Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
fantastic, sorry I missed that!
Agree - after a bit of fiddling I came up with this for lights. Thisā€™ll come in quite handy with the lot of door/window sensors I need to define in the dashboard. Thanks !!!
card:
  square: false
  type: grid
  columns: 3
card_param: cards
filter:
  include:
    - domain: light
      state: //
      options:
        type: custom:mushroom-light-card
        vertical: true
        tap_action:
          action: toggle
        double_tap_action:
          action: more-info
        card_mod: null
        style: |
          ha-card {
            {% set x = states(config.entity) %}
            --primary-text-color:
            {% if x == "on" %} black ;
            {% else %}         red;
            --secondary-text-color:
            {% if x == "on" %} blue ;
            {% else %}         magenta;
            background:
               {% if x == "on" %}
               lightgreen
               {% elif x == "off" %}
               white
               lightgrey
With massive help on that forum, I played with my fan cards and ended up with the following.
On the main dashboard screen, I have a simple fan card with a couple of presets and a gear icon that takes me to the detailed settings screen. There I can control not only the fan but also the associated automation and their thresholds.
The cards also have an animated glow effect around the icon to indicate if the automation is on and a double tab action to toggle it on/off.
Simple view
Code
type: custom:stack-in-card
cards:
  - type: custom:mushroom-fan-card
    entity: fan.whisper_flex
    icon_animation: true
    show_percentage_control: true
    collapsible_controls: true
    tap_action:
      action: call-service
      service: script.fan_on_off_with_automation
    hold_action:
      action: navigate
      navigation_path: /dashboard-mushroom/fan
    double_tap_action:
      action: navigate
    card_mod:
      style:
        mushroom-shape-icon$: |
          {% if is_state('input_boolean.auto_fan', 'on') %}
          .shape {
            --shape-animation: ping 5s infinite;
          @keyframes ping {
            0% {
              box-shadow: 0 0 5px 1px rgba(var(--rgb-blue), 0.7);
            100% {
              box-shadow: 0 0 5px 5px transparent;
          {% elif is_state('input_boolean.auto_fan', 'off') %}
    chips:
      - type: entity
        entity: scene.fan_15
        icon_color: null
        icon: mdi:fan-speed-2
        content_info: none
        tap_action:
          service: script.fan_15
        card_mod:
          style: |
            ha-card {
              --chip-background: rgba(var({{ '--rgb-red' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
              --icon-color: rgb(var(--rgb-disabled));
      - type: entity
        entity: scene.fan_20
        icon_color: null
        icon: mdi:fan-speed-3
        content_info: none
        tap_action:
          service: script.fan_20
        card_mod:
          style: |
            ha-card {
              --chip-background: rgba(var({{ '--rgb-green' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
      - type: entity
        icon_color: blue
        icon: mdi:cog
        content_info: none
        tap_action:
          action: navigate
        card_mod:
          style: |
            ha-card {
              --chip-background: rgba(var({{ '--rgb-purple' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
    card_mod:
      style: |
        ha-card {
            --chip-box-shadow: none;
            top: 16px;
            width: -webkit-fill-available;
            right: 12px;
            position: absolute;
        .chip-container {
            right: 0px;
            position: absolute;
Detailed view
Code
cards:
#Main fan card
    collapsible_controls: false
    tap_action:
    hold_action:
      action: navigate
    card_mod:
      style:
          .shape {
          @keyframes ping {
            0% {
            100% {
#Chips with presets
    chips:
      - type: entity
        icon_color: null
        content_info: none
        tap_action:
        card_mod:
          style: |
            ha-card {
      - type: entity
        icon_color: null
        content_info: none
        tap_action:
        card_mod:
          style: |
            ha-card {
    card_mod:
      style: |
        ha-card {
            margin: 0px 12px 0px;
            top: 16px;
            right: 12px;
            position: absolute;
        .chip-container {
            right: 0px;
            position: absolute;
#Header for Mode control
  - type: custom:mushroom-title-card
    subtitle: Mode
    card_mod:
      style: |
        ha-card {
          margin: -12px 0px 0px;
#Mode control
  - type: horizontal-stack
    cards:
        chips:
          - type: template
            tap_action:
              service: fan.set_preset_mode
                preset_mode: nature
                entity_id: fan.whisper_flex
            icon: mdi:forest
            content: Nature
            card_mod:
              style: |
                ha-card {
                  justify-content: center;
                  {% if is_state('fan.whisper_flex', 'off') and is_state_attr('fan.whisper_flex','preset_mode','nature') %}
                    --chip-background: rgba(var(--rgb-disabled), 0.7);
                  {% elif is_state_attr('fan.whisper_flex','preset_mode','nature') %}
                    --chip-background: rgba(var(--rgb-green), 0.7);
                    --chip-background: inherit;  # set it to the default or whatever color you want
          - type: template
            tap_action:
                preset_mode: sleep
            icon: mdi:power-sleep
            content: Sleep
            card_mod:
              style: |
                ha-card {
                  {% if is_state('fan.whisper_flex', 'off') and is_state_attr('fan.whisper_flex','preset_mode','sleep') %}
                  {% elif is_state_attr('fan.whisper_flex','preset_mode','sleep') %}
          - type: template
            tap_action:
                preset_mode: smart
            icon: mdi:fan
            content: Smart
            card_mod:
              style: |
                ha-card {
                  {% if is_state('fan.whisper_flex', 'off') and is_state_attr('fan.whisper_flex','preset_mode','smart') %}
                  {% elif is_state_attr('fan.whisper_flex','preset_mode','smart') %}
        alignment: Center
        card_mod:
          style: |
            mushroom-template-chip {
              width: 100%;
            div.chip-container {
              justify-content: space-evenly;
              flex-wrap: nowrap;
            ha-card {
              margin: -15px 12px 0px;
              --chip-background: rgba(var(--rgb-disabled), 0.15);
              --chip-border-radius: 10px;
              --chip-height: 42px;
              --chip-padding:10px;
#Header for Oscillation control
    subtitle: Oscillation and Timer
    card_mod:
      style: |
        ha-card {
          margin: 0px 0px 0px;
#Oscillation control
    cards:
        chips:
          - type: template
            entity: switch.whisper_flex_horizontal_oscilation
            tap_action:
              service: switch.toggle
                entity_id: switch.whisper_flex_horizontal_oscilation
            icon: mdi:pan-horizontal
            content: Horizontal
            card_mod:
              style: |
                ha-card {
                  {% if is_state('fan.whisper_flex', 'off') and is_state('switch.whisper_flex_horizontal_oscilation','on') %}
                  {% elif is_state('switch.whisper_flex_horizontal_oscilation','on') %}
          - type: template
            entity: switch.whisper_flex_vertical_oscilation
            tap_action:
                entity_id: switch.whisper_flex_vertical_oscilation
            icon: mdi:pan-vertical
            content: Vertical
            card_mod:
              style: |
                ha-card {
                  {% if is_state('fan.whisper_flex', 'off') and is_state('switch.whisper_flex_vertical_oscilation','on') %}
                  {% elif is_state('switch.whisper_flex_vertical_oscilation','on') %}
          - type: template
            entity: select.whisper_flex_countdown
            tap_action:
              action: more-info
            icon: mdi:timer-sand-complete
            content: '{{states(''select.whisper_flex_countdown'') }} hours'
            card_mod:
              style: |
                ha-card {
        alignment: Center
        card_mod:
          style: |
              width: 100%;
              flex-wrap: nowrap;
            ha-card {
              margin: -15px 12px 12px;
I had some trouble modifying the spacing before and after the title card but I somehow managed although it is probably not the cleanest approach
ha-card {
Please can someone help, I am trying to stop popups on my phone from taking the full screen, I have created this very small test popup and it works fine on my desktop but when opened on my phone its still full screen;
desktop:
phone:
action: fire-dom-event
browser_mod:
  service: browser_mod.popup
    title: Test Popup
    style: |
      --popup-min-width: 200px;
      --popup-max-width: 290px;
      --popup-border-width: var(--ha-card-border-width, 2px);
      --popup-border-color: var(--ha-card-border-color, var(--divider-color, #eee));
      --popup-border-radius: 28px;
      --popup-background-color: var(--ha-card-background, var(--card-background-color, white));
      --popup-padding-x: 0px;
      --popup-padding-y: 0px;
    content:
        type: entity
        entity: binary_sensor.garage_door
Hoping someone can help me with this oneā€¦ Iā€™m trying to call the service input_select.select_option while using jinja2 in the option field.
The following code is working perfectly in the dev tools
service: input_select.select_option
  entity_id: input_select.home_mode
  option: |
    {{'Thuis' if states('input_select.home_mode') == 'Hold' else 'Hold'}}
But for some reason it doesnā€™t work inside the mushroom template card
  - type: template
    icon: mdi:walk
    content: '{{ states(''input_select.home_mode'') }}'
    tap_action:
        option: |
When I press the card it gives me an error
This is not the right place to ask this question. Take it to the browser mod page. This question has nothing to do with mushroom cards.
FYI its a known bug if you looked at just a few recent posts on the right page.
Hello everyone, tell me, maybe someone has examples of flower cards.
Sorry for a delayed reply. I am posting my code below for this card. However, I feel that if you change the setting of your theme to Mushroom Shadow on the viewing device, your line problem may go away.
mode: vertical
cards:
    primary: Kitchen
    secondary: šŸŒ”{{ states('sensor.kitchen_temperature') }}Ā°C
    icon: mdi:countertop
    icon_color: |-
      {% set state=states('light.kitchen_cabinet_lights') %}
      {% if state=='on' %}
      green
      {% elif state=='off' %}
      grey
      grey
    layout: horizontal
    multiline_secondary: false
    tap_action:
      action: navigate
      navigation_path: /dashboard-cards/kitchen
    hold_action:
      action: none
    double_tap_action:
      action: none
    style: |
      :host([dark-mode]) {
        background: rgba(var(--rgb-primary-background-color), 0.2);
      :host {
        background: rgba(var(--rgb-primary-text-color), 0.025);
    style: |
      ha-card {
        --chip-background: none;
        --chip-spacing: 0;
    alignment: end
    chips:
      - type: conditional
        conditions:
          - entity: light.kitchen_cabinet_lights
            state: 'on'
        chip:
          type: entity
          icon_color: amber
          tap_action:
            service: light.turn_off
            service_data: {}
              entity_id: light.kitchen_cabinet_lights
          content_info: none
          icon: mdi:lightbulb
      - type: conditional
        conditions:
          - entity: switch.fridge
            state: 'on'
        chip:
          type: entity
          icon_color: red
          tap_action:
            service: switch.turn_off
            service_data: {}
              entity_id: switch.fridge
          content_info: none
          icon: mdi:fridge-variant
      - type: conditional
        conditions:
          - entity: switch.deep_freezer
            state: 'on'
        chip:
          type: entity
          icon_color: deep-purple
          tap_action:
            service_data: {}
              entity_id: switch.deep_freezer
          content_info: none
          icon: mdi:treasure-chest
      - type: conditional
        conditions:
          - entity: fan.kitchen_exhaust_fan
            state: 'on'
        chip:
          type: entity
          icon_color: green
          card_mod: null
          style: |
            @keyframes rotation {
              0% {
                transform: rotate(0deg);
              100% {
                transform: rotate(360deg);
            ha-card {
              animation: rotation linear infinite;
              {% if states('fan.kitchen_exhaust_fan') == 'on' %}
               animation-duration: 1s;
              {%- else -%}
              {%- endif %}
          tap_action:
            service: fan.turn_off
            service_data: {}
              entity_id: fan.kitchen_exhaust_fan
          content_info: none
          icon: mdi:fan
style: |
  ha-card {
    height: 100px;
    {% if is_state('light.kitchen_cabinet_lights', 'on') %}
       background: rgba(255, 152, 0, 0.1);
view_layout:
  grid-area: cen4
card_mod:
  style: |
    ha-card {
      background: none !important;
      {% if states('light.kitchen_cabinet_lights') == 'on' %}
      box-shadow: 0px 0px 5px 5px #56DD3F !important;
but I still donā€™t understand how these conditional cards work? ID card where do I get it? :frowning:
Anyone know how to change the size of the font when casting? My Google Hub seems to ignore any of the font stuff.
I have problem with animated icon on mushroom chips card. I instaled car mod but I affraid it doesnā€™t work correctly. Every time when I put some animated code nothings happend. I havenā€™t expirience of CSS. Mny thanks for help. I enclose code. Please help.
Hi @MarcinGuc and welcome to the forum!
I encourage you to read this post:
If anyone has been wondering how to create a template card for controlling a fan, including sliding speed control, hereā€™s an example.
cards:
#Template card with all its capabilities available
    primary: Cooling Fan
    icon: mdi:fan
    tap_action:
      action: toggle
#Fan card stripped of all unnecessary components through configuration
    icon_type: none
    primary_info: none
    secondary_info: none
    show_oscillate_control: true
#Car mod to manage the spacing between the two cards
    card_mod:
      style: |
        ha-card {
          padding-top: 0px !important;
        {% if is_state('fan.whisper_flex', 'off') %}
          padding-bottom: 0px !important;
If you set collapsible_controls: false then use this for card_mod instead
    card_mod:
      style: |
        ha-card {
Here is my idea for a vacuum control card.
It consists of two cards
  • Main vacuum controls
    • Presets for most frequent segments cleaning
    • Cogwheel to navigate to another view where I manage other vacuum settings
    • Play button to clean all house
    • List play for segments selected on the next card
  • Segment selector
    • Buttons to select segments for cleaning
    • A long tap on the button initiates individual segment cleaning
I also utilize the swipe card to navigate between the two cards on the dashboard.
RPReplay_Final1693513690
Code
type: custom:swipe-card
cards:
#Main control card
  - type: custom:stack-in-card
    cards:
#Card icon and name
        primary: Roborock
        secondary: '{{ states("sensor.roborock_s7_status") | title }}'
        icon: mdi:robot-vacuum
        icon_color: |-
          {% if not is_state('vacuum.roborock_s7_2', 'docked') %}
            amber
          {% elif is_state('input_boolean.vacuum_auto_start', 'on') %}
            blue
            disabled
        entity: vacuum.roborock_s7_2
        badge_icon: |-
          {% if is_state('input_boolean.vacuum_auto_start', 'on') %}
            mdi:home-automation
          {% elif is_state('input_boolean.vacuum_auto_start', 'off') %}
        badge_color: |-
            blue
        tap_action:
          action: navigate
          navigation_path: /dashboard-mushroom/vacuum
        double_tap_action:
          service: input_boolean.toggle
          data: {}
            entity_id: input_boolean.vacuum_auto_start
        hold_action:
          action: navigate
#Presets
        chips:
          - type: entity
            icon_color: white
            icon: mdi:hanger
            content_info: none
            tap_action:
              service: vacuum.send_command
                command: app_segment_clean
                params:
                  - segments:
                      - 16
                    repeat: '{{ states(''input_number.vacuum_repeat_count'') | int }}'
                entity_id: vacuum.roborock_s7_2
            card_mod:
              style: |
                ha-card {
          - type: entity
            icon_color: white
            icon: mdi:chef-hat
            content_info: none
            tap_action:
                params:
                  - segments:
                      - 22
            card_mod:
              style: |
                ha-card {
          - type: entity
            icon_color: blue
            icon: mdi:cog
            content_info: none
            tap_action:
              action: navigate
            card_mod:
              style: |
                ha-card {
        card_mod:
          style: |
            ha-card {
                top: 16px;
                right: 12px;
                position: absolute;
            .chip-container {
                right: 0px;
                position: absolute;
#Control buttons
        chips:
          - type: template
            tap_action:
              service: vacuum.start
            icon: mdi:play
            content: null
            card_mod:
              style: |
                ha-card {justify-content: center;}
          - type: template
            tap_action:
              service: script.vacuum_selected_rooms
            icon: mdi:playlist-check
            content: null
            card_mod:
              style: |
          - type: template
            tap_action:
              service: vacuum.pause
            icon: mdi:pause
            content: null
            card_mod:
              style: |
          - type: template
            tap_action:
              service: vacuum.return_to_base
            icon: mdi:home-map-marker
            content: null
            card_mod:
              style: |
        alignment: Center
        card_mod:
          style: |
              width: 100%;
              flex-wrap: nowrap;
            ha-card {
              margin: 0px 12px 12px;
#Segment selector card
    cards:
#First row of buttons
        cards:
            chips:
              - type: template
                entity: input_boolean.vacuum_bathroom
                tap_action:
                    entity_id: input_boolean.vacuum_bathroom
                hold_action:
                    params:
                      - segments:
                          - 24
                icon: null
                content: Bathroom
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_bathroom', 'on') %}
                        --chip-background: rgba(var(--rgb-blue), 0.7);
              - type: template
                entity: input_boolean.vacuum_bedroom
                tap_action:
                    entity_id: input_boolean.vacuum_bedroom
                hold_action:
                    params:
                      - segments:
                          - 19
                icon: null
                content: Bedroom
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_bedroom', 'on') %}
              - type: template
                entity: input_boolean.vacuum_hallway
                tap_action:
                    entity_id: input_boolean.vacuum_hallway
                hold_action:
                    params:
                      - segments:
                          - 16
                icon: null
                content: Hallway
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_hallway', 'on') %}
              - type: template
                entity: input_boolean.vacuum_kitchen
                tap_action:
                    entity_id: input_boolean.vacuum_kitchen
                hold_action:
                    params:
                      - segments:
                          - 22
                icon: null
                content: Kitchen
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_kitchen', 'on') %}
            alignment: Center
            card_mod:
              style: |
                  width: 100%;
                  flex-wrap: nowrap;
                ha-card {
                  margin: 12px 12px 12px;
#Second row of buttons
        cards:
            chips:
              - type: template
                entity: input_boolean.vacuum_living_room
                tap_action:
                    entity_id: input_boolean.vacuum_living_room
                hold_action:
                    params:
                      - segments:
                          - 23
                icon: null
                content: Living Room
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_living_room', 'on') %}
              - type: template
                entity: input_boolean.vacuum_technical
                tap_action:
                    entity_id: input_boolean.vacuum_technical
                hold_action:
                    params:
                      - segments:
                          - 18
                icon: null
                content: Technical
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_technical', 'on') %}
              - type: template
                entity: input_boolean.vacuum_toilet
                tap_action:
                    entity_id: input_boolean.vacuum_toilet
                hold_action:
                    params:
                      - segments:
                          - 17
                icon: null
                content: Toilet
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_toilet', 'on') %}
              - type: template
                entity: input_boolean.vacuum_veronika_room
                tap_action:
                    entity_id: input_boolean.vacuum_veronika_room
                hold_action:
                    params:
                      - segments:
                          - 20
                icon: null
                content: Veronika
                card_mod:
                  style: |
                    ha-card {
                      {% if is_state('input_boolean.vacuum_veronika_room', 'on') %}
            alignment: Center
            card_mod:
              style: |
                  width: 100%;
                  flex-wrap: nowrap;
                ha-card {
Looks good!
Post your finished cards here btw :slight_smile:
Hey there! Can anyone help with combining all the smart outlets of a particular selected room into one card, with the ability to disable all outlets by pressing just one card? Thanks!!!
Has anyone successfully managed to make a sticky bottom navbar like this from minimalist? Iā€™ve seen a few posts in this massive thread but theyā€™re often not in a finished state and have a few bugs related. Iā€™d love to see some inspiration, and the code!
Hi guys,
I hope you can help me or guide me in the right direction. I created the following dashboard mainly using mushroom cards. My main idea is that I get only shown the minimum information to have an overview what is going on currently in my house. By clicking on the entity card I get more detailed information for each floor.
On the left side you see how the dashboard currently looks like. Every floor is created with an entity card and several chip cards that are only shown if they have a certain status. Otherwise they remain hidden not to overblow the view.
On the right side you find the dashboard how I would like it to look like. Basically every chip card gets a ā€œheaderā€ or ā€œtitleā€. I tried to realize it by stacking a markdown card and a chip card together. But then I can not use it as a chip card anymore. So how do I horizontally stack them aligned at the end.
Thanks for your help.
I was planning to have a look at that too:) Did you try this Mushroom Cards - Build a beautiful dashboard easily šŸ„ - #7023 by Guizmos
I have dropped a random card to my dashboard, applied the card mod and it worksā€¦but I have an issue with the position of the card. It seems like the further down you place the card (order-wise) the further on top it is placed but some of the cards are still further on top.
RPReplay_Final1693569913
i think it is likely to do with your z-index: in card-mod. you can try and set your other cards to z-index: 0; and then having your sticky card by z-index: 1? that might work.
