Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
I’m looking for the solution to display the date in template card like entity card for the secondary line.
By defaut, we’ve a date format “XX minutes ago” but when we use the template card, it show a timestamp.
How can I convert the timestamp to have the same resultat that the entity card by default ?
Here is my secondary line for the template card
secondary: |
  {{ states(entity) }}
Capture d’écran 2022-07-30 à 17.40.32
Capture d’écran 2022-07-30 à 17.40.46
Thanks.
Whilst I am not a football fan I can see the considerable work that has gone into this and it looks great. Well done.
This is the route I ended up taking, thanks very much for pointing me in this direction! It’s not quite perfect yet, but minimalist area card definitely does manage to cover most of the functionality I was looking for in migrating. Moving over to mushroom has been very enjoyable so far!
Thank you very much. I am trying to use Home Assistant not only for Smart home but for smart life. Now I have found much more informative calendars for football as well. I think I may also display match results from fixtures, but of course it mostly depends on how accurately and fast these services upload the scores to calendar events.
Later on I am also planning to use rss services for different pages.
Mushroom cards create the --rgb-[color] dynamically, so are only available within a Mushroom card. If --mush-rgb-[color] is defined it uses this value, otherwise it uses the hardcoded --default-[color] value. The --mush-rgb-[color] values can be defined in a theme file and these will then also be available to other cards. So, if you want to use the CSS values outside of the Mushroom cards you will need to define them in a custom theme. The quick and easy way to do this is to copy @piitaya’s example from his theme github and place it in a new theme file.
Here is a Mushroom Input Number card if anyone needs one. It requires stack-in-card, mushroom-card, car-mod and my-slider from my-cards.
type: custom:stack-in-card
cards:
    entity: input_number.lounge_pc_volume
    icon: |
      {% set vol_level = states(entity) | float %}
      {% if vol_level == 0 %}
        mdi:volume-mute
      {% elif vol_level > 0.66 %}
        mdi:volume-high
      {% elif vol_level < 0.33 %}
        mdi:volume-low
        mdi:volume-medium
    icon_color: indigo
    primary: Volume
    secondary: |
      {% set vol = states(entity) | float * 100 %}
      {{ vol | round | int }}%
  - type: custom:my-slider
    radius: 12px
    height: 42px
    mainSliderColor: rgb(var(--mush-rgb-indigo))
    secondarySliderColor: rgba(var(--mush-rgb-indigo), 0.2)
    mainSliderColorOff: rgb(var(--mush-rgb-disabled))
    secondarySliderColorOff: rgba(var(--mush-rgb-disabled), 0.2)
    thumbHorizontalPadding: 0px
    thumbVerticalPadding: 0px
    thumbWidth: 0px
    card_mod:
      style: |
        ha-card {
          padding: 0px 11px 11px;
          --mush-rgb-disabled: 189,189,189;
          --mush-rgb-indigo: 63, 81, 181;
Hey folks,
I’m just starting to migrate over to the Mushroom Cards, and I want to show a chip for each person with the appropriate battery level as the icon, coloured based on the battery percentage.
The following code returns the correct result in developer settings -> templates, however when I move it into the card editor for the dashboard it throws missed comma between flow collection entries
{% for p in states.person -%}
{% set name = p.entity_id -%}
# Make sure we have a source from which to collect the battery level
{% if  state_attr(name, 'source') -%}
# Get the battery_level data for the appropriate user
{% set battery_level = states('sensor.{}_battery_level'.format(state_attr(name,
      'source').split('.')[1])) -%}
{% else -%}
# If we don't have a battery_level, set it to -1 so we can filter on it later
{% set battery_level = -1 -%}
{% endif -%}
type: custom:mushroom-chips-card
chips:
  - type: template
    content: >
      {{ state_attr(name, "friendly_name") }} {% if (battery_level != "unknown") and (battery_level | int >= 0) %}({{ battery_level }}%){% endif %}
    icon: >-
      {{ state_attr(states('sensor.{}_battery_level'.format(state_attr(name,
      'source').split('.')[1])), 'icon') }}
    icon_color: >-
      {% if states('sensor.{}_battery_level'.format(state_attr(name,
      'source').split('.')[1])) | int < 20 -%}
        red
      {% elif states('sensor.{}_battery_level'.format(state_attr(name,
      'source').split('.')[1])) | int < 50 -%}
        orange
      {% else -%}
        green
{% endfor -%}
The resulting card should look like this for each user:
Is anyone able help?
mode: vertical
keep:
  box_shadow: true
  border_radius: true
  margin: true
  outer_padding: true
  background: true
cards:
  - type: vertical-stack
    cards:
      - type: conditional
        conditions:
          - entity: media_player.garage
            state_not: 'off'
        card:
          type: custom:mini-media-player
          style: |
            :host {
              --mini-media-player-name-font-weight: 500;
              --mini-media-player-artwork-opacity: 1;
              --mini-media-player-media-cover-info-color: white;
              --mini-media-player-overlay-base-color: #2196f3;
          info: scroll
          artwork: cover
          volume_stateless: false
          toggle_power: true
          hide:
            runtime_remaining: false
            runtime: false
            info: false
            power: true
            power_state: false
            progress: false
            source: false
            play_stop: true
            volume_level: false
            controls: true
            volume: true
            icon: true
      - type: conditional
        conditions:
          - entity: media_player.kuche
            state_not: 'off'
        card:
          style: |
            :host {
          info: scroll
          artwork: cover
          toggle_power: true
          hide:
            runtime: false
            info: false
            power: true
            power_state: false
            progress: false
            source: false
            play_stop: true
            volume_level: false
            controls: true
            volume: true
            icon: true
      - type: conditional
        conditions:
          - entity: media_player.tv_samsung_6_series_55
            state: 'on'
        card:
          style: |
            :host {
          info: scroll
          artwork: cover
          toggle_power: true
          hide:
            runtime: false
            info: false
            power: true
            power_state: false
            progress: false
            source: false
            play_stop: true
            volume_level: false
            controls: true
            volume: true
            icon: true
      - type: conditional
        conditions:
          - entity: media_player.laptop
            state: playing
        card:
          style: |
            :host {
          info: scroll
          artwork: cover
          toggle_power: true
          hide:
            runtime: false
            info: false
            power: true
            power_state: false
            progress: false
            source: false
            play_stop: true
            volume_level: false
            controls: true
            volume: true
            icon: true
  - square: false
    columns: 4
    type: grid
    cards:
        style: |
          :host {
            --primary-text-color:
            {% if is_state('input_select.lms_player', 'garage')%} #2196f3
            {% else %} #9e9e9e
        secondary: ''
        icon: mdi:radio
        primary: Garage
        multiline_secondary: true
        icon_color: >-
          {{ is_state("input_select.lms_player", "garage") | iif("blue",
          "disabled") }}
        tap_action:
          action: call-service
          service: input_select.select_option
          service_data:
            option: garage
            entity_id: input_select.lms_player
        fill_container: true
        hold_action:
          action: more-info
        layout: vertical
        style: |
          :host {
            {% if is_state('input_select.lms_player', 'kuche')%} #2196f3
            {% else %} #9e9e9e
        secondary: ''
        icon: mdi:silverware-fork-knife
        primary: Küche
        icon_color: >-
          {{ is_state("input_select.lms_player", "kuche") | iif("blue",
          "disabled") }}
        tap_action:
          service_data:
            option: kuche
        layout: vertical
        hold_action:
          action: more-info
        style: |
          :host {
            {% if is_state('input_select.lms_player', 'tv_samsung_6_series_55')%} #2196f3
            {% else %} #9e9e9e
        secondary: ''
        icon: mdi:television-classic
        entity: media_player.tv_samsung_6_series_55_3
        icon_color: >-
          {{ is_state("input_select.lms_player", "tv_samsung_6_series_55") |
          iif("blue", "disabled") }}
        tap_action:
          service_data:
            option: tv_samsung_6_series_55
        layout: vertical
        hold_action:
          action: more-info
        primary: TV
        style: |
          :host {
            {% if is_state('input_select.lms_player', 'laptop')%} #2196f3
            {% else %} #9e9e9e
        secondary: ''
        icon: mdi:laptop
        primary: Laptop
        icon_color: >-
          {{ is_state("input_select.lms_player", "laptop") | iif("blue",
          "disabled") }}
        tap_action:
          service_data:
            option: laptop
        layout: vertical
        hold_action:
          action: more-info
  - type: entities
    entities:
      - type: custom:fold-entity-row
        padding: 0
        style:
          ha-icon:
              ha-svg-icon {
               color: #ff5722;
        head:
          type: custom:button-card
          name: Romania Radiostation
          tap_action:
            action: none
          styles:
            card:
              - margin-bottom: 0px
              - padding-bottom: 0px
              - padding-top: 0px
              - box-shadow: none
            name:
              - justify-self: start
              - padding-left: 8px
              - font-size: 15px
              - font-weight: bold
              - color: '#795548'
        entities:
            card_mod:
              style: |
                ha-card {
                  --chip-border-radius: 12px;
                  --primary-text-color: grey;
            chips:
              - type: template
                entity: input_select.chromecast_radio_station
                icon_color: >-
                  {{ is_state("input_select.chromecast_radio_station", "ProFM")
                content: 'Pro FM '
                icon: >-
                  | iif("mdi:checkbox-blank-circle",
                  "mdi:checkbox-blank-circle-outline") }}
                tap_action:
                  service_data:
                    option: ProFM
                    entity_id: input_select.chromecast_radio_station
              - type: template
                icon_color: >-
                  {{ is_state("input_select.chromecast_radio_station", "KissFM")
                content: Kiss FM
                icon: >-
                tap_action:
                  service_data:
                    option: KissFM
              - type: template
                icon_color: >-
                  "EuropaFM") | iif("blue", "disabled") }}
                content: Europa FM
                icon: >-
                  "EuropaFM") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: EuropaFM
              - type: template
                icon_color: >-
                  "RadioZu") | iif("blue", "disabled") }}
                content: RadioZu
                icon: >-
                  "RadioZu") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: RadioZu
              - type: template
                icon_color: >-
                  {{ is_state("input_select.chromecast_radio_station", "DigiFM")
                content: Digi FM
                icon: >-
                tap_action:
                  service_data:
                    option: DigiFM
              - type: template
                icon_color: >-
                  "MagicFM") | iif("blue", "disabled") }}
                content: Magic FM
                icon: >-
                  "MagicFM") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: MagicFM
              - type: template
                icon_color: >-
                  "VirginRadio") | iif("blue", "disabled") }}
                content: Virgin Radio
                icon: >-
                  "VirginRadio") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: VirginRadio
              - type: template
                icon_color: >-
                  "RadioMedias") | iif("blue", "disabled") }}
                content: Radio Medias
                icon: >-
                  "RadioMedias") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: RadioMedias
              - type: template
                icon_color: >-
                  "RadioPetrecere") | iif("blue", "disabled") }}
                content: Radio Petrecere
                icon: >-
                  "RadioPetrecere") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: RadioPetrecere
              - type: template
                icon_color: >-
                  "NationalFM") | iif("blue", "disabled") }}
                content: National FM
                icon: >-
                  "NationalFM") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: NationalFM
              - type: template
                icon_color: >-
                  "WefunkRadio") | iif("blue", "disabled") }}
                content: WeFunk Radio
                icon: >-
                  "WefunkRadio") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: WefunkRadio
              - type: template
                icon_color: >-
                  "FunkyRadio") | iif("blue", "disabled") }}
                content: Funky Radio
                icon: >-
                  "FunkyRadio") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: FunkyRadio
              - type: template
                icon_color: >-
                  "RadioFunkyThrills") | iif("blue", "disabled") }}
                content: Radio Funky Thrills
                icon: >-
                  "RadioFunkyThrills") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: RadioFunkyThrills
            alignment: null
  - type: entities
    entities:
        padding: 0
        style:
          ha-icon:
              ha-svg-icon {
               color: #ff5722;
        head:
          tap_action:
            action: none
          styles:
            card:
              - padding-top: 0px
              - box-shadow: none
            name:
              - padding-left: 8px
              - font-size: 15px
              - font-weight: bold
              - color: '#795548'
        entities:
            card_mod:
              style: |
                ha-card {
            chips:
              - type: template
                icon_color: >-
                  "Bayern1") | iif("blue", "disabled") }}
                content: Bayern1
                icon: >-
                  "Bayern1") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: Bayern1
              - type: template
                icon_color: >-
                  "Bayern3") | iif("blue", "disabled") }}
                content: Bayern3
                icon: >-
                  "Bayern3") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: Bayern3
              - type: template
                icon_color: >-
                  "Charivari") | iif("blue", "disabled") }}
                content: Charivari
                icon: >-
                  "Charivari") | iif("mdi:checkbox-blank-circle",
                tap_action:
                  service_data:
                    option: Charivari
              - type: template
                icon_color: >-
                  {{ is_state("input_select.chromecast_radio_station", "Energy")
                content: Energy
                icon: >-
                tap_action:
                  service_data:
                    option: Energy
    chips:
      - type: action
        icon_color: blue
        icon: mdi:play
        tap_action:
          service: script.lms
          service_data: {}
          target: {}
      - type: action
        icon_color: deep-orange
        icon: mdi:stop
        tap_action:
          service: script.lms_stop
          service_data: {}
          target: {}
      - type: action
        tap_action:
          service: input_number.decrement
          service_data: {}
            entity_id: input_number.lms_volume
        icon: mdi:volume-minus
        icon_color: grey
      - type: action
        icon: mdi:volume-plus
        tap_action:
          service: input_number.increment
          service_data: {}
        icon_color: grey
Has anyone used mushroom card/custom in stack card with input_selects and input_numbers? If yes can you share yaml/pictures?
Just with sensors.
Code if it helps :slight_smile:
mode: horizontal
cards:
  - type: custom:mushroom-entity-card
    icon: mdi:water
    entity: sensor.tomat_plante_manuel_moisture
    layout: vertical
    icon: mdi:weather-sunny
    icon_color: amber
    entity: sensor.tomat_plante_manuel_brightness
    layout: vertical
    icon_color: light-green
    entity: sensor.tomat_plante_manuel_temperature
    layout: vertical
    icon: mdi:sprout
    icon_color: brown
    entity: sensor.tomat_plante_manuel_conductivity
    layout: vertical
Thank you. What I’m really looking for is how someone handled the ability to select from an input select. Was it simply using a tap action: more-info or did they use something more elegant to avoid using that generic page/pop-up.
Simple question here but trying to figure out best way to do it. I’m trying have a dropdown from the “All Living Room Switches.” Any thoughts/code on how to do that or do I have to use custom conditional card and custom card mod and write the code? Obviously using Mushroom to avoid any yaml editing for my basic needs like this. Would like to do it from the “double tap action” option
It looks very impressive.
I would really love to see a code for a rss weather forecast,
Thank you for the reply. So I guess I have to bite the bullet and confront something I’d been wary of my own understanding all along :slight_smile: I’ve noted the various comments in the thread about the separate Theme package but never quite understood how to put it into practice. When installed manually or through HACS, the actual theme files are just a few lines long (3-5) however the Github page lists several pages of variables. I’ve just assumed that what we see on the Github page we get for “free” in the cards themselves, and if we wanted to extend the theme out to non-Mushroom cards one would just need to include the variables listed in Github in the actual theme file loaded by HA. Is that right? That’s what I’ve done to try and expose the colors for this use-case, anyway. My mushroom.yaml theme file now contains everything listed in the Github and I think I have many more variables available to me when working through Inspector.
However… I still can’t seem to get this licked. Original problem statement just for recap was that I’d like to use you (Rhys’) room card or something similar but vary the colors of the individual rooms a bit. So the icon color is easy enough to set, but it’s the rest of the card’s background I’m having trouble setting. Would you mind terribly to share a snippet of one of your room cards where one of the target rooms utilizes a color other than the default/orange?
Thank you!
The Mushroom theme settings allow you to customize/override the the default settings of the Mushroom cards. For instance if you want to use amber for the lights, instead of orange, you can override it by adding mush-rgb-state-light: var(--mush-rgb-amber) to your theme file. In the same way you can change what red is by specifying a different value for mush-rgb-red, say pure red with mush-rgb-red: 255, 0, 0. Now every time a Mushroom card uses red it will be this new value of red we have specified in our theme. These ‘mush’ values are only for Mushroom cards, they don’t affect any of the normal HA cards. The advantage of specifying the ‘mush’ values in a theme, even if we do not change them, is that they are now available to be used in CSS anywhere.
This is what I have in my Mushroom theme file:
mushroom-custom.yaml
Mushroom Custom:
    # HA variables
    ha-card-box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.16)
    ha-card-border-radius: 20px
    # Mushroom layout
    #mush-spacing: 12px
    # Title
    #mush-title-padding: 24px 12px 16px
    #mush-title-spacing: 12px
    #mush-title-font-size: 24px
    #mush-title-font-weight: normal
    #mush-title-line-height: 1.2
    # Subtitle
    #mush-subtitle-font-size: 16px
    #mush-subtitle-font-weight: normal
    #mush-subtitle-line-height: 1.2
    # Card
    #mush-card-primary-font-size: 14px
    #mush-card-secondary-font-size: 12px
    #mush-card-primary-font-weight: bold
    #mush-card-secondary-font-weight: bolder
    #mush-card-primary-line-height: 1.5
    #mush-card-secondary-line-height: 1.5
    # Chip
    #mush-chip-spacing: 8px
    #mush-chip-padding: 0 0.25em
    #mush-chip-height: 36px
    #mush-chip-border-radius: 18px
    #mush-chip-font-size: 0.3em
    #mush-chip-font-weight: bold
    #mush-chip-icon-size: 0.5em
    #mush-chip-avatar-padding: 0.1em
    #mush-chip-avatar-border-radius: 50%
    #mush-chip-box-shadow: var(--ha-card-box-shadow)
    #mush-chip-background: var(--ha-card-background)
    # Control
    #mush-control-border-radius: 12px
    #mush-control-height: 42px
    #mush-control-button-ratio: 1
    #mush-control-icon-size: 0.5em
    # Slider
    #mush-slider-threshold: 10
    # Badge
    #mush-badge-size: 16px
    mush-badge-icon-size: 0.8em
    #mush-badge-border-radius: 50%
    # Icon
    #mush-icon-border-radius: 50%
    #mush-icon-size: 42px
    #mush-icon-symbol-size: 0.5em
    # Colors
    mush-rgb-red: 244, 67, 54
    mush-rgb-pink: 233, 30, 99
    mush-rgb-purple: 156, 39, 176
    mush-rgb-deep-purple: 103, 58, 183
    mush-rgb-blue: 33, 150, 243
    mush-rgb-light-blue: 3, 169, 244
    mush-rgb-cyan: 0, 188, 212
    mush-rgb-teal: 0, 150, 136
    mush-rgb-green: 76, 175, 80
    mush-rgb-light-green: 139, 195, 74
    mush-rgb-lime: 205, 220, 57
    mush-rgb-yellow: 255, 235, 59
    mush-rgb-amber: 255, 193, 7
    mush-rgb-orange: 255, 152, 0
    mush-rgb-deep-orange: 255, 87, 34
    mush-rgb-brown: 121, 85, 72
    mush-rgb-grey: 158, 158, 158
    mush-rgb-blue-grey: 96, 125, 139
    mush-rgb-black: 0, 0, 0
    mush-rgb-white: 255, 255, 255
    #mush-rgb-info: var(--mush-rgb-blue)
    #mush-rgb-success: var(--mush-rgb-green)
    #mush-rgb-warning: var(--mush-rgb-orange)
    #mush-rgb-danger: var(--mush-rgb-red)
    #mush-rgb-state-fan: var(--mush-rgb-green)
    #mush-rgb-state-entity: var(--mush-rgb-blue)
    #mush-rgb-state-switch: var(--mush-rgb-blue)
    #mush-rgb-state-alarm-disarmed: var(--mush-rgb-info)
    #mush-rgb-state-alarm-armed: var(--mush-rgb-success)
    #mush-rgb-state-alarm-triggered: var(--mush-rgb-danger)
    #mush-rgb-state-person-home: var(--mush-rgb-success)
    #mush-rgb-state-person-not-home: var(--mush-rgb-danger)
    #mush-rgb-state-person-zone: var(--mush-rgb-info)
    #mush-rgb-state-person-unknown: var(--mush-rgb-grey)
    #mush-rgb-state-cover-open: var(--mush-rgb-blue)
    #mush-rgb-state-cover-closed: var(--mush-rgb-disabled)
    #mush-rgb-state-climate-auto: var(--mush-rgb-green);
    #mush-rgb-state-climate-cool: var(--mush-rgb-blue);
    #mush-rgb-state-climate-dry: var(--mush-rgb-orange);
    #mush-rgb-state-climate-fan-only: var(--mush-rgb-blue-grey);
    #mush-rgb-state-climate-heat: var(--mush-rgb-deep-orange);
    #mush-rgb-state-climate-heat-cool: var(--mush-rgb-green);
    #mush-rgb-state-climate-idle: var(--mush-rgb-grey);
    #mush-rgb-state-climate-off: var(--mush-rgb-disabled);
    # You must keep this to support light/dark theme
    modes:
        light:
            mush-rgb-disabled: 189, 189, 189
        dark:
            mush-rgb-disabled: 111, 111, 111
As you can see, most of it is commented out. I mainly use it for the mush-rgb-[color] values.
To apply this to my Room card we can now do this:
cards:
    primary: Lounge
    secondary: '{{ states("sensor.lounge_sensor_temperature") | round(0) }} °C'
    icon: mdi:sofa
    entity: light.lounge_light
    tap_action:
      action: navigate
      navigation_path: lounge
    hold_action:
      action: toggle
    icon_color: '{{ ''red'' if is_state(entity, ''on'') else ''disabled'' }}'
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 76px;
          height: 66px;
          margin-left: -18px !important;
    chips:
      - type: conditional
        conditions:
          - entity: binary_sensor.lounge_motion_occupancy
            state: 'on'
        chip:
          type: template
          icon_color: disabled
          icon: mdi:motion-sensor
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: media_player.lounge_tv
            state_not: 'off'
            state_not: unavailable
        chip:
          type: template
          icon: |-
            {% set media_type = state_attr('media_player.lounge_tv',
            'media_content_type') %}
            {% if media_type == 'tvshow' %}
            {% elif media_type == 'movie' %}
              mdi:movie-open
            {% elif media_type == 'music' %}
              mdi:music
            {% elif media_type == 'playlist' %}
              mdi:music
              mdi:plex
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: climate.air_conditioner
            state_not: 'off'
        chip:
          type: template
          icon: |-
            {% if is_state(entity, 'heat_cool') %}
              mdi:sync
            {% elif is_state(entity, 'heat') %}
              mdi:fire
            {% elif is_state(entity, 'cool') %}
              mdi:snowflake
            {% elif is_state(entity, 'dry') %}
              mdi:water-percent
            {% elif is_state(entity, 'fan_only') %}
              mdi:fan
              mdi:air-conditioner
          tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              @keyframes rotation {
                0% {
                  transform: rotate(0deg);
                100% {
                  transform: rotate(360deg);
              ha-card {
                {% if is_state('climate.air_conditioner', 'fan_only') %}
                   animation: rotation 2s linear infinite;
      - type: conditional
        conditions:
          - entity: group.lounge_windows
            state: 'on'
        chip:
          type: template
          icon: mdi:window-open
          tap_action:
            action: none
          hold_action:
            action: none
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 0;
card_mod:
  style: |
    ha-card {
      height: 102px;
      {% if is_state('light.lounge_light', 'on') %}
        background: rgba(var(--mush-rgb-red), 0.1);
The last card_mod: style: is being applied to the stack-in-card, which is not a Mushroom card so cannot see the dynamically created --rgb-[color] values. However it can see the --mush-rgb-[color] values that we have defined in our theme file.
Alternatively we can find the value of --rgb-orange and manually specify that in our CSS, which is what I originally did with my Room card:
card_mod:
  style: |
    ha-card {
      height: 102px;
         background: rgba(255, 152, 0, 0.1);
I hope that’s clearer than mud :grin:.
You can add paper-item-icon-active-color: 253, 216, 53 to your theme file. This defines the yellow in RGB values.
@rhysb have you used mushroom card/custom in stack card with input_selects and input_numbers? If yes can you share yaml/pictures?
I’m wondering how to make them take up less space while still having readable titles for each select/number.
3 input selects. 1 Input number and 1 input boolean. I’m trying to create an interface for custom light effects.
For a clean mobile setup I’m thinking the order should be
Input selects (horizontal or vertical)
Input number (horizontal or vertical)
Input Boolean (centered potentially)
Simply use
relative_time(here.timestamp)
Thanks for that @rhysb. But in my case, I would prefer to use the paper-item-icon-active-color that is already defined by the user-selected theme. I don’t want to explicitly define any color in particular, but rather just use the theme’s color. To be totally clear, I am not a css expert, so I might be missing something very simple. I guess maybe there must be a way to convert the already-defined paper-item-icon-active-color from a HEX to RGB so I can use the rgba function to adjust the opacity of the shape color, or perhaps there is already a mechanism in place to use the user-selected theme colors? Am I overthinking this, or is there no simple way to do this?
Anyone else having this issue with the climate cards? I just finally updated mushroom when I realized these are available, and if I pull down to refresh they work fine. But when I first open up HA, the card always looks like this.
