U can set size of chip with this code and your adjustments:
style: |
ha-card {
justify-content: center;
--chip-icon-size: 64px;
--chip-height: 64px;
width: var(--chip-height) !important;
border-radius: 50% !important;
--chip-background: rgba(var(--rgb-green), 0.2);
And look at this my post Mushroom Cards - Build a beautiful dashboard easily š - #10113 by SoulAssassin , today @LiQuid_cOOled gived a best tip for my case, as I understood, u have similiar issue.
tombom
(tom)
February 12, 2024, 3:42pm
10148
thank you very much! that works splendidly
_Mitch07
February 12, 2024, 3:48pm
10149
Iām also interested in the .yaml code of the custom mushroom-template-card you made for the washing machine. Looks great.
Can you share the total .yaml code with us please
Markus99
(Mark)
February 12, 2024, 4:01pm
10150
tap_action: using a template
Possible to do this? This is my code, but doesnāt appear to be working:
de_mushroom_entity:
card:
type: custom:mushroom-template-card
primary: '[[name]]'
secondary: ''
icon: '[[icon]]'
entity: '[[entity]]'
icon_color: '{{ ''amber'' if is_state(''[[entity]]'', ''on'') else ''#44739e'' }}'
layout: vertical
tap_action:
action: >-
{% if 'sensor' in [[entity]] %}
more-info
toggle
double_tap_action:
action: more-info
Worth noting, Iām also using the ādecluttering-cardā
Thx!
(James Scialdone)
February 12, 2024, 8:24pm
10151
Can someone tell me how to make a mushroom card wider?
I have a vertical layout Im doing for my daughterās ipad. Full screen is a bit much and distorted, but veritcal layout isnāt quite wide enough. Is there a way to do this based off of a percentage?
This question seems more appropriate for the decluttering topic
Hey,
Iāve created a new card that helps you declutter your LL config if you use multiple times the same block of cards with small differences (like an entity for example) to display things in LL.
Visit github for installation instructions, up to date documentation and troubleshooting guide
[GitHub Release] [GitHub Activity] [custom_updater] [Project Maintenance]
decluttering-card
This card is for Lovelace on Home Assistant .
We all use multiple times the same block of configuration acrosā¦
explore the @media screen and (max-width: 600px) {
settings.
Itās used is to apply different styles for different media types/devices and will not adjust your PC settings.
An example of itās use
card_mod:
style: |
ha-card {
--icon-size: 40px;
--icon-symbol-size: 35px ;
ha-card {
--icon-size: 60px;
--icon-symbol-size: 45px ;
You can set height and width of the card
type: custom:mushroom-fan-card
entity: fan.bedroom_fan
card_mod:
style: |
ha-card{
width: 150% !important;
height: 300px !important;
Markus99
(Mark)
February 13, 2024, 3:10am
10155
Possibly. Havenāt seen any other issues with that card at all using templates, so why I posted here.
In searching this thread I wasnāt able to find anyone trying to use a template in a tap_action.
Itās an interesting concept, Iāll do some testing. I do believe the call service with a script is probably easier.
Very similar question
Hello, I am currently trying to have a script triggered by a button. Only I need here service_template or similar. This seems not to work directly on the button. The script should definitely not be outsourced. Does anyone have an idea?
type: button
tap_action:
action: call-service
service: climate.set_temperature
service_data:
entity_id: climate.hz_ankleidezimmer_group
temperature: >-
{{ state_attr('climate.hz_ankleidezimmer_group', 'temperature') | float +
0.5 | floatā¦
Straight from the HA website
Diegocampy
(Diegocampy)
February 13, 2024, 11:41am
10158
I would like to change the color of the icon at the change of state, I use 4 states, but I donāt know how to compose the command. 3 I would like 4 of states, not only 2 but also with two nothing.
type: custom:mushroom-select-card
entity: input_select.modalita_posizione
icon_color: '{% if is_state(entity, ''Assente'') %} grey {%else %} blue {% endif %}'
fill_container: true
try this:
card_mod:
style: |
ha-state-icon {
{% if is_state(entity, ''Assente'') %} yellow {%else %} blue {% endif %}'
Diegocampy
(Diegocampy)
February 13, 2024, 3:26pm
10160
I try but not work. The icon are Blu (the standard color). I try whitout card mode and the icon is only white. Iām not sure if is possible with this card
Sorry, try this:
entity: input_select.selettore_irrigazione
card_mod:
style: |
ha-state-icon {
color: {{ 'var(--red)' if is_state('input_select.selettore_irrigazione', 'Giardino') else 'var(--contrast2)' }};
Diegocampy
(Diegocampy)
February 13, 2024, 4:21pm
10162
Sorry, I wrote wrong entities, I wrote the correct code below but it doesnāt work.
I would like 4 different colors for 4 modes:
Red Absent
Green House
Purple Nanna children
Night blue
card_mod:
style: |
ha-state-icon {
color: {{ 'var(--red)' if is_state('input_select.modalita_posizione', 'Casa') else 'var(--contrast2)' }};
I really donāt know how to do it, Iāve done other similar things but without card mode, directly in the icon color settings for example like this:
icon: >-
{% set humid = states(entity) | float%} {% if humid < 40 %}
mdi:water-percent-alert {% elif humid > 60 %} mdi:water-percent-alert
{%else %} mdi:water-percent {% endif %}
icon_color: >-
{% set humid = states(entity) | float%} {% if humid < 40 %} blue {% elif
humid > 60 %} red {% else %} green {% endif %}
This only works in the template card, template chip, and the title card.
if you need to use templates - i suggest you use the template card or chip. if you cant for whatever reason use that, then you do need to use card mod. for example this:
entity: input_select.speaker_group_dropdown
card_mod:
style:
mushroom-shape-icon$: |
.shape {
{% if is_state('input_select.speaker_group_dropdown', 'Upstairs Speakers') %}
--shape-color: rgba(var(--rgb-red),0.2) !important;
--shape-color: rgba(var(--rgb-blue), 0.2) !important;
ha-state-icon {
color: rgba(var(--rgb-red), 1) !important;
color: rgba(var(--rgb-blue), 1) !important;
Diegocampy
(Diegocampy)
February 13, 2024, 5:01pm
10164
Thank you very much, at least I understood why it didnāt work. Now Iāll have to understand how to use this, Iām trying, but Iām missing some notions, I havenāt understood how to decide 4 different colors for 4 different states of the entity. The example only has 2 that reason, āif soā do this, āotherwiseā do that. At least I think thatās how I understood it.
Could you give me an example?
Iāve gotten this far, then Iāll also have to understand how to define the colors, but I think that will be a minor problem, I should find some information online
card_mod:
style:
.shape {
{% if is_state('input_select.modalita_posizione', 'Casa') %}
--shape-color: rgba(var(--rgb-red),0.0) !important;
ha-state-icon {
{% if is_state('input_select.modalita_posizione', 'Assente') %}
Sure. just use elseif like this:
{% elif is_state('input_select.modalita_posizione', 'Assente') %}
--shape-color: rgba(var(--rgb-green), 0.2) !important;
and keep going with more elif
if you need
Diegocampy
(Diegocampy)
February 13, 2024, 5:10pm
10166
many thanks!
so in your example there are not 2 different possibilities indicated but two things to change, the shape and the color? correct?
Sorry for the many stupid questions, Iām trying to learn slowly
