Mushroom Cards Card Mod Styling/Config Guide
Are you using any themes?
I have installed “Mushroom Themes” and am using “Mushroom Shadow” overall, it is set on my profile.
Try switching to the default theme and see if you have the same issue. Worth eliminating theme issues.
Unfortunately same :frowning:
You have me stumped.
is it possible that it has sth. with the HA Version? I do not have the latest 2024.4.
I have Core 2024.3.0. + OS 12.0
PS: I have even created a new empty view, and the problem still exists…
Its a possibility but I never seen an alignment issue with chips like yours.
Maybe someone else can test as well.
I see now, that code works on my windows (chrome)! On Mac Safari though, i have that strange allignment… it might be a Safari Bug :nauseated_face (edit: not Safari bug, but i think bug in chips):
For those who are interested:
Here you can see that there is a margin-right for all chip-container children (except the last one). That is basically the space between multiple chips. This margin definition is actually just relevant for the chip itself (mushroom-conditional-chip). But i think because of its definition (.chip-container:not(:last-child)) it somehow also effects the grand-children. So we see the margin-right also for the specific chip type mushroom-template-chip. This does not have any effect on Chrome, but Safari has this strange behaviour and adds some space to top.
Here you see a workaround: when i set margin-right of mushroom-template-chip to 0, it behaves also correctly on Safari:
I think this is relevant for all devices which run safari… (iphone, ipad etc.)
I think the margins between the chips should be defined with the direct child symbol “.chip-container > *” instead of “.chip-container *” so it should not effect the other elements. Where is the correct location to discuss this / open issue? Github?
Where can i change the definition “.chip-container:not(:last-child)” globally?
Anyone know please? thanks
I also copied his code and have the same
Thanks! Always good to have a second test. It looks like he pinned it down to Chips not playing well with Safari Browser.
how edit light slider background color when light is off?
@milutm This will change the OFF color
card_mod:
  style:
    mushroom-light-brightness-control$: |
      mushroom-slider {
        --bg-color-inactive: red !important;
Hello all,
I have a problem with mushroom cards and I can’t seem to fix it.
This cards change color wether one person is home or isn’t. However, the distance between the cards getting bigger when someone is leaving home. Does anyone know where i made a mistake in my code?
Oh and maybe someone can help me a bit more. I also would like it to pulse green when someone is at home and pulse red when someone is out. I don’t know how to do it. This is the code i found with a pulse badge.
CODE FROM ABOVE
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: masonry
    layout: {}
    cards:
      - square: false
        columns: 3
        type: grid
        cards:
          - type: horizontal-stack
            cards:
              - type: custom:mushroom-chips-card
                chips:
                  - type: conditional
                    conditions:
                      - entity: person.robert
                        state: home
                    chip:
                      type: entity
                      content_info: nam
                      use_entity_picture: true
                      card_mod:
                        style: |
                          ha-card {
                              --chip-background: rgba(var(--rgb-state-person-home), 0.4);
                              margin-top: 5px;
                              margin-bottom: -20px;
                  - type: conditional
                    conditions:
                      - entity: person.froukje
                        state: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                              margin-top: 5px;
            cards:
                chips:
                  - type: conditional
                    conditions:
                        state_not: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                            {% if is_state('person.robert', 'not_home') %}
                              --chip-background: rgba(var(--rgb-state-person-not-home), 0.4);
                            {% elif is_state('person.robert', 'unknown') %}
                              --chip-background: rgba(var(--rgb-state-person-unknown), 0.4);
                            {% else %}
                              --chip-background: rgba(var(--rgb-state-person-zone), 0.4);
                            {% endif %}
                              margin-top: 5px;
                  - type: conditional
                    conditions:
                        state_not: home
                    chip:
                      type: entity
                      content_info: none
                      card_mod:
                        style: |
                          ha-card {
                            {% if is_state('person.froukje', 'not_home') %}
                            {% elif is_state('person.froukje', 'unknown') %}
                            {% else %}
                            {% endif %}
                              margin-top: 5px;
PULSE BADGE
type: custom:mushroom-person-card
card_mod:
  style:
    mushroom-badge-icon$: |
      .badge {
        animation: ping 2s infinite;
      @keyframes ping {
          0% {box-shadow: 0 0 0 0 rgba(var(--rgb-green), 0.7);}
          70% {box-shadow: 0 0 0 6px transparent;}
          100% {box-shadow: 0 0 0 0 transparent;}
Your biggest mistake, is you copy code you don’t understand :wink:
It’s an awfull mess
cards:
    layout: {}
    cards:
      - square: false
        columns: 3
        type: grid
        cards:
            cards:
                chips:
                  - type: conditional
                    conditions:
                        state: home
            cards:
                chips:
                  - type: conditional
                    conditions:
                        state_not: home
So You have a “stack-in card” with no further definition, beside
cards:
    layout: {}
    cards:
For another unknown reason
In this masonry-layout-card you then place
cards:
      - square: false
        columns: 3
        type: grid
        cards:
A Grid ! ( 3 columns )
where you place a horizontal-stack ( This one seems ok, somehow )
How ever then you place another horizontal-stack ( In your grid !)
Which ends up in column 2 ( 1=Home 2=Not_Home )
And !, what you apparently just want is that the cards change color + “pulse”
Which you accomplice with card-mod !
So what are all the cards stacks, grid, horizontal, and conditional-chips good for ?
You mix everything together in a big pile of … “something” … nice spoken
So it’s not easy to “tell you” what and where, beside my attempt above
  • in short you have 2 conditional-cards in First horizontal-stack, in your grids column1, in your masonry layout, in your stack-in-card , those card only shows when persons is Home
  • then you have 2 conditional cards in Second horizontal-stack, in your grids column2, in your masonry layout, in your stack-in-card , those card only shows when persons is Not_Home
PS: Do you have plans for column 3, which is relevant in this context ?
Trying to change justify-content to flex-start instead of flex-end:
Cannot manage to get it right:
mushroom-climate-temperature-control$:
                mushroom-button-group$: |
                .container {
                  justify-content: flex-start!important;
For some reason it doesn’t work. It works if I inspect in browser and change the value. Am I pointing it wrong?
You need to post your code.
type: custom:vertical-stack-in-card
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        entity: climate.hc1
        icon: |-
          {% if is_state(entity, 'heat') %}
            mdi:fire
          {% elif is_state(entity, 'heat_cool') %}
            mdi:sun-snowflake
          {% elif is_state(entity, 'cool') %}
            mdi:snowflake
          {% elif is_state(entity, 'fan_only') %}
            mdi:fan
          {% else %}
            mdi:radiator-off
          {% endif %}
        icon_color: |-
          {% if is_state_attr(entity,
          'hvac_action', 'heating') %}
            deep-orange
          {% elif is_state_attr(entity,
          'hvac_action', 'cooling') %}
            var(--blue-color)
          'hvac_action', 'fan') %}
            turquoise
          {% else %}
            disabled
          {% endif %}
        primary: |
          {{ states('sensor.a4c1385c22dd_temperature') | round(1) }} °C
        secondary: |-
          {% if is_state(entity, 'heat_cool') %}
            Heat/Cool
            Heating
            Cooling
          {% elif is_state(entity, 'heat') %}
            Heat
            Cool
            Fan
          {% else %}
            Off
          {% endif %}
        entity: sensor.a4c1385c22dd_humidity
        primary: |
          {{ states(entity) | round(1) }} %
        secondary: Humidity
        icon: mdi:water-percent
        icon_color: blue
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.a4c1385c22dd_temperature
        color: var(--red-color)
      - entity: sensor.a4c1385c22dd_humidity
        color: var(--light-blue-color)
        y_axis: secondary
    hours_to_show: 12
    line_width: 3
    font_size: 50
    animate: true
    show:
      icon: false
      state: false
      legend: false
      points: false
      labels: false
      labels_secondary: false
      fill: fade
    card_mod:
      style: |
        .line--rect,
        .fill--rect,
        .line--points {
          {% set state = states('climate.hc1') %}
          {% set states = {'heat_cool':'green',
                           'heat':'#FF5722',
                           'cool':'var(--blue-color)',
                           'dry':'orange',
                           'fan_only':'turqoise'} %}
          {{states.get(state,'grey')}}
          fill: {{COLOR}};
          stroke: {{COLOR}};
        .line--rect:last-of-type,
        .fill--rect:nth-of-type(2),
        .line--points:last-of-type {
          fill: var(--blue-color);
          stroke: var(--blue-color);
  - type: custom:mod-card
    card_mod:
      style:
        hui-horizontal-stack-card $: |
          div#root > :first-child {
            width: 70%;
            flex: auto;
          div#root > :last-child {
            width: 30%;
            flex: auto;
    card:
      cards:
        - type: custom:mushroom-climate-card
          entity: climate.hc1
          layout: horizontal
          primary_info: none
          secondary_info: none
          icon: mdi:fire
          icon_type: icon
          show_temperature_control: true
          card_mod:
            style: |
              ha-card {
                box-shadow: none;
                background: none;
                border-style: none;
                display: flex;
                justify-content: center;
                flex-direction: column;
                .container {
          icon: mdi:thermometer-water
          icon_color: |
            {% if is_state(entity, 'eco') %}
            light-green
            {% elif is_state(entity, 'high_demand') %}
            red
            {%- else -%}
            orange
            {%- endif %}
          layout: horizontal
          entity: water_heater.dhw1
          secondary: |
            Eco
            Komfort
            {%- else -%}
            Normal
            {%- endif %}
          tap_action:
            action: more-info
          card_mod:
            style: |
              ha-card {
                box-shadow: none;
                background: none;
                border-style: none;
                display: flex;
The space you are trying to occupy is reserved for the heat_cool setting. There is not much room for moving the control buttons unless you move to margin adjustments. That would only work if your system doesn’t have heat_cool.
          card_mod:
            style:
                mushroom-input-number$: |
                  .container {
                    background-color: grey !important;
                    margin-left: -130px;
                ha-card {
                 box-shadow: none;
                 background: none;
                 border-style: none;
                 display: flex;
The margin adjust is just a quick fix. I’m sure there are other ways if we individualize the control groups.
