Mushroom Cards Card Mod Styling/Config Guide
Shape shadow:
type: custom:mushroom-light-card
entity: light.bedroom_chest_lamp
secondary_info: none
icon: mdi:toggle-switch
card_mod:
  style:
    mushroom-state-info$: |
      .container {
        align-items: start;
        transform: scalex(-1);
    mushroom-shape-icon$: |
      .shape {
        box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.36) !important;
      ha-card {
        ha-card-background: none;
      mushroom-shape-icon {
        --shape-color: rgba(255,255,255,0.9) !important;
Thank you so much. I can see my mistake now.
Is there also a way to center the chipcard (vertically seeing) next to a title card? I cant see anything about alignment in the chip card documentation. Now if I place a chipcard next to a title card. The chipcard is slightly above center.
Knipsel
type: horizontal-stack
cards:
  - type: custom:mushroom-title-card
    title: Livingroom
  - type: custom:mushroom-chips-card
    chips:
      - type: entity
        entity: sensor.battery_living
    alignment: end
With the code down here I can get it to work (sort of), but I dont think this is the right way to do it
cards:
    title: Livingroom
    chips:
      - type: entity
    alignment: end
    card_mod:
      style: |
        ha-card {
          margin-top: 8%;
          margin-bottom: 8%;
If you add outlines to each of the card you would see what the actual issue is. it is because the chip card doesnt have the same height at all as the title card. so we first need to ensure that this is the case. so we set the height to 100% so that it takes up the maximum space. the chips also live in a container that then also needs to be the same height as the card. so set to 100% too. we can then align the items to the center. if we did it before without changing the heights nothing would happen as the card is basically the same height as the chip already.
cards:
    title: Livingroom
    card_mod:
      style: |
        ha-card {
          outline: blue solid 1px !important;
    chips:
      - type: entity
        entity: sensor.alarm_time
    alignment: end
    card_mod:
      style: |
        ha-card {
          outline: red solid 1px !important;
          height: 100%;
          justify-content: center !important;
        .chip-container {
          height: 100%;
          border: green solid 1px !important;
          align-items: center !important;
try it without the heights being set and see what it looks like. you can see what is happening with the outlines there.
Just as we did with the other times you wanted to replace text with other text in card that doesnt support itā€¦
but instead of using a template, just write your text that you want.
card_mod:
  style:
      .secondary {
        color: transparent !important;
        position: relative;
      .secondary:after {
        content: 'Test';
        color: var(--secondary-text-color);
        position: absolute;
        left: 0px;
Hi Dimitri,
Iā€™m not finding what Iā€™m looking for, hope you can help.
is it possible to modify the ā€œbuttonā€ part in the number-card?
I would like to change the font-size, background-color, etcā€¦
mushroom number card
Yes, and i am very surprised that this hasnt been pointed out by anyone before. looks like i mistakenly have said that the number card does not have buttons. that is just plainly wrong, so ill have to update that section :slight_smile:
but for now here you go :slight_smile:
type: custom:mushroom-number-card
entity: input_number.dishwasher_pod_add
display_mode: buttons
card_mod:
  style:
    mushroom-number-value-control$: |
      mushroom-input-number {
        font-size: 20px;
        --text-color: red;
        --icon-color: blue;
        --bg-color: rgba(var(--rgb-green), 0.2);
Fantastic!
Thank you sir :slight_smile:
Dear all,
first of all thank you for this page, because it helped me already a lot to customize the mushroom cards to my needs. With one thing I still struggle unfortunately. Is it also possible to change the width of all the chips in the chips card? I want that they have the same width independent of the content in the chips.
Greetz to all!
Hi @dimitri.landerloos, This is just great!. I have been testing this in my lab page :grinning:
I have a thing that is not working. Individually they are but when put together one of the two stops working.
This is my code:
type: custom:mushroom-template-card
primary: Hello,
secondary: How are you?
icon: mdi:home
card_mod:
  style: |
    ha-card {
      font-variant: small-caps;
      .container {
       --card-secondary-font-size: 45px;
       --card-primary-font-size: 58px;
        --primary-text-color: #EA906C;
        --secondary-text-color: teal;
        align-items: end;
badge_icon: ''
badge_color: ''
When I do it this way the font size and color is not working. Must be something I am doing wrong but I tried many different combinations but I canā€™t figure it out.
greetings
Have a look in the first post the section about what the $ and .: | symbols do. But to fix your code its just this:
primary: Hello,
icon: mdi:home
card_mod:
  style:
      .container {
        align-items: end;
      ha-card {
badge_icon: ''
badge_color: ''
You are great and thanks for explaining the $ and .: | symbols
It is somewhat clear now :rofl: At least I know how it should be used.
You could set a min and max width to the same on all your chip types like this. But content will overflow.
chips:
  - type: entity
    entity: person.dimitri_landerloos
  - type: template
    icon: mdi:test-tube
    icon_color: green
  - type: weather
    entity: weather.openweathermap
  - type: conditional
    conditions:
      - condition: state
        entity: light.lounge_main_light
        state: 'on'
    chip:
      type: alarm-control-panel
      entity: alarm_control_panel.home_mode
  - type: spacer
  - type: menu
  - type: light
    entity: light.pc_lights
card_mod:
  style: |
    mushroom-template-chip {
      max-width: 80px;
      min-width: 80px;
    mushroom-conditional-chip {
      max-width: 80px;
      min-width: 80px;
    mushroom-entity-chip {
      max-width: 80px;
      min-width: 80px;
    mushroom-weather-chip {
      max-width: 80px;
      min-width: 80px;
    mushroom-light-chip {
      max-width: 80px;
      min-width: 80px;
    mushroom-menu-chip {
      max-width: 80px;
      min-width: 80px;
    mushroom-spacer-chip {
      max-width: 80px;
      min-width: 80px;
Or maybe a bit neater like this:
chips:
  - type: entity
  - type: template
    icon: mdi:test-tube
    icon_color: green
  - type: weather
  - type: conditional
    conditions:
      - condition: state
        state: 'on'
    chip:
  - type: spacer
  - type: menu
  - type: light
card_mod:
  style: |
    mushroom-template-chip,
    mushroom-conditional-chip,
    mushroom-entity-chip,
    mushroom-weather-chip,
    mushroom-light-chip,
    mushroom-menu-chip,
      max-width: 80px;
      min-width: 80px;
When I do this it creates an extra border around my weather chip, it does not replace the border that is already there. And I actually want to remove my border but I have no luck with that either :slight_smile:
SchermĀ­afbeelding 2023-11-13 om 14.39.31
I have done it like this now:
card_mod:
  style: |
    ha-card {
      --chip-background: transparent;
      --chip-border-color: transparent;
Is that the right way?
With that you are making it so all chips have no background and no border. If thats what you want then sure.
Otherwise if you only want to change one at a time you need to make sure you place the card mod under the chip itself like this for example.
SmartSelect_20231113_135559_Home Assistant
chips:
  - type: template
    icon: mdi:test-tube
    card_mod:
      style: |
        ha-card {
          border: inset blue 2px !important;
  - type: template
    icon: mdi:test-tube
    card_mod:
      style: |
        ha-card {
          border: outset green 2px !important;
What you have used is like this:
chips:
  - type: template
    icon: mdi:test-tube
  - type: template
    icon: mdi:test-tube
card_mod:
  style: |
    ha-card {
And this will apply to the card containing the chips, instead of the chip itself.
Thanks! good to know the difference to :+1:
Template card with vertical layout.
Iā€™m looking to bring the Off (primary) up closer to the bottom of the button and struggling.
Any help is appreciated. Thanks!
Please do post what you have tried next time :slight_smile:
primary: 'Off'
secondary: Test
icon: mdi:power
layout: vertical
card_mod:
  style:
      .primary {
        position: relative;
        bottom: 10px !important;
Hi guys :wave:
I have this interesting problemā€¦ I would like to animate a chip card with the condition.
If I write the script like this, the icon is displayed when ā€œinput_boolean.vd_testā€ is turned on, but the animation does not work :frowning:
chips:
  - type: conditional
    conditions:
      - condition: state
        entity: input_boolean.vd_test
        state: 'on'
    chip:
      type: template
      tap_action:
        action: toggle
      icon: mdi:test-tube
      icon_color: red
card_mod:
  style:
    mushroom-conditional-chip:nth-child(1):
      mushroom-template-chip$: |
        ha-state-icon {
          animation: pulse 2s ease-in-out infinite;
But when I create a classic ā€œcustom:mushroom-template-cardā€ the animation works normally :exploding_head:
icon: mdi:pulse
icon_color: accent
primary: ''
secondary: Aktivita domƔcnosti
card_mod:
  style: |
    ha-state-icon {
    ha-card {
     border: unset;
     background: unset;
     padding-left: 0px !important;
Does anyone know where the problem might be? :ok_man: :speak_no_evil:
I am redesigning a mobile dashboard and would like to display chip cards based on conditions. Of course animated icons :smiley:
hamobile
For example, if the washing machine is on, show the icon and animate it.
Thank you in advance for any help! :clap:
@dimitri.landerloos , i tried this card mod code. the static boder line works. the animated border does not work on this card.
im trying to show the border when there is motion, for now the border stays ad all time. Can you pherhaps point me in the right direction?
the code:
show_state: false
show_name: false
camera_view: live
type: picture-entity
entity: camera.oprit
camera_image: camera.oprit
aspect_ratio: 16x9
card_mod:
  style: |
    ha-card {
      -- if (binary_sensor.motion_sensor_inloopkast_occupancy == 'on') return;
      border: 2.5px outset red
the output:
the red border is there all the time.
