Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
hi all
I am looking for an animated icon, which shows a burning candle when burning…and a normal candle when…not burning.
Somebody knows where to find this, or maybe someone who is willing to create this please?
type: custom:mushroom-template-card
primary: Kaarsen
secondary: ''
icon: mdi:candle
icon_color: >-
          {% if
          is_state('input_boolean.kaarsen',
          'on') %}
                    yellow
                {% else %}
                    grey
                {% endif %}
entity: input_boolean.kaarsen
layout: vertical
fill_container: true
tap_action:
  action: more-info
Many thanks!
My bad… .works fine
is there a way to show up the Person Picture in a badge?
this is not working
type: custom:mushroom-template-badge
picture: person.xxxx
Yes,
content: xxxxx
entity: person.xxxxx
picture: /local/images/Xxxxx.jpg
Would it be possible to add a icon before the title? “mdi:shower”
@dimitri.landerloos
#  Bathroom
type: custom:stack-in-card
cards:
  - type: custom:button-card
    entity: sensor.indoor_humidity
    icon: mdi:shower
    # show_icon: false
    styles:
      card:
        - border-style: none
        - box-shadow: 0px 0px 10px -9px black
      custom_fields:
        temp:
          - filter: opacity(100%)
          - justify-self: start
          - margin-left: 10px
          - margin-top: 20px
          - padding-bottom: 10%
          - font-size: 65%
        graph:
          - padding-top: 0%
          - width: 100%
          - height: 100%
          - margin-bottom: "-3%"
      icon:
        - width: 25px
        - color: auto
      name:
        - font-size: 87%
        - font-weight: var(--mcg-title-font-weight, 500)
        - margin-top: 6px
        - margin-left: 12px
        - opacity: 0.65
      grid:
        - grid-template-areas: '"n n" "temp temp" "graph graph"'
        - grid-template-columns: 1fr min-content
        - grid-template-rows: 1fr min-content min-content min-content
    custom_fields:
      temp: |
          return `<ha-icon
            icon="mdi:thermometer"
            style="width:18px; height: 18px; color:#ff8c00;">
            </ha-icon><span style="font-size:120%; font-weight: 300;">
            ${states['sensor.indoor_temperature'].state}°C </span>
            <ha-icon
            icon="mdi:water-percent"
            style="width: 18px; height: 18px; color: #3399ff;">
            </ha-icon><span style="font-size:120%; font-weight: 300; text-align: center;">
            ${states['sensor.indoor_humidity'].state}%</span>`
    card_mod:
      style: |
        ha-card {
          z-index: 1;
          height: 70px !important;
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.indoor_temperature
        color: "#ff8c00"
      - entity: sensor.indoor_humidity
        color: "#3399ff"
        y_axis: secondary
    height: 50
    hours_to_show: 24
    line_width: 3
    font_size: 50
    animate: true
    show:
      icon: false
      state: false
      legend: false
      fill: fade
    card_mod:
      style: |
        ha-card {
          position: absolute !important;
          height: 100%;
          width: 100%;
          top: 0px;
          --ha-card-border-width: 0;
        ha-card:after {
          content: "";
          position: absolute;
          width: 100%;
          height: 100%;
          background: linear-gradient(to right, var(--card-background-color) 20%, transparent);
  - type: custom:mushroom-chips-card
    chips:
      - type: light
        entity: light.0x00178801023e71ab
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none !important;
              background: none !important;
    alignment: end
    card_mod:
      style: |
        ha-card {
          height: 100%;
          width: 100%;
          top: 0px;
          z-index: 1;
you need the button card thread.
the icon is there but not within the card. if you change the height you can see it.
try adding “i” to the grid layout
grid:
you will get better help in the relevant forum thread
hi but it is possible to replicate this card exactly like and with mushroom or with something else without using minimalist ui:
https://ui-lovelace-minimalist.github.io/UI/usage/custom_cards/custom_card_nik_door/
Can someone assist me in enforcing height and width of a card?
“Livingroom” has not the same height.
          - type: custom:vertical-stack-in-card
            cards:
              - type: custom:swipe-card
                parameters:
                  spaceBetween: 8
                cards:
                    primary: Livingroom
                    secondary: "{{ states('sensor.0x001788010bcfb11d_temperature') }}°C"
                    icon: mdi:fireplace
                    tap_action:
                      action: navigate
                      navigation_path: livingroom
                  - type: glance
                    show_name: false
                    show_icon: true
                    show_state: false
                    state_color: true
                    theme: mushroom_room
                    entities:
                      - entity: sensor.0x001788010bcfb11d_temperature
                      - entity: media_player.living_room_r_2
                    card_mod:
                      style: |
                        ha-card {
                          height: 100% !important;
                          margin-top: -20px;
                          margin-bottom: -20px;
                          box-shadow: none;
                          background: rgba(0, 0, 0, 0);
                  - type: custom:mushroom-media-player-card
                    entity: media_player.home_display
                    use_media_artwork: true
                    use_media_info: true
                    collapsible_controls: true
                    show_volume_level: false
                    fill_container: false
                    tap_action:
                      action: call-service
                      service: media_player.media_play_pause
                      data: {}
                        entity_id: media_player.home_display
                    card_mod:
                      style: |
                        ha-card {
                          border-radius: 16px 16px 0px 0px;
                          {% if is_state(config.entity, 'playing') or is_state(config.entity, 'paused') %}
                            background: rgba(var(--rgb-card-background-color), 0.9) url( '{{ state_attr(config.entity, "entity_picture" ) }}' ) center no-repeat;
                            background-size: cover;
                            background-blend-mode: overlay;
                          {% else %}
                          {% endif %}
                card_mod:
                  style: |
                    ha-card {
                      height: 100%;
                      width: 100%;
                      top: 0px;
                      left: 3px;
did you try:
I have been having a problem with my cards for some time now. They don’t load correctly. After refreshing several times it will load correctly. Is anyone able to help?
Card code:
mode: vertical
cards:
    entity_id: light.natalia
    primary: Natalia
    secondary: '{{ state_attr(''climate.natalia'', ''current_temperature'') }} °C'
    picture: /local/img/natalia-avatar2.png
    layout: horizontal
    multiline_secondary: false
    badge_icon: >-
      {{ 'mdi:motion-sensor' if is_state('binary_sensor.natalka', 'on') else
      'mdi:motion-sensor-on' }}
    tap_action:
      service: light.toggle
      service_data: {}
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        ha-card {
         top: -12px;
         right: 15px;}
        mushroom-badge-icon {
          left: 135px;
          top: 10px;
          --icon-color: red;
          --main-color: none;
        :host {
          --mush-badge-font-size: 25px;
          --mush-badge-icon-size: 18px;
    card_mod:
      style: |
        ha-card {
           --chip-box-shadow: none;
           --chip-background: none;
           --chip-border-width: 0;
           --chip-height: 38px;
           --chip-spacing: 0;
          top: -28px;
    alignment: end
    chips:
      - type: template
        entity: light.natalia
        icon: mdi:lightbulb
        tap_action:
          service_data: {}
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='on' %}
          amber
          {% elif state=='off' %}
          #6f6f6f
          {% else %}
          #6f6f6f
          {% endif %}
      - type: template
        entity: light.lozko_natali
        icon: mdi:track-light
        tap_action:
          service_data: {}
            entity_id: light.lozko_natali
        icon_color: |-
          amber
          #6f6f6f
          {% else %}
          #6f6f6f
          {% endif %}
      - type: template
        entity: cover.natalia_2
        icon: >-
          {% if states('binary_sensor.natalia2_contact')=='on' %}
          mdi:door-open
          {% elif states('binary_sensor.natalia2_contact')=='off' and
          states('cover.natalia_2')=='closed' %}
          mdi:window-shutter
          {% else %}
              mdi:door
          {% endif %}
        tap_action:
          action: more-info
        icon_color: |-
          red
          {% elif states('binary_sensor.natalia2_contact')=='off' %}
          #6f6f6f
          {% else %}
          #6f6f6f
          {% endif %}
      - type: template
        icon: >-
          {% if states('binary_sensor.natalia1_contact')=='on' %}
          mdi:door-open
          {% elif states('binary_sensor.natalia1_contact')=='off' and
          states('cover.natalia')=='closed' %}
          mdi:window-shutter
          {% else %}
              mdi:door
          {% endif %}
        tap_action:
          action: more-info
        icon_color: |-
          red
          {% elif states('binary_sensor.natalia1_contact')=='off' %}
          #6f6f6f
          {% else %}
          #6f6f6f
          {% endif %}
card_mod:
  style: |
    :host {
        --mush-icon-size: 55px;
        top: -20px ;
    ha-card {
      height: 85px;
      box-shadow:
       {% if is_state('light.lampy_natalia', 'on') %}  0 0 0.3em #FFD700 {%
          else %}  {% endif %}
I am looking for the same!
Just an animated icon with a candle, would be awesome.
Hope someone is able to help you (and me :laughing:)
Start by changing
to this
card_mod:
  style: |
    ha-card {
        --icon-size: 55px;
        top: -20px ;
Hi im trying to make a new dashboard using mushrooms cards, but when i use this code
    card_mod:
      style: |
        ha-card {
         background: none;
         border: 2px outset #cc8418;
the text gets invisible when i cast it to my google home nest, is there a way to change the text color so i can see the text ?
i have tryed with this code
    card_mod:
      style:
        mushroom-state-info$: |
          .container {
            --card-primary-color: blue;
            --card-secondary-color: orange;
but i cant use these two codes together or im doing something wrong.
I have a silly issue. I’m using Ecobee thermostats, all of which have the ability to turn on just the fan on our HVAC units. The default Lovelace Climate card also allows this functionality. The Mushroom card, unfortunately, does not.
I think this is because our HVAC integration doesn’t have a ‘fan_only’ option under ‘hvac_modes’. Rather, it only has a separate ‘fan_modes’ entity that can be either ‘auto’ or ‘on’. Does anyone know if there is a way to make that work with the Mushroom climate card so that we can toggle the fans on and off separately when we want to circulate the air?
Is it possible use mushroom chip card what displays only entity value without icon. I can remove icon but this gray area remains where icon was.
2024-10-08 15_14_13-Dwains Dashboard – Home Assistant
How to integrate this into yaml THEME in order to be applied to each card. This is from the guide in the first post Mushroom Cards Card Mod Styling/Config Guide - #10 by dimitri.landerloos
   mushroom-shape-icon$: |
     .shape {
       background-color: transparent !important;
This construction:
    ha-card.type-custom-mushroom-light-card
        .shape {
doesn’t work
I modified some code earlier in the thread to add a 4th badge (bottom left) but I can’t seem to make that badge opaque. Can someone help me out?
primary: Test Icon
icon: mdi:dots-grid
icon_color: red
badge_icon: mdi:bug
badge_color: green
card_mod:
  style: |
    {% if is_state('light.test_light', 'on') %}
    mushroom-badge-icon:after {
        content: "humidity_indoor";
        font-size: 0.9em;
        font-family: 'Material Symbols Outlined';
        position: absolute;
        display: flex;
        justify-content: center;
        align-items: center;
        top: 26px;
        color: var(--icon-color);
        background: var(--main-color);
        width: var(--mush-badge-size, 16px);
        height: var(--mush-badge-size, 16px);
        border-radius: var(--mush-badge-border-radius, 50%);
    mushroom-badge-icon:before {
        content: "bug_report";
        font-size: 0.9em;
        font-family: 'Material Icons';
        position: absolute;
        display: flex;
        right: 26px;
    mushroom-shape-icon:before {
        font-size: 0.9em;
        position: absolute;
        display: flex;
        bottom: -3px;
        left: -3px;
        color: white;
        background-color: green !important;
    {% endif %}
