Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Is there any code that allows you to make a space in this part (marked with an arrow)
You can use the “custom:gap-card” for this.
type: custom:gap-card
height: 5
hello i have this card for my spotify now it shows the spotify icon that blinks when not playing and i would like it to show color red is that possible ?
type: custom:mushroom-media-player-card
entity: media_player.spotify_jarne_roussard
media_controls:
  - on_off
  - previous
  - play_pause_stop
  - next
  - shuffle
  - repeat
use_media_info: false
show_volume_level: true
volume_controls: []
layout: vertical
tap_action:
  action: call-service
  service: script.g
  data: {}
  target: {}
double_tap_action:
  service: script.gv
  data: {}
  target: {}
card_mod:
  style: |
    mushroom-shape-icon {
      display: flex;
      {% set media_type = state_attr(config.entity, 'media_content_type') %}
      {% if media_type == 'music' %}
        --card-mod-icon: mdi:spotify;
        animation: flicker 1s linear infinite alternate;
      {% else %}
        --icon-color-disabled: rgb(var(--rgb-red));
        --shape-color-disabled: rgba(var(--rgb-red), 0.2);
      {% endif %}
    @keyframes flicker {
      0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-green), 1); }
      32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-green), 0.6); }
    @keyframes beat {
      0%, 60% { --icon-symbol-size: 21px; }
      5%, 17%, 57% { --icon-symbol-size: 22px; }
      10%, 20%, 51% { --icon-symbol-size: 23px; }
      25%, 45% { --icon-symbol-size: 24px; }
      30%, 39% { --icon-symbol-size: 25px; }
      33% { --icon-symbol-size: 26px; }
    ha-card {
      {% if not is_state(config.entity, 'inactief') %}
        background: rgba(var(--rgb-card-background-color), 0.6) url( '{{ state_attr(config.entity, "entity_picture") }}' ) center no-repeat;
        background-size: cover;
        background-blend-mode: overlay;
      {% endif %}
I have a small question.
Is there a way to get a batch icon on the icon from the mushroom-cover-card?
Basti
Thank you very much for the tip
how are you tracking your d/load & u/load totals?
Did you get this resolved, I have the same problem and not sure how to proceed
@rhysb Following up on this, any thoughts?
Hi, thank you very much for your wondeful work.
when you have time can you please add ‘mdi:thermostat’ and ‘mdi:solar-power-variant( sun turns while the panel stays)’.
thank you.
maybe this helps: Lovelace: Migrate from storage to yaml mode - Configuration / Frontend - Home Assistant Community (home-assistant.io)
Mushroom Animations :mushroom: - Part 4
Even More Mushroom Card Icon Animations
Mushroom HA Animation
HA Animation
type: custom:mushroom-template-card
icon: mdi:home-assistant
icon_color: blue
primary: Home Assistant
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon {
        --icon-animation: boing 3s ease infinite;
        transform-origin: 50% 90%;
      @keyframes boing {
        0% { transform: scale3d(1, 1, 1); }
        7% { transform: scale3d(1.25, 0.75, 1); }
        10% { transform: scale3d(0.75, 1.25, 1); }
        12% { transform: scale3d(1.15, 0.85, 1); }
        16% { transform: scale3d(0.95, 1.05, 1); }
        19% { transform: scale3d(1.05, 0.95, 1); }
        25% { transform: scale3d(1, 1, 1); }
Mushroom Surprise Animation
Surprise Animation
icon: mdi:gift
icon_color: deep-orange
primary: Surprise
card_mod:
  style:
      ha-icon {
        --icon-animation: surprise 3s ease infinite;
      @keyframes surprise {
        0%, 20%, 100% { transform: translateY(0); }
        2.5% { transform: translateY(-6px) rotate(-14deg); }
        5% { transform: translateY(-6px) rotate(11deg); }
        7.5% { transform: translateY(-6px) rotate(-8deg); }
        10% { transform: translateY(-6px) rotate(5deg); }
        12.5% { transform: translateY(0); }
        15% { transform: translateY(-3px) }
Mushroom Ring Animation
Ring Animation
type: custom:stack-in-card
cards:
    icon: mdi:phone-classic
    icon_color: light-green
    primary: Ring
    card_mod:
      style:
          ha-icon {
            clip-path: polygon(0 100%, 100% 100%, 100% 67%, 66% 39%, 66% 25%, 34% 25%, 34% 40%, 0 68%);
    icon: mdi:phone-hangup
    card_mod:
      style:
          ha-icon {
            --icon-animation: ring 1s ease infinite;
          @keyframes ring {
            0%, 50%, 80%, 100% { transform: translateY(0); }
            10% { transform: translateY(-4px) rotate(-27deg); }
            20% { transform: translateY(-4px) rotate(21deg); }
            30% { transform: translateY(-4px) rotate(-15deg); }
            40% { transform: translateY(-4px) rotate(9deg); }
            60% { transform: translateY(-2.4px); }
          .shape {
            --shape-color: none;
            top: -4px;
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Marker Animation
Marker Animation
icon: mdi:map-marker
icon_color: red
primary: Marker
card_mod:
  style:
      ha-icon {
      @keyframes boing {
        7% { transform: translateY(-4px) scale3d(0.75, 1.25, 1); }
        10% { transform: scale3d(1.25, 0.75, 1); }
        12% { transform: translateY(-2px) scale3d(0.85, 1.15, 1); }
        16% { transform: scale3d(1.05, 0.95, 1); }
        19% { transform: scale3d(0.95, 1.05, 1); }
Mushroom Beat Animation
Beat Animation
primary: Beat
icon: mdi:speaker
icon_color: blue
card_mod:
  style:
      .shape {
        --icon-animation: beat 1.3s ease-out infinite both;
        transform-origin: 50% 60%;
      @keyframes beat {
        0% { transform: scale(1); }
        10% { transform: scale(1.1); }
        17% { transform: scale(1.05); }
        33% { transform: scale(1.25); }
        60% { transform: scale(1); }
Mushroom Door Animation
Door Animation
icon: mdi:door
icon_color: brown
primary: Door
card_mod:
  style:
      ha-icon {
        --icon-animation: open 6s ease-in-out infinite;
        transform-origin: 30%;
      @keyframes open {
        0%, 66% { transform: rotateY(0deg); }
        33% { transform: rotateY(-120deg); }
      .shape {
        perspective: 45px;
Mushroom Bounce Animation
Bounce Animation
icon: mdi:tennis-ball
icon_color: amber
primary: Bounce
card_mod:
  style:
      ha-icon {
        --icon-animation: bounce 0.6s cubic-bezier(0.30, 2.40, 0.85, 2.50) infinite;
        transform-origin: 50% 100%;
      @keyframes bounce {
        0%, 100% { transform: translateY(0px) scaleY(0.9); }
        80% { transform: translateY(-3px); }
Mushroom Ghost Animation
Ghost Animation
primary: Ghost
icon: mdi:ghost-outline
icon_color: grey
card_mod:
  style:
      ha-icon {
        --icon-animation: drift 10s ease-in-out infinite, blink 4s infinite;
      @keyframes drift {
        0%, 100% { transform: translate(3px, 0px); }
        30% { transform: translate(-1px, 2px); }
        45% { transform: translate(1.5px, 0px); }
        75% { transform: translate(-3.2px, -3px); }
      @keyframes blink {
        0%, 24%, 35%, 74%, 85%, 100% { clip-path: inset(0 0 0 0); }
        25% { clip-path: polygon(0 0, 0 100%, 100% 100%, 100% 53%, 25% 52%, 27% 31%, 49% 31%, 49% 54%, 100% 54%, 100% 0); }
        75%  { clip-path: polygon(0 0, 0 100%, 100% 100%, 100% 53%, 49% 51%, 52% 30%, 73% 31%, 75% 52%, 100% 54%, 100% 0); }
Mushroom Ducky Animation
Ducky Animation
primary: Rubber Ducky
icon: mdi:duck
icon_color: amber
card_mod:
  style:
      ha-icon {
        --icon-animation: ducky 2s ease-in-out infinite;
        transform-origin: 50% 75%;
      @keyframes ducky {
        0%, 100% { transform: rotate(-15deg); }
        50% { transform: rotate(15deg); }
Mushroom Robot Animation
Robot Animation
primary: Robot
icon: mdi:robot-outline
icon_color: deep-purple
card_mod:
  style:
      ha-icon {
        --icon-animation: tilt 4s steps(1) infinite, blink 4s infinite;
        transform-origin: 50% 92%;
      @keyframes tilt {
        0%, 100% { transform: rotate(0deg); }
        33% { transform: rotate(8deg); }
        66% { transform: rotate(-8deg); }
      @keyframes blink {
        0%, 20%, 30%, 45%, 55%, 70%, 80%, 100% { clip-path: inset(0 0 0 0); }
        25% { clip-path: polygon(0 0, 100% 0, 100% 53%, 25% 52%, 24% 77%, 75% 77%, 76% 52%, 100% 52%, 100% 100%, 0 100%); }
        50%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 51% 54%, 51% 76%, 76% 77%, 75% 53%, 100% 52%, 100% 100%, 0 100%); }
        75%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 24% 53%, 24% 77%, 47% 77%, 47% 52%, 100% 52%, 100% 100%, 0 100%); }
Mushroom Coffee Machine Animation
icon: mdi:coffee-maker
icon_color: brown
primary: Coffee Machine
card_mod:
  style:
      ha-icon {
        --icon-animation: java 4s linear infinite;
      @keyframes java {
        0%, 80%, 100% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 0 100%); }
        10% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 79%, 63% 76%, 67% 70%, 66% 54%, 42% 55%, 42% 70%, 47% 77%, 55% 80%, 57% 100%, 0 100%); }
        15% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 79%, 63% 76%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 47% 77%, 55% 80%, 55% 100%, 0 100%); }
        20% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 76%, 63% 76%, 67% 70%, 66% 54%, 42% 55%, 42% 70%, 47% 76%, 55% 76%, 57% 100%, 0 100%); }
        25% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 76%, 63% 76%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 47% 76%, 55% 76%, 56% 100%, 0 100%); }
        30% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 73%, 64% 73%, 66% 70%, 66% 55%, 42% 55%, 42% 69%, 44% 73%, 55% 73%, 57% 100%, 0 100%); }
        35% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 73%, 64% 73%, 66% 70%, 66% 55%, 42% 54%, 42% 69%, 44% 73%, 55% 73%, 56% 100%, 0 100%); }
        40% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 70%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 57% 70%, 57% 100%, 0 100%); }
        45% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 70%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 55% 70%, 56% 100%, 0 100%); }
        50% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 66%, 67% 65%, 66% 54%, 42% 54%, 42% 65%, 57% 65%, 57% 100%, 0 100%); }
        55% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 66%, 67% 65%, 66% 54%, 42% 54%, 42% 65%, 55% 65%, 56% 100%, 0 100%); }
        60% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 60%, 66% 60%, 66% 54%, 42% 54%, 42% 60%, 57% 60%, 57% 100%, 0 100%); }
        65% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 60%, 66% 60%, 66% 54%, 42% 54%, 42% 60%, 55% 60%, 56% 100%, 0 100%); }
        70% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 56%, 66% 56%, 66% 54%, 42% 54%, 42% 56%, 57% 56%, 57% 100%, 0 100%); }
        75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 56%, 66% 56%, 66% 54%, 42% 54%, 42% 56%, 55% 56%, 55% 100%, 0 100%); }
Mushroom Apple Animation
Apple Animation
primary: Apple
icon: mdi:food-apple
icon_color: green
card_mod:
  style:
      ha-icon {
        --icon-animation: bite 4s infinite;
      @keyframes bite {
        0%, 19%, 100% { clip-path: inset(0 0 0 0); }
        20%, 39% { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 69% 62%, 74% 66%, 74% 66%, 79% 70%, 100% 75%, 100% 100%, 0 100%); }
        40%, 59%  { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 63% 60%, 61% 66%, 59% 72%, 61% 79%, 63% 85%, 66% 91%, 76% 100%, 0 100%); }
        60%, 79%  { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 63% 60%, 61% 66%, 59% 72%, 61% 79%, 63% 85%, 66% 91%, 76% 100%, 0 100%, 0 84%, 23% 75%, 29% 71%, 33% 66%, 35% 59%, 35% 52%, 34% 45%, 29% 40%, 23% 35%, 0 27%); }
        80%, 99%  { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 63% 60%, 61% 66%, 59% 72%, 61% 79%, 63% 85%, 66% 91%, 76% 100%, 0 100%, 32% 88%, 37% 83%, 39% 76%, 39% 67%, 35% 59%, 35% 52%, 34% 45%, 29% 40%, 23% 35%, 0 27%); }
Mushroom Memory Animation
Memory Animation
primary: Memory
icon: mdi:memory
icon_color: orange
card_mod:
  style:
      ha-icon {
        --icon-animation: bit 250ms infinite;
      @keyframes bit {
        50% { clip-path: polygon(0% 0%, 0% 100%, 29% 100%, 30% 30%, 70% 30%, 70% 70%, 29% 70%, 29% 100%, 100% 100%, 100% 0%); }
Mushroom Pump Animation
Pump Animation
primary: Pump
icon: mdi:water-pump
icon_color: light-blue
card_mod:
  style:
      ha-icon {
        --icon-animation: drip 2s infinite;
      @keyframes drip {
        15%, 85% { clip-path: polygon(0 0, 100% 0, 100% 57%, 64% 57%, 64% 100%, 0 100%); }
Mushroom Power Animation
Power Animation
primary: Power
icon: mdi:power
icon_color: teal
card_mod:
  style:
      ha-icon {
        --icon-animation: power 1.5s infinite;
      @keyframes power {
        50% { clip-path: polygon(0 0, 42% 0, 42% 58%, 58% 58%, 58% 0, 100% 0, 100% 100%, 0 100%); }
Mushroom Garage Animation
Garage Animation
primary: Garage
icon: mdi:garage
icon_color: amber
card_mod:
  style:
      ha-icon {
        --icon-animation: door 3s steps(1) infinite alternate;
      @keyframes door {
        25%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 73%, 32% 73%, 31% 100%, 0 100%); }
        50%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 61%, 32% 61%, 31% 100%, 0 100%); }
        75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 48%, 32% 48%, 31% 100%, 0 100%); }
Mushroom Coffee Animation
Coffee Animation
cards:
    icon: mdi:coffee
    icon_color: brown
    primary: Coffee
    card_mod:
      style:
          ha-icon {
            transform: scaleY(0.8);
    icon: mdi:pot-steam
    icon_color: brown
    card_mod:
      style:
          ha-icon {
            --icon-animation: steam 2s ease-in infinite;
            clip-path: inset(0 0 61% 0);
          @keyframes steam {
            0%, 100% { opacity: 1; }
            80% { opacity: 0; }
          .shape {
            top: -2px;
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Auto Fix Animation
Auto Fix Animation
icon: mdi:auto-fix
icon_color: cyan
primary: Auto Fix
card_mod:
  style:
      ha-icon {
        --icon-animation: sparkle 1.8s linear infinite, kadabra 1.8s ease-in-out infinite;
       transform-origin: 10% 90%
      @keyframes sparkle {
        0%, 69%, 74%, 79%, 85% { clip-path: inset(0 0 0 0); }
        70% { clip-path: polygon(0 100%, 0 76%, 75% 0, 100% 0, 100% 100%); }
        75% { clip-path: polygon(0 100%, 0 0, 39% 0, 100% 62%, 100% 100%); }
        80% { clip-path: polygon(0 100%, 0 0, 100% 0, 100% 26%, 25% 100%); }
      @keyframes kadabra {
        0%, 65%, 100% { transform: rotate(-15deg); }
        70% { transform: rotate(20deg); }
        75% { transform: rotate(15deg); }
        80% { transform: rotate(25deg); }
Mushroom Grinder Animation
Grinder Animation
icon: mdi:blender
icon_color: orange
primary: Grinder
card_mod:
  style:
      ha-icon {
        --icon-animation: shake 400ms ease-in-out infinite;
        clip-path: polygon(24% 0, 100% 0, 100% 100%, 0 100%, 0 75%, 33% 62%);
      @keyframes shake {
        0%, 100% { transform: rotate(3deg); }
        50%  { transform: rotate(-3deg); }
Mushroom Solar Panel Animation
icon: mdi:solar-power-variant
icon_color: amber
primary: Solar Panel
card_mod:
  style:
      ha-icon {
        --icon-animation: rays 2s infinite;
      @keyframes rays {
        80% { clip-path: polygon(100% 99%, 0% 99%, 11% 50%, 57% 48%, 56% 31%, 41% 31%, 33% 25%, 29% 18%, 27% 11%, 27% 6%, 74% 6%, 73% 15%, 69% 23%, 62% 29%, 71% 42%, 87% 47%); }
Mushroom Light Bulb Animation
icon: mdi:lightbulb-on
icon_color: amber
primary: Light Bulb
card_mod:
  style:
      ha-icon {
        --icon-animation: illumination 2s infinite;
      @keyframes illumination {
        80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
Mushroom Eureka Animation
Eureka Animation
icon_color: orange
primary: Eureka
card_mod:
  style:
      ha-icon {
        --icon-animation: eureka 1.8s infinite;
      @keyframes eureka {
        0%, 45%, 55%, 100% { transform: translateY(0) scale(1); clip-path: polygon(20% 100%, 21% 38%, 36% 22%, 62% 21%, 79% 37%, 80% 100%, 53% 100%, 55% 67%, 62% 62%, 66% 55%, 67% 46%, 62% 38%, 55% 34%, 47% 34%, 39% 37%, 34% 44%, 33% 53%, 36% 60%, 41% 64%, 45% 66%, 45% 76%, 56% 76%, 54% 100%); }
        10%, 40% { transform: translateY(-5px) scale(1.12); clip-path: inset(0 0 0 0); }
        50% { transform: translateY(-2px) }
Mushroom Trash Animation
Trash Animation
cards:
    icon: mdi:trash-can
    icon_color: green
    primary: Trash
    card_mod:
      style:
          ha-icon {
            clip-path: inset(26% 0 0 0);
    icon: mdi:trash-can
    icon_color: green
    card_mod:
      style:
          ha-icon {
            --icon-animation: lid 1s ease infinite;
            clip-path: inset(0 0 75% 0);
            transform-origin: 50% 25%;
          @keyframes lid {
            10% { transform: translateY(-5px) rotate(-37deg); }
            20% { transform: translateY(-5px) rotate(31deg); }
            30% { transform: translateY(-5px) rotate(-25deg); }
            40% { transform: translateY(-5px) rotate(19deg); }
            60% { transform: translateY(-3px); }
          .shape {
            top: 0.3px;
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Heat Pump Animation
Heat Pump Animation
cards:
    icon: mdi:heat-pump-outline
    primary: Heat Pump
    card_mod:
      style:
          ha-icon {
            clip-path: polygon(0% 0%, 0% 100%, 23% 100%, 23% 23%, 78% 22%, 77% 78%, 23% 78%, 22% 100%, 100% 100%, 100% 0%);
    card_mod:
      style:
          ha-icon {
            position: absolute;
            --icon-animation: spin 2s linear infinite;
            clip-path: circle(27.3% at 50% 50%);
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Air Purifier Animation
icon: mdi:air-purifier
icon_color: cyan
primary: Air Purifier
card_mod:
  style:
      ha-icon {
        --icon-animation: air 1s infinite;
      @keyframes air {
        25% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 98% 32%, 63% 42%, 65% 58%, 100% 43%); }
        75% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 100% 44%, 64% 61%, 64% 73%, 100% 72%); }
        50% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 78% 38%, 64% 43%, 64% 72%, 100% 73%); }
Mushroom Calendar Clock Animation
cards:
    icon: mdi:calendar-clock
    icon_color: purple
    primary: Calendar Clock
    card_mod:
      style:
          ha-icon {
            clip-path: polygon(0 100%, 0 0, 100% 0, 100% 67%, 85% 69%, 73% 52%, 59% 52%, 59% 72%, 77% 81%, 85% 68%, 100% 67%, 100% 100%);
    icon_color: purple
    card_mod:
      style:
          ha-icon {
            --icon-animation: spin 1s linear infinite;
            transform-origin: 67% 67%;
            clip-path: circle(17% at 67% 67%);
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom CRT Animation
CRT Animation
primary: CRT
entity: switch.television
icon: mdi:television-classic
icon_color: '{{ ''orange'' if is_state(entity, ''on'') }}'
card_mod:
  style:
      ha-icon {
        {{ '--icon-animation: tube-on 1s linear, flicker 1s linear 1s infinite alternate;' if is_state(config.entity, 'on') else '--icon-animation: tube-off 2s linear forwards;' }}
      @keyframes tube-off {
        1%, 15% { transform: scale(1, 0.2); }
        40%  { transform: scale(0.2); opacity: 1; }
        100%  { transform: scale(0.2); opacity: 0; }
      @keyframes tube-on {
        5%  { transform: scale(1, 0.2); opacity: 0.3; }
        15%  { transform: scale(1); opacity: 0.4; }
        100%  { transform: scale(1); opacity: 1; }
        0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { opacity: 0.6; }
        32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { opacity: 1; }
Mushroom Microwave Animation
Microwave Animation
icon: mdi:microwave
icon_color: blue
primary: Microwave
card_mod:
  style:
      ha-icon:before {
        content: "";
        position: absolute;
        width: 25%;
        height: 25%;
        margin: 10%;
        animation: cook 1s linear infinite;
      @keyframes cook {
        0%, 100% { background: linear-gradient(90deg, white 0%, transparent 50%, transparent 100%); }
        33% { background: linear-gradient(90deg, transparent 0%, white 50%, transparent 100%); }
        66% { background: linear-gradient(90deg, transparent 0%, transparent 50%, white 100%); }
Controlling the Animation in your Card
The animations can be controlled using a Jinja Template condition on the animation command.
For example if I wanted an animation when my coffee machine is on I would use an if statement like this:
{{ '--icon-animation: java 4s linear infinite;' if is_state(config.entity, 'on') }}
The complete card would look like this:
Coffee Machine Card
entity: switch.coffee_machine
icon_color: '{{ ''brown'' if is_state(entity, ''on'') }}'
card_mod:
  style:
      ha-icon {
      @keyframes java {
Or if I wanted to have the dryer animate when the load is over 4w I would do this:
{{ '--icon-animation: shake 400ms ease-in-out infinite, drum 1s infinite;' if states('sensor.dryer_power') | float > 4 }}
Dryer Card
entity: switch.dryer
icon: mdi:tumble-dryer
icon_color: '{{ ''teal'' if states(''sensor.dryer_power'') | float > 4 }}'
primary: Dryer
card_mod:
  style:
      ha-icon {
        transform-origin: 50% 65%;
      @keyframes shake {
        0%, 100% { transform: rotate(4deg); }
        50%  { transform: rotate(-4deg); }
      @keyframes drum {
        50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
You will need to add the if condition for each animation:, --icon-animation: or --shape-animation: command in the card.
Using the Animations with Tile Card
The structure of the new Tile Card is very similar to the Mushroom Cards, so it is easy to use these animations with it.
Mushroom Card
card_mod:
  style:
      ha-icon {
Tile Card
card_mod:
  style:
    ha-tile-icon$: |
      ha-svg-icon {
Animated Tile Card
type: tile
entity: fan.bathroom_fan
color: green
card_mod:
  style:
    ha-tile-icon$: |
      ha-svg-icon {
        animation: rotate 1s linear infinite;
      @keyframes rotate {
        100% { transform: rotate(360deg); }
:point_right: Continued in Part 1, Part 2, Part 3 & Part 5
@rhysb Thank you so much on the door. And thank you for investing.
Added one for Solar Power. Can’t rotate half a sun sorry. :slightly_frowning_face:
Not much to animate with the Thermostat… :thinking:
Would require a lot of work to do.
This should do what you want:
primary: Heater
secondary: >-
  {{ 'Heating' if states('sensor.smartplug_heater_2nd_floor_power') | float >
  4 else 'Idle' }}
icon: mdi:heat-wave
entity: switch.smartplug_heater_2nd_floor
icon_color: '{{ ''red'' if is_state(entity, ''on'') }}'
tap_action:
  action: toggle
This is really amazing work! Love it, many thanks! If I where to wish for one animation it would be for the light bulb.
@rhysb Thank you for sharing your knowledge :slight_smile:
How can I use the animation only when the state of the entity is on?
IOS on Ipad Pro
Can you share yours energy cards?
Works like a charm! Thanks again.
Btw, with all the work you contribute in this thread you should have a patreon :sweat_smile:
