Hello WebPower, which theme are you using? I love the colors. Great work Greetings Tom
Hi @ingo.niehues,
I don’t know why but my card looks different and not as expected.
This is my yaml:
type: custom:button-card
entity: sensor.gasverbrauch_monate
variables:
max_entity: sensor.gasverbrauch_monate_bis_ende
name: '[[[ return entity.attributes.friendly_name ]]]'
color: purple
units: '[[[ return entity.attributes.unit_of_measurement ]]]'
icon: mdi:calendar
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 3px
grid:
- grid-template-areas: '"mush bar"'
- grid-template-columns: 1fr 1fr
- grid-template-rows: 100%
custom_fields:
mush:
- filter: opacity(100%)
- overflow: visible
bar:
- overflow: visible
custom_fields:
mush:
card:
type: custom:mushroom-template-card
tap_action:
action: more-info
entity: '[[[ return entity.entity_id ]]]'
icon_color: '[[[ return variables.color ]]]'
secondary: '[[[ return variables.name ]]]'
primary: >-
[[[ return entity.state + "/" + states[variables.max_entity].state + " "
+ variables.units ]]]
icon: '[[[ return variables.icon ]]]'
card_mod:
style: |
ha-card {
padding: 0px !important;
padding-bottom: 3px !important;
text-align: left !important;
border: none !important;
box-shadow: none !important;
background: none !important;
bar:
card:
type: custom:bar-card
max: '[[[ return states[variables.max_entity].state ]]]'
min: 0
unit_of_measurement: >-
[[[ return "/ " + states[variables.max_entity].state + " " +
variables.units ]]]
decimal: 0
entity_row: true
positions:
icon: 'off'
indicator: 'off'
minmax: inside
title: 'off'
value: 'off'
style: |-
.contentbar-direction-right {
flex-direction: row;
bar-card-contentbar {
align-items: flex-end;
display: flex;
justify-content: space-between;
bar-card-backgroundbar, bar-card-currentbar {
left: 0px !important;
bar-card-iconbar {
color: white;
bar-card-name {
margin-top: 2px;
margin-bottom: 2px;
margin-left: 2px;
margin-right: 2px;
font-size: 1em;
font-weight: bold;
color: white;
bar-card-value {
margin-top: 2px;
margin-bottom: 2px;
margin-left: 2px;
margin-right: 2px;
font-size: 1em;
font-weight: bold;
color: white;
bar-card-max {
display: none;
bar-card-divider {
display: none;
.min-direction-right {
display: none;
Do you have any ideas what I’m doing wrong? Thanks in advance.
Cheers
I had the Same Problem after one of the Last Updates. I removed that Card.
Oh, okay. Thanks for the info.
Heaps of inspiration from here so thanks everyone, I like to keep mine super simple so most of the cards are pop-up to cameras or weather tab etc. Yell out if you would like any code for the below.
Cheers
What theme are you using?
I just wanted to make everyone aware, that this should have been a show-off topic!
It is very clearly stated in the first post, what should go here, and what not!
This topic was meant to show people what is possible, and not to answer questions how this is achieved. We have another topic for that!
People who are looking for inspiration have to scroll through all that clutter and useless questions, where this was meant to show pictures and code!
Please refrain from cluttering this topic any further and be so kind to just use this topic, as it was intended by the OP.
Room card “mushroom style”
I had quite a struggle to adapt a room card to mushroom style without too mush modification. Hereafter the state I currently keep.
Massive use of pop-ups with tap actions on the buttons, and hold action on buttons allows quick control of functions…
All description and code are available (and updated…) on the French forum here: [Carte] Mise en forme de ma mushroom room-card et tuto - Interface / Lovelace / Thème / Custom Card - Home Assistant Communauté Francophone
Plus a simpler variation with step by step tuto to install there (room card for dummies): [Carte] Mise en forme de ma mushroom room-card et tuto - #12 par BBE - Interface / Lovelace / Thème / Custom Card - Home Assistant Communauté Francophone
Picture of the cards:
Basic format :
Horizontal format:
You must have missed my post above or the first post in this topic, unfortunately. That’s no problem, I’ll quote it again for you:
To resolve this, I took the liberty to report your post as off-topic. Please use the aformentioned topic to ask questions or send a PM to the user.
The topic is here:
And this is the link to @ingo.niehues
profile summary, where you can send a PM to him, in the top right corner is a button “Message”.
Thank you very much for your understanding
I read the code but the cards are duplicated in two sites desktop and mobile, how are managed in desktop version?
Hello can you share this card, please? i can’t find them on the forums.
Thanks!
Sorry for a very late response. But if you still are interested here’s the code for the card.
type: tile
entity: fan.ceiling_fan
vertical: false
features:
- type: fan-speed
Here it is with the animated fan.
type: tile
vertical: false
features:
- type: fan-speed
card_mod:
style: |
ha-state-icon {
{% if is_state(config.entity, 'on') %}
animation: rotate .5s infinite linear}
@keyframes rotate {
0% {
transform: rotate(0deg);
100% {
transform: rotate(-359deg);
Might be a niche use case:
I wanted a way to see the fluid level in my watering tank, so I used the background to represent the fluid level:
card_mod:
style:
mushroom-shape-icon$: |
.shape {
background: linear-gradient(0deg, rgba(96, 125, 139, 0.3) calc( {{ states('sensor.wassertank') }}% / 0.62 ), rgba(96, 125, 139, 0.12) 0.1%) !important;
This effectively sets the background to a gradient with minimal transition. !important
is used as usual to overwrite the background color.
Might also be a nice way to show percentage progress of something, e.g. washing machine or similar. Thank you!
By modifying the angle (0deg → 90deg) this would work nicely as a progress indicator. Correct.
Good morning everyone.
I really tried to search for the answer but i wasnt successful.
So i try here and hope not to get fried.
I am using them as well and i am playing with the tab action.
Can i actually open something else then just the entity that is set for one specific card?
Can i open for example a different card or a grid card or something totally different like a pop up card?
That would be awesome
Thx for any thoughts
Think its appropriate to post this here too
Here’s my mushroom-style Home Summary Page. Still very much a work in progress (as always), but I’m very happy with how it’s looking.
(Special thanks to @rhysb and @dimitri.landerloos for putting the work into making the animated icons with card_mod!)
Weather Warnings: 4 separate conditional cards pulling data from my weather integration (Environment Canada) that only show when there is an active weather alert.
type: vertical-stack
cards:
- type: conditional
conditions:
- entity: sensor.thermal_comfort_frost_risk
state: high
card:
primary: Frost Alert
secondary: >-
Frost likely to occur when tempearature reaches {{
states('sensor.thermal_comfort_frost_point') | round(1) }}°C
icon: mdi:snowflake-alert
icon_color: red
tap_action:
action: more-info
- type: conditional
conditions:
- entity: sensor.WEATHERENTITY_statements
state: '1'
card:
primary: '{{ state_attr(''sensor.WEATHERENTITY_statements'', ''alert_1'') }}'
secondary: >-
{{ state_attr('sensor.WEATHERENTITY_statements', 'alert_time_1')
icon: mdi:alert-circle
icon_color: blue
tap_action:
action: url
url_path: ## YOUR URL PATH HERE
badge_icon: ''
fill_container: false
- type: conditional
conditions:
- entity: sensor.WEATHERENTITY_advisory
state: '1'
card:
primary: '{{ state_attr(''sensor.WEATHERENTITY_advisory'', ''alert_1'') }}'
secondary: '{{ state_attr(''sensor.WEATHERENTITY_advisory'', ''alert_time_1'') }}'
icon: mdi:alert
icon_color: amber
tap_action:
action: url
- type: conditional
conditions:
- entity: sensor.WEATHERENTITY_watches
state: '1'
card:
primary: '{{ state_attr(''sensor.WEATHERENTITY_watches'', ''alert_1'') }}'
secondary: '{{ state_attr(''sensor.WEATHERENTITY_watches'', ''alert_time_1'') }}'
icon: mdi:alert
icon_color: orange
tap_action:
action: url
- type: conditional
conditions:
- entity: sensor.WEATHERENTITY_warnings
state: '1'
card:
primary: '{{ state_attr(''sensor.WEATHERENTITY_warnings'', ''alert_1'') }}'
secondary: '{{ state_attr(''sensor.WEATHERENTITY_warnings'', ''alert_time_1'') }}'
icon: mdi:alert
icon_color: red
tap_action:
action: url
card_mod:
style: |
ha-state-icon {
animation: pulse 3s ease-in-out infinite;;
@keyframes pulse {
100% {opacity: 0;}
- type: conditional
conditions:
- condition: state
entity: sensor.WEATHERENTITY_endings
state: '1'
card:
primary: '{{ state_attr(''sensor.WEATHERENTITY_endings'', ''alert_1'') }}'
secondary: '{{ state_attr(''sensor.WEATHERENTITY_endings'', ''alert_time_1'') }}'
icon: mdi:clock-check
icon_color: grey
tap_action:
action: url
Garbage Collection: template card using custom schedule sensors
primary: Garbage Collection
secondary: |-
{% if states('sensor.garbage_collection') == '0' %}
Today between 8-9AM
{% elif states('sensor.garbage_collection') == '1' %}
Tomorrow between 8-9AM
in {{ states('sensor.garbage_collection') }} days
icon: |-
mdi:trash-can
mdi:trash-can-outline
entity: sensor.garbage_collection
icon_color: |-
green
amber
disabled
tap_action:
action: more-info
hold_action:
action: more-info
visibility:
- condition: numeric_state
below: 2
Weather Summary: The actual summary is provided by my weather integration (Environment Canada), but I imagine you could create something similar with a template.
For this card, I also created 2 separate template sensors: "sensor.weather_icon_colour" which provides a colour value for the card icon based on the weather condition, and "sensor.weather_condition_easy" which makes the current condition more “grammatically correct” for the card (see the primary text on the card). The icons are also animated (check the forum for more animation options), and there’s several conditional chips for different information (the chips will also scroll horizontally when they won’t fit in the card width).
type: custom:stack-in-card
cards:
primary: >-
Its currently {{ states('sensor.WEATHERENTITY_temperature') | round(0)
}}°C outside and {{ states('sensor.weather_condition_easy') }}.
secondary: '{{ states(''sensor.WEATHERENTITY_summary'') }}'
icon: |-
{% if is_state('weather.WEATHERENTITY_forecast', 'clear-night') %}
mdi:weather-night
{% elif is_state('weather.WEATHERENTITY_forecast', 'partlycloudy') %}
{% if is_state('sun.sun', 'below_horizon') %}
mdi:weather-night-partly-cloudy
mdi:weather-partly-cloudy
mdi:weather-{{ states('weather.WEATHERENTITY_forecast') }}
multiline_secondary: true
tap_action:
action: navigate
navigation_path: /mu-main/weather
icon_color: '{{ states(''sensor.weather_icon_colour'') }}'
card_mod:
style: |
{% set weather_code = states('weather.WEATHERENTITY_forecast') %}
{% if weather_code == 'clear-night' %}
ha-state-icon {
animation: moon 10s linear infinite, stars 5s linear infinite;
@keyframes moon {
0%, 100% { transform: rotate(12deg); }
30% { transform: rotate(-6deg); }
45% { transform: rotate(8deg); }
75% { transform: rotate(-10deg); }
@keyframes stars {
0%, 3.1%, 14.1% { clip-path: inset(0 0 0 0); }
3% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 99% 62%, 68% 62%, 62% 44%, 76% 34%, 100% 34%, 99% 0%); }
14% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 100% 25%, 51% 45%, 38% 34%, 36% 0); }
{% elif weather_code == 'partlycloudy' %}
ha-state-icon {
animation: cloudy 10s ease-in-out infinite, sun 2s infinite;
@keyframes cloudy {
0%, 100% { transform: translateX(3px); }
30% { transform: translateX(-1px); }
45% { transform: translateX(1.5px); }
75% { transform: translateX(-3.2px); }
{% elif weather_code == 'cloudy' %}
ha-state-icon {
@keyframes cloudy {
{% elif weather_code == 'pouring' %}
ha-state-icon {
animation: cloudy 10s ease-in-out infinite, rain 1s infinite;
@keyframes cloudy {
@keyframes rain {
0%, 50%, 100% { clip-path: inset(0 0 0 0); }
25% { clip-path: polygon(0 0, 100% 0, 100% 83%, 54% 83%, 62% 47%, 47% 46%, 38% 83%, 0 83%); }
75% { clip-path: polygon(0 0, 100% 0, 100% 70%, 75% 70%, 80% 48%, 63% 48%, 54% 94%, 32% 94%, 46% 46%, 30% 46%, 23% 72%, 0 72%); }
{% elif weather_code == 'rainy' %}
ha-state-icon {
animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;
@keyframes cloudy {
@keyframes rain {
50% { clip-path: polygon(0 0, 100% 0, 100% 73%, 71% 73%, 50% 39%, 29% 73%, 0 73%); }
{% elif weather_code == 'snowy' %}
ha-state-icon {
animation: cloudy 10s ease-in-out infinite, snow 4s infinite;
@keyframes cloudy {
@keyframes snow {
50% { clip-path: polygon(0 0, 100% 0, 100% 100%, 65% 100%, 76% 73%, 57% 49%, 34% 56%, 26% 79%, 37% 100%, 0 100%); }
51% { clip-path: inset(0 0 0 0); }
{% elif weather_code == 'fog' %}
ha-state-icon {
animation: cloudy 10s ease-in-out infinite, fog 4s infinite;
@keyframes cloudy {
@keyframes fog {
0%, 26%, 76%, 100% { clip-path: inset(0 0 0 0); }
25% { clip-path: polygon(0 0, 100% 0, 100% 59%, 60% 59%, 60% 74%, 100% 74%, 100% 100%, 0 100%); }
75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 26% 100%, 26% 76%, 0 76%); }
{% elif weather_code == 'windy' %}
ha-state-icon {
animation: cloudy 10s ease-in-out infinite;
transform-origin: 15% 50%
@keyframes cloudy {
0%, 100% { transform: scaleX(1.2); }
30% { transform: scaleX(0.9); }
45% { transform: scaleX(1.1); }
75% { transform: scaleX(0.8); }
{% elif weather_code == 'sunny' %}
ha-state-icon {
animation: spin 6s ease-in-out infinite alternate;
{% elif weather_code == 'lightning' %}
ha-state-icon {
animation: cloudy 10s ease-in-out infinite, lightning 4s infinite;
@keyframes cloudy {
@keyframes lightning {
10%, 15% { clip-path: polygon(0 0, 100% 0, 100% 100%, 47% 100%, 69% 55%, 66% 40%, 48% 39%, 24% 100%, 0 100%); transform: scale(1.1); }
10.1%, 15.1% { clip-path: inset(0 0 0 0); transform: scale(1); }
chips:
- type: conditional
conditions:
- condition: state
entity: sun.sun
state: below_horizon
chip:
type: entity
entity: sensor.sun_next_rising
icon: mdi:weather-sunset-up
icon_color: orange
use_entity_picture: false
- type: conditional
conditions:
- condition: state
entity: sun.sun
state: above_horizon
chip:
type: entity
entity: sensor.sun_next_setting
icon: mdi:weather-sunset-down
icon_color: deep-orange
- type: entity
entity: sensor.WEATHERENTITY_humidity
icon_color: cyan
icon: mdi:water-opacity
- type: conditional
conditions:
- condition: state
entity: sensor.WEATHERENTITY_chance_of_precipitation
state_not: unknown
chip:
type: entity
tap_action:
action: more-info
hold_action:
action: more-info
icon: mdi:weather-rainy
icon_color: light-blue
- type: conditional
conditions:
- condition: state
entity: sensor.WEATHERENTITY_wind_chill
state_not: unknown
chip:
type: template
icon: mdi:weather-windy-variant
icon_color: cyan
content: '{{ states(''sensor.WEATHERENTITY_wind_chill'') }}°C Wind Chill'
- type: conditional
conditions:
- condition: or
conditions:
- condition: state
state: high
- condition: state
state: probable
chip:
type: template
icon_color: blue
content: Frost Risk
- type: conditional
conditions:
entity: sensor.WEATHERENTITY_wind_speed
above: 0
chip:
type: template
icon_color: grey
content: >-
{{ states('sensor.WEATHERENTITY_wind_speed') }}km/h {{
states('sensor.WEATHERENTITY_wind_direction') }}
tap_action:
action: more-info
- type: conditional
conditions:
entity: sensor.WEATHERENTITY_aqhi
above: 4
chip:
type: template
icon: mdi:air-filter
icon_color: |-
{% set aqhi = states('sensor.WEATHERENTITY_aqhi') | int %}
{% if aqhi >= 8 %}
red
{% elif aqhi >= 6 %}
orange
{% elif aqhi > 3 %}
amber
green
content: |-
{% if aqhi >= 8 %}
AQHI Very High
AQHI High
{% elif aqhi > 3 %}
AQHI Moderate
AQHI Low
({{ states('sensor.WEATHERENTITY_aqhi') }})
- type: conditional
conditions:
- condition: state
entity: sun.sun
entity: sensor.WEATHERENTITY_uv_index
above: 4
chip:
type: template
icon: mdi:sun-wireless
icon_color: |-
{% set uv_index = states('sensor.WEATHERENTITY_uv_index') | int %}
{% if uv_index >= 8 %}
red
{% elif uv_index > 6 %}
orange
{% elif uv_index > 3 %}
amber
green
content: |-
UV Very High
UV High
UV Moderate
UV Low
({{ states('sensor.WEATHERENTITY_uv_index') }})
alignment: left
card_mod:
style: |
ha-card {
margin: -10px 12px 10px;
--chip-border-width: 0;
--chip-box-shadow: 0;
--chip-background: #9E9E9E20;
ha-card > .chip-container {
flex-wrap: nowrap;
overflow-x: scroll;
ha-card > .chip-container > * {
flex-shrink: 0;
Climate Summary: First, I made a “HVAC Action” template sensor to record the current action of the thermostat (I think this is redundant, but I was planning on using it for other things and wanted it to be readily available):
{{ state_attr('climate.nest_thermostat_name', 'hvac_action') }}
Then, I made the following Historical Stats sensors in my configuration.yaml (can’t make these in the UI yet):
##History Stats
- platform: history_stats
name: Climate Heat Today
entity_id: sensor.hvac_action
state: "heating"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0) }}"
end: "{{ now() }}"
name: Climate Cool Today
state: "cooling"
type: time
end: "{{ now() }}"
name: Climate Heat Yesterday
state: "heating"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0) - timedelta(days=1) }}"
end: "{{ now().replace(hour=0, minute=0, second=0) }}"
name: Climate Cool Yesterday
state: "cooling"
type: time
With the 4 sensors created, I made 2 conditional template cards (one for Cooling and one for Heating) as below which will display “Heated (or Cooled) for __ hours and __ minutes” as the primary and “__hours and __ minutes more/less than yesterday” - if the heating/cooling time is less than yesterday, it will display a badge with a leaf otherwise it will display an up arrow:
(The conditional cards are set to only show the cards if the heating/cooling time is above “0”):
cards:
- type: conditional
conditions:
entity: sensor.climate_heat_today
above: 0
card:
primary: '{{ states(''sensor.climate_heat_time_summary'') }}'
secondary: '{{ states(''sensor.climate_heat_yesterday_summary'') }}'
icon: mdi:home-thermometer-outline
icon_color: red
tap_action:
action: more-info
badge_icon: >-
{% set total_minutes_today = states('sensor.climate_heat_today') | float
* 60 %}
{% set total_minutes_yesterday = states('sensor.climate_heat_yesterday')
| float * 60 %}
{% if total_minutes_today < total_minutes_yesterday %}
mdi:leaf
mdi:chevron-up
badge_color: >-
* 60 %}
| float * 60 %}
green
red
- type: conditional
conditions:
entity: sensor.climate_cool_today
above: 0
card:
primary: '{{ states(''sensor.climate_cool_time_summary'') }}'
secondary: '{{ states(''sensor.climate_cool_yesterday_summary'') }}'
icon_color: blue
tap_action:
action: more-info
badge_icon: >-
{% set total_minutes_today = states('sensor.climate_cool_today') | float
* 60 %}
{% set total_minutes_yesterday = states('sensor.climate_cool_yesterday')
| float * 60 %}
mdi:leaf
mdi:chevron-down
badge_color: >-
* 60 %}
| float * 60 %}
green
red
Calendar: Weekly Planner Card by FamousWolf (GitHub - FamousWolf/week-planner-card: Custom Home Assistant card displaying a responsive overview or multiple days with events from one of multiple calendars)
(NOT SHOWN) Vacation Mode and Guest Mode Cards: Conditional Template cards that indicate if Vacation/Guest Mode is on and what it means for certain schedules or routines (this is for the day my household inevitably decides to use Home Assistant… some day lol).
I would love to know your thoughts and feedback!!
I have now updated this card to the new look of the mushroom cards. I am also using colors more faithfull to the original mushroom colors
follow the directions in the original post to make this work for you.
As last time code is too large to post in 1 post, so i will split it into 2 and you can just add the code in the same card right below eachother.
1st Half of Code
cards:
- type: grid
square: false
columns: 2
cards:
- type: custom:auto-entities
card:
card_mod:
style: |
ha-card {
padding-top: 0px;
padding-bottom: 0px;
padding-right: 30px;
width: 200%;
background: transparent !important;
box-shadow: none;
card_param: cards
filter:
template: >-
{%- for state in states.sensor |
selectattr('entity_id','search','battery_plus') |
selectattr('entity_id','search','lounge') |
rejectattr('entity_id','search','type') |
rejectattr('entity_id','search','last_replaced') -%}
'type': 'custom:bar-card',
'entity': state.entity_id,
'name': state.attributes.friendly_name.split(' Battery')[0].split(' battery')[0].split('Lounge')[1],
'card_mod':
'style': 'bar-card-currentbar, bar-card-backgroundbar {
border-radius: 12px !important;
height: 36px !important;
margin-top: -7px !important;
width: calc(100% + 56px);
left: -4%;
ha-icon {
position: relative;
padding: 8px;
border-radius: 50%;
--mdc-icon-size: 21px;
margin-top: -19px;
right: 8px;
bar-card-name {
display: relative;
font-weight: bold;
width: fit-content;
bottom: 8px;
right: 8px;
bar-card-name:after {
content: "{{states(config.entity)}} %";
display: flex;
position: relative;
font-size: 11px;
font-weight: light;
bottom: 2px;
left: 0px;
{% if states(config.entity) | int(default=unknown) == unknown %}
bar-card-row bar-card-currentbar, ha-icon, bar-card-backgroundbar {
/* Bar color */
--bar-color: #0033ff !important;
/* Icon */
--card-mod-icon: mdi:bug;
@media (prefers-color-scheme: dark) {
/* Dark theme text colors */
bar-card-name {
color: var(--card-primary-color) !important;
filter: invert(1);
color: #cccccc !important;
@media (prefers-color-scheme: light) {
/* Light theme text colors */
bar-card-name {
color: #3b3b3b !important;
{% elif states(config.entity) | int <= 10 %}
/* Bar color */
--bar-color: rgb(244, 67, 54) !important;
/* Icon */
--card-mod-icon: mdi:battery-10 !important;
bar-card-name {
bar-card-name {
{% elif states(config.entity) | int <= 20 %}
/* Bar color */
--bar-color: rgb(255, 111, 0) !important;
/* Icon */
--card-mod-icon: mdi:battery-20 !important;
bar-card-name {
bar-card-name {
{% elif states(config.entity) | int <= 30 %}
/* Bar color */
--bar-color: rgb(255, 152, 0) !important;
/* Icon */
--card-mod-icon: mdi:battery-30 !important;
bar-card-name {
filter: invert(1);
bar-card-name {
{% elif states(config.entity) | int <= 40 %}
/* Bar color */
--bar-color: rgb(255, 193, 7) !important;
/* Icon */
--card-mod-icon: mdi:battery-40 !important;
bar-card-name {
filter: invert(1);
bar-card-name {
{% elif states(config.entity) | int <= 50 %}
/* Bar color */
--bar-color: rgb(255, 235, 59) !important;
/* Icon */
--card-mod-icon: mdi:battery-50 !important;
bar-card-name {
filter: invert(1);
bar-card-name {
{% elif states(config.entity) | int <= 60 %}
/* Bar color */
--bar-color: rgb(205, 220, 57) !important;
/* Icon */
--card-mod-icon: mdi:battery-60 !important;
bar-card-name {
filter: invert(1);
bar-card-name {
{% elif states(config.entity) | int <= 70 %}
/* Bar color */
--bar-color: rgb(139, 195, 74) !important;
/* Icon */
--card-mod-icon: mdi:battery-70 !important;
bar-card-name {
filter: invert(1);
bar-card-name {
{% elif states(config.entity) | int <= 80 %}
/* Bar color */
/* Icon */
--card-mod-icon: mdi:battery-80 !important;
bar-card-name {
filter: invert(1);
bar-card-name {
{% elif states(config.entity) | int <= 90 %}
/* Bar color */
--bar-color: rgb(76, 175, 80) !important;
/* Icon */
--card-mod-icon: mdi:battery-90 !important;
bar-card-name {
filter: invert(1);
bar-card-name {
{% elif states(config.entity) | int <= 100 %}
/* Bar color */
/* Icon */
--card-mod-icon: mdi:battery !important;
bar-card-name {
filter: invert(1);
bar-card-name {
bar-card-row, ha-icon {
color: color-mix(in srgb, var(--bar-color) 100%, transparent) !important;
background: color-mix(in srgb, var(--bar-color) 20%, transparent);
bar-card-indicator {
top: -8px;
bar-card-value {
color: transparent !important;
ha-card {
margin: 0px 0px 0px 0px !important;
height: 54px;
{%- endfor %}
sort:
method: state
numeric: true
count: 1
chips:
- type: template
icon: |-
{% if states(entity) == 'on' %}
mdi:chevron-up
mdi:chevron-down
entity: input_boolean.lounge_battery_dropdown
card_mod:
style: |
ha-card {
top: 10px;
right: 11px;
--chip-icon-size: 23px;
alignment: end
2nd Half of Code
visibility:
- conditon: state
state: 'on'
card:
card_mod:
style: |
ha-card {
padding-top: 0px;
padding-bottom: 18px;
margin: -18px 0px 0px 0px;
background: transparent;
box-shadow: none;
border: none;
card_param: cards
filter:
template: >-
'card_mod':
margin-top: -8px !important;
width: calc(100% + 18px);
left: -3.5%;
ha-icon {
position: relative;
padding: 8px;
border-radius: 50%;
margin-top: -19px;
right: 8px;
bar-card-name {
display: relative;
font-weight: bold;
width: fit-content;
bottom: 8px;
right: 8px;
display: flex;
position: relative;
font-size: 11px;
font-weight: light;
bottom: 2px;
left: 0px;
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
/* Bar color */
/* Icon */
bar-card-name {
filter: invert(1);
bar-card-name {
top: -8px;
bar-card-value {
ha-card {
margin: 0px 0px -18px 0px !important;
height: 54px;
}}, {%- endfor %}
sort:
method: state
numeric: true
first: 1
count: 100
