yes. I have a custom theme created, and the latest version of the card mushroom is 5.0.8.
yes, this is not the first time I use the card mod, but due to the lack of programming knowledge, it is not easy for me.
Is your Theme only Mushroom related or is it card-mod-theme: based?
not only mushrooms, I also style other cards in card-mod-card:
card-mod-card: |
mushroom-shape-icon {
--shape-color: none !important;
--shape-color-disabled: none !important;
ha-card {
--chip-background: none;
This thread is probably not the best place for your question. Iâd move it to
Many thanks, but unfortunately this is not working ![]()
Not sure if the custom:mushroom-template-card has a special behaviour hereâŚ
Do you have another idea?
Many many thanks in advance!!!
This should work. Here is my working example
type: custom:mushroom-template-card
primary: Hello, {{user}}
secondary: How are you?
icon: mdi:mushroom
features_position: bottom
tap_action:
action: more-info
color: green
card_mod:
style:
ha-card {
--ha-card-background: red;
ha-tile-icon$: |
.container {
background: blue;
I found the issue @RkcCorian is experiencing. When you add a entity to the Template card and want the background transparent, you have to use ![]()
primary: Hello, LiQuid_cOOled
icon: mdi:mushroom
entity: light.corner_stand
card_mod:
style:
ha-tile-icon$: |
.container:before {
display: none;
card_mod:
style:
ha-tile-icon$: |
.container:before {
background: none ;
or
card_mod:
style:
ha-tile-icon$: |
.container:before {
background: none !important ;
Good find on the ripple getting involved. Nice.
Nice!! The second one is working
card_mod:
style:
ha-tile-icon$: |
.container:before {
Many many thanks!!!
I am struggling to combine card mod to both color the icon conditionally based on entity state and set the secondary text to a fixed color. On their own each works but I cannot find a way to use both sets of styling in the one card. Here is my first card that colors the icon :
entity: sensor.r5_battery_level
icon: mdi:car-battery
card_mod:
style: >
ha-state-icon { {% set battery = states('sensor.hg25dyb_battery') | float
%} {% if battery > 50 %}
color: green;
{% elif battery > 25 %}
color: yellow;
{% else %}
color: red;
{% endif %} }
and here is the code to color the secondary text I want to add into the above card. I cant find a way to use both in the same card that works:
card_mod: style: mushroom-state-info$: | .container { --card-secondary-color: orange; }
Here some trouble with coloring primary and secondary text as well for the Mushroom Template Card
âback in the dayâsâ (I can;t remeber when) the following code worked for me:
card_mod:
style: |
ha-card {
height: 120px !important;
mushroom-card {
--icon-size: 60px;
--card-primary-font-size: 1.75rem;
--card-secondary-font-size: 1rem;
--card-secondary-color: {{ 'coral' if is_state_attr('climate.thermostat_attic', 'hvac_action', 'heating') else 'grey'}};
--card-primary-line-height: 30px;
Now I learned I probably have to do something different, as posted in the âtutorialâ posts something like:
card_mod:
style:
.container {
--card-primary-color: grey;
--card-secondary-color: coral;
Unfortunately this does not work for me. All text stayâs the same grey color. I tried to find a solution (working on it for quite some time before I reached out here).
I still would like to combine the mods I wrote in the first code (card height, icon size, font sizes, font color (depending on the state of the âhvac_actionâ) and line height. But unfortunately Iâm lost.
Start with this as an exampleâŚ
primary: Example
secondary: Icon/Fonts
icon: mdi:mushroom
card_mod:
style: |
ha-card {
ha-tile-icon {
--tile-icon-color: blue !important;
--mdc-icon-size: 44px;
#info {
--tile-info-primary-font-size: 20px;
--tile-info-secondary-font-size: 15px;
--tile-info-primary-color: orange;
--tile-info-secondary-color: lime;
Please specify the Mushroom card type. The card_mod code for Mushroom is card specific with recent updates.
Yes! Thanx for your âpush in the right directionâ!
Iâm using the mushroom template card.
I ended up with following, which suits my needs:
card_mod:
style:
ha-tile-icon$: |
.container:before {
background: none !important;
ha-card {
ha-tile-icon {
--mdc-icon-size: 40px;
--tile-icon-size: 45px;
#info {
--tile-info-primary-font-size: 1.75rem !important;
--tile-info-secondary-font-size: 1rem !important;
--tile-info-primary-line-height: 30px !important;
--tile-info-primary-color: grey !important;
--tile-info-secondary-color: {{ 'coral' if is_state_attr('climate.thermostat_attic', 'hvac_action', 'heating') else 'grey'}} !important;
My âHomeâ dashboard is up and running again:
I consider the code provided a little more than a push is the right direction ![]()
The card type question was directed at another user.
Happy to assist!
I have an input text helper which i want to show in the ui.
I want it so it has an inline text fieldâŚ
I tried using mushroom entity card, but then when i click i go to more info to fill in something.
Is it possible to fill in directly without going to the more info field?
Thx in advance !
Use a standard tile card and add the âselect optionsâ feature.
Hey there⌠i am using a bottom menu which worked for very long but one recent update broke it so it stays no longer at the bottom of my ios ha-app - browser works fine⌠any suggestions?
type: custom:mod-card
card:
type: grid
square: false
columns: 5
cards:
- type: custom:mushroom-chips-card
chips:
- type: template
icon: mdi:trash-can-outline
icon_color: teal
tap_action:
action: navigate
navigation_path: /dashboard-home/trash
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-teal), 0.2);
justify-content: center;
--chip-icon-size: 36px;
--chip-height: 48px;
- type: template
icon: mdi:gas-station
tap_action:
action: navigate
navigation_path: /dashboard-home/benzin
icon_color: cyan
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-cyan), 0.2);
- type: template
icon: phu:cupra
icon_color: "#B87333"
tap_action:
action: navigate
navigation_path: /dashboard-home/zug
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-blue), 0.2);
- type: template
icon: mdi:leaf
icon_color: purple
tap_action:
action: navigate
navigation_path: /dashboard-home/misc
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-purple), 0.2);
- type: template
icon: mdi:calendar
icon_color: pink
tap_action:
action: navigate
navigation_path: /dashboard-home/kalender
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-pink), 0.2);
alignment: justify
card_mod:
style: |
@media (min-width:180px) {
ha-card {
z-index: 1;
position: fixed;
bottom: 30px;
left: 10px;
width: calc(100% - 20px);
height: 68px;
background: #222222;
border-radius: 100px;
padding: 10px;
box-shadow: none;
transition: all 0s;
@media (min-width:1400px) {
ha-card {
width: calc(40% - 30px);
height: 68px;
left: calc(30% + 30px);
transition: all 0s;
card_mod:
style: |
ha-card {
z-index: 1;
position: fixed;
bottom: 30px;
left: 10px;
height: 68px;
padding: 10px;
box-shadow: none;
transition: all 0s;
ha-card {
height: 68px;
transition: all 0s;
Tested it on both a Masonry and Sections dashboards. I had no issues with the bottom sticky menu floating on my iPhone 16 Pro Max or my PCâs browser.
Hi together,
now I would like to add a shadow to the icon of my chips as well to the text. So not to the chip itself, but for the icon and the text. Can anybody help me here?
Many many thanks!
My current YAMLâŚ
chips:
- type: template
entity: sensor.haustemperatur
icon: mdi:thermometer
icon_color: "#FF6F22"
content: "{{ states(entity) | float | round(1) }} %"
tap_action:
action: more-info
double_tap_action:
action: navigate
navigation_path: /dashboard-haus/klima
card_mod:
style: |
ha-card {
border-width: 0px !important;
- type: template
entity: sensor.hausfeuchtigkeit
icon: mdi:water-percent
icon_color: "#2196F3"
tap_action:
action: more-info
double_tap_action:
action: navigate
card_mod:
style: |
ha-card {
- type: template
entity: sensor.beschattungsfreigabe
icon: |
{% if is_state(entity, 'on') %}
mdi:shield-sun
{% else %}
mdi:shield-moon-outline
{% endif %}
icon_color: |
var(--corian-blue)
{% else %}
var(--corian-gray)
{% endif %}
tap_action:
action: more-info
double_tap_action:
action: navigate
card_mod:
style: |
ha-card {
- type: template
entity: binary_sensor.hausbatterien
icon: |
mdi:battery-alert-variant-outline
{% else %}
mdi:battery
{% endif %}
icon_color: |
var(--corian-red)
{% else %}
var(--corian-gray)
{% endif %}
tap_action:
action: more-info
double_tap_action:
action: navigate
navigation_path: /dashboard-haus/infrastruktur
card_mod:
style: |
ha-card {
ha-state-icon {
{% if is_state('binary_sensor.arbeitszimmerfenster_links_batterie', 'off') %}
color: var(--success-color) !important;
{% else %}
color: var(--state-binary_sensor-battery-on-color) !important;
animation: blink 2s linear infinite;
{% endif %}
@keyframes blink {50% {opacity: 0;}}
- type: template
entity: binary_sensor.hausfenster
icon: |
mdi:window-open
{% else %}
mdi:window-closed
{% endif %}
icon_color: |
var(--corian-yellow)
{% else %}
var(--corian-gray)
{% endif %}
tap_action:
action: more-info
double_tap_action:
action: navigate
navigation_path: /dashboard-haus/sicherheit
card_mod:
style: |
ha-card {
- type: template
entity: binary_sensor.haustueren
icon: |
mdi:door-open
{% else %}
mdi:door
{% endif %}
icon_color: |
{% else %}
var(--corian-gray)
{% endif %}
tap_action:
action: more-info
double_tap_action:
action: navigate
card_mod:
style: |
ha-card {
alignment: end
card_mod:
style: |
ha-card {
position: absolute;
top: 9px;
left: 12px;
:host {
--chip-icon-size: 20px !important; /* Default is 24px */
--mush-chip-spacing: 0px; /* Standard ist 8px */
