a better idea how to do it with standard cards to stop potential breaks with new updates :smiley:
Hey everybody! Any idea how to remove the delay before it accepts the value for custom:mushroom-number-card ?
chrome_FhHPqFZDjz
in what way have they gotten bigger. is it the icons or the card itself?
what css is no longer working.
I put your code into a new card and from what I can see it looks as it should.
Unfortunately I have no screenshot from the time before :smiley:
But the height of the card got much bigger - it was way smaller before.
I donā€™t remember having a separate css to be honest :smiley: Could you please send me a screenshot how it looks on your end?
I have that as dashboard ā€œcodeā€
grid-template-columns: 50% 50%
grid-template-rows: auto
grid-template-areas: |
  "left right"
mediaquery:
  "(max-width: 390px)":
    grid-template-columns: 100%
      "left"
      "right"
  "(max-width: 800px)":
      "left left"
      "right right"
These are the resources I have from HACS
thatā€™s how it looks my end obviously without all the entities changed.
are you using the new sections layout. in the patch notes on resizing cards it mentions cards have a default min and max size
Iā€™m having an issue with mushroom cards on my dash that have a background image. After upgrading to 2024.7.0 the background image no longer displays, does anybody have any suggestions?
HA 2024.6.4
HA 2024.7.0
cards:
    primary: Hallway
    secondary: >-
      {{ states('sensor.hallway_temperature') | round (1) }}Ā°C - {{
      states('sensor.hallway_humidity')}}%
    icon: none
    entity: light.hallway_lamp
    tap_action:
      action: navigate
      navigation_path: /home-v2/hallway
    icon_color: '{{ "orange" if is_state("light.hallway_lamp", "on") else "disabled" }}'
    layout: horizontal
    card_mod:
      style:
        mushroom-state-info$: |
          .primary {
            text-shadow: 0px 0px 5px black;
            --card-primary-font-weight: 350;
           --card-primary-color: white;
            --card-primary-font-size: 20px;
            align-items: end;
            margin-top: 175px;
            inline-size: 180px;
            height: 25px;
          .secondary {
            --card-secondary-font-size: 13px;
           --card-secondary-color: white;
            --card-secondary-font-weight: 320;
              margin-top: -2px;
          :host {
            background: url('/local/images/areas/hallway.PNG') center;
            background-size: cover;
            background-blend-mode: overlay;
            #filter: grayscale(70%);
            background-color: rgba(var(--rgb-card-background-color), 0.0);
             --mush-icon-size: 0px;
            height: 220px;
            margin-left: -15px !important;
            margin-top: -70px !important;
          mushroom-shape-icon {
            --shape-color: rgba(var(--rgb-{{ 'orange' if is_state('light.hallway_lamp', 'on') else 'disabled' }}), 0.4) !important;
    chips:
      - type: conditional
        conditions:
          - entity: binary_sensor.front_door
            state: 'on'
        chip:
          type: template
          icon_color: red
          icon: mdi:door-open
          tap_action:
            action: more-info
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: lock.front_door
            state: unlocked
        chip:
          type: template
          icon_color: red
          icon: mdi:lock-open-variant
          tap_action:
            action: more-info
          hold_action:
            action: none
      - type: template
        icon: >-
          {{ 'mdi:lightbulb' if expand(area_entities('Hallway')) |
          selectattr('domain','eq','light') | selectattr('state','eq','on') |
          list | count > 0 else 'mdi:lightbulb-outline' }}
        icon_color: >
          {% set lights_in_hallway = expand(area_entities('Hallway')) |
          selectattr('domain', 'eq', 'light') | list %} {{ 'orange' if
          lights_in_hallway | selectattr('state', 'eq', 'on') | list | count > 0
          else 'grey' }}
        content: >-
          {{ expand(area_entities('Hallway')) |
          list | count }}
        tap_action:
          action: call-service
          service: light.toggle
            area_id: hallway
        hold_action:
          action: more-info
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-spacing: -15px;
          margin-top: -10px;
card_mod:
  style: |
    ha-card {
      height: 180px;
      width: 180px;
      margin-left: auto;
      margin-right: auto;
      {% if is_state('light.hallway_lamp', 'on') %}
          #box-shadow: 0 0 20px rgba(245, 173, 66, 0.5);
          #border-radius: 10px;
          #background: rgba(245, 173, 66, 0.3);      {% endif %}
