Is there no way to add a name to the Chips? Home Assistant copied the Mushroom chips in the last few updates as Badges, and they added names, which seem to be missing from the Mushroom chips.
I also miss this function and opened an issue on Github a few weeks ago. But still no response from the developers. Itās unfortunately only possible for mushroom template chips card in the badge area.
hey
I want to achieve next:
I have created a timer in helper
instead of āONā and āOFFā I want to see a timer countdown
this is my mushrrom card:
type: custom:mushroom-template-card
primary: Parents heater
secondary: '{{ ''OFF'' if states(entity) == ''on'' else ''ON'' }}'
icon: mdi:patio-heater
entity: switch.heaterparentsbathroom
fill_container: false
layout_options:
grid_columns: 2
grid_rows: auto
icon_color: '#D8A25E'
multiline_secondary: true
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--shape-color: rgb(29, 52, 71) !important;
--icon-symbol-size: 45px;
--icon-size: 60px;
ha-card {
box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.66);
background: {% if states('switch.heaterParentsBathRoom') == 'on' %} #F7F9F2 {% endif %};
--card-primary-color: {% if states('switch.heaterParentsBathRoom') == 'on' %} black {% endif %};
--card-secondary-color: {% if states('switch.heaterParentsBathRoom') == 'on' %} black {% endif %};
I would suggest using
easier to customise and itās usable with mushroom
I have tried, no sucess
when i use it I break my view type āSectionsā
Is it possible to use emojis in place of an icon with CHIPS cards? Itās not working when I use the google noto or the emoji database
Can i add power wattage to display together with chip card icon?
I understand this is for sure to work with mushroom template card but maybe also with chip card?
type: custom:mushroom-chips-card
chips:
- type: template
card_mod:
style: |
ha-card:before {
font-size: 21px;
content: 'š©';
margin-left: 10px;
content: Testing
Need your help again. The Code worked Perfect. Also the high and so was awesome.
Sinne a few days, the whole Card mod will Not be shownā¦ there was no update, But Not everything is malā¦ do you have an idea?
Picture befor and After:
I have similar issues with my own dashboard that I am trying to work out whatās going on, I donāt believe Iāve done an update either. can you post your full code for that view and Iāll take a look for you
Good/Bad to hear that I am Not the only oneā¦
Sure:
kiosk_mode:
non_admin_settings:
hide_header: true
hide_sidebar: true
wallpanel:
enabled: true
hide_toolbar: false
idle_time: 1
image_url: /
cards:
- type: custom:clock-weather-card
entity: weather.openweathermap
sun_entity: sun.sun
temperature_sensor: sensor.temperature_30
weather_icon_type: line
forecast_rows: 5
locale: de
time_pattern: HH:mm
time_format: 24
date_pattern: cccc, d. MMM yyyy
hide_today_section: false
hide_forecast_section: true
hide_clock: false
hide_date: false
card_mod:
style: |
ha-card {
zoom: 400%;
font-size: 8px;
width: 250%;
margin-left: -115%;
margin-top: 70%;
background-color: transparent;
text-shadow: 1px 1px 3px black;
border: transparent;
primary: Pooltemperatur
secondary: '{{states("sensor.pooltemperatur")}} Ā°C'
icon: mdi:fan
icon_color: |
{% if is_state('climate.inverter_pool_warmepumpe','heat') %}
orange
{% else %}
grey
{% endif %}
card_mod:
style:
mushroom-state-info $: |
.container {
--card-primary-font-size: 25px !important;
--card-primary-color: black;
--card-primary-line-height: 28px;
--card-secondary-font-size: 25px;
--card-secondary-color: black;
--card-secondary-line-height: 28px;
flex-direction: row !important;
align-items: baseline !important;
gap: 30px;
{% set state = states('sensor.pooltemperatur') | int %}
{% if state <= 23 %}
--card-secondary-color: blue;
{% elif state <= 27 %}
--card-secondary-color: orange;
{% elif state <= 32 %}
--card-secondary-color: red;
{% else %}
{% endif %}
.shape {
--shape-color: transparent;
ha-card {
zoom: 120%;
font-size: 15px%;
margin-left: 160%;
margin-top: -170%;
width: 85%;
height: fit-content !important;
opacity: '';
ha-state-icon {
--icon-symbol-size: 31px;
{{ 'animation: spin 2s linear infinite;' if is_state('climate.inverter_pool_warmepumpe','heat') }}
primary: PV Anlage
secondary: >-
{{"\U000026A1"}}{{
"{0:_.0f}".format(states('sensor.ala001022111073_instantaneous_generation')
| int) | replace("_", ".") }}W {{"\U0001F50B"}} {{
states('sensor.ala001022111073_instantaneous_battery_soc') | float(0) |
round(0) }}%
icon: mdi:solar-power-variant-outline
entity: ''
picture: ''
fill_container: true
multiline_secondary: false
layout: horizontal
icon_color: green
card_mod:
style:
mushroom-state-info$: |
.container {
--card-primary-font-size: 23px;
--card-secondary-font-size: 40px;
--card-primary-line-height: 30px;
--card-secondary-line-height: 30px;
gap: 3px;
'--state-color: none !important;
--card-secondary-color: yellow;
{% elif state <= 30 %}
{% else %}
{% endif %} '
.shape {
--shape-color: none !important;
ha-card {
zoom: 120%;
font-size: 15px%;
margin-left: 160%;
margin-top: -160%;
width: 180%;
opacity: '';
ha-state-icon {
--icon-symbol-size: 25px;
Iāve had a look but unfortunately I canāt help to much as I donāt run kiosk/or a screen as big as yours.
as for the layout I would play around with the above margins until you get it back to the way you had it.
sorry I couldnāt fix it for you
EDIT:
I believe the problem lies with this itās not working as it should
itās no longer on the same line as before
This could also be, Yes, But as you See, the whole points in Card mod, Like Color, Font Are Not shown correctly anymoreā¦ this is What I do Not understand, because i did not change somethingā¦
What you mean with, Bit Longer on the Same line?
The Code is sent is the Same as befor.
Als Card Mod Are used and the result was Picture 1. Picture 2 is now
I meant in the first picture you have secondary next to primary on the same line. second picture the secondary is underneath.
I also noticed you have a duplicated
and
{% else %}
{% endif %}
Yes this is correct, But it worked with that Codeā¦ hm
Yes is also do Not know why it is now in the other lineš
I remember reading further up someone had a similar issue with
card_mod:
style:
.container {
not working.
one thing I noticed aswell if you remove
{% else %}
{% endif %}
a few issues resolve itself, I am only guessing here because like I said I canāt replicate your display size
Hm I checked it here but I can Not find the Post you talked aboutā¦
Every Change I do, nothing will be Changedā¦
You Are Right, once it is removed, it Looks better and needs Several changes.
But where I should add these points?
How can I use it, as Wanted?
What am i missing?
The animation is not working as intended.
layout: vertical
tap_action:
action: navigate
navigation_path: house
icon: mdi:home-assistant
icon_color: blue
primary: ""
secondary: Home
card_mod:
style: |
ha-state-icon {
animation: boing 3s ease infinite;
transform-origin: 50% 90%;
@keyframes boing {
0% { transform: scale3d(1, 1, 1); }
7% { transform: scale3d(1.25, 0.75, 1); }
10% { transform: scale3d(0.75, 1.25, 1); }
12% { transform: scale3d(1.15, 0.85, 1); }
16% { transform: scale3d(0.95, 1.05, 1); }
19% { transform: scale3d(1.05, 0.95, 1); }
25% { transform: scale3d(1, 1, 1); }
ha-card {
background: var(--card-background-color);
#width: 66px;
border-radius: 30px;
margin-left: auto;
margin-right: auto;
margin-bottom: 2px;
