Thank you so much - it IS simple, can you point me in the right direction of where i can reference this in the future or read from? be great to learn the different bits to pull together. Thank you
It may be a bit daunting, but have a look at the examples here. I try to provide ones that have the essential components and there are many other contributors. I find a good way to learn is to create a separate dashboard where you can create cards and figure out how it all works.
I am a bit confused by the new theme situation. For instance, do the Mushroom cards now respond to those new variables as well as the original mush-rgb ones (so I could use the āmushā ones to apply only to the Mushroom cards)? If I have used mush-rgb in my own theme, do I now have to change it to --rgb ones? And do all the other Mushroom variables still work in my own theme? And should I now remove
from my own theme, because those are now the HA defaults (there being no need for a default Mushroom theme any more). So many questions! Hope you can enlighten meā¦
If Iām understanding correctly, your chip is conditional and only shows up if the input_boolean.home is on, but in your screenshot the chip shows Away, how does that work?
No the Mushroom cards do not use the new variables yet. The --mush-rgb-<color> variables are used to override the default Mushroom colors but by defining them in your theme it allows you to use them in other cards. With the new --rgb-<color>-color variables we no longer need to do that. You can continue to use --mush-rgb-<color> or change to --rgb-<color>-color.
The Mushroom cards will work without any theme file, but if you want to change the defaults you can.
I just started with exploring the custom Mushroom Cards. But now I have seen the new Tile Card in Home Assistant I got the feeling that more Mushroom look-a-like cards will be introduced soon in standard Home Assistant.
So I started doubting if it is wise to migrate more of my dashboard screens to custom Mushroom or that it is better to wait a bit so that similar cards become available in standard Home Assistant.
Is my assumption correct? And if so where can I find roadmap/plans about upcoming front-end changes?
Card is slightly updated now (here). solarnet is the solar power going back into the grid (so after deduction of own use of solar). The bars are actual power consumption. Green area = solar power generated
I have a 2 sensors called sensor.gad_today and sensor.gad_tomorrow. They hold fixed values: None, gft, papier, pmd or restafval. In the ācustom button cardā I can change the image that is shown in the button based on the state (see code below).
I know want to transform this into a button that belongs to the look and feel of Mushroom, like the rest of my dash. So the mushroom āiconā should show an icon when value is non and use the pictures if any of the other states.
Probably can be done by a template but have not found one yet where an image is loaded. Help appreciated
