Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
You can use whatever mini-media-player supports.
Hi Rhysb
Is there a way to greyout chip pictures depending on the state of an input boolean ?
type: custom:mushroom-chips-card
chips:
  - type: conditional
    conditions:
      - entity: input_boolean.ana_sayfa_menu
        state: 'off'
    chip:
      type: template
      entity: input_boolean.futbol
      picture: /local/icons/besiktas2.png
      content: |
        {% if is_state('input_boolean.futbol', 'off') %}
        Maç Yok
        {% elif is_state('input_boolean.futbol', 'on') %}
        Maç GĂŒnĂŒ
        HATA
      icon: |-
        {% set state=states(entity) %}
        {% if state=='off' %}
        mdi:soccer
        {% elif state=='on' %}
        mdi:soccer
        mdi:door
      icon_color: |-
        grey
        amber
        grey
      tap_action:
        action: more-info
Like in this one :
Ekran Resmi 2022-07-22 04.50.00
“Maç Yok” is appearing during the state off. I would also like to greyout the logo based on the state. If the boolean is off the color of the picture should be grey ? Is this possible ? I trıed with card mode but had no luck.
Hello everyone!
Is there a way to hide the one chip card if one condition is set?
Example: I use one chip card with the couter of lights that are on at the moment.
If the number of this counter = 0, the chip should not be displayed.
Is it possible?
Simply use a conditional chip.
chips:
  - type: conditional
    conditions:
      - entity: light.lights
        state: 'on'
    chip:
      type: light
Yes, probably like this :grin::
chips:
  - type: conditional
    conditions:
        state: 'off'
    chip:
      type: template
      content: |
        {% if is_state(entity, 'off') %}
        Maç Yok
        {% elif is_state(entity, 'on') %}
        Maç GĂŒnĂŒ
        HATA
      icon: |-
        mdi:soccer
        mdi:soccer
        mdi:door
      icon_color: |-
        grey
        amber
        grey
      tap_action:
        action: more-info
      card_mod:
        style: |
          ha-card {
              {{ 'filter: grayscale(100%);' if is_state('input_boolean.futbol', 'off') }}
BTW, using picture has precedence over icon and icon_color, so you can remove them.
popup_cards:
      light.all_lights:
        title: All Lights
        card:
          type: entity-filter
          entities:
            - light.ambilight_wled
            - light.bedroom_light
            - light.cabinet_lights
            - light.entryway
            - light.front_lights
            - light.kitchen
            - light.living_room
            - light.minecraft_wled
            - light.mirrorlight
            - light.wled
            - light.office_ambient
            - light.office_led_strip
            - light.office_lights
          state_filter:
            - 'on'
this shows a popup card using browser mod of only lights that are on in that list.
Screenshot 2022-07-21 213444
Animated SVG icons do not work for me using your method.
type: custom:mushroom-template-card
primary: light.arbeitszimmer
icon: ''
picture: /local/3D-printing.svg
entity: light.arbeitszimmer_deckenleuchte
secondary: ''
:thinking: Weird, are you able to share your SVG and I can test here?
You can grab the animated weather icons I used here:
Funny, the SVGs you recommended work. I don’t know why the SVG I have didn’t work.
Works: rainy.svg (from the Free animated SVG weather icons - amCharts)
Does not work: deckenleuchte2_an.svg (Link: https://file.io/cDxOiCKbcF6X)
But I have found another (less user-friendly) solution for animated icons: Animated SVG Icon - Album on Imgur
love that - is there any way you can get the effect to apply for a few seconds only when an entity changes state ?
I everything I tried so far applies the effect on page load too
 but I’m not sure if it’s actually possible to only apply it when the state changes (after the page has loaded).
      card_mod:
        style: |
          ha-card {
I’m using this with a person card, is there a way to keep the (away) badge the original (red) color?
Thank you so much!!! This works great!
              picture: |
              {% if is_state('climate.john_s_device', 'cool') %}
              /local/animated/spinning.gif
              /local/animated/afan.gif
I’m replying to my own post to show my solution.
I was trying to find a way to combine a conditional chip and a template chip together, so that I could display the below template chip ONLY if the AC is turned on and actively cooling.
2022-07-22 20_03_25-Wall – Home Assistant
I found a solution with the help of this older post # 195 (thanks @pedolsky!) that had worked on the same issue, modified for my purposes.
Also tagging @berkans who had liked my earlier post and presumably was also looking for a solution to this.
The solution requires the card-mod addon installed.
Using card-mod, I have two Air Conditioner template chips - but each will only appear if that particular AC is turned on. See below if this is something you’d like to achieve!
chips:
  - type: template
    icon: mdi:snowflake
    icon_color: blue
    content: |
      Bedroom AC on / Set to {{ state_attr('climate.bedroom_ac', 'temperature') }}°
    tap_action:
      action: toggle
    card_mod:
      style: |
        :host {
          display:
            {%- if states('climate.bedroom_ac') == 'cool' %}inline;
            {%- else %}none
            {%- endif %}
  - type: template
    icon: mdi:snowflake
    icon_color: blue
    content: |
      Living Room AC on / Set to {{ state_attr('climate.living_room_ac', 'temperature') }}°
    tap_action:
      action: toggle
    card_mod:
      style: |
        :host {
          display:
            {%- if states('climate.living_room_ac') == 'cool' %}inline;
            {%- else %}none
            {%- endif %}
Love the new climate card but I have a problem with my thermostat setup that is a x-comfort 12channel controller for water heating.
This is not a regular thermostat and the hvac-modes does not set the states automatic. This has to be done manually. How can this be done in the new climate card?
To get a button glow on press you could try something like this:
Activate
primary: Activate
secondary: null
icon: mdi:radioactive
icon_color: red
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      box-shadow: 0 0 20px red;
Your SVG does animate, it just does it once. The SVG animation needs to loop/repeat.
You can do that like this:
card_mod:
  style: |
    mushroom-shape-avatar {
I tried this, unfortunately this doesn’t work.
  - type: custom:mushroom-person-card
    entity: person.step
    primary_info: none
    secondary_info: none
    use_entity_picture: true
    card_mod:
      style: |
Nothing changed, I expected it to always be grayscale, also tried it with this:
{{ 'filter: grayscale(100%);' if is_state('person.step', 'not_home') }}
The above works on the entire card (including the badge using ha-card without card_mod), but not on ‘mushroom-shape-avatar’.
Any ideas? It’s like it is not recognizing the mushroom-shape-avatar.
Hi rhysb,
im little bit struggling with your code. Im trying to use your code and just changed the entities, but im always getting this result:
Do you have an idea whats wrong here?
type: custom:stack-in-card
cards:
  - type: custom:apexcharts-card
    chart_type: radialBar
    series:
      - entity: sensor.docker_cpu
        color: rgb(255, 87, 34)
        max: 90
        show:
          legend_value: false
    apex_config:
      plotOptions:
        radialBar:
          offsetY: 0
          startAngle: -108
          endAngle: 108
          hollow:
          dataLabels:
            name:
              show: false
            value:
              show: false
          track:
            strokeWidth: 80%
            margin: 0
      fill:
        type: gradient
        gradient:
          shade: light
          type: horizontal
          shadeIntensity: 0.3
          inverseColors: false
          opacityFrom: 1
          opacityTo: 1
          stops:
            - 0
            - 50
            - 55
            - 90
      legend:
        show: false
      chart:
        height: 240
  - type: custom:mushroom-entity-card
    primary_info: state
    secondary_info: name
    icon_color: deep-orange
    layout: vertical
    card_mod:
      style: |
        ha-card {
          margin-top: -90px;
          width: 140px;
          margin-left: auto;
          margin-right: auto;
That works like a charm. Thank you very much.
I have a last question and I think that question could also interest others as well.
Can we change the color of the chip picture depending on the state ?
For example an air condition. I have a white picture of an air condition.
So can the color of this picture change depending on whether its on “cool” state or other. I would like it to be red when it’s on heat mode and blue when on cool.
        chips:
          - type: conditional
            conditions:
                state: 'off'
            chip:
              type: template
              entity: climate.146235046506144_climate
              icon: mdi:home-thermometer
              tap_action:
                action: more-info
              icon_color: |-
                {% if state=='cool' %}
                blue
                {% elif state=='heat' %}
                red
                grey
        card_mod:
          style: |
            ha-card {
              --chip-icon-size: 22px;
              --chip-box-shadow: none;
              --chip-background: none;
              --chip-spacing: 0px;
              --chip-padding: 15px;
              margin-left: 15px;
              margin-bottom: -auto;
              width: 400px;
        alignment: start
I know I can easily change it with using conditional card but I guess card mode will be a shorter way.
