Mushroom Cards Card Mod Styling/Config Guide
Drops down
Expands upwards
That helps a bunch. Iā€™ll take a look. :eyes:
check out this thread
Sorry, not sure what to look at. Couldnā€™t find anything related.
This portionā€¦
card_mod:
          style:
            mushroom-select-option-control$:
              mushroom-select$: |
                .mdc-select__anchor{
                  background: none !important;
                  border-radius: 20px !important;
                .mdc-line-ripple::before {
                  border-bottom-width: 0px !important;
                .mdc-line-ripple::after {
                .mdc-select__selected-text {
                  color: transparent !important;
                .mdc-select__dropdown-icon {
                  fill: transparent !important;
                .mdc-select {
                  position: absolute !important;
                  width: 100% !important;
                  --select-height: 97px;
                  top: 0%;
                  right: 0%;
OK, Iā€™ll look into it when I get home and let you know how it works. Thank you!
So far this is what Iā€™ve found while inspecting the CSS. It seems that the list is created under the ā€œ.mdc-menu-surfaceā€ class, and one property that drew my attention was ā€œtransform-originā€, not sure if Iā€™m on the right track though, nor how to reference that, in order to overwrite the properties there.
Hi all, need your expertise advice on how I could fine tune my mushroom template card to achieve the following. Sample code snippet only showing the card for Den.
I wonder if it is possible to have tooltip (or call it hover text if you wish) when hover the battery badge icon to show the actual reading of the blind battery sensor.
type: grid
cards:
  - type: custom:stack-in-card
    cards:
        primary: Den
        secondary: |-
          {% if is_state('cover.den_blind','open') %}
            Open
          {% elif is_state('cover.den_blind','closed') %}
            Closed
          {% else %}
            {{ states('sensor.den_blind_motor_state') }}
          {% endif%}
          - {{ state_attr('cover.den_blind', 'current_position') }}%
        icon: |-
            mdi:window-shutter-open
          {% else %}
            mdi:blinds-horizontal-closed
          {% endif%}
        badge_icon: |-
          {% set bl = states('sensor.den_blind_battery') | int %}
          {% if bl < 10 %} mdi:battery-outline
          {% elif bl < 20 %} mdi:battery-10
          {% elif bl < 30 %} mdi:battery-20
          {% elif bl < 40 %} mdi:battery-30
          {% elif bl < 50 %} mdi:battery-40
          {% elif bl < 60 %} mdi:battery-50
          {% elif bl < 70 %} mdi:battery-60
          {% elif bl < 80 %} mdi:battery-70
          {% elif bl < 90 %} mdi:battery-80
          {% elif bl < 100 %} mdi:battery-90
          {% elif bl == 100 %} mdi:battery
          {% else %} mdi:battery-unknown
          {% endif %}
        badge_color: |-
          {% if bl < 10 %} red
          {% elif bl < 20 %} red
          {% elif bl < 30 %} red
          {% elif bl < 40 %} orange
          {% elif bl < 50 %} orange
          {% elif bl < 60 %} green
          {% elif bl < 70 %} green
          {% elif bl < 80 %} green
          {% elif bl < 90 %} green
          {% elif bl < 100 %} green
          {% elif bl == 100 %} green
          {% else %} disabled
          {% endif %}
        tap_action:
          action: none
        card_mod:
          style: |
            mushroom-badge-icon {
              left: 30px;
            ha-card {
              box-shadow: none;
              --ha-card-border-width: 0px;
      - type: custom:mushroom-cover-card
        entity: cover.den_blind
        primary_info: none
        secondary_info: none
        icon_type: none
        tap_action:
          action: none
        show_buttons_control: true
        card_mod:
          style: |
            ha-card {
              margin-top: -20px;
              box-shadow: none;
    card_mod:
      style: |
        ha-card {
          {% if is_state('cover.den_blind','open')}
              background: rgba(101,170,91,0.2);
          {% else %}
              background: rgba(226,84,66,0.2);
          {% endif %}
Thanks in advance!
G
got no way of testing but I think you can play around with
ha-card:hover
if the card uses ha-card that is
@Frosty is on the right trackā€¦ If you want to isolate the badge,use mushroom-badge-icon:hover {
I am unsure if you can get the state of cover battery to appear. Iā€™d have to think about a method to accomplish that.
card_mod:
  style: |
      left: 30px;
      transform: scale(5);
      transform-origin: top center;
      z-index: 1;
      transition: all 1s;
    ha-card {
      box-shadow: none;
another option is to add a second badgeā€¦
tap_action:
  action: toggle
card_mod:
  style: |
    ha-state-icon::after {
      content: "{{ states('sensor.basement_sensor_battery') }}";
      position: absolute;
      top: 0%;
      right: 80%;
      display: flex;
      justify-content: center;
      align-items: center;
      width: 14px;
      height:14px;
      border-radius: 50%;
      background-repeat: no-repeat;
      background: red;
      font-size: 9px;
      left: 28px;
      z-index: 1;
      transition: all 1s;
    ha-card {
      box-shadow: none;
One more option that is a bit hacky, but worksā€¦
type: custom:mushroom-template-card
primary: Hover
secondary: more info
entity: cover.bed_curtains
icon: mdi:curtains
icon_color: white
badge_icon: |-
  {% set bl = states('sensor.bed_curtains_battery') | int %}
  {% endif %}
badge_color: |-
  {% set bl = states('sensor.bed_curtains_battery')| int(0) %}
  {% elif bl <= 100 %} green
  {% else %} disabled
  {% endif %}
tap_action:
  action: toggle
card_mod:
  style:
    mushroom-state-info$: |
     .primary {
        color: green !important;
        margin-left: 10px !important;  }
      .secondary {
        color: white !important;
       content: "{{ states('sensor.bed_curtains_battery') }}";
       position: absolute;
       top: -10px;
       left: 30px;
       display: flex;
       width: 24px;
       height:24px;
       border-radius: 50%;
       background: blue;
       font-size: 12px;
       font-weight: bold;
       --main-color: transparent !important;
       --icon-color: transparent;
       transform: scale(3);
       z-index: 1;
       transition: all 1s;
       left: 30px;
       top: -10px;
       --badge-icon-size: 16px;
       --badge-size: 24px;
      ha-card {
       box-shadow: none;
Untitled video - Made with Clipchamp
Just a heads up, your color logic is overkill.
badge_color: |-
  {% else %} disabled
  {% endif %}
Is it possible to replace badge icon with entity state?
The only way I know how is to use a pseudo-element
primary: Hover
icon: mdi:curtains
icon_color: white
tap_action:
  action: toggle
card_mod:
  style:
      .primary {
       .secondary {
       position: absolute;
       top: -10px;
       left: 30px;
       display: flex;
       width: 24px;
       height:24px;
       border-radius: 50%;
       background: blue;
       font-size: 12px;
       font-weight: bold;
      ha-card {
       box-shadow: none;
If you search badge here, there are a lot of examples.
Thank you. But I need 2 badges with numbers :crazy_face:
just use two pseudo-elements
primary: Hover
icon: mdi:curtains
icon_color: white
tap_action:
  action: toggle
card_mod:
  style:
      .primary {
       .secondary {
       position: absolute;
       top: -10px;
       left: 30px;
       display: flex;
       width: 24px;
       height:24px;
       border-radius: 50%;
       background: blue;
       font-size: 12px;
       font-weight: bold;
      ha-state-icon::before {
       position: absolute;
       top: -10px;
       left: -16px;
       display: flex;
       width: 24px;
       height:24px;
       border-radius: 50%;
       background: green;
       font-size: 12px;
       font-weight: bold;
       z-index: 1
      ha-card {
       box-shadow: none;
super cool! thank you!
The code I provide is a rough draft. Other elements will need to shift right with this method.
Happy codingā€¦
it works great!
Iā€™ve been at this for hours trying to combine fixing the height of the slider with the ha-card height, and Iā€™m currently at the point where my laptop is soon going to fly out of the window. Why the **** doesnā€™t this work, please, for the love of god, enlighten me. Iā€™ve tried all possible combinations of intends on .: and it still doesnā€™t work. Except the combination that works that I havenā€™t found yet.
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: vertical-stack
        cards:
          - type: custom:mushroom-light-card
            entity: light.light_bulb_vardagsrummet_golvlampan
            show_brightness_control: true
            use_light_color: true
            card_mod:
              style: |
                ha-card {
                  height: 200px !important;
                  width: 200px;
                mushroom-light-brightness-control$:
                  mushroom-slider$: |
                    .slider {
                      width: 400px !important;
entity: light.lounge_main_light
card_mod:
  style:
      mushroom-slider$: |
        .slider {
      ha-card {
        width: 200px;
Or:
card_mod:
  style:
      ha-card {
        width: 200px;
      mushroom-slider$: |
        .slider {
Hi, can you help me with the select card? Or if this is hard to achieve, cause it seems that nobody can help, at least how can I make the list element visible outside a parent container with the overflow property set to scroll?
Or at least how can i reference the ā€œ.mdc-menu-surface.mdc-menu-surfaceā€“fixed.mdc-menu-surfaceā€“openā€ class, so I could overwrite itā€™s values?
Anyone?
