I have an auto entities card that lists all light groups.
I would like to be able to tap on the specific light group card and then have a pop-up (browser mod) that lists all the lights in the group.
The easiest way to do this because the groups are zha groups which donāt expose child entities is to parse the area out of the group entity id which will all have a corresponding area.
light.kitchen_lights
group is kitchen
I have an easy template that will extract the area. I just donāt know if itās possible to do this or Iām going about it wrong. Not sure what variables the auto entities exposes that could be useful I was trying to read the documentation and play with it but I canāt figure that out.
Hereās how the current setup looks.
Edit: I think I need to do something with this, auto entities and mushroom template card to achieve what I want
type: custom:auto-entities
card:
type: grid
columns: 2
square: false
card_param: cards
filter:
include:
- domain: light
entity_id: /[li]ghts/
options:
type: custom:mushroom-template-card
primary: '{{ states[entity].name }}'
secondary: '{{ states(entity) | title }}'
picture: local/icons/custom_icons/ceiling-lamp-off3.png
hold_action:
action: toggle
double_tap_action:
action: more-info
tap_action:
action: fire-dom-event
browser_mod:
command: popup
title: '{{ states[entity].name }}'
card:
card:
type: grid
columns: 2
square: false
card_param: cards
filter:
template: >-
{% set area = entity | replace('light.','')
|replace('_lights','') | replace('_',' ') %} {{ states.light |
selectattr('entity_id', 'in', area_entities(area)) |
map(attribute='entity_id') | list }}
include:
- domain: light
area: filter.template
options:
type: custom:mushroom-light-card
tap_action:
action: none
card_mod:
style: |
mushroom-shape-icon {
--shape-color: none !important;
--shape-color-disabled: none !important;
ha-card {
background: transparent;
border-radius: 30px;
margin-left: auto;
margin-right: auto;
margin-bottom: 2px;
--icon-border-radius: 0;
--icon-size: 55px;
Do you try to keep this card on the home page? Iām trying to take a slightly different approach by simply having a chip on my mushroom home page top bar that visually shows the count of issues/notifications found (coupled maybe with a color change). Clicking on the chip brings me to a page with the standard home feed card; while itās not mushroom itās away from the main UI and so doesnāt destroy the clean interface mushroom provides - something I understand youād like to change; i.e. a home feed card styled in mushroom, right?
Youāre talking about ordered functionality which brings me to a question if you donāt mind. Are you monitoring a set number of devices/entities as per the examples? Iām wondering whether thereās a way of creating a ādynamicā list of exceptions (e.g. if battery of any device in my home is <50% then register the device(s) in the home feed etc.).
Thanks everyone, especially Rhys, for all the ideas and tips Iāve learned here.
However, there is one thing that I havenāt been able to accomplish, and Iām hoping someone can point me in the right directionā¦
Is there a way to move the badge on a template card to the left side of the icon (using card-mod)?
This seems to be the CSS, when I remove the right
declaration (in my browserās dev tools), it does move the icon to the left side. However, Iām struggling with getting the card-mod code right.
.icon ::slotted([slot="badge"]) {
position: absolute;
top: -3px;
right: -3px;
Any help would be greatly appreciated!
type: horizontal-stack
cards:
- type: custom:stack-in-card
cards:
- type: custom:mushroom-person-card
entity: person.sylwester
icon_type: entity-picture
primary_info: state
secondary_info: last-changed
tap_action:
action: navigate
navigation_path: sylwester
card_mod:
style: |
:host([dark-mode]) {
background: rgba(var(--rgb-primary-background-color), 0.2);
:host {
background: rgba(var(--rgb-primary-text-color), 0.025);
chips:
- type: template
icon: >
{% set battery_level = (states(entity) | int / 10) | round(0) |
int * 10 %} {% if is_state('binary_sensor.sm_g960f_is_charging',
'on' ) %}
{% if battery_level > 0 %}
mdi:battery-charging-{{ battery_level }}
mdi:battery-charging-outline
{% if battery_level == 100 %}
mdi:battery
{% elif battery_level > 0 %}
mdi:battery-{{ battery_level }}
mdi:battery-alert-variant-outline
icon_color: |-
{% set battery_level = states(entity) | int %}
{% if battery_level > 90 %}
green
{% elif battery_level > 60 %}
light-green
{% elif battery_level > 50 %}
lime
{% elif battery_level > 40 %}
yellow
{% elif battery_level > 30 %}
amber
{% elif battery_level > 20 %}
orange
{% elif battery_level > 10 %}
deep-orange
red
card_mod:
style: |
@keyframes blink {
50% {opacity: 0;}
ha-card {
animation: blink linear infinite;
{% if states('sensor.sm_g960f_battery_level') < '15' %}
animation-duration: 1s;
tap_action:
action: none
entity: sensor.sm_g960f_battery_level
- type: template
tap_action:
action: none
entity: sensor.sm_g960f_wifi_connection
icon_color: >-
{% if is_state('sensor.sm_g960f_wifi_connection', '<not
connected>' ) %}
disabled
light-green
icon: >
connected>' ) %}
mdi:wifi-alert
mdi:wifi
- type: template
tap_action:
action: toggle
entity: switch.samsung_galaxy_s9
icon_color: |-
{% if is_state('switch.samsung_galaxy_s9', 'on' ) %}
blue
disabled
icon: |
mdi:network
mdi:network-off
alignment: start
card_mod:
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0;
card_mod:
style: |
ha-card {
height: 102px;
cards:
entity: person.jolanta
primary_info: state
tap_action:
action: navigate
navigation_path: jolanta
card_mod:
style: |
:host {
chips:
- type: template
icon: >
int * 10 %} {% if is_state('binary_sensor.sm_a705fn_is_charging',
'on' ) %}
mdi:battery
icon_color: |-
green
light-green
lime
yellow
amber
orange
deep-orange
red
card_mod:
style: |
@keyframes blink {
50% {opacity: 0;}
ha-card {
{% if states('sensor.sm_a705fn_battery_level') < '15' %}
tap_action:
action: none
entity: sensor.sm_a705fn_battery_level
- type: template
tap_action:
action: none
entity: sensor.sm_a705fn_wifi_connection
icon_color: >-
{% if is_state('sensor.sm_a705fn_wifi_connection', '<not
connected>' ) %}
disabled
light-green
icon: >
connected>' ) %}
mdi:wifi-alert
mdi:wifi
- type: template
tap_action:
action: toggle
entity: switch.samsung_a70
icon_color: |-
{% if is_state('switch.samsung_a70', 'on' ) %}
blue
disabled
icon: |
mdi:network
mdi:network-off
alignment: start
card_mod:
style: |
ha-card {
--chip-spacing: 0;
card_mod:
style: |
ha-card {
height: 102px;
I am trying to create person card with chips card on it. all is working fine apart blinking battery icon. I am not yaml person and I used only codes what I found here. My idea was to have battery icon which change color and icon depending from battery level. That part is working fine. Then I tried to add blinking when battery is below 15% and that is not working. It works but when battery level drops below 15 and then goes up gain above 15 icon is blinking constantly. Thanks for help.
@MetalOnes, thank you for your kind words.
You can position the Mushroom Badge like this:
Top Left:
primary: Top Left
icon: mdi:mushroom
icon_color: red
badge_icon: mdi:snail
badge_color: teal
secondary: Mushroom
card_mod:
style: |
mushroom-badge-icon {
left: -3px;
Bottom Left:
primary: Bottom Left
icon: mdi:mushroom
icon_color: red
badge_color: teal
secondary: Mushroom
card_mod:
style: |
left: -3px;
top: 30px;
Bottom Right:
primary: Bottom Right
icon: mdi:mushroom
icon_color: red
badge_color: teal
secondary: Mushroom
card_mod:
style: |
top: 30px;
hallo nice man & can you sharing you config pleas ?
Hey there, thanks for the reply! So as far as approach, I think my answer is both. Currently I do a version of what you described - I use something mushroom-esque on my index page to tell me something might be up and warrant a deeper look. Then I go to a separate page which shows the graphic in my original post. Keep the non-mushroomy stuff hidden But yes, you stated the goal perfectly: a home feed card styled in mushroom.
There is a use case in that I have a few tablets around the house that would be in āsecurity modeā always and have a view restricted to things like cameras/sensors. For instance, if my wife hears a noise in the night, I want her to be able to easily glance to see which motion sensors triggered most recently. Maybe itās a kid up going to the restroom or something more concerning. The home feed card functionality works perfectly for this (again aside from that weird entry in my example :)).
I think you can accomplish the filtering aspect of what youāre describing by making creative use of the exclude_states function available for each entity in the home-feed-card. I havenāt investigated it yet, but if it allows you to operate on indirect entities you could always use an input helper thatās influenced by the % state of the actual entity, or perhaps youād have to use a template to control the state and supply a hint that you can use in the exclude_states stanza. Iāll try to find some time to muck with this a bit.
Thanks again for the reply and again if anyone has any creative ideas around how to mushroomize a home feed as in my original example, Iād be very interested and appreciative!
Well, I think I need to go back to rhys CSS bootcamp again Or anyone else who might be willing to re-hash something Iām sure has been discussed. Iām having an awful lot of trouble conceptualizing how to access pieces of the hierarchy to stylize those pieces in my mushroom cards. I put together a super simple use case to try and illustrate my question. I basically have a card with two columns. Each column has a mushroom-light-card as part of it. I want some cards to take up both columns, however. With live CSS editors I can accomplish this with either --grid-column: span 2 or --grid-column: 1/ -1. However, I canāt figure out how to accomplish that with the card_mod/style construct and Iām fairly certain Iām overthinking it.
- type: custom:layout-card
layout_type: masonry
cards:
- type: grid
square: false
columns: 2
cards:
- type: custom:mushroom-light-card
entity: light.kitchen_sink
show_brightness_control: true
use_light_color: false
fill_container: true
card_mod:
style: |
mushroom-light-card {
grid-column: span 2;
entity: light.kitchen_bar_area
primary: Kitchen Bar Area
entity: light.kitchen_overhead
entity: light.kitchen_table_2
primary: Kitchen Table
A lot of the examples here show us how to navigate the CSS tree to find specific elements within a primary card so I imagine it should be easy to apply something to the top of the hierarchy, right? If I am in the Inspector via Chrome or Firefox, I can manually adjust the grid-column attribute to either of the above and watch the card expand to fill both columns. That -only- works when applied to the element { } section when selecting the mushroom-light-card itself. Modifying any of its children, e.g. ha-card, has no effect.
Whatās the equivalent card_mod syntax to affect the mushroom-light-card portion of the hierarchy such that it expands to 2 columns?
Thanks!
Added a dropdown to the Mushroom media card as a conditonal source select for my alexas.
How can I disable to input select from popping up with the show more page and just drop down right from the card? heres my code for reference
square: false
columns: 1
type: grid
cards:
- type: conditional
conditions:
- entity: input_select.alexa_media_mode
state: office
card:
cards:
layout_type: grid
layout:
grid-template-rows: 8px
grid-template-areas: |
"entity menu"
- type: custom:mushroom-media-player-card
entity: media_player.office_echo
icon: si:amazonalexa
view_layout:
grid-area: entity
grid-column-start: 1
grid-column-end: 3
use_media_artwork: false
fill_container: false
use_media_info: true
show_volume_level: false
media_controls:
- previous
- play_pause_stop
- next
collapsible_controls: true
tap_action:
action: toggle
card_mod:
style: |
ha-card {
padding-bottom: 0px !important;
alignment: end
view_layout:
grid-area: menu
card_mod:
style: |
ha-card {
background-color: transparent !important;
margin-top: -40px;
margin-right: 10px;
text-align: right;
box-shadow: none !important;
chips:
- type: entity
- entity: media_player.office_echo
hide:
icon: true
runtime: true
source: true
power: true
state_label: true
volume: true
info: true
progress: true
controls: true
more_info: false
tts:
platform: alexa
type: custom:mini-media-player
toggle_power: false
group: true
card_mod:
style: |
ha-card {
padding: 10px 8px 8px !important;
card_mod:
style: |
ha-card {
{% if not is_state('media_player.office_echo', 'standby') %}
background: rgba(var(--rgb-card-background-color), 0.5) url( '{{ state_attr( "media_player.office_echo", "entity_picture" ) }}' ) center no-repeat;
background-size: cover;
background-blend-mode: overlay;
- type: conditional
conditions:
state: kitchen
card:
cards:
layout_type: grid
layout:
"entity menu"
entity: media_player.kitchen_echoshow
view_layout:
grid-area: entity
grid-column-end: 3
media_controls:
- previous
- play_pause_stop
- next
tap_action:
action: toggle
card_mod:
style: |
ha-card {
alignment: end
view_layout:
grid-area: menu
card_mod:
style: |
ha-card {
margin-top: -40px;
margin-right: 10px;
text-align: right;
chips:
- type: entity
- entity: media_player.kitchen_echoshow
hide:
icon: true
runtime: true
source: true
power: true
state_label: true
volume: true
info: true
progress: true
controls: true
more_info: false
tts:
platform: alexa
toggle_power: false
group: true
card_mod:
style: |
ha-card {
card_mod:
style: |
ha-card {
{% if not is_state('media_player.kitchen_echoshow', 'standby') %}
background: rgba(var(--rgb-card-background-color), 0.5) url( '{{ state_attr( "media_player.kitchen_echoshow", "entity_picture" ) }}' ) center no-repeat;
- type: conditional
conditions:
state: bedroom
card:
cards:
layout_type: grid
layout:
"entity menu"
entity: media_player.bedroom_echo
view_layout:
grid-area: entity
grid-column-end: 3
media_controls:
- previous
- play_pause_stop
- next
tap_action:
action: toggle
card_mod:
style: |
ha-card {
alignment: end
view_layout:
grid-area: menu
card_mod:
style: |
ha-card {
margin-top: -40px;
margin-right: 10px;
text-align: right;
chips:
- type: entity
- entity: media_player.bedroom_echo
hide:
icon: true
runtime: true
source: true
power: true
state_label: true
volume: true
info: true
progress: true
controls: true
more_info: false
tts:
platform: alexa
toggle_power: false
group: true
card_mod:
style: |
ha-card {
card_mod:
style: |
ha-card {
{% if not is_state('media_player.bedroom_echo', 'standby') %}
background: rgba(var(--rgb-card-background-color), 0.5) url( '{{ state_attr( "media_player.bedroom_echo", "entity_picture" ) }}' ) center no-repeat;
- type: conditional
conditions:
state: living room
card:
cards:
layout_type: grid
layout:
"entity menu"
entity: media_player.livingroom_echo
view_layout:
grid-area: entity
grid-column-end: 3
media_controls:
- previous
- play_pause_stop
- next
tap_action:
action: toggle
card_mod:
style: |
ha-card {
alignment: end
view_layout:
grid-area: menu
card_mod:
style: |
ha-card {
margin-top: -40px;
margin-right: 10px;
text-align: right;
chips:
- type: entity
- entity: media_player.livingroom_echo
hide:
icon: true
runtime: true
source: true
power: true
state_label: true
volume: true
info: true
progress: true
controls: true
more_info: false
tts:
platform: alexa
toggle_power: false
group: true
card_mod:
style: |
ha-card {
card_mod:
style: |
ha-card {
{% if not is_state('media_player.livingroom_echo', 'standby') %}
background: rgba(var(--rgb-card-background-color), 0.5) url( '{{ state_attr( "media_player.livingroom_echo", "entity_picture" ) }}' ) center no-repeat;
sure for which part ? as I already put some cards here
in the meantime I created 2 new viewes, maybe someone is intereseted
first one is inspired by the card from other Polish forum, it was written based on the button cards, I;ve rearranged it to Mushroom:
it is it not ideal yet though
second is the pollution, here I;m yet struggling to change the background based on the pollution, but the rest is done
hello if it is possible the map of system would I like the config which is very nicely made ?
Youāve got a point re the dynamic list.
Possibly a combination of exclusion via exclude_states
(as this is exception reporting after all) and specific inclusions via id_filter
may provide the list Iām after.
From GitHub
id_filter (optional)
This is a regular expression for filtering persistent notifications by notification id. In the example above, "^home_feed_.*" will result in only notifications with ids starting with home_feed_ from being displayed.
Not really clear to me what this notification id
is - donāt see this being assigned in the examples. Logically though this would have to be part of a particular event/notificationā¦
More research neededā¦
Here is my card. Its 90% finished though. PS5 button need to set to grab sensor attributes and TV to grab selected mediaā¦ but I donāt know how to do it
mode: vertical
cards:
- type: horizontal-stack
cards:
- type: custom:mushroom-entity-card
entity: switch.plug_mediasystem
primary_info: name
tap_action:
action: toggle
icon: mdi:youtube-tv
icon_color: cyan
style: |
ha-card {
--chip-spacing: none;
--chip-height: 43px;
margin-top: 12px;
chips:
- type: entity
icon_color: yellow
entity: sensor.plug_mediasystem_power
alignment: center
style: |
ha-card {
margin-top: 12px;
chips:
- type: entity
icon_color: blue
entity: sensor.plug_mediasystem_energy
alignment: center
- type: conditional
conditions:
- entity: switch.plug_mediasystem
state: 'on'
card:
cards:
entity: media_player.tv
icon: mdi:television-box
media_controls: []
tap_action:
action: toggle
secondary_info: state
icon_type: icon
collapsible_controls: false
card_mod:
style: |
ha-card {
--rgb-state-media-player: var(--rgb-red)
entity: media_player.denon
media_controls: []
tap_action:
action: call-service
service: media_player.toggle
data: {}
device_id: 3533f012333423eaae9c51a8bd87ba87
card_mod:
style: |
ha-card {
--rgb-state-media-player: var(--rgb-green)
entity: switch.ps5_175_power
icon_color: blue
primary_info: name
tap_action:
action: toggle
- type: conditional
conditions:
state: 'on'
card:
media_controls:
- previous
- play_pause_stop
- next
volume_controls: []
secondary_info: none
primary_info: none
icon_type: none
tap_action:
action: toggle
- type: conditional
conditions:
state: 'on'
card:
volume_controls:
- volume_mute
- volume_set
- volume_buttons
primary_info: none
icon_type: none
card_mod:
style: |
ha-card {
Hi all,
in this card I have content: ā{{ states(entity) }}ā but iād show an attribute of entity (message). Can you help me please?
Can I use this syntax?
state_attr(ādevice_tracker.paulusā, ābatteryā)
I resolved
content: ā{{ state_attr(āācalendar.garbage_collectionāā, āāmessageāā) }}ā
very nice card thank you for sharing made it beautiful
Exactly what I was looking for. Thanks man. I knew their had to be a way to call media controls from different entities. Iāll play around with this tonight and see what I can come up with.
Have a look at the Universal Media Player. You can combine multiple Media Player Entities.
