Mushroom Cards Card Mod Styling/Config Guide
We talked about this if you scroll up in the topic a bit. If your entity has an on off state it seems like --shape-color is only being applied when the entity is on.
If you wanted to change regardless of on state you can use:
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: orange !important;
I am still needing to update the documentation to reflect this.
Can I not change the name or Second-Info in the Mushroom-Entity-Card
status in the Mushroom-Entity-Card, or what do I have to do to
card to get this to work?
state:
  - value: 'on'
  - value: 'off'
or in this way for the name?
{% if is_state('automation.heizung_anne', 'on') %} ..... ???
You can only use templates in cards that support templates. the only cards in Mushroom that support templates are:
Mushroom Template Card
Mushroom Title Card
Mushroom Chips Card (If using a Template Chip)
The only other way to change things and use templates in cards that dont support it, is with card mod.
Thanks Dimitri for info.
How would you do it then. I am biting my teeth on it right now
I have shown you how to replace certain text with another here:
try and use this example to figure out how to solve your problem :slight_smile:
How do I remove the button and keep only the slider?fe35d14279dfa3ba08d0ab5a2ce46804ca45d675_2_690x126
Like this? Or do you want still keep the name and state?
type: custom:mushroom-light-card
entity: light.bedroom_chest_lamp
use_light_color: true
show_brightness_control: true
layout: horizontal
card_mod:
  style: |
    mushroom-state-item {
      display: none;
layout: horizontal
card_mod:
  style:
    mushroom-light-brightness-control$:
      mushroom-slider$: |
        .container {
          position: absolute;
          width: 94% !important;
          left: 10px;
      mushroom-shape-icon {
        display: none;
      mushroom-state-info {
        z-index: 1;
        pointer-events: none;
Success, thank you :+1:
Is it possible to change the Card-Background if an Entity is on?
‘{% if is_state(‘light.wohnzimmerlicht’, ‘on’) %}
orange
{% else %}
grey
{% endif %}’
Is there any Code?
all i use… colored background if lights are on … default background if nothing is on
type: custom:stack-in-card
card_mod:
  style: |
    ha-card {
      background-color: {{ '#190019' if is_state('light.living_room_group', 'on') else '' }};
cards:
Look at the examples in the first post on the section about templating in card mod :slight_smile:
Hello everyone,
i am trying to color the “mushroom-slider” of a mushroom-number-card,
depending on the “is_volume_muted”-attribute of a media player entity.
Could anyone nudge me in the right direction on how to accomplish this?
something like this?
type: custom:mushroom-number-card
entity: input_number.dishwasher_pod_add
display_mode: slider
icon_color: green
card_mod:
  style:
    mushroom-number-value-control$: |
      mushroom-slider {
        {% if state_attr('media_player.office_speaker','is_volume_muted') != true %}
          --slider-color: rgba(var(--rgb-{{config.icon_color}}), 1) !important;
          --slider-bg-color: rgba(var(--rgb-{{config.icon_color}}), 0.2) !important;
        {% else %}
          --slider-color: rgba(var(--rgb-grey), 1) !important;
          --slider-bg-color: rgba(var(--rgb-grey), 0.2) !important;
        {% endif %}
the {{config.icon_color}} is only there to support whatever color you choose to use in your card. so if you update the icon_color: green to lets say red instead. then the bar would color along with that.
EXACTLY like this.
Thanks a lot!
Dimitri?
can ya guide to how to get a border on my chips?
i could not find it in Your guides…
card_mod:
  style:
    mushroom-entity-chip:nth-child(1)$: |
      ha-state-icon {
        {% if is_state('switch.computer','on') %}
        animation: shake 400ms ease-in-out infinite;
       transform-origin: 50% 90%;
        clip-path: polygon(24% 0, 100% 0, 100% 100%, 0 100%, 0 75%, 62%);
        {% else %}
        {% endif %}
      @keyframes shake {
        0%, 100% { transform: rotate(3deg); }
        50%  { transform: rotate(-3deg); }
this border i wanted to use…
border: 0.5px outset grey;
can be done through the chip itself rather than drilled down from the main chip card:
type: custom:mushroom-chips-card
chips:
  - type: entity
    entity: person.dimitri_landerloos
    card_mod:
      style: |
        ha-card {
          border: 2.5px outset green !important;
wow! so easy!..pfffuuuu
thank You sir! keep on rocking!
Hi unfortunately I have to ask a question again. Today it is about two “switches” in one card.
One is the “MAIN-SWITCH” the other is another switch which is only on when the main is on.
So far it is so lalala … if I can make it better, please let me know.
But how can I at least assign a free text to primary and secondary, which shows me the name of the two switches.
cards:
  - type: custom:mushroom-entity-card
    entity: switch.esz_sw_unifi
    name: ❮ ezSW-eMAIN ❯
    fill_container: true
    secondary_info: name
    primary_info: name
    icon_type: icon
    secondary: none
    collapsible_controls: true
    show_color_temp_control: true
    show_color_control: true
    double_tap_action:
      action: more-info
    hold_action:
      action: more-info
    card_mod:
      style:
          .shape {
            --icon-symbol-size: 25px;
            --icon-size: 36px;
          mushroom-state-info$: |
            .container {
              --card-secondary-font-size: 10px;
              --card-primary-font-size: 10px;
            ha-card {
              box-shadow: 0px 0px 0px 0px rgb(32,150,243, 0.6);
              border-radius: 6px;
              {% if states(config.entity) == 'on' %}
                border: 2.5px outset rgb(32,150,243, 0.6) !important;
              {% else %}
                border: none;
              {% endif %}
              font-family: "Roboto";
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        icon: mdi:power
        entity: switch.phone_board_main
        secondary_info: none
        card_mod:
          style: |
            ha-card {
                border: 4px outset rgb(32,150,243, 0.6) !important;
              {% else %}
                border: 4px outset transprant !important;
              {% endif %}
    alignment: end
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 12px;
          right: 13px;
          --chip-spacing: -8px !important;
Is there a way to change the positions of the text (primary) and the icons?
A lot of times I want the icon to be on the right like a normal entity card.
Knipsel
type: custom:mushroom-template-card
primary: livingroom
icon: mdi:toggle-switch-off-outline
card_mod:
  style:
      .container {
        align-items: end;
Oke I got it.
The only thing I cant get to work, is to add a shadow to the mushroom-shape-icon
entity: light.livingroom
card_mod:
  style:
      .container {
        align-items: start;
        transform: scalex(-1);
      ha-card {
        ha-card-background: none;
        --shape-color: rgba(255,255,255,0.9) !important;
