Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Well done on the wobble! Is it possible to do that with the template card icon I wonder?
Try:
icon_color: |-
        {% set icsp = states('sensor.solaredge_current_power')|float(0) %}
        {% if icsp > '0' %}
          green
        {% else %}
          red
        {% endif %}
That helps!!
Thank you!!
Here goes to anyone looking:
   primary: 'Motion: {{ states("binary_sensor.bedroom_motion_sensor_occupancy") }}'
   secondary: 'Battery: {{ states("sensor.bedroom_temp_sensor_battery_2") }}%'
   entity: binary_sensor.bedroom_motion_sensor_occupancy
   icon: mdi:motion
   use_light_color: false
motion
Expanding on @Boostin4HP card as a base, done the drop down as well, but with custom colours for the indoor/outdoor temperature and it just uses heatings (radiators), so no cooling.
Also merged in the climate title to flatten the card into a whole.
type: custom:stack-in-card
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: custom:mushroom-title-card
    title: Climate
    subtitle: ''
  - type: grid
    square: false
    columns: 2
    cards:
        style: |
          ha-card {
            padding-bottom: 14px !important;
        primary: Thermostat
        secondary: |
          Currently: {{ state_attr('climate.home', 'hvac_action') }}
        icon: |-
          {% set mode = states('climate.home') %}
          {% if mode == 'off' %}
          mdi:radiator-off
          {% elif mode == 'heating' %}
          mdi:radiator
          {% else %}
          mdi:radiator-disabled
          {% endif %}
        icon_color: |-
          {% set status = state_attr('climate.home','hvac_action') %}
          {% if status == 'heating' %}
          red
          {% else %}
          grey
          {% endif %}
        tap_action: none
      - type: vertical-stack
        cards:
          - type: custom:simple-thermostat
            style: |
              ha-card {
                --st-spacing: 0px;
              ha-card .current--value {
                color: #ffffff;
              header {
                margin-bottom: 10px !important;
                padding-bottom: 0px !important;
              ha-card .thermostat-trigger {
                color: #6f6f6f;
            entity: climate.home
            header:
              icon: false
            decimals: '1'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '0.5'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
    style: |
      ha-card {
        --st-font-size-toggle-label: 6px
        --st-spacing: 0px;
        --st-default-spacing: 0px;
        --st-mode-background: #2d2d2d;
        margin-left: 12px;
        margin-right: 12px;
      ha-card .mode-item.active.off {
        background: #363636;
        color: #9e9e9e;
      ha-card .mode-item.active.heat {
        background: #472421;
        color: #f44336;
      ha-card .mode-item.active {
        background: #263926;
        color: #4caf50;
      ha-card .mode-item.active:hover {
        color: #9e9e9e;
      ha-card .mode-item:hover {
        color: #9e9e9e;
      ha-card .mode-item {
        --st-spacing: 10px;
        border-radius: 10px;
      ha-card .modes {
        grid-gap: 12px
    header: false
    setpoints: false
    hide:
      temperature: true
      state: true
    layout:
      mode:
        headings: false
        icons: true
        names: false
      step: row
    control:
      hvac:
        'off':
        heat:
  - type: custom:mushroom-chips-card
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
        --chip-spacing: 0px;
        --chip-padding: 0 0.2em
    alignment: justify
    chips:
      - type: template
        content: '{{state_attr(entity, "current_temperature")}} °C'
        icon: mdi:home-thermometer
        tap_action:
          action: more-info
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='cool' %}
          blue
          {% elif state=='heat' %}
          red
          {% else %}
          grey
          {% endif %}
        style: |
          ha-card {
            margin-left: 6px;
      - type: template
        double_tap_action:
          action: none
        content: >-
          {{ states(entity) }}{{ state_attr(entity, "unit_of_measurement") }}
          Humidity
        entity: sensor.humidity
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        double_tap_action:
          action: none
        content: >-
          {{ states(entity) }} {{ state_attr(entity, "unit_of_measurement") }}
          Pressure
        entity: sensor.average_indoor_pressure_downstairs
        icon: mdi:gauge
        icon_color: grey
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        icon: |-
          {% if is_state(entity, 'off') %}
            mdi:chevron-down
          {% elif is_state(entity, 'on') %}
            mdi:chevron-up
          {% endif %}
        tap_action:
          action: toggle
        entity: input_boolean.thermostat_dropdown
        icon_color: disabled
        style: |
          ha-card {
            --chip-icon-size: 1em
  - type: conditional
    conditions:
      - entity: input_boolean.thermostat_dropdown
        state: 'on'
    card:
      keep:
        margin: false
        box_shadow: false
        background: false
      cards:
        - type: grid
          square: false
          columns: 2
          cards:
              entity: sensor.average_indoor_temperature_downstairs
              primary: >-
              secondary: Inside
              icon_color: |-
                {% set temp = states(entity) %}
                {% if temp >= '19' %}
                  red
                {% elif temp >= '17' and temp < '19' %}
                  orange
                {% elif temp == 'unknown' %}
                  grey
                {% else %}
                  blue
                {% endif %}
              icon: mdi:home-thermometer-outline
              entity: sensor.outdoor_temperature
              primary: >-
              secondary: Outside
              icon_color: |-
                  red
                  orange
                  grey
                {% else %}
                  blue
                {% endif %}
              icon: mdi:thermometer
              style: |
                ha-card {
                  --st-spacing: 0px;
                  --st-default-spacing: 1.6px;
                  margin-right: 12px;
                  color: #4caf50;
                  color: #9e9e9e;
                  color: #9e9e9e;
                  --st-spacing: 6px;
                ha-card .modes {
                  grid-gap: 12px
              header: false
              setpoints: false
              hide:
                temperature: true
                state: true
              layout:
                mode:
                  headings: false
                  icons: true
                  names: false
                step: row
              control:
                hvac:
                  'off': false
                  heat: false
                  cool: false
                  heat_cool: false
                fan:
                  Auto low:
                    icon: mdi:fan-auto
                  Low:
                    icon: mdi:fan
        - type: custom:mini-graph-card
          entities:
            - entity: sensor.average_indoor_temperature_downstairs
              name: Inside Temperature
              color: '#4caf50'
            - entity: sensor.outdoor_temperature
              name: Outside Temperature
              color: '#2196f3'
              y_axis: secondary
          hours_to_show: 24
          line_width: 3
          font_size: 50
          animate: true
          show:
            icon: false
            state: false
            legend: false
            fill: fade
Have to pinch this too. Stop it! :stuck_out_tongue:
@rhysb trying to incorporate the adaptive lighting settings into the card as well, so have the following:
Any ideas how to get that rgb color matching working for the icon_color? Does the mushroom-template-card support returning rgb?
Do you mean from the icon color? Maybe, I’ll have a look later…
Yer. Would appreciate it, it just says string in docs
And they said it couldn’t be done… It was a bit tricky though.
Rocking Horse
type: custom:mushroom-template-card
primary: Yeehaa!
icon: mdi:horse-human
icon_color: yellow
card_mod:
   style:
     mushroom-shape-icon$: |
       ha-icon {
         --icon-animation: wobbling 0.5s linear infinite alternate;
       @keyframes wobbling {
         0% {
           transform: rotate(-20deg);
         100% {
           transform: rotate(20deg);
pinwheel
primary: Weeeee!
icon: mdi:pinwheel
icon_color: green
card_mod:
  style:
      ha-icon {
       --icon-animation: rotation 1s linear infinite;
      @keyframes rotation {
        100% {
          transform: rotate(360deg);
Which bit looks weird for you?
bathroom
hey @Posreg How did you make these polish radios work.
I want to have same thing for my wife as well
Thanks in advance
can you share your code?
Hi, the following template is not showing the state of the sensor in the secondary information part. It is left empty. The template itself is OK. It renders fine in the template check in the developer section of HA. Any ideas why?
    primary: Upstream Fehler
    entity: sensor.upstream_fehler
    secondary: |
      {% if states('sensor.upstream_fehler') in ['unknown','unavailable'] %}
        Offline
      {% else %}
        {{ states('sensor.upstream_fehler') }}
      {% endif %}
Do this in a chip and I will give you a cookie.
I figured out that the issue is that the template renders to 0 (zero). Zero is not displayed, even if just using the number zero instead of the template. The following also does NOT work.
        Offline
      {% else %}
       0
      {% endif %}
The following works:
secondary: |
    Offline
  {% else %}
    - {{ states('sensor.upstream_fehler') }} -
  {% endif %}
It would be awesome to have style supported in the visual editor
Who wants a cookie? :grinning:
cookie
chips:
  - type: template
    icon: mdi:cookie
    icon_color: brown
    content: Cookie
card_mod:
  style:
    mushroom-template-chip$: |
      ha-icon {
        100% {
Mind posting your yaml?
How are you getting the fan to rotate?
I think I already posted it in here but here it is again:
        chips:
          - type: template
            double_tap_action:
              action: none
            icon: |-
              {% if is_state('fan.YOURFAN', 'on') %}
                mdi:fan
              {% else %}
              {% endif %}
            icon_color: |-
              {% if is_state_attr('fan.YOURFAN', 'preset_mode',
              'Normal')%}
                blue
              {% elif is_state_attr('fan.YOURFAN', 'preset_mode',
              'Nature')%}
                green
              {% else %}
                disabled
              {% endif %}
            tap_action:
              action: more-info
            hold_action:
              action: none
            entity: fan.YOURFAN
            card_mod: null
            style: |
                0% {
                  transform: rotate(0deg);
                100% {
              ha-card {
                --chip-box-shadow: 0px 0px;
                animation: rotation linear infinite;
                {% if states('fan.YOURFAN') == 'on' %}
                 animation-duration: 3s;
                {%- else -%}
                {%- endif %}
And it’s right above your question:
