exen904
(Daniel)
October 19, 2024, 5:34pm
1274
Im quite new to templating and dont quite get how I need to set this up, help much appreciated I want to create a plant status card with the mushroom template and change the icon color, depending on the moisture percentage of the sensor.
The value is stated in a attribute of the plant entity, which seems to kind of be my issue.
I currently started with this, taken from another card that successfully changes color depending on the value of the corresponding entity.
type: custom:mushroom-template-card
primary: Monsterra
secondary: "{{state_attr('plant.monsterra', 'moisture')}}%"
icon: mdi:flower
icon_color: |-
{% set moisture="{{state_attr('plant.monsterra', 'moisture')}}%"
{% if moisture|int()<= 20 %}
red
{% elif moisture|int()>20 and moisture|int() <=65 %}
green
{% elif moisture|int()>65 and moisture|int() <=999 %}
blue
{% else %}
red
{%endif %}
entity: plant.monsterra
the value is displayed as secondary information, but I dont get the icon color to work. I guess the syntax there is not correct for defining the moisture variable?
MrGrey
October 20, 2024, 4:56am
1275
At a glance, youโre quotes seem wrong. Have you tested/tried this in Developer Tools โ Templates?
MrGrey.
Should be:
{% set moisture = state_attr('plant.monsterra', 'moisture') %}
You donโt need the curly bracket pairs inside the set variable expression.
And as you have set plant.monsterra
as the entity for the card, you can replace all references to it with entity
{% set moisture = state_attr(entity, 'moisture') %}
I cant get it working. I want to show another Icon if the state is 50% and an other text.
type: custom:mushroom-cover-card
entity: cover.rollladen_office
show_position_control: true
show_buttons_control: true
layout: horizontal
card_mod:
style: |
ha-state-icon {
--card-mod-icon: >
{% if state_attr(entity, "current_position") == 50 %}
mdi:weather-sunny-alert
{% else %}
{% endif %}
I can change the icon, but i am not able to change only in this specific position.
Anyone a simple hint what is wrong?
Thanks alot!
Vandana
(Vandana Dass)
October 20, 2024, 1:46pm
1278
Hello guys,
Plz help me out here.
How to add buttons at circled area?
type: custom:mushroom-select-card
entity: input_select.playlists
fill_container: false
exen904
(Daniel)
October 20, 2024, 1:58pm
1279
Thank you so much, that works perfectly. The ammount of brackets also really set me off a bit, but I didnt get the hang of it last night.
Your reference for the entity attribute also solved a second question I was asking myself, thanks a lot for that
fela93
(Fela93)
October 22, 2024, 11:04am
1280
I have in cover card edit each button
for example
mushroom-button:nth-child(1)$: |
.button ::slotted(*) {
--card-mod-icon: mdi:arrow-up-bold;
.button {
border: 0.1px outset gray !important;
box-shadow: 4px 4px 4px 0px rgba(0,0,0,0.66);
how can I add to this button for example
ha-card:active {
transform: scale(0.875);
transition: 0s;
majdzik84
(Majdzik84)
October 25, 2024, 4:38pm
1282
Hi. I changed the custom component from vertical-stack-in-card to stack-in-card and it displays correctly. Try it
FireDragon
(Nguyen Dac Manh)
October 26, 2024, 4:09pm
1283
Hi @Vandana Thatโs all I can do
type: custom:stack-in-card
mode: horizontal
cards:
- type: custom:stack-in-card
card_mod:
style: |
ha-card {
border: none !important;
--ha-card-border-width: 0;
box-shadow: none !important;
cards:
- type: custom:mushroom-select-card
entity: input_select.media_player
- square: false
columns: 3
type: grid
cards:
- type: custom:mushroom-entity-card
entity: [entity_XXX]
primary_info: none
secondary_info: none
layout: horizontal
icon: mdi:repeat-variant
icon_color: orange
card_mod:
style: |
ha-card {
box-shadow: none;
border: none;
primary_info: none
layout: horizontal
icon: mdi:music-note-off
icon_color: red
card_mod:
style: |
ha-card {
box-shadow: none;
border: none;
primary_info: none
layout: horizontal
icon: mdi:play-pause
icon_color: green
card_mod:
style: |
ha-card {
box-shadow: none;
border: none;
Vandana
(Vandana Dass)
October 26, 2024, 4:30pm
1284
Thank you so so much.
How to extend the dropdown to have the full width?
Tried to find a tip to my question in this very long thread. Maybe solution would be very easy.
I show different numbers without units in mushroom template and entity cards. But for all numbers trailing zeros are cut off. 5.00
will be shown as 5
The only way I found is to add a char (e.g. a dot) after number.
Code snippet:
{{ '%.2f' | format(states('sensor.ebusd_cop_current') | float) }}
This will cut off any trailing zeros.
Seems mushroom card do same magic on numbers and removes trailing zeros when no other text follows.
Vandana
(Vandana Dass)
October 27, 2024, 4:19am
1286
mode: horizontal
cards:
- type: horizontal-stack
cards:
entity: switch.geyser
icon: mdi:water-boiler
layout: vertical
icon_color: "{{ 'green' if is_state(entity, 'on') else 'pink' }}"
primary_info: none
tap_action:
action: toggle
layout: vertical
primary_info: none
tap_action:
action: toggle
layout: vertical
primary_info: none
tap_action:
action: toggle
layout: vertical
primary_info: none
tap_action:
action: toggle
layout: vertical
primary_info: none
tap_action:
action: toggle
layout: vertical
primary_info: none
tap_action:
action: toggle
layout: vertical
primary_info: none
tap_action:
action: toggle
Hello Guys,
How do I remove the spaces between each mushroom-template-card?
Kindly guide
Why are you using a core horizontal-stack
card within a custom stack-in-card
in horizontal mode? Itโs completely redundant.
See if removing it helps. If not, you might have to set the gap variable through card-mod.
Vandana
(Vandana Dass)
October 27, 2024, 8:02am
1288
Thank you so muchโฆ fixedโฆ
FireDragon
(Nguyen Dac Manh)
October 27, 2024, 1:08pm
1289
@Vandana Change options according to personal needs.
cards:
entity: input_select.chon_loa
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: [entity_id]
icon_color: green
content_info: none
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-background: rgba(var({{ '--rgb-green' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
--icon-color: rgb(var(--rgb-disabled));
- type: entity
entity: [entity_id]
icon_color: orange
content_info: none
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-background: rgba(var({{ '--rgb-orange' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
- type: entity
entity: [entity_id]
icon_color: purple
content_info: none
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-background: rgba(var({{ '--rgb-purple' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
- type: entity
entity: [entity_id]
icon_color: red
content_info: none
tap_action:
action: toggle
card_mod:
style: |
ha-card {
--chip-background: rgba(var({{ '--rgb-red' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
card_mod:
style: |
ha-card {
--chip-box-shadow: none;
top: 16px;
width: -webkit-fill-available;
right: 12px;
position: absolute;
.chip-container {
right: 0px;
position: absolute;
type: custom:layout-card
layout_type: custom:vertical-layout
layout: {}
cards:
card_mod:
style: |
ha-card {
background: rgba(28,28,28,0.6)
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 90% 10%
cards:
card_mod:
style: |
ha-card {
box-shadow: none;
background: none;
- type: vertical-stack
cards:
chips:
- type: action
icon_color: blue
tap_action:
action: call-service
service: light.turn_on
color_temp: 154
entity_id: [light_id]
icon: mdi:lightbulb
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-blue), 0.2);
chips:
- type: action
icon_color: amber
icon: mdi:lightbulb
tap_action:
color_temp: 267
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-amber), 0.2);
chips:
- type: action
icon_color: orange
icon: mdi:lightbulb
tap_action:
color_temp: 500
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-orange), 0.2);
Vandana
(Vandana Dass)
October 27, 2024, 1:18pm
1290
Exactly what i was looking forโฆ
Thank you so so so so muchโฆ
Is it possible to change the secondary info to the fan card to show High, Medium, Low, or Off instead of the percentage?
Iโve used this on other cards.
if (entity.attributes.percentage == 100) return "High";
if (entity.attributes.percentage == 74) return "Medium";
if (entity.attributes.percentage == 25) return "Low";
if (entity.attributes.percentage == 0) return "Off";
return "Unknown";
Faecon
(Jo)
October 29, 2024, 4:08pm
1292
is it possible to template โprimaryโ ?
Like this ?
cards:
{% if state_attr('media_player.wachtzaal', 'source') == 'Spotify Connect' %}
primary: Spotify-Lijst ({{ state_attr("media_player.wachtzaal", 'media_artist') }} - {{ state_attr("media_player.wachtzaal", 'media_title') }})
{% else %}
primary: Muziek
{% endif %}
cards:
primary: |-
{% else %}
Muziek
{% endif %}
