Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 2)
And to transform this from legacy to normal card ?
        card_mod:
          style:
            ha-tile-info$: |
              .secondary {
                color: {% if is_state('script.sifao_1_hora','off') %}
                         green !important
                       {% else %}
                         red !important
                       {% endif %};
            mushroom-shape-icon:
                {% if is_state('script.sifao_1_hora','on') %}
                  ha-state-icon {
                    animation: spin 1s linear infinite;
                {% else %}
                {% endif %}
The ha-tile-info$, work OK, but the icon don’t spin
Have you taken the time to review recent examples in this thread? I have posted quite a few examples in this thread and here
Thanks for the help. I checked and managed to make most of them.
Now I can’t get the effect on this one at all.
Please post your code using the forum standards vs images
:one::one: Format it properly
When sharing the code, share it as text and not an image. When you do that, remember that spacing is critical in YAML, and if you just throw the code on the page then it’ll look ugly and nobody will know if the problem is because of spacing. We need you to use code blocks and appropriate markup.
sorry. you’re right
  type: custom:mushroom-legacy-template-card
  icon: mdi:home
  entity: switch.int_quarto_2_l1
  primary: Gradient
  icon_color: blue
  secondary: secondary
  tap_action:
    action: more-info
  card_mod:
    style:
      mushroom-shape-icon$: |
        .shape {
         --shape-color: none;
        .shape:after {
         content: '';
         position: absolute;
         width: inherit;
         height: inherit;
         background: radial-gradient(farthest-side, rgb(var(--rgb-blue)) 94%, transparent) top/4px 4px no-repeat, conic-gradient(transparent 30%, rgb(var(--rgb-blue)));
         -webkit-mask: radial-gradient(farthest-side, transparent calc(100% - 4px), #000 0);
         --shape-animation: spin 1s infinite linear;
         border-radius:50%;
         animation: spin 2s ease infinite;
This should work to help you move away from the legacy template card
type: custom:mushroom-template-card
icon: mdi:home
primary: Gradient
tap_action:
  action: more-info
color: blue
features_position: bottom
card_mod:
  style:
    ha-tile-icon$: |
      .container:before {
        display: none;
      .container:after {
        content: "";
        position: absolute;
        inset: 0;
        background: radial-gradient(farthest-side, var(--blue-color, #0000FF) 94%, transparent) top/4px 4px no-repeat,
                    conic-gradient(transparent 30%, var(--blue-color, #0000FF));
        will-change: transform;
      @keyframes spin {
        0% { transform: rotate(0deg); }
        100% { transform: rotate(360deg); }
example
Only a short question to doublecheck. I can use then same card mods for Tile Cards and the new mushroom cards.
Effects are the same?
Am i right?
For the most part yes!
type: tile
entity: light.night_stand
card_mod:
  style:
    ha-tile-icon$: |
      .container:before {
        display: none;
      .container:after {
        content: "";
        position: absolute;
        inset: 0;
      @keyframes spin {
The changes to the Mushroom Template card were intended to align with the Tile card elements.
for the most? What would not work, to get an idea
For example, Tile Cards with cover and climate entities have significant CSS structural differences vs Mushroom cards with the same entities.
What are you trying to achieve? Your question is very broad.
Thanks or your feedback, was more in general as i need to rebuild some stuff and don’t want to use old style by copy/ paste. Thx
If you run into any roadblocks with either Tile or Mushroom cards, just reach out!
[quote=“LiQuid_cOOled, post:1891, topic:693055”]
Thank you very much.
hello can someone help me out of lagacy card? Much thanks. animations don’t work. attach picture before and after update
icon: mdi:delete
primary: Směs
secondary: |2-
    {% set dny = state_attr('sensor.cerna_popelnice','dny')|float |round()%}
    {% if dny == 0 %}
      dnes
    {% elif dny == 1 %}
      zĂ­tra
    {% elif dny > 5 %}
      za {{dny}} dnĂ­
    {% elif dny <= 5 and dny > 1 %}
      za {{dny}} dny
    {% endif %}
color: grey
card_mod:
  style:
      {% if state_attr('sensor.cerna_popelnice','dny') |float == 0 %}
      .shape {
      --shape-animation: ping 3.0s infinite ;
      card_mod:
      {% else %}
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-red)) {{  (state_attr('sensor.cerna_popelnice','dny')|int / 14 ) *100 }}% 0%, var(--card-background-color) 0% 100%);
      .shape:after {
        content: "";
        height: 100%;
        width: 100%;
        position: absolute;
        border-radius: 50%;
        background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
      {% endif %}
      @keyframes ping {
      0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 1); }
      100% { box-shadow: 0 0 5px 15px transparent; }
      @keyframes blink {
      100% {opacity: 0;}
      ha-card  {
      #border: none !important;
      #background: transparent;
new
Cleanup your code (2x card_mod:?), make sure you have the right indentation and it’ll work.
Hello, sorry but all is copy paste from internet. So I don’t know what are you talking about. What two cards mod?
Two card mods underlined
I’d check out the forum guidelines
:nine: Show your workings
If you turn up with a post that suggests you’ve put in no effort, you’re less likely to get quality help, and your post may even be ignored. Explain a bit of what you’ve done so far, such as:
  • Link to some other threads that you’ve found, and tried, and explain why they didn’t help you
  • Describe what you’ve tried, and what the problems were
Showing that you’ve put effort in will help demonstrate that you’re not simply looking for others to do all the work for you.
Has anyones card-mod changes stopped working since the upgrade to 2025.11.0?
There is a known issue with entities rows with 2025.11. For that 3.4.6 had been released.
Are you using animations? Then you have to explicitly declare keyframes:
    ha-tile-badge$: |
      .badge {
        height: 16px !important;
        width: 16px !important;
        left: -12px !important;
        top: 0px !important;
        position: absolute;
        border-radius: 10% !important;
        animation: flash 2s infinite;
        animation-play-state: var(--badge-flash-state, paused) !important;
        pointer-events: none;
      @keyframes flash {
        0%, 100% { opacity: 1; }
        50%      { opacity: 0; }
Here is my dashboard with cardmod:
ezgif-52a3227d967b2d26
