Hi Dimitri, my idea was to retain the toggle on/off function.
Just add a toggle action to the template chip.
type: custom:mushroom-chips-card
chips:
- type: template
entity: switch.office_screen_left
icon: |-
{% if states(config.entity) == 'on' %}
mdi:power
{% else %}
mdi:power-off
{% endif %}
icon_color: |-
white
{% else %}
grey
{% endif %}
tap_action:
action: toggle
Unfortunatelly not. The color is not applied either.
I give up, thank you all for your invested time.
Will use as a final solution, Mushoroom card placed bellow each vertical slider. Looks reasonable as well.
You ever figure it out, please let me know.
Would that be a bug report that I bring to card-mod or mushroom-card? Iâd love to see this get patched up soon.
i think it is just a limitation of CSS. CSS is rendered when the website is first displayed. the way that we are getting around it with card mod updating cards on state changes is probably a bit hacky in the first place.
you can certainly try and open a bug report on card-mod. but find it unlikely it will be considered to be honest.
@petrij98 Did you see my comments about the the animation continuing after the light turns off. It did the same thing for me until I relocated the following below the @keyframes
{% else %}
{% endif %}
I was curious if that at least fixed the animation issue?
Brother, I fail to understand how, but that absolutely fixed it. Thank you so much! So, do I need to make sure the keyframes are defined within the if statement from now on?
I would suggest doing so, but if you have an example where it doesnât seem necessary, just reach out.
Any idea why this is no longer working after the latest core update? I mean the ha-icon specifically. It used to before that, now it seems that the whole structure has changed.
I also re-downloaded mushroom cards and card-mod, but it didnât make any difference.
type: custom:mushroom-update-card
card_mod:
style:
mushroom-update-buttons-control$:
mushroom-button:nth-child(1):
.button {
height: 42px !important;
width: 42px !important;
border-radius: 21px !important;
background: rgba(10, 10, 10, 0.2) !important;
margin-left: 5px !important;
ha-icon {
--card-mod-icon: mdi:close-circle-outline !important;
height: 21px;
width: 21px;
mushroom-button:nth-child(2):
.button {
ha-icon {
--card-mod-icon: mdi:download !important;
height: 21px;
width: 21px;
Can you give a little more context? What is not working?
UPDATEâŚI see what you are saying
Sorry for the misunderstanding. I shouldâve been more specificâŚ
I meant the ha-icon styling specifically. The button styling works just fine.
ha-icon {
height: 21px;
width: 21px;
I was able to change the icon size so itâs still adjsutable. Is there a specific setting you are looking to adjust? Iâll need a bit to check the other settings.
entity: update.home_assistant_supervisor_update
show_buttons_control: true
card_mod:
style: |
ha-card {
--control-icon-size: 40px;
Yes, the icon itself.
Actually the icons of the buttons, not the main icon. Each one individually: mdi:close-circle-outline for nth-child(1) and mdi:download for nth-child(2).
The CSS was doing that just fine, as it was, before the core update.
Ok⌠Thanks. Iâll keep looking into it as well.
I loaded Core 2024.1.6 and Mushroom 3.4.1 on my test system and it still didnât work.
You may better off with a template card.
Template card doesnt have buttons, so defeats the purpose a little.
Ill take a look when i am back from work today
I meant youâd have to create the card he wantsâŚadditional work I canât get the icons or colors changed. Nothing reacts inside the shadow-root.
@dimitri.landerloos since the last mushroom Update the card mod fails by the primary and secondary text color. The color didnât change anymore:
Herr is the code:
Amy idear whatâs wrong?
Best Regards!
