Mushroom Cards Card Mod Styling/Config Guide
I don’t have heat/cool, only heat.
What I want to do is like your first picture, but make the temperature control as wide as both controls with only a single control.
I tried your code, but only got this:
Also got this weird error.
I understand more now, so let me see what I can do. The card is built for all scenarios and it holds that left space for the heat_cool button when activated.
There was a lot of code for heat_cool in the code you posted.
Yes, sorry about that. The heat cool code is something I haven’t touched yet. It is a copy from another user in this thread!
Let’s see where we are with this. You should get this…
type: custom:vertical-stack-in-card
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        entity: climate.hc1
        icon: |-
          {% if is_state(entity, 'heat') %}
            mdi:fire
          {% elif is_state(entity, 'heat_cool') %}
            mdi:sun-snowflake
          {% elif is_state(entity, 'cool') %}
            mdi:snowflake
          {% elif is_state(entity, 'fan_only') %}
            mdi:fan
          {% else %}
            mdi:radiator-off
          {% endif %}
        icon_color: |-
          {% if is_state_attr(entity,
          'hvac_action', 'heating') %}
            deep-orange
          {% elif is_state_attr(entity,
          'hvac_action', 'cooling') %}
            var(--blue-color)
          'hvac_action', 'fan') %}
            turquoise
          {% else %}
            disabled
          {% endif %}
        primary: |
          {{ states('sensor.a4c1385c22dd_temperature') | round(1) }} °C
        secondary: |-
          {% if is_state(entity, 'heat_cool') %}
            Heat/Cool
            Heating
            Cooling
          {% elif is_state(entity, 'heat') %}
            Heat
            Cool
            Fan
          {% else %}
            Off
          {% endif %}
        entity: sensor.a4c1385c22dd_humidity
        primary: |
          {{ states(entity) | round(1) }} %
        secondary: Humidity
        icon: mdi:water-percent
        icon_color: blue
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.a4c1385c22dd_temperature
        color: var(--red-color)
      - entity: sensor.a4c1385c22dd_humidity
        color: var(--light-blue-color)
        y_axis: secondary
    hours_to_show: 12
    line_width: 3
    font_size: 50
    animate: true
    show:
      icon: false
      state: false
      legend: false
      points: false
      labels: false
      labels_secondary: false
      fill: fade
    card_mod:
      style: |
        .line--rect,
        .fill--rect,
        .line--points {
          {% set state = states('climate.hc1') %}
          {% set states = {'heat_cool':'green',
                           'heat':'#FF5722',
                           'cool':'var(--blue-color)',
                           'dry':'orange',
                           'fan_only':'turqoise'} %}
          {{states.get(state,'grey')}}
          fill: {{COLOR}};
          stroke: {{COLOR}};
        .line--rect:last-of-type,
        .fill--rect:nth-of-type(2),
        .line--points:last-of-type {
          fill: var(--blue-color);
          stroke: var(--blue-color);
  - type: custom:mod-card
    card_mod:
      style:
        hui-horizontal-stack-card $: |
          div#root > :first-child {
            width: 70%;
            flex: auto;
          div#root > :last-child {
            width: 30%;
            flex: auto;
    card:
      type: horizontal-stack
      cards:
        - type: custom:mushroom-climate-card
          entity: climate.hc1
          layout: horizontal
          primary_info: none
          secondary_info: none
          icon: mdi:fire
          icon_type: icon
          show_temperature_control: true
          card_mod:
            style:
              mushroom-climate-temperature-control$:
                mushroom-input-number$: |
                  #container {
                    position: absolute;
                    width: 70%;
                    left: 25%;
                    z-index: 1 !important;
                    background-color: {{ 'rgba(255, 144, 0, .4)' if state_attr('climate.hc1', 'hvac_action') ==
                           'heating' else  'rgba(255, 140, 0, 1)' }}
                ha-card {
                 border: none;
          icon: mdi:thermometer-water
          icon_color: |
            {% if is_state(entity, 'eco') %}
            light-green
            {% elif is_state(entity, 'high_demand') %}
            red
            {%- else -%}
            orange
            {%- endif %}
          layout: horizontal
          entity: water_heater.dhw1
          secondary: |
            Eco
            Komfort
            {%- else -%}
            Normal
            {%- endif %}
          tap_action:
            action: more-info
          card_mod:
            style: |
              ha-card {
                box-shadow: none;
                background: none;
                border-style: none;
                display: flex;
                justify-content: center;
                flex-direction: column;
Thanks man! Works great!!
I have a hopefully simple question to the community.
Im trying to create a Mushroom climate card, which Icon color is changing in dependence to the temperature.
This works so far, but I try to change the colour of the shape also, but this rather doesnt work.
My code is:
card_mod:
  style: |
    ha-card {
      {% if ( states('sensor.ha_temperatur_schlafzimmer') | float(0) > 19) %}
        --card-mod-icon-color: green;
      {% elif ( states('sensor.ha_temperatur_schlafzimmer') | float(0) > 17 < 19)%}
        --card-mod-icon-color: orange;
      {% elif ( states('sensor.ha_temperatur_schlafzimmer') | float(0) < 17)%}
        --card-mod-icon-color: red;
      {% endif %}
    mushroom-shape-icon$: |
      .shape {
        --shape-color: white;
Does anyone have an idea? Chat GPT fails also :frowning:
2024-04-14 13_05_26-P1 – Home Assistant
I have no clou where the shape color is defined, kind of light pink
I think I understand.
card_mod:
  style: |
    ha-card {
      {% endif %}
    ha-state-icon {
      color: white;
@LiQuid_cOOled will help more when he can.
thank you for your support. still not working on my side :frowning:
oh I got it wrong.
although I would now be interested in the answer.
if using mushroom template you can use the build in icon colour icon_color: white but with your code that didn’t change to white for me either.
I also tried yours with !important; on the end
I had another go this worked for me
type: custom:mushroom-template-card
primary: Hello,
secondary: How are you?
icon: mdi:home
card_mod:
  style:
      .shape {
        --shape-color: white !important;
      ha-card {
      19)%}
      {% endif %}
It works. Thank you so much :slight_smile:
@SchwabiI I simplified a few things…
Your IF statement can be 2 steps vs 3 and icon_color: will accept templates in the mushroom template card. This saves an additional mod.
primary: Shape Color
secondary: test
icon: mdi:home
icon_color: |
  {% if states('sensor.ha_temperatur_schlafzimmer') | int < 17 %}
     red
  {% elif states('sensor.ha_temperatur_schlafzimmer') | int < 19 %}
    orange
  {% else %}
     green
  {% endif %}
card_mod:
  style:
      .shape {
        background: white !important;
Hello LiQuid_cOOled, thanks for your help and providing this nice code.
I really appreciate that.
I tested it for my use case and it works pretty well.
primary: Schlafzimmer
secondary: ''
icon: mdi:home-thermometer
icon_color: |
     blue
    orange
  {% else %}
     green
  {% endif %}
layout: horizontal
multiline_secondary: false
fill_container: false
entity: climate.intelligente_raumregelung
tap_action:
  action: more-info
card_mod:
  style:
      .shape {
Do you have an idea how to write the actual value of the entitiy “sensor.ha_temperatur_schlafzimmer” so that it is also displayed in the card?
2024-04-15 11_57_36-Präsentation1 - PowerPoint
found out on my own:
secondary: '{{states(''sensor.ha_temperatur_schlafzimmer'')}}°'
ty
2024-04-15 12_12_07-Test – Home Assistant
I have a very minor issue with a new card I am trying to do with stack in card.
i couldn’t get it within one statement of stack-in-card so I split it into 2 but now have the radius of the 2 in the middle. the picture explains it better. I could remove the radius but it wouldn’t match the other cards.
is it a simple fix or should I change the card?
type: vertical-stack
cards:
    primary: p o n d
    icon: mdi:fish
    secondary: 'o u t s i d e l i g h t s '
    icon_color: blue
    card_mod:
      style: |
        ha-card {
            --card-primary-font-size: 1.5rem;
            --primary-text-color: white;
            --secondary-text-color: green;
            border: 1px;
            box-shadow: none;
            background: rgba(0,0,0,0);
            margin-top: 1.5rem;
  - type: custom:stack-in-card
    title: Pond Switches
    keep:
      background: true
      box_shadow: true
    mode: horizontal
    cards:
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
              ha-card-border-width: 0px;
              margin-top: -30px;
        primary: Wifi
        secondary: '{{ states(''sensor.4ch_relay_wifi_signal_percent'')}}%'
        icon: mdi:wifi
        multiline_secondary: true
        icon_color: >-
          {% set state =
          states('sensor.4ch_relay_wifi_signal_percent')|float(-1) %}
          {% if state >= 20 %} blue
          {% else %} red
          {% endif %}
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
              margin-top: -30px;
        secondary: |-
          {% set s = states('sensor.4ch_relay_uptime_sensor')|int %}
           {{ s | timestamp_custom("%H:%M:%S", false) }}
        primary: Uptime
        icon: mdi:timer
        icon_color: blue
        entity: sensor.4ch_relay_uptime_sensor
        tap_action:
          action: more-info
        layout: vertical
      - type: custom:mushroom-entity-card
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
              margin-top: -30px;
        layout: vertical
        secondary_info: state
        tap_action:
          action: toggle
        entity: input_boolean.esphome_backlight
        icon: mdi:fit-to-screen
        icon_color: blue
    card_mod:
      style:
          h1.card-header {
            font-size: 16px;
            padding-top: 1px;
            padding-bottom: 18px;
            color:var(--secondary-text-color);
    mode: horizontal
    card_mod:
      style: |
        ha-card {
          border: none;
          box-shadow: none;
          margin-top: -15px;
    cards:
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        secondary: Pump & filter
        icon: mdi:water-pump
        icon_color: |-
          {% set state = states('switch.4ch_relay_relay1') %}
          {% if state >= "on" %} green
          {% else %} grey
          {% endif %}
        badge_icon: mdi:numeric-1-box-outline
        badge_color: blue
        tap_action:
          action: toggle
        entity: switch.4ch_relay_relay1
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        secondary: Air Pump
        icon: mdi:chart-bubble
        icon_color: |-
          {% set state = states('switch.4ch_relay_relay2') %}
          {% else %} grey
          {% endif %}
        badge_icon: mdi:numeric-2-box-outline
        badge_color: blue
        tap_action:
          action: toggle
        entity: switch.4ch_relay_relay2
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        secondary: Waterfall
        icon: mdi:waterfall
        icon_color: |-
          {% set state = states('switch.4ch_relay_relay3') %}
          {% else %} grey
          {% endif %}
        badge_icon: mdi:numeric-3-box-outline
        badge_color: blue
        tap_action:
          action: toggle
        entity: switch.4ch_relay_relay3
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        secondary: Bridge Downlights
        icon: mdi:light-flood-down
        icon_color: |-
          {% set state = states('switch.4ch_relay_relay4') %}
          {% else %} grey
          {% endif %}
        badge_icon: mdi:numeric-4-box-outline
        badge_color: blue
        tap_action:
          action: toggle
        entity: switch.4ch_relay_relay4
        layout: vertical
No need to change. border-radius: 10px 10px 0px 0px; in two spots will fix it.
cards:
    primary: p o n d
    icon: mdi:fish
    icon_color: blue
    card_mod:
      style: |
        ha-card {
            border: 1px;
            box-shadow: none;
            margin-top: 1.5rem;
    keep:
      background: true
      box_shadow: true
    mode: horizontal
    cards:
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
              margin-top: -30px;
        primary: Wifi
        icon: mdi:wifi
        icon_color: >-
          {% set state =
          {% else %} red
          {% endif %}
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
              margin-top: -30px;
        secondary: |-
        primary: Uptime
        icon: mdi:timer
        icon_color: blue
        tap_action:
          action: more-info
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
              margin-top: -30px;
        layout: vertical
        tap_action:
          action: toggle
        icon_color: blue
    card_mod:
      style: |
        ha-card {
            border: none;
            padding-top: 1px;
            --ha-card-header-font-size: 16px;
    mode: horizontal
    card_mod:
      style: |
        ha-card {
         border: none;
          box-shadow: none;
          margin-top: -15px;
          border-radius: 0px 0px 10px 10px;
          --ha-card-header-font-size: 5px !important;
    cards:
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        icon_color: |-
          {% else %} grey
          {% endif %}
        badge_color: blue
        tap_action:
          action: toggle
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        secondary: Air Pump
        icon_color: |-
          {% else %} grey
          {% endif %}
        badge_color: blue
        tap_action:
          action: toggle
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        icon: mdi:waterfall
        icon_color: |-
          {% else %} grey
          {% endif %}
        badge_color: blue
        tap_action:
          action: toggle
        layout: vertical
        card_mod:
          style: |
            ha-card {
              border: none;
              box-shadow: none;
        icon_color: |-
          {% else %} grey
          {% endif %}
        badge_color: blue
        tap_action:
          action: toggle
        layout: vertical
brilliant, I should of thought about that.
so I can use the same principle to apply a border to one side or top and bottom for example.
Thanks again
Yes sir!!!
Finally had a chance to update the guide to the newest version of Mushroom and Card Mod.
This now fixes the issues with addressing icons in buttons on cards that have them. and fixes the change in addressing text color.
i am still extremely busy at work, so this is not a return of me being able to respond to things sent to me.
Thank you so much for making this guide. You saved me hours and hours of troubleshooting.
