i got it working i been wanting to see an example of someone adding it a template in chips. So thank you
type: template
entity: binary_sensor
icon: |
{% set state=states('binary_sensor.garage_door_status') %}
{% if state=='off' %}
mdi:garage-variant-lock
{% elif state=='on' %}
mdi:garage-open-variant
{% else %}
mdi:garage-alert-variant
{% endif %}
icon_color: |-
green
red
{% else %}
orange
{% endif %}
content: |-
Closed
Open
{% else %}
Neither
{% endif %}
tap_action:
action: toggle
hold_action:
action: call-service
service: switch.toggle
service_data: {}
entity_id: switch.garage_door_opener
nickrout
(Nick Rout)
2
Wrong forum section, you’re not sharing anything.
crap, i thought i wasnt sending a message lol need to delete this
Thanks, used your code and amended for my case, working great.
edit: chips now support pictures (including animated gifs) and this is how I set mine up:
entity: switch.pump_2_water_switch
type: template
picture: |
{% set state=states('switch.pump_2_water_switch') %}
/local/off_button_red.png
/local/water_arrow_down.gif
{% else %}
{% endif %}
content: |-
Stopped
Running
{% else %}
Stopped
{% endif %}
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
Footy
6
Hi all…saw this and thought that it would be perfect but I cannot get my icon to change based on the value of my sensor. Any help greatly appreciated
This is one part of a mushroom chip set
- type: entity
entity: sensor.bens_room_indoor_aqi
icon: mdi:blur
use_entity_picture: false
icon_color: >
{% set aqi=states('sensor.bens_room_indoor_aqi') | float %}
{% if aqi<=50 %}
green
{% elif aqi >=150 %}
red
{% else %}
orange
{% endif %}
How can I change the text color along with the icon_color?
Footy
9
I should be helpful and post the final code that I got working in case it is useful for someone else…
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: sensor.bens_room_average_temperature
icon: mdi:thermometer
icon_color: red
content_info: state
tap_action:
action: more-info
- type: entity
entity: sensor.temp_sensor_1_humidity
icon_color: blue
tap_action:
action: more-info
- type: entity
entity: sensor.bens_room_pm2_5
icon_color: brown
tap_action:
action: more-info
- type: template
icon: mdi:blur
icon_color: |-
{% if aqi<=50 %}
green
{% elif aqi>=150 %}
red
{% else %}
orange
{% endif %}
content: AQI {{ states(entity) }}
double_tap_action:
action: none
tap_action:
action: more-info
hold_action:
action: none
- type: template
icon: pap:nanoprotect_filter
icon_color: |-
{% set filter=states('sensor.bens_room_nanoprotect_filter') | float %}
{% if filter<=20 %}
red
{% else %}
black
{% endif %}
content: Filter {{ states(entity) }}%
entity: sensor.bens_room_nanoprotect_filter
tap_action:
action: more-info
- type: entity
entity: fan.bens_room
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
content_info: name
icon_color: purple
Appreciate you sharing your code, but you are going to get log errors using float without defining the default.
