Left align was exactly what I was looking for, thank you!
What would be the best way to show the icon on the right side for the Person card?
Iām trying to create a profile icon that shows at the far right of the card, but with my code it shows different for each device. Would it be better to use a Template card in this scenario?
card:
type: custom:stack-in-card
cards:
- type: custom:mushroom-person-card
entity: person.hazio
icon_type: entity-picture
primary_info: none
secondary_info: none
layout: vertical
card_mod:
style: |
mushroom-badge-icon {
--badge-icon-size: 0px;
--badge-size: 10px;
outline: 3px #171717;
border-radius:50%;
top: 30px;
card_mod:
style:
mushroom-state-item$: |
.container {
display: flex;
flex-direction: column !important;
mushroom-state-info$: |
.container {
width: 83%;
align-items: center;
mushroom-shape-avatar$: ''
ha-card {
-icon-size: 20px;
width: fit-content;
margin: 5px 0px 0px 100px;
padding-left: 20px;
background: transparent !important;
border: 0px !important;
You mean like this?
This code works for any mushroom card:
Code
entity: person.dimitri_landerloos
card_mod:
style:
.container {
transform: scalex(-1);
align-items: end;
ha-card {
or just like this:
again code works for any mushroom card:
Code
card_mod:
style: |
ha-card {
mushroom-state-info {
Oh wow, thanks! Canāt believe I over complicated it, when itās just a single line of code. ![]()
Edit: @dimitri.landerloos Iāve noticed this flips the avatar as well. Would it be possible to flip it back to the right way? As Iām using a entity picture, itās quite noticeable.
card_mod:
style:
.container {
align-items: end;
mushroom-shape-avatar$: |
.container {
ha-card {
if using an avatar.
card_mod:
style:
.container {
align-items: end;
ha-card {
ha-state-icon {
if just using the icon still.
Hey there, Iāve been really struggling with getting animated state icons working with this chips card and was hoping to get some help. Iād like to make it so the chip for the fan will have a spinning icon only when the fan is on. I was able to get this working with a mushroom template card, but trying to transition to a chips card instead has been difficult.
Hereās the yaml:
type: custom:mushroom-chips-card
chips:
- type: light
entity: light.bedroom
content_info: none
hold_action:
action: none
double_tap_action:
action: none
use_light_color: true
icon: mdi:lightbulb
card_mod:
style: |
ha-card {
box-shadow: none !important;
border: none !important;
min-width: 0px !important;
width: 32px !important;
height: 32px !important;
justify-content: center;
- type: template
tap_action:
action: toggle
icon: mdi:fan
icon_color: '{{ ''amber'' if states(entity) == ''on'' else '''' }}'
card_mod:
style: |-
{% if is_state('light.bedroom_hue_plug', 'on') %}
ha-state-icon {
animation: spin 1.5s linear infinite;
{% elif is_state('light.bedroom_hue_plug', 'off') %}
{% endif %}
ha-card {
entity: light.bedroom_hue_plug
- type: action
tap_action:
action: navigate
navigation_path: /dashboard-test/bedroom-lights
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:cog
card_mod:
style: |
ha-card {
card_mod:
style:
mushroom-light-chip:nth-child(1)$: |
ha-state-icon {
--chip-icon-size: 30px;
ha-card {
--chip-spacing: 13px;
padding-right: 5px;
padding-bottom: 2px;
height: 35px;
mushroom-template-chip:nth-child(2)$: |
ha-state-icon {
@keyframes spin {
100% {transform: rotate(360deg);}
ha-card {
padding-right: 5px;
height: 35px;
mushroom-action-chip:nth-child(3)$: |
ha-state-icon {
ha-card {
padding-right: 5px;
height: 35px;
chips:
- type: template
icon: mdi:fan
icon_color: red
entity: switch.4ch_relay_relay1
card_mod:
style:
mushroom-template-chip:nth-child(1)$: |
ha-state-icon {
{% if 'on' in states('switch.4ch_relay_relay1') %}
animation: spin 1s linear infinite;
{% endif %}
@keyframes spin {
you have to do everything in the one place
Thanks! Below code works:
chips:
- type: light
content_info: none
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:lightbulb
card_mod:
style: |
ha-card {
- type: template
tap_action:
action: toggle
icon: mdi:fan
card_mod:
style: |-
ha-state-icon {
{% endif %}
ha-card {
- type: action
tap_action:
action: navigate
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:cog
card_mod:
style: |
ha-card {
card_mod:
style:
ha-state-icon {
ha-state-icon {
@keyframes spin {
ha-state-icon {
{% endif %}
ha-state-icon {
ha-card {
--chip-spacing: 25px;
padding-right: 5px;
height: 35px;
I have removed the background from the chips card according to your guide, also tried removing box shadow.
I still get a small border showing on the gradient part of my background. Very obvious on my phone, not on my computer:
How do I remove this, around the right icon?
Hey everyone. Looking to get some help on a the last few items for my setup. Iāve typically been able to get things working through trial and error, but I canāt seem to figure these out. Any help would be appreciated.
The first are these circular buttons in the Frigate card. Iām trying to change the background circle color, as well as the icon color:
For the background circle color, the card-mod helper output is
"body>home-assistant$home-assistant-main$ha-drawer>partial-panel-resolver>ha-panel-lovelace$hui-root$#view>hui-view>hui-masonry-view$#columns>div>hui-vertical-stack-card$#root>frigate-card$#ha-card>frigate-card-menu$div.matching>ha-icon-button:nth-child(1)"
with the property to change being background-color within ha-icon-button.button.
The icon color for it is within the same card-mod helper output, and the property is color, but this is not within ha-icon-button.button.
The last thing is the selected icon color within the controls in a tile card:
The card-mod helper output is:
"body>home-assistant$home-assistant-main$ha-drawer>partial-panel-resolver>ha-panel-lovelace$hui-root$#view>hui-view>hui-masonry-view$#columns>div>hui-vertical-stack-card$#root>hui-tile-card$ha-card>hui-card-features$hui-fan-speed-card-feature$div>ha-control-select$#option-off"
with the property being color within .option.selected
For all of these, Iām able to get the property I want changed when inspecting, but canāt figure out how to format it properly for card-mod.
Neither of these questions relate to mushroom and card mod. Please create a new post or post these questions in the card mod thread.
- Post your code.
- Have you tried to remove any border as well?
Had both open in tabs and posted here by accident, sorry about that!
Iām struggling to do what feels like it should be a fairly simple task: I want my door contact sensors to be green when closed (āsafe/all goodā color) and red when they are open. I have this working in Mushroom as long as I use a template card. I have been advised that I should be instead using a Theme and globally modifying the behavior that way. However, I have not been able to successfully get the icon color right even with non-theme attempts when using CardMod. The biggest issue has been getting the icon background to be light/partly translucent. When I specify a color in a template this seems to be done automatically. Examples Iāve seen online all seem to also show that this is not something that is handled manually. Iām aiming for the look of the bottom right card.
First Method: sets icon and background independently, but does not make background translucent.
- type: custom:mushroom-entity-card
entity: binary_sensor.basement_door_contact_sensor
card_mod:
style:
mushroom-shape-icon$: |
.shape {
background-color: {{ 'green' if is_state('binary_sensor.main_door', 'off') else 'var(--green-color)' }} !important;
ha-state-icon {
color: var(--black-color);
Second Method: Sets the icon, but not the background
card_mod:
style: |
ha-state-icon {
color: var(--orange-color);
Third Method: Sets the background, ignores code that works in method 2 for the icon
card_mod:
style: |
mushroom-shape-icon {
--shape-color: var(--pink-color);
--shape-color-disabled: var(--blue-color);
ha-state-icon {
Fourth Method: Does everything I want, but is a hassle to copy/paste and difficult to apply globally:
primary: Basement Door
secondary: |-
{% if is_state('binary_sensor.basement_door_contact_sensor', 'off') %}
Closed
{% else %}
Open
{% endif %}
icon: |-
mdi:door-closed
{% else %}
mdi:door-open
{% endif %}
icon_color: |-
green
{% else %}
red
{% endif %}
Hey, you could Set your binari.sensor as door.
Then the state und Icon got Set automaticly
1st method:
entity: binary_sensor.hallway_front_door_contact
card_mod:
style:
.shape {
background-color: {{ 'rgba(var(--rgb-green),0.2)' if is_state('binary_sensor.main_door', 'off') else 'rgba(var(--rgb-green),0.2)' }} !important;
ha-state-icon {
2nd method you already had working, but nothing other than icon was being changed.
3rd method:
card_mod:
style: |
--shape-color: rgba(var(--rgb-pink), 0.2);
--shape-color-disabled: rgba(var(--rgb-blue), 0.2);
ha-state-icon {
4th method you dont really need my input, but you can make it a tiny bit easier:
type: custom:mushroom-template-card
secondary: |-
{% if is_state(entity, 'off') %}
Closed
{% else %}
Open
{% endif %}
icon: |-
mdi:door-closed
{% else %}
mdi:door-open
{% endif %}
icon_color: |-
green
{% else %}
red
{% endif %}
FYI if you want to use this simplified if statement in the card mod section as well you have to use config.entity instead of just entity like i have above.
Thanks! This confirms that it isnāt done automatically for me, and that I have to add the transparency myself. How come we donāt need a .: - between mushroom-shape-icon and ha-state-icon?
Is there a good way to add this to a theme for all door types? I could figure out how to do it for more global things, but not how to narrow it down further. state-binary_sensor-door-off-color: var(--green-color) and state-binary_sensor-door-on-color: var(--red-color) seems to only apply to non-custom entities.
I already have the simplified template as:
primary: Front Door
secondary: |-
{% if is_state(config.entity, 'off') %}
Closed
{% else %}
Open
{% endif %}
icon: |-
mdi:door-closed
{% else %}
mdi:door-open
{% endif %}
icon_color: |-
green
{% else %}
red
{% endif %}
Do you have a suggested method between the options? Theme it globally? Or just use the template?
Correct. The transparency is done by mushroom dynamically when you select a color if you override this color with card mod you have to add transparency back yourself.
You only need to use .: | if you have previously entered the shadow-root of an object, using $. If you dont do that you dont have to use .: | at all. Take a look at the section in the top post called
Its not easy to theme for specific entity types, and i am not too experienced with themes honestly.
I think for what you want to do its probably best to look into the Decluttering card. You can define templates and then use them across multiple cards.
so I have the
- type: custom:mushroom-chips-card
chips:
and I want the card centered
so I was thinkingā¦
chips:
card_mod:
style: |
ha-card {
but it looks it isnāt working
