Probably, but not apparent with the example code you posted.
Bookmarked
Another stupid question: whats the difference between
--icon-symbol-size: and --icon-size: ?
--icon-symbol-size: the actual icon
--icon-size: the background size of the icon
Ahhhh, makes perfectly sense, thank you!
Iām going to experiment a bit when I come home from work and post the results (at least if they are good
PS: I changed my variables and it still works, so no predefinitions used ![]()
Tried both ways, second one is advised by chatgpt
- type: custom:mushroom-chips-card
chips:
- type: template
entity: sensor.kotela6_pmeter_power
content: "{{ states('sensor.boiler_temp') | float | round(1) }} °C"
icon: mdi:thermometer
tap_action:
action: more-info
chips:
- type: template
tap_action:
action: more-info
at first glance Iād say the first version should work⦠but is states(āsensor.boiler_tempā) the right entity?
and is there a reason why you use the template-chips-card?
chips:
- type: template
entity: sensor.sensor_bad_temperatur
content: "{{ states('sensor.sensor_bad_temperatur') | float | round(1) }} °C"
tap_action:
action: more-info
- type: entity
both cards result in the same chip in my environmentā¦
Hi all, I am asking for help!
The new mushroom card has done some weird things with my animations; some stopped working others lost the icon circle.
Here are some examples and I hope someone can point me in the the right direction.
This one the animation stopped working:
type: custom:mushroom-template-card
primary: Circulation Pump
icon: mdi:pump
secondary: >
{{ states('switch.circulation_pump') | title }} - {{
states('sensor.circulation_pump_power') }} W - {{
states('sensor.circulation_pump_temperature') }}°C
tap_action:
action: more-info
grid_options:
columns: 6
rows: 1
entity: switch.circulation_pump
color: |
{% if is_state('switch.circulation_pump', 'on') %}
green
{% else %}
grey
{% endif %}
features_position: bottom
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--icon-symbol-size: 30px;
--shape-color: none;
background: none;
border-radius: 50%;
animation: {{ 'spin 2s linear infinite' if is_state(config.entity, 'on') else 'none' }} !important;
stroke: white;
stroke-width: .3px;
.shape:before {
content: "";
background: {{ 'lightgrey' if is_state(config.entity, 'on') else 'red' }};
position: absolute;
height: 24px;
width: 24px;
border-radius: 50%;
@keyframes spin {
0% { transform: rotate(0deg); }
100% { transform: rotate(360deg); }
And this one is a moving but the circle background has disappeared.
primary: Solar Panels
secondary: >
{{ states('sensor.solarnet_power_photovoltaics') | float | round(2) }} Solar
kWh -
{{ states('sensor.solarnet_energy_day') | float | round(2) }} kWh
icon: |-
{% if is_state('sensor.solarnet_power_photovoltaics', 'unavailable') %}
mdi:lightning-bolt
{% elif states('sensor.solarnet_power_photovoltaics') | float >= 0.1 %}
mdi:solar-power-variant
{% else %}
mdi:lightning-bolt
{% endif %}
tap_action:
action: navigate
navigation_path: /panel-backend/solar_panel
entity: sensor.solarnet_power_photovoltaics
multiline_secondary: false
grid_options:
columns: 6
rows: 1
color: >-
{% set pv = states('sensor.solarnet_power_photovoltaics') | float %} {% if pv
>= 0.1 and pv < 2 %}
deep-orange
{% elif pv >= 2 and pv <= 4 %}
orange
{% elif pv > 4 and pv < 15 %}
amber
{% else %}
red
{% endif %}
card_mod:
style: >-
{% set real_power = states('sensor.smart_meter_ts_65a_3_real_power') | float
%} {% set solar = states('sensor.solarnet_power_photovoltaics') | float %}
{% if real_power <= 0 and solar > 0 %}
{% if solar > 6 %}
ha-state-icon { animation: rays 0.5s infinite; }
{% elif solar > 4 %}
ha-state-icon { animation: rays 1s infinite; }
{% elif solar > 2 %}
ha-state-icon { animation: rays 1.5s infinite; }
{% else %}
ha-state-icon { animation: rays 2s infinite; }
{% endif %}
@keyframes rays {
0%, 100% { clip-path: inset(0 0 0 0); }
80% {
clip-path: polygon(
100% 99%, 0% 99%, 11% 50%, 57% 48%, 56% 31%, 41% 31%,
33% 25%, 29% 18%, 27% 11%, 27% 6%, 74% 6%, 73% 15%,
69% 23%, 62% 29%, 71% 42%, 87% 47%
{% elif real_power > 0 and solar <= 0 %}
ha-state-icon {
animation: charge 1s linear infinite;
@keyframes charge {
0%, 10%, 20%, 30%, 40%, 50%, 60%, 70%, 80%, 90%, 100% { transform: translate(0, 0); }
5% { transform: translate(0.6px, -0.9px); }
15% { transform: translate(-0.7px, 0.8px); }
25% { transform: translate(0.4px, -0.5px); }
35% { transform: translate(-0.6px, 0.4px); }
45% { transform: translate(0.5px, -0.7px); }
55% { transform: translate(-0.3px, 0.6px); }
65% { transform: translate(0.7px, -0.4px); }
75% { transform: translate(-0.5px, 0.3px); }
85% { transform: translate(0.4px, -0.6px); }
95% { transform: translate(-0.6px, 0.5px); }
{% else %}
ha-state-icon {
animation: none !important;
clip-path: none !important;
transform: none !important;
{% endif %}
I have this case with several buttons.
Try replacing custom:mushroom-template-card with custom:mushroom-legacy-template-card.
The mushroom-template-card has been renewed an changed in several ways. The mushroom-legacy-version should be the old variant (according to the creator(s?)).
Let me know if it works, otherwise we need further investigation ![]()
Yeah that works for some, but i still want to know how to get it to work with the new version!
Even when using custom:mushroom-legacy-template-card some of the colours arenāt working:
type: custom:mushroom-legacy-template-card
icon: mdi:pump
secondary: >
tap_action:
action: more-info
grid_options:
columns: 6
rows: 1
color: |
green
{% else %}
grey
{% endif %}
card_mod:
style:
.shape {
background: none;
border-radius: 50%;
stroke: white;
stroke-width: .3px;
.shape:before {
content: "";
position: absolute;
height: 24px;
width: 24px;
border-radius: 50%;
@keyframes spin {
Its on and spinning and should be green but I get grey.
An example you can work with
entity: light.xxxxx
primary: Example
icon: mdi:mushroom
tap_action:
action: more-info
color: >
{{"#%02x%02x%02x" % (state_attr(config.entity, 'rgb_color') or (128, 128,
128)) }}
icon_tap_action:
action: toggle
card_mod:
style:
ha-tile-icon$: |
.container {
width: 70px !important;
height: 70px !important;
border-radius: 50% !important;
--mdc-icon-size: 45px !important;
ha-state-icon {
animation: jump 2400ms ease-in-out infinite;
transform-origin: 50% 110%;
@keyframes jump {
0%, 100% {transform: translate(0, 0) rotate(0) scaleY(1) scaleX(1); }
12% {transform: translate(0, 0) rotate(0) scaleY(0.85) scaleX(1.1); }
24% {transform: translate(0, -4px) rotate(-2deg) scaleY(1) scaleX(1);}
30% {transform: translate(-0.1px, -4px) rotate(2deg);}
45% {transform: translate(0, 0) rotate(0); }
50% {transform: translate(0, 0) rotate(0) scaleY(0.95) scaleX(1.07); }
60% {transform: translate(0, -2px) rotate(0) scaleY(1.05) scaleX(0.95);}
70% {transform: translate(0, 0) rotate(0) scaleY(1) scaleX(1);}
80% {transform: translate(-0.2px, -0.2px) rotate(-1deg);}
90% {transform: translate(0.2px, 0.2px) rotate(1deg);}
Other examples here
You need to define the entity here
config.entity will not work.
needs to be
animation: {{ 'spin 2s linear infinite' if is_state('switch.circulation_pump', 'on') else 'none' }} !important;
New format example
icon: mdi:pump
secondary: >
{{ states(entity) | title }} - {{
tap_action:
action: more-info
grid_options:
columns: 6
rows: 1
color: |
{% if is_state(entity, 'on') %}
green
{% else %}
grey
{% endif %}
card_mod:
style:
ha-tile-icon$: |
.container {
background: none;
border-radius: 50%;
stroke: white;
stroke-width: .3px;
.container:before {
content: "";
background: {{ 'lightgrey' if is_state('switch.circulation_pump', 'on') else 'red' }} !important;
position: absolute;
height: 24px;
width: 24px;
border-radius: 50%;
@keyframes spin {
Thanks @LiQuid_cOOled it worked for one but not this one:
primary: Compressor
secondary: |-
{% set d = {'off':'Off','on':'On'} %}
{{ d.get(states(entity)) }}
icon: mdi:pump
tap_action:
action: more-info
entity: binary_sensor.s1255_compressor_status
color: |-
green
{% else %}
grey
{% endif %}
card_mod:
style:
.shape {
background: ;
border-radius: 50%;
animation: {{ 'spin 2s linear infinite' if is_state(binary_sensor.s1255_compressor_status, 'on') else 'none' }} !important;
stroke: white;
stroke-width: .3px;
.shape:before {
content: "";
background:{{ 'lightgrey' if is_state(binary_sensor.s1255_compressor_status, 'on') else 'red' }};
position: absolute;
height: 24px;
width: 24px;
border-radius: 50%;
@keyframes spin {
What am I missing?
Quotes on the entity name. Use this
format on both background: and:
animation: {{ 'spin 2s linear infinite' if is_state('binary_sensor.s1255_compressor_status', 'on') else 'none' }} !important;
Ok i did that. Colour is right but not animating now:
card_mod:
style:
.shape {
background: ;
border-radius: 50%;
stroke: white;
stroke-width: .3px;
.shape:before {
content: "";
background:{{ 'lightgrey' if is_state('binary_sensor.s1255_compressor_status', 'on') else 'red' }};
position: absolute;
height: 24px;
width: 24px;
border-radius: 50%;
@keyframes spin {
This doesnāt work?
icon: mdi:pump
secondary: >
{{ states(entity) | title }} - {{ states('sensor.circulation_pump_power') }} W
- {{ states('sensor.circulation_pump_temperature') }}°C
tap_action:
action: more-info
grid_options:
columns: 6
rows: 1
icon_color: |
green
{% else %}
grey
{% endif %}
card_mod:
style:
.shape {
background: ;
border-radius: 50%;
stroke: white;
stroke-width: .3px;
.shape:before {
content: "";
position: absolute;
height: 24px;
width: 24px;
border-radius: 50%;
@keyframes spin {
I think you are mixing Legacy fields with the updated fields.
Probably! This is extremely frustrating! I think they need to introduce animated icons as standardā¦
Spin and Blink are included
icon: mdi:pump
secondary: >
tap_action:
action: toggle
grid_options:
columns: 6
rows: 1
icon_color: |
green
{% else %}
grey
{% endif %}
card_mod:
style:
.shape {
background: ;
border-radius: 50%;
stroke: white;
stroke-width: .3px;
.shape:before {
content: "";
position: absolute;
height: 24px;
width: 24px;
border-radius: 50%;
Keyframes are removed in this exampleā¦
I apologize if I am not being clear with what is needed.
@LiQuid_cOOled I got it! but i also noticed an interesting behaviour with the new card. If you put nothing in the icon setting under interactions then the icon āhaloā disappears!!
