Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 2)
although youā€™ve deleted your post, if your after a radial dial with mushroom you could do it like this.
Screenshot_20241031_165639_Home Assistant
type: custom:mushroom-template-card
                primary: Memory
                icon: none
                layout: horizontal
                icon_color: pink
                entity: sensor.system_monitor_memory_usage
                badge_icon: mdi:memory
                badge_color: pink
                secondary: ""
                tap_action:
                  action: more-info
                card_mod:
                  style:
                    mushroom-shape-icon$: |
                      .shape {
                        background: radial-gradient(var(--card-background-color) 60%,
                                                    transparent calc(60% + 1px)),
                                    conic-gradient(var(--icon-color) {{ states(config.entity) }}% 0%,
                                                    var(--card-background-color) 0% 100%);
                      .shape:after {
                        content: '';
                        height: 100%;
                        width: 100%;
                        position: absolute;
                        border-radius: var(--icon-border-radius);
                        background: var(--shape-color);
                      ha-state-icon:after {
                        content: "{{ states(config.entity) | round(0)  }}%";
                        font-size: var(--card-primary-font-size);
                        position: absolute;
                        top: 19px;
                        left: 8px;
                      ha-card {
                        margin-left: 20px;
                        margin-top: 7px;
Change float to int. Should give you 5 instead of 5.00
Would like to have 5.00 as value. But mushroom card cuts the 0s at the end. Default value format for the entity is 5.00` (two decimal places). Default entity card is showing correct. Only mushroom card is cutting trailing zeros.
I currently updated my Home assistant from 2.6 ā†’ 2.10 and since then my Cards didnĀ“t work anymore.
Normally when I click the light bulb there is a detaile window with the single lights in it that opens. But now if I press it, it just opens sensor stats.
The Card:
The Code:
type: custom:vertical-stack-in-card
horizontal: true
card_mod:
  style: |
    ha-card {
      padding: 15px;
cards:
    primary: Schlafzimmer
    secondary: |-
      {{state_attr('climate.','current_temperature') }} Ā°C
      {{states('sensor.schlafzimmer_heizung_humidity') | round(0) }}%
    icon: mdi:bed-double-outline
    multiline_secondary: true
    badge_color: blue
    fill_container: true
    layout: horizontal
  - type: vertical-stack
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
            entity: sensor.total_active_lights_schlafzimmer
            icon: mdi:lightbulb
            card_mod:
              style: |
                ha-card {
                  {% if states('sensor.total_active_lights_schlafzimmer') < '0.0' %}
                    --card-mod-icon-color: grey;
                  {% elif states('sensor.total_active_lights_schlafzimmer') > '0.9' %}
                    --card-mod-icon-color: orange;
                  {% endif %}
          - type: entity
            entity: cover.schlafzimmer_jalousie
            content: sensor.schlafzimmer_jalousie_status
            icon: mdi:window-shutter
            card_mod:
              style: |
                ha-card {
                  {%- if is_state('sensor.schlafzimmer_jalousie_status','SchlieƟt') or is_state('sensor.schlafzimmer_jalousie_status','Ɩffnet') -%}
                    --card-mod-icon: mdi:window-shutter-open;
                  {% elif is_state('sensor.schlafzimmer_jalousie_status','Offen') -%}
                  {% elif is_state('sensor.schlafzimmer_jalousie_status','Geschlossen') -%}
                    --card-mod-icon: mdi:window-shutter;
                    --card-mod-icon-color: #012b6e;
                  {% elif states('sensor.schlafzimmer_jalousie_status').replace(' %','')|float > 1 -%}
                    --card-mod-icon-color: #b38b50;
                  {% endif %}
          - type: template
            entity: climate.schlafzimmer_heizung
            content: >-
              {{ state_attr('climate.schlafzimmer_heizung','target_temp_low') }}
              Ā°C
            icon: mdi:thermometer
            tap_action:
              action: more-info
            card_mod:
              style: |
                ha-card {
                  {%- if state_attr('climate.schlafzimmer_heizung','hvac_action') == 'idle' or (state_attr('climate.schlafzimmer_heizung','target_temp_low') < state_attr('climate.schlafzimmer_heizung','current_temperature')) -%}
                    --card-mod-icon: mdi:thermometer-off;
                    --card-mod-icon-color: #144380;
                  {% elif state_attr('climate.schlafzimmer_heizung','hvac_action') == 'heating' and (state_attr('climate.schlafzimmer_heizung','target_temp_low') > state_attr('climate.schlafzimmer_heizung','current_temperature')) -%}
                    --card-mod-icon: mdi:thermometer-chevron-up;
                    --card-mod-icon-color: #b30505;
                  {% endif %}
        card_mod:
          style: |
            ha-card {
              right:10%;
The Code:
type: custom:popup-card
entity: sensor.total_active_lights_wohnzimmer
title: Licht Wohnzimmer
dismissable: true
card:
  type: horizontal-stack
  cards:
      cards:
        - type: custom:mushroom-light-card
          icon: mdi:floor-lamp-dual
          use_light_color: true
          show_brightness_control: true
          show_color_temp_control: true
          show_color_control: true
          collapsible_controls: false
          hold_action:
            action: more-info
          double_tap_action:
            action: more-info
          entity: light.wohnzimmer_stehlampe_fenster
          hold_action:
            action: more-info
          double_tap_action:
            action: more-info
          entity: light.wohnzimmer_stehlampe_sofa
          icon: hue:play-bar-two
          hold_action:
            action: more-info
          double_tap_action:
            action: more-info
          entity: light.wohnzimmer_ambiente_licht
          icon: mdi:chandelier
          hold_action:
            action: more-info
          double_tap_action:
            action: more-info
          entity: light.wohnzimmer_esstisch_deckenlampe
          icon: mdi:lamp
          hold_action:
            action: more-info
          double_tap_action:
            action: more-info
          entity: light.wohnzimmer_marokkanische_lampen
I cant figure out why HA is not able to open the Detailed Window like it did beforeā€¦
Can anyone help?
Quick question regarding card-mod in themesā€¦
Iā€™m building a dashboard with Mushroom Cards and Iā€™d like to have 2 different fonts for the primary & secondary info. Right now I can achieve this by adding the following to each mushroom card manually:
  style:
    mushroom-state-info$: |
      span.primary {
        font-family: Inter-Bold;
      span.secondary {
        font-family: Inter-Light;
Iā€™d like to be able to apply this through a theme so it kicks in on all Mushroom cards. How can I achieve this?
Thanks in advance.
(sorry for the hacky photo)
Is anyone aware of a relatively simple way to accomplish this vertical layout for the mushroom light card? Iā€™d like to get a much bigger slider for easier interactions, and to move the control buttons up to next to the entity info.
This is what I get now if I use vertical layout:
Thank you!!!
Can anyone point me into the right direction, why those two rows are not overlapping for me please? I copied the exact code and just changed the entities.
cards:
  - card_mod:
      style: |
        ha-card {
          z-index: 1;
          height: 70px !important;
    custom_fields:
      temp: |
          return `<ha-icon
            icon="mdi:thermometer"
            style="width:18px; height: 18px; color:#ff33ff;">
            </ha-icon><span style="font-size:120%; font-weight: 300;">
            ${states['sensor.wohnzimmer_temperature'].state}Ā°C </span>
            <ha-icon
            icon="mdi:water-percent"
            style="width: 18px; height: 18px; color: #3399ff;">
            </ha-icon><span style="font-size:120%; font-weight: 300; text-align: center;">
            ${states['sensor.wohnzimmer_humidity'].state}%</span>`
    entity: sensor.wohnzimmer_humidity
    show_icon: false
    styles:
      card:
        - border-style: none
        - box-shadow: 0px 0px 10px -9px black
      custom_fields:
        graph:
          - padding-top: 0%
          - width: 100%
          - height: 100%
          - margin-bottom: "-3%"
        temp:
          - filter: opacity(100%)
          - justify-self: start
          - margin-left: 10px
          - margin-top: 20px
          - padding-bottom: 10%
          - font-size: 65%
      grid:
        - grid-template-areas: "\"n n\" \"temp temp\" \"graph graph\""
        - grid-template-columns: 1fr min-content
        - grid-template-rows: 1fr min-content min-content min-content
      icon:
        - width: 25px
        - color: auto
      name:
        - font-size: 87%
        - font-weight: var(--mcg-title-font-weight, 500)
        - margin-top: 6px
        - margin-left: 12px
        - opacity: 0.65
    type: custom:button-card
  - animate: true
    card_mod:
      style: |
        ha-card {
          position: absolute !important;
          height: 100%;
          width: 100%;
          top: 0px;
          --ha-card-border-width: 0;
        ha-card:after {
          content: "";
          position: absolute;
          width: 100%;
          height: 100%;
          background: linear-gradient(to right, var(--card-background-color) 20%, transparent);
    entities:
      - color: "#ff33ff"
        entity: sensor.wohnzimmer_temperature
      - color: "#3399ff"
        y_axis: secondary
    font_size: 50
    height: 50
    hours_to_show: 24
    line_width: 3
    show:
      fill: fade
      icon: false
      legend: false
      state: false
    type: custom:mini-graph-card
type: custom:stack-in-card
Thank you so much!
PS: The alphabetical sorting is done by my Home Assistant automatically.
I have fan card
type: custom:mushroom-fan-card
entity: fan.cabinet_pritok
show_percentage_control: true
icon_animation: true
show_oscillate_control: false
primary_info: last-changed
I want to write in the primary_info field both last-changed and name, please show me by example how to do it ?
That is the effect I want to achieve:
Somehow editing the previous gave me an 422 error no matter whatā€¦
I cant get it working. I want to show another Icon if the state is 50% and an other text.
type: custom:mushroom-cover-card
entity: cover.rollladen_office
show_position_control: true
show_buttons_control: true
layout: horizontal
card_mod:
  style: |
    ha-state-icon {
      --card-mod-icon: >
        {% if state_attr(entity, "current_position") == 50 %}
          mdi:weather-sunny-alert
        {% else %}
        {% endif %}
I can change the icon, but i am not able to change only in this specific position.
Anyone a simple hint what is wrong?
Thanks alot!
Solved it myself. The card-mod which enables CSS was not installedā€¦
I have the following but when I add it to a badge using the new sections it doesnā€™t keep itā€™s alignment correctly for the bell and the hamburger.
Top is inside a the badge, below is before using a normal card inside a section. Iā€™d like to maintain the layout of the bottom but inside a badge.
Code Snippet
cards:
    chips:
      - type: menu
      - type: template
        content: "{{ now().strftime(\"%H:%M %a, %-d %b\") }}"
        card_mod:
          style: |
            /* Style date & time */
            ha-card {
              --chip-box-shadow: none;
              --chip-background: none;
              --chip-border-width: 0;
      - type: template
        content: "{{ states('sensor.office_temperature') }} Ā°C"
        show_conditions: true
        show_temperature: true
        tap_action:
          action: navigate
          navigation_path: heating
        card_mod:
          style: |
            ha-card {
      - type: template
        entity: input_boolean.notifications
        icon: mdi:bell
        tap_action:
          action: toggle
        hold_action:
          action: none
    alignment: justify
  - type: conditional
    conditions:
      - entity: input_boolean.notifications
        state: "on"
    card:
      chips:
        - type: template
          entity: alarm_control_panel.house
          icon: mdi:shield-home
          icon_color: |-
            {% set alarm_status = states(entity) %}
            {% if alarm_status == 'armed_away' %}
              green
            {% elif alarm_status == 'disarmed' %}
              orange
            {% elif alarm_status == 'arming' %}
               yellow
            {% elif alarm_status == 'triggered' %}
               red
            {% endif %}
          tap_action:
            action: fire-dom-event
            browser_mod:
              service: browser_mod.popup
                title: Alarm
                content:
                  type: custom:mushroom-alarm-control-panel-card
                  states:
                    - armed_away
          hold_action:
            action: none
        - type: conditional
          conditions:
            - entity: light.all_lights
              state: "on"
          chip:
            type: template
            icon: mdi:lightbulb
            content: >
              {{ expand(states.light.all_lights) | selectattr('state', 'eq',
              'on') | list | count }}
            icon_color: amber
            tap_action:
              browser_mod:
                  title: Lights On
                  content:
                    type: custom:auto-entities
                    filter:
                      include:
                        - group: light.all_lights
                          state: "on"
                          options:
                            layout: horizontal
                            tap_action:
                              action: toggle
                        - entity_id: light.all_lights
                          state: "on"
                          options:
                            layout: horizontal
                            secondary_info: none
                            tap_action:
                              action: toggle
                            card_mod:
                              style: |
                                /* Style & position All Lights button */
                                ha-card {
                                  background: color-mix(in srgb, rgb(var(--rgb-state-light)) 10%, var(--card-background-color));
                                :host {
                                  margin: 0px 0px 12px !important;
                      exclude: []
                    card:
                      type: custom:layout-card
                      cards: []
                      layout_type: masonry
                    sort:
                      method: friendly_name
                  card_mod:
                    style: |
                      /* Position & style buttons */
                      .content {
                        margin: -24px -16px -24px -16px !important;
                        --ha-card-background: none;
                        --ha-card-box-shadow: 0;
                        --masonry-view-card-margin: -12px 0px 0px 0px;
        - type: conditional
          conditions:
            - entity: binary_sensor.all_doors
              state: "on"
          chip:
            type: template
            content: >
              {{ expand(states.binary_sensor.all_doors) | selectattr('state',
              'eq', 'on') | list | count }}
            icon_color: brown
            icon: mdi:door-open
            tap_action:
              browser_mod:
                  title: Doors Open
                  content:
                    filter:
                      include:
                        - group: binary_sensor.all_doors
                          state: "on"
                          options:
                            type: custom:mushroom-entity-card
                            layout: horizontal
                            secondary_info: last-changed
                            icon_color: brown
                            tap_action:
                              action: none
                            hold_action:
                              action: none
                      exclude: []
                    show_empty: false
                    card:
                      cards: []
                    sort:
                  card_mod:
                    style: |
                      .content {
        - type: conditional
          conditions:
            - entity: binary_sensor.all_windows
              state: "on"
          chip:
            type: template
            icon_color: grey
            icon: mdi:window-open
            content: >
              {{ expand(states.binary_sensor.all_windows) | selectattr('state',
            tap_action:
              browser_mod:
                  title: Windows Open
                  content:
                    filter:
                      include:
                        - group: binary_sensor.all_windows
                          state: "on"
                          options:
                            layout: horizontal
                            tap_action:
                              action: none
                            hold_action:
                              action: none
                      exclude: []
                    show_empty: false
                    card:
                      cards: []
                    sort:
                  card_mod:
                    style: |
                      .content {
        - type: conditional
          conditions:
            - entity: sensor.black_bin_days
              state_not: "2"
          chip:
            type: template
            icon_color: grey
            icon: mdi:trash-can
            tap_action:
              action: none
        - type: conditional
          conditions:
            - entity: sensor.brown_bin_days
              state_not: "2"
          chip:
            type: template
            icon_color: brown
            icon: mdi:trash-can
            tap_action:
              action: none
        - type: conditional
          conditions:
            - entity: sensor.blue_bin_days
              state_not: "2"
          chip:
            type: template
            icon_color: blue
            icon: mdi:trash-can
            tap_action:
              action: none
        - type: conditional
          conditions:
            - entity: sensor.devices_with_low_battery
              state_not: "0"
          chip:
            type: template
            content: |
              {{ states(config.entity) | int }}
            icon_color: red
            icon: mdi:battery-alert
            tap_action:
              browser_mod:
                  title: Low Batteries
                  content:
                    filter:
                      include:
                        - attributes:
                            device_class: battery
                          state: < 30
                          options:
                            primary: "{{ states(entity) }}%"
                            secondary: "{{ state_attr(entity, 'friendly_name') | title }}"
                            icon: >
                              {% set battery_level = (states(entity) | int / 10)
                              | round(0) | int * 10 %}
                              {% if battery_level == 100 %}
                                mdi:battery
                              {% elif battery_level > 0 %}
                                mdi:battery-{{ battery_level }}
                              {% else %}
                                mdi:battery-outline
                              {% endif %}
                            icon_color: |-
                              {% set battery_level = states(entity) | int %}
                              {% if battery_level > 90 %}
                                green
                              {% elif battery_level > 60 %}
                                light-green
                              {% elif battery_level > 50 %}
                                lime
                              {% elif battery_level > 40 %}
                                yellow
                              {% elif battery_level > 30 %}
                                amber
                              {% elif battery_level > 20 %}
                                orange
                              {% elif battery_level > 10 %}
                                deep-orange
                              {% else %}
                                red
                              {% endif %}
                            layout: horizontal
                            tap_action:
                              action: none
                            badge_icon: >-
                              {{ 'mdi:exclamation-thick' if states(entity) | int
                              < 10 }}
                            badge_color: red
                      exclude: null
                    show_empty: false
                    card:
                      cards: []
                    sort:
                  card_mod:
                    style: |
                      .content {
        - type: conditional
          conditions:
            - entity: group.smoke_alarm
              state: "on"
          chip:
            type: template
            icon_color: red
            icon: mdi:fire-alert
            tap_action:
              action: more-info
            card_mod:
              style: |
                .content {
                  animation: blink 1s linear infinite;
                @keyframes blink {
                  50% {opacity: 0;}
      alignment: end
      card_mod:
        style: |
          /* Set margins on notification chips */
          ha-card {
            margin: var(--chip-spacing) calc(-1 * var(--chip-spacing)) 0px;
            transition: all 0s;
card_mod:
  style: |
    /* Remove styling from top card with chips */
    ha-card {
      /* Allow pseudo elements to display outside card */
      overflow: visible !important;
      /* Remove gap at top of card */
      margin-top: calc(-1 * var(--mush-chip-spacing, 8px));
      /* Remove styling from card */
      box-shadow: none;
      border: none;
      background: none;
      padding: var(--mush-chip-spacing, 8px);
      transition: all 0s;
    /* Pseudo element to hide card styling when at top */
    ha-card:after {
      content: "";
      /* Make fixed so element scrolls up */
      position: fixed;
      top: var(--header-height);
      /* Adjust height when notifications visible */
      height: {{ '104px' if is_state('input_boolean.notifications', 'on') else '60px' }};
      /* Set width to match */
      width: calc(100% - var(--mush-chip-spacing, 8px));
      max-width: calc(var(--column-max-width) - 2 * var(--ha-card-border-width, 1px) - var(--mush-chip-spacing, 8px));
      /* Center element on page */
      left: 50%;
      transform: translateX(-50%);
      /* Position between chips and background pseudo elemnt */
      z-index: -1;
      /* Match background to main card */
      background: color-mix(in srgb, var(--card-background-color) 40%, var(--primary-background-color));
      border-radius: 0px 0px var(--ha-card-border-radius, 12px) var(--ha-card-border-radius, 12px);
    /* Pseudo element for background & other card styling */
    ha-card:before {
      content: "";
      /* Position & size card behind chips */
      position: absolute;
      top: 0px;
      left: 0px;
      height: 100%;
      /* Adjust width to account for border */
      width: calc(100% - 2 * var(--ha-card-border-width, 1px));
      /* Position card at back */
      z-index: -1;
      /* Blur content behind card */
      backdrop-filter: blur(12px);
      -webkit-backdrop-filter: blur(12px);
      /* Adjust opacity of card */
      background: rgba(var(--rgb-card-background-color), 0.8);
      /* Set styling of card */
      box-shadow: var(--ha-card-box-shadow);
      border: var(--ha-card-border-width, 1px) solid var(--ha-card-border-color, var(--divider-color, #e0e0e0));
need some help with an if else structure ā€¦
  1. if the player is in state 'paused" or "idle , I want the icon mdi:volume-variant-of and in grey
  2. if the player is playing i want the icon mdi:volume-high and the colour in {{ states(ā€œinput_text.kleur_iconenā€)}}
  3. if the player is playing and it is attribute ā€œspotify connectā€ I want the icon mdi:volume-variant-of and in grey
                  primary: >-
                    {{ states('input_text.' ~ user |lower ~
                    '_radiostations').split(',')[3] |default('') | title}}
                  icon: >
                    {% if is_state('media_player.ruimte1', 'paused') or is_state('media_player.ruimte1', 'idle') %}
                    mdi:volume-variant-off
                    {% elif state_attr('media_player.ruimte1', 'source') == 'Spotify Connect'%}
                    {% else %}
                    mdi:volume-high
                    {% endif %}
                  icon_color: >
                    grey
                    grey
                    {% else %}
                    {{ states("input_text.kleur_iconen")}}
                    {% endif %}
is this ok ?
    cards:
      - type: picture-entity
        camera_image: camera.deurbel_profile_name
        camera_view: live
        entity: camera.deurbel_profile_name
        show_state: false
      - type: horizontal-stack
        cards:
            primary: Afwijzen
            tap_action:
              browser_mod:
                service: browser_mod.close_popup
                  - browser_id: THIS
            card_mod:
              style:
                  .container {
                    margin: -10px;
                    text-align: center !important;
                  ha-card {
                      background-color: rgb({{ states("input_text.kleur_iconen")}}) !important;
                      width: 100px;
                      margin-left: 65px;
            primary: Deur Openen
            tap_action:
              action: call-service
              service: rest_command.example_request
            card_mod:
              style:
                  .container {
                    margin: -10px;
                  ha-card {
                      width: 100px;
                      margin-left: 65px;
                      align-items: center
how do I get the 2 buttons centered ?
@dimitri.landerloos
I am loving the work by @rhysb and appreciate your updated code for his animations.
I need some help with Mushroom Chip automation before I pull out what little hair I have left!
Is it possible to implement the Door Animation icon in a mushroom-chips-card with perspective, like it does in a mushroom-template-card?
Mushroom Door Animation
icon: mdi:door
icon_color: brown
primary: Door
card_mod:
  style:
      .shape {
        perspective: 45px;
      ha-state-icon {
        animation: open 6s ease-in-out infinite;
        transform-origin: 30%;
      @keyframes open {
        0%, 66% { transform: rotateY(0deg); }
        33% { transform: rotateY(-120deg); }
I can get it the chip animating ok but it remains flat with no perspective and I am unable to find any examples of this in a chip.
Is this possible or am I barking up the wrong tree?
This is the code I have.
cards:
    chips:
      - type: template
        icon: mdi:door
        icon_color: |-
          {% if is_state('binary_sensor.kitchen_door_contact','on') %}
            red
          {% elif is_state('binary_sensor.kitchen_door_contact','off') %}
            green
          {% else %}
            disabled
          {% endif %}
    alignment: center
    card_mod:
      style:
        mushroom-template-chip:nth-child(1)$: |
          ha-state-icon {
            {{ 'animation: open 6s ease-in-out infinite;' if is_state('binary_sensor.kitchen_door_contact', 'on') }}
          @keyframes open {
          .shape {
            perspective: 45px;
          ha-card {
            --chip-spacing: 0;
            padding-top: 5px;
Hoping someone can help with brining back my overlapping chips! I used to have a set of 4 chips which would overlap like below:
I havenā€™t updated my code but have updated a bunch of cards including card mod and mushroom, and now my chips donā€™t overlap.
Any ideas how I get the overlap back? Code below, screenshot only as for some reason I canā€™t copy from the visual editor :slight_smile: the missing code is 'var(--mush-chip-spacing, 18px));'
Still loving the mushroom cards! Using this dashboard for mobile, wife acceptance factor is great! Each room shows temp / humidty, when clicking on it, it opens the room with all the lights.
Couple questions:
  1. I am using horizontal stack for the door lock section + heating / airco. Unfortunately both the digital locks with open/closed donā€™t fit. The Temp and Airco symbols can easily be smaller. How to fix this? Iā€™m using horizontal layout and see code below. Any ideaā€™s? Maybe just have the door and garage icon with toggle close/open and shwo the right color? How to remove those other buttons?
cards:
  - type: custom:mushroom-lock-card
    entity: lock.bosch_bijkeuken_deur
    icon: mdi:door
    fill_container: false
    primary_info: none
    layout: horizontal
    entity: lock.garage
    icon: mdi:garage
    primary_info: none
    layout: horizontal
    primary: ""
    secondary: ""
    icon: mdi:home
    entity: climate.home
    layout: horizontal
    tap_action:
      action: navigate
      navigation_path: /dashboard-mushroom/verwarming
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        mushroom-shape-icon {
          {% if state_attr('climate.keuken', 'temperature') <= 13 and state_attr('climate.woonkamer', 'temperature') <= 13 and state_attr('climate.kamer_fleur', 'temperature') <= 13 and state_attr('climate.kamer_sanne', 'temperature') <= 13 and state_attr('climate.hoofdslaapk', 'temperature') <= 13 and state_attr('climate.zolder', 'temperature') <= 13 and state_attr('climate.speelkamer', 'temperature') <= 13 and state_attr('climate.werkkamer', 'temperature') <= 13 and state_attr('climate.sportkamer', 'temperature') <= 13 and state_attr('climate.washok', 'temperature') <= 13 %}
            --card-mod-icon: mdi:leaf;
            --card-mod-icon-color: rgba(var(--rgb-green), 1);
            --shape-color: rgba(var(--rgb-green), 0.2) !important;
          {% else %}
            --card-mod-icon: mdi:fire;
            --card-mod-icon-color: rgba(var(--rgb-deep-orange), 1);
            --shape-color: rgba(var(--rgb-deep-orange), 0.2) !important;
          {% endif %}
    primary: ""
    secondary: ""
    icon: mdi:home
    layout: horizontal
    tap_action:
      action: navigate
      navigation_path: /dashboard-mushroom/airco
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
            --card-mod-icon: mdi:air-conditioner;
          {% else %}
          {% endif %}
  1. Iā€™m using horizontal stack with chips. The entity ā€œfanā€ only toggles on/off. I want this to toggle between fan mode 1 and fan mode 3. Is this possible? This is a fan system for the entire house and it should never be allowed to be fully turned off, only switch between mode 1 and mode 3. Is this possible?
  2. We have common routines in house, for example set temp in the living room to 20C and turn on the lights. Another example is ā†’ a work from home day, set the temp in the office room etc. How do others add this to the mushroom dashboard? Can you link to a automation with a chip icon?
Have you seen any update for this in card_mod? I have the same issue I am trying to fix :slight_smile:
Would appreciate a ā€œyes it can be doneā€ or no it cant do it answer before I troll thru 1278 posts.
Is it possible to get a number card to display in VERTICAL (up and down) orientation with the value on the inside of the slider??? (card-mod)
Ive searched and oddly I cant find anything on this.
Alternately can anyone suggest another card???
