Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
You need to rename the animation something other than pulse. Pulse is a standard Mushroom animation and appears to conflict with your keyframes css.
code with renamed animation to test
type: vertical-stack
cards:
  - type: custom:button-card
    icon: mdi:cog-outline
    tap_action:
      action: navigate
      navigation_path: /dashboard-mushroom/net
    entity: sensor.cpu_temperature
    show_state: true
    custom_fields:
      btn:
        card:
          type: custom:mushroom-chips-card
          chips:
            - type: template
              tap_action:
                action: toggle
              icon: mdi:pi-hole
              entity: input_boolean.pi_hole_timer
              card_mod:
                style: |
                  ha-card {
                    --chip-background: transparent;
                    padding: 5px !important;
                    border-radius: 100px !important;
                    color: yellow !important;
                    border: none !important;
                    {% if is_state('input_boolean.pi_hole_timer', 'on') %}
                      opacity: 1 !important;
                      animation: test 2s infinite !important;
                    {% else %}
                      opacity: 0.4 !important;
                      animation: none !important;
                    {% endif %}
                  @keyframes test {
                    0% { transform: scale(1); }
                    50% { transform: scale(1.2); }
                    100% { transform: scale(1); }
            - type: template
              tap_action:
                action: toggle
              icon: mdi:fan
              entity: sensor.argon_one_addon_fan_speed
              card_mod:
                style: |
                  ha-card {
                    padding: 5px!important;
                    border-radius: 100px!important;
                    color: yellow!important;
                    border: none!important;
                    {% set fan_speed = states('sensor.argon_one_addon_fan_speed') %}
                    {% if fan_speed != 'unknown' and fan_speed | int > 0 %}
                      animation: spin 1s linear infinite !important;
                     {% else %}
                    {% endif %}
                  @keyframes spin {
                    100% { transform: rotate(360deg); }
    card_mod:
      style: |
        ha-card {
          background: linear-gradient(135deg, rgba(220, 20, 60, 1) 0%, rgba(0, 0, 0, 1) 100%);
          border: transparent!important;
          color: white;
          box-shadow: 2px 2px 10px rgba(0, 0, 0, 0.5);
          padding: 20px;
    styles:
      grid:
        - grid-template-areas: '"n btn" "s btn" "i btn"'
        - grid-template-columns: 1fr min-content
        - grid-template-rows: min-content min-content 1fr
      card:
        - padding: 10px 2px 91px 10px
      img_cell:
        - justify-content: start
        - position: absolute
        - width: 150px
        - height: 150px
        - left: 0
        - bottom: 0
        - margin: 0 0 -30px -30px
        - background: transparent;
        - border-radius: 500px
      icon:
        - width: 60px
        - color: black
        - opacity: 1
      custom_fields:
        btn:
          - justify-content: end
          - align-self: start
      name:
        - justify-self: start
        - align-self: start
        - font-size: 18px
        - font-weight: 500
        - color: white
      state:
        - min-height: 80px
        - align-self: start
        - font-size: 14px
        - opacity: 0.7
columns: 3
I have a mushroom template card , where I want the background a litlle darker. I have this cardmod
but it is not working. what is wrong here ?
            card_mod:
              style:
                  ha-card {
                    box-shadow: 0px 2px 5px 0px rgba(0,0,0,0.8) !important;
                  :host {
                  background: rgba(rgb({{ states("input_text.kleur_iconen")}}), 0.2);
I am sure you could have worked it out on your own. :wink:
card_mod:
  style: |
    ha-card {
            primary: '{{ states(''input_text.ruimte_1'')}}'
            secondary: "{{ states('sensor.ruimte1_temperatuur') | round(1) | float(0) }} °C"
            icon: >
              {% set STRING = states('input_text.ruimte_1') %}
              {% if is_state('input_boolean.ruimte1', 'on') %}
                mdi:lightbulb
              {% else %}
                mdi:alpha-{{STRING[0]| lower}}-circle-outline
              {% endif %}
            entity: input_boolean.ruimte1
            tap_action:
              action: navigate
              navigation_path: ruimte1
            hold_action:
              action: toggle
            icon_color: >
              {% if is_state("input_boolean.ruimte1", 'on') %}
              {% else %}
                disabled
              {% endif %}
            fill_container: true
            layout: horizontal
            multiline_secondary: false
            card_mod:
              style: |
                ha-card {
                  background-color: blue;
it is getting blue, but after half a second it is gone ( white or transparant I don’t know)
try !important on the end
thanks to @Frosty this is what it has to be
            card_mod:
              style: |
                ha-card {
                  background-color: rgba({{ states("input_text.kleur_iconen")}},0.2) !important;
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        entity: climate.eetplaats
        icon_color: "{{ states("input_text.kleur_iconen_hex")}}"
is it possible that it is not possible to use states(“input_text.kleur_iconen_hex”) ?
I have this error
invalid key: “{‘states(“input_text.kleur_iconen_hex”)’: None}” in “/config/ui_lovelace_minimalist/dashboard/views/home.yaml”, line 17, column 0
try
icon_color: '{{ states(''input_select.test'') }}'
I take it your using a input select drop down helper with the colours
EDIT:
either will work
Thanks, that worked!
fixed mine:
Bildschirmfoto 2024-07-16 um 13.40.47
The important thing is the card_mod for the template-card and the chips card
Code
type: custom:stack-in-card
cards:
    primary: Schlafzimmer
    secondary: >-
      🌡️ {{ states('sensor.schlafzimmer_raumthermostat_temperature') | round(1)
      }} °C
    icon: mdi:bed-double
    entity: light.schlafzimmer
    tap_action:
      action: navigate
      navigation_path: schlafzimmer
    hold_action:
      action: toggle
    icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
    layout: horizontal
    card_mod:
      style: |
        ha-card([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        ha-card {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --icon-size: 76px;
          margin-top: -20px !important;
          margin-left: -18px !important;
          margin-bottom: -11px !important;
    chips:
      - type: conditional
        conditions:
          - entity: climate.schlafzimmer_thermostat
            state_not: 'off'
        chip:
          type: template
          icon: |-
            {% if is_state(entity, 'heat') %}
              mdi:fire
            {% endif %}
          icon_color: red
      - type: conditional
        conditions:
          - entity: binary_sensor.schlafzimmer_fenster
            state: 'on'
        chip:
          type: template
          icon_color: amber
          icon: mdi:window-open
          tap_action:
            action: more-info
      - type: light
        content_info: none
        use_light_color: true
        icon: mdi:lightbulb
        tap_action:
          action: toggle
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 1;
          margin-top: -10px !important;
card_mod:
  style: |
    ha-card {
      height: 102px;
      {% if is_state('light.schlafzimmer', 'on') %}
         background: rgba(255, 152, 0, 0.1);
      {% endif %}
Same problem as well. I was able to narrow it down to the following lines of code
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.3);
        :host {
          --icon-size: 80px;
          height: 76px !important;
          margin-left: -23px !important;
          margin-bottom: -10px !important;
If I changed it to the following it works correctly
    card_mod:
      style: |
        ha-card{
          --icon-size: 80px;
No clue if this is the correct way to fix it but it worked for me.
Didn’t see this before I posted. This also worked for me.
    card_mod:
      style: |
        ha-card {
          --icon-size: 76px;
Since 2024.07 I’ve not been able to get negative values to work with chip spacing. Positive values work, but not negative.
cards:
    primary: Entry
    secondary: |-
      🌡️ {{ state_attr('weather.home', 'temperature') }}°F |
      💦 {{ state_attr('weather.home', 'humidity') }}%
    icon: mdi:coach-lamp
    entity: light.entry_lights
    icon_color: blue
    layout: horizontal
    card_mod:
      style: |
        ha-card {
          height: 35px !important;
          border-style: none;
          left: -25px;
          top: 5px;
          --icon-size: 75px;
    chips:
      - type: template
        entity: light.front_porch_light
        card_mod:
          style: |
            ha-card {
              border-style: none;
      - type: template
        entity: light.permanent_outdoor_lights
        icon: mdi:led-strip-variant
        card_mod:
          style: |
            ha-card {
              border-style: none;
      - type: template
        entity: binary_sensor.mail_notify
        icon: mdi:mailbox-open-up-outline
        card_mod:
          style: |
            ha-card {
              border-style: none;
      - type: template
        entity: binary_sensor.door_front
        icon: mdi:door-open
        card_mod:
          style: |
            ha-card {
              border-style: none;
    card_mod:
      style: |
        .chip-container {
          --chip-spacing: -10px;
    alignment: end
I’ve tried both with !important and without with no success.
I am also having the same issue, reported it in the card_mod topic but had no reply :frowning:
This worked for me and fixed the padding:
    card_mod:
      style: |
          background: rgba(var(--rgb-primary-background-color), 0.2) !important;
        ha-card {
          background: rgba(var(--rgb-primary-text-color), 0.025) !important;
          height: 55px;
          width: 500px;
          position: relative;
          left: -18px;
          top: -18px;
          --spacing: 12px 10px 0 12px;
          --icon-size: 76px;
          --ha-card-border-width: 0;
        mushroom-state-info {
          padding-left: 5px !important;
Hello! help me please! how can I edit my code so as to preserve the animation of the icon but at the same time add a temperature adjustment on the side as in the second picture. I photoshopped this picture
type: custom:mushroom-template-card
entity: climate.otoplenie_zal
secondary: |
  {% if states(config.entity) == 'heat' %}
  On -
   {{state_attr(config.entity, 'temperature')}}%
  {% else %}
    off
  {% endif %}
tap_action:
  action: more-info
icon: mdi:fire
layout: vertical
icon_color: |
  {{ '#ff6f22' if is_state(config.entity, 'heat') else 'grey' }}
primary: Hall
fill_container: false
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
      ha-state-icon {
      {% if state_attr(config.entity, 'hvac_action') ==
      'heating'  %}
        animation: fire 3.5s infinite;
        transform-origin: 50% 85%;
      {% endif %} }
      ha-card {
          box-shadow: none;
          margin-left: -0px !important;
          margin-right: 0px !important;
          margin-bottom: 0px !important;
      @keyframes fire {
        0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
        95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
        100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
I have an icon I want to spin. but it is not working
the state of climate.ruimte1_airco is “cool”. What is wrong ?
                card_mod:
                  style:
                    mushroom-state-info$: |
                      .container {
                        margin: 10px;
                      .shape {
                      margin-top: 0px;
                      ha-state-icon {
                        {{ 'animation: spin 1s linear infinite;' if not is_state('climate.ruimte1_airco','off') }}
                        @keyframes spin {
                      ha-card {
                        box-shadow: none !important;
Hi @rhysb ! I have a problem with this card since the last update :slightly_frowning_face:
Here’s how it looks on a smartphone :
Capture d’écran 2024-07-19 à 08.54.33
Thank you in advance ! And sorry for my bad english :slight_smile:
Like this:
type: custom:mushroom-climate-card
entity: climate.office_heating
collapsible_controls: false
show_temperature_control: true
layout: horizontal
layout_options:
  grid_columns: 4
  grid_rows: 1
icon: mdi:fire
card_mod:
  style: |
    ha-state-icon {
      {% if state_attr(config.entity, 'hvac_action') == 'heating'  %}
      {% endif %}
    ha-card {
      box-shadow: none;
    @keyframes fire {
or like this:
mode: horizontal
cards:
    entity: climate.lounge_heating
    secondary: |
        On -
      {% else %}
        Off
      {% endif %}
    tap_action:
      action: more-info
    icon: mdi:fire
    layout: horizontal
    icon_color: |
    primary: Hall
    card_mod:
      style: |
        ha-state-icon {
          {% endif %}
        ha-card {
          box-shadow: none;
        @keyframes fire {
  - type: custom:mushroom-climate-card
    layout: horizontal
    card_mod:
      style: |
        mushroom-state-item {
          display: none;
both give the same kinda effect:
Untitled video - Made with Clipchamp - 2024-07-19T122927.001
works fine for me:
Untitled video - Made with Clipchamp - 2024-07-19T123204.220
layout: horizontal
layout_options:
  grid_columns: 4
  grid_rows: 1
icon: mdi:fire
card_mod:
  style: |
    ha-state-icon {
      {{ 'animation: spin 1s linear infinite;' if not is_state('climate.bedroom_heating','off') }}
    @keyframes spin {
