ffm777
(Carlo)
December 27, 2022, 5:38pm
4595
Is it possible to display conditional chips based on numerical conditions? The following code unfortunately does not work:
- type: conditional
conditions:
- entity: sensor.humidity_zimmer_hannah
condition: numeric_state
above: 70
chip:
type: entity
icon_color: red
tap_action:
action: none
content_info: none
icon: mdi:water-percent
Have a look at this card?
Viss
(Viss)
December 27, 2022, 10:28pm
4597
Is there a way to add secondary data to a mushroom fan card?
I have two āModern Formsā brand fans, and the integration will tell me which direction the fans are running, and Iād like to change their direction based on environmental conditions, so Iād like to have the fan direction displayed on the card.
I tried building my own fan card from scratch, but sadly mushroom cards dont let you easily take that nice spinning fan icon and use it in a mushroom template card, or use the fan/dimmer horizontal slider. Is there a way to do this, or am I out of luck unless mushroom cards get an update letting folks use those elements in template cards?
esr2
December 28, 2022, 4:29am
4598
Robbi-Ho
(Rob)
December 28, 2022, 8:07am
4601
You could try this:
{{ as_timestamp(states.binary_sensor.voordeur.last_changed) | timestamp_custom('%H %M',True) }}
Found at: Last_updated State and last-changed in Lovelave - #18 by weado
Thanks for your help.
I got it working now without the āexpander cardā.
now just use the mushroom cards.
CypherMK
December 28, 2022, 11:36am
4603
That worked. Can someone explain why this is not a standard option?
I made a couple remotes mostly using mushroom, stack-in, stack, and grid cards.
Iād like to make two more improvements if possible, so Iām seeking suggestions:
The navigation area with the arrows and select button would be better as a track pad style, but I cannot find a good card for that.
The volume works well for tapping, but Iād prefer a large slider style that would look and work like the mushroom light card dimmer control. I know I can customize one of the media player cards (core, mini, or mushroom), but (1) theyāre all horizontal and (2) theyāre all very thin and hard to see at a glance.
Any ideas?
douglasfl
(Douglas)
December 28, 2022, 1:13pm
4605
nice card!
Can you share te code?
so, Iām almost there with my car charging card.
One thing would freak me out - if the icon from the template card would sit in the left corner like in the picture below AND if the ping animation would work - as shown here:
Mushroom Cards - Build a beautiful dashboard easily š - #2925 by rhysb ?
I have already spent hours combining the various CSS ācommandsā - I just canāt get it combined.
No chance, maybe @rhysb still has an idea ?
arifroni
(Arif Roni)
December 28, 2022, 4:32pm
4607
I made this thermostat card with some controls. How can I make it glow around the border based on the thermostat status?
code:
- type: custom:vertical-stack-in-card
cards:
- type: custom:mushroom-climate-card
entity: climate.room_climate_office
icon: mdi:briefcase
fill_container: false
show_temperature_control: true
layout: horizontal
collapsible_controls: false
- type: horizontal-stack
cards:
entity: light.office_group_1
icon: mdi:ceiling-light
icon_color: |
{% if is_state('light.office_group_1', 'on') %}
yellow
disabled
tap_action:
action: toggle
primary: ''
layout: vertical
secondary: Lights1
badge_color: ''
entity: light.office_group_2
icon_color: |
{% if is_state('light.office_group_2', 'on') %}
yellow
disabled
tap_action:
action: toggle
primary: ''
layout: vertical
secondary: Lights2
primary: ''
secondary: >-
{% if is_state_attr('climate.room_climate_office', 'preset_mode',
'boost') %}
Boost ON
Boost OFF
icon: mdi:radiator
layout: vertical
tap_action:
action: call-service
service: script.climate_boost_toggle
climate_entity: climate.room_climate_office
target: {}
icon_color: >-
'boost') %}
red
disabled
primary: ''
secondary: |-
T: {{states('sensor.temperature_office')}}Ā°C
H: {{states('sensor.humidity_office')}}%
V: {{states('sensor.office_thermostat_valvetappet')}}%
icon: ''
layout: vertical
icon_color: ''
multiline_secondary: true
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
First of all thank you very much for sharing this code. I used it and it looks great!
I have an issue when i use 1 decimal for setting the temperature. The minus sign gets under the temperature and the layout is ruined. i tried altering the lettertype size but css not really my thing. Any suggestions would really be appreciated.
I tried this but nothing changed
cards:
- type: custom:simple-thermostat
style: |
ha-card {
--st-font-size-xl: 16px;
--st-font-size-m: 14px;
--st-font-size-title: 16px;
--st-font-size-sensors: 18px;
--st-spacing: 2px;
ha-card {
--st-spacing: 0px;
ha-card .current--value {
color: #ffffff;
header {
margin-bottom: 10px !important;
padding-bottom: 0px !important;
ha-card .thermostat-trigger {
color: #6f6f6f;
Full code:
type: custom:stack-in-card
keep:
margin: false
box_shadow: false
background: false
cards:
- type: grid
square: false
columns: 2
cards:
style: |
ha-card {
padding-bottom: 14px !important;
primary: Office
secondary: |
{{ state_attr('climate.office_thermostaat', 'hvac_action') }}
icon: |-
{% set mode = states('climate.office_thermostaat') %}
{% if mode == 'off' %}
mdi:power
{% elif mode == 'cool' %}
mdi:snowflake
{% elif mode == 'heat' %}
mdi:fire
{% elif mode == 'heat_cool' %}
mdi:autorenew
mdi:home-thermometer
icon_color: >-
{% set status = state_attr('climate.office_thermostaat','hvac_action')
{% if status == 'off' %}
grey
{% elif status == 'cooling' %}
blue
{% elif status == 'heating' %}
red
grey
tap_action: none
- type: vertical-stack
cards:
style: |
ha-card {
--st-spacing: 0px;
color: #ffffff;
header {
color: #6f6f6f;
entity: climate.office_thermostaat
header:
icon: false
decimals: '0'
fallback: 'Off'
hide:
temperature: true
state: true
layout:
mode:
names: false
icons: false
headings: false
step: row
step_size: '1'
control:
hvac:
'off': false
heat: false
cool: false
heat_cool: false
style: |
ha-card {
--st-font-size-toggle-label: 6px
--st-spacing: 0px;
--st-default-spacing: 0px;
--st-mode-background: #2d2d2d;
margin-left: 12px;
margin-right: 12px;
ha-card .mode-item.active.off {
background: #363636;
color: #9e9e9e;
ha-card .mode-item.active.cool {
background: #1d3447;
color: #2196f3;
ha-card .mode-item.active.heat {
background: #472421;
color: #f44336;
ha-card .mode-item.active.heat_cool {
background: #493516;
color: #ff9800;
ha-card .mode-item.active {
background: #263926;
color: #4caf50;
ha-card .mode-item.active:hover {
color: #9e9e9e;
ha-card .mode-item:hover {
color: #9e9e9e;
ha-card .mode-item {
--st-spacing: 10px;
border-radius: 10px;
ha-card .modes {
grid-gap: 12px
header: false
setpoints: false
hide:
temperature: true
state: true
layout:
mode:
headings: false
icons: true
names: false
step: row
control:
hvac:
'off':
heat:
cool:
heat_cool:
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0px;
--chip-padding: 0 0.2em
alignment: justify
chips:
- type: template
content: '{{state_attr(entity, ''current_temperature'')}} Ā°C'
icon: mdi:home-thermometer
tap_action:
action: more-info
icon_color: |-
{% set state=states(entity) %}
{% if state=='cool' %}
blue
{% elif state=='heat' %}
red
grey
style: |
ha-card {
margin-left: 6px;
- type: template
content: |
{{ state_attr(entity, 'fan_mode') }}
icon: mdi:fan
icon_color: green
tap_action: none
- type: template
double_tap_action:
action: none
content: '{{ states(entity) }}% '
entity: sensor.lumi_lumi_sens_humidity
icon: mdi:water
icon_color: blue
tap_action:
action: none
hold_action:
action: none
- type: template
icon: |-
{% if is_state(entity, 'off') %}
mdi:chevron-down
{% elif is_state(entity, 'on') %}
mdi:chevron-up
tap_action:
action: toggle
entity: input_boolean.thermostat_dropdown_office
icon_color: disabled
style: |
ha-card {
--chip-icon-size: 1em
- type: conditional
conditions:
- entity: input_boolean.thermostat_dropdown_office
state: 'on'
card:
keep:
margin: false
box_shadow: false
background: false
cards:
- type: grid
square: false
columns: 2
cards:
- type: custom:mushroom-entity-card
entity: sensor.19791209321807_outdoor_temperature
primary_info: state
secondary_info: name
icon_color: blue
style: |
ha-card {
--st-spacing: 0px;
--st-default-spacing: 1.6px;
margin-right: 12px;
color: #4caf50;
color: #9e9e9e;
color: #9e9e9e;
--st-spacing: 6px;
ha-card .modes {
grid-gap: 12px
entity: climate.werkkamer_airco
header: false
setpoints: false
hide:
temperature: true
state: true
layout:
mode:
headings: false
icons: true
names: false
step: row
control:
hvac:
'off': false
heat: false
cool: false
heat_cool: false
fan_only: false
dry: false
auto: false
fan:
LOW_MID: false
NATURE: false
MID_HIGH: false
MID:
icon: mdi:fan-speed-2
HIGH:
icon: mdi:fan-speed-3
Auto: false
LOW:
icon: mdi:fan-speed-1
- type: custom:mini-graph-card
entities:
- entity: sensor.lumi_lumi_sens_temperature
name: Inside Temperature
color: '#4caf50'
- entity: sensor.19791209321807_outdoor_temperature
name: Outside Temperature
color: '#2196f3'
y_axis: secondary
hours_to_show: 24
line_width: 3
font_size: 50
animate: true
show:
icon: false
state: false
legend: false
fill: fade
Screenshot_2022-12-28-17-30-46-51_40deb401b9ffe8e1df2f1cc5ba480b12|320x500
You did a great job here. Do you mind sending us the whole dashboard source config so we can reuse?
deeef
(Kristoffer)
December 28, 2022, 7:34pm
4610
In the picture from 7ahang that @piitaya lists as an inspiration, there is a ādevice countā under the āliving roomā title, and Iāve been wanting to make a similar count to use in my āroom cardsā.
Iāve tried to search and look through this whole thread (and others) but I havenāt found a way to do it yet.
Does anyone know if there is an easy way to do that?
I have a regular āareaā for all the devices, so I was hoping to just do some template area count.
bobboviking
(Andreas Tiandre)
December 28, 2022, 7:47pm
4611
Hi, a css style question. I would like to center bottom button but my css skills are failing me, anyone have a take? They are horizontally stacked, mushroom template cards (I have card mod etc installed). Been searching the forum and perhaps css god @rhysb could help?
Thanks in advance.
How can I make this only animate when its on?
features:
- type: light-brightness
type: tile
entity: light.master_bedroom_main_lights
icon: mdi:lightbulb-on
card_mod:
style:
ha-tile-icon$: |
ha-icon {
animation: illumination 1s infinite;
@keyframes illumination {
0%, 100% { clip-path: inset(0 0 0 0); }
80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
check this ā¦
animation:
{% if is_state('light.master_bedroom_main_lights', 'on') %}
Did you ever figure this one at? Iām at the same point right now.
nice man & can you share you code pleas ?
