DanySilvaa
(Daniel Silva)
December 7, 2023, 11:19am
185
I’m trying to using your cards but i’m having some problems to use room colors.
For example in my kitchen i have this code:
# Kitchen
- type: custom:button-card
view_layout:
grid-area: room3
template:
- custom_card_andyblac_room
icon: fas:kitchen-set
icon: mdi:silverware-fork-knife
tap_action:
action: navigate
navigation_path: kitchen
variables:
ulm_custom_card_andyblac_room_color: red
ulm_custom_card_andyblac_room_color_on: true
sensor_label_1: sensor.ble_temperature_cozinha
sensor_label_2: sensor.ble_humidity_cozinha
sensor_1:
entity_id: cover.estore_cozinha
entity_2:
entity_id: light.focus_channel_1
ulm_custom_card_andyblac_room_use_light_color: true
entity_3:
entity_id: light.focus_channel_2
Can you please help to understand what i’m doing wrong?
andyblac
(Andy Blackburn)
December 7, 2023, 11:23am
186
have you set your Theme to minimalist-desktop or minimalist-mobile ?
DanySilvaa
(Daniel Silva)
December 7, 2023, 11:24am
187
Thank you for help, i set minimalist-desktop.
DanySilvaa
(Daniel Silva)
December 7, 2023, 11:25am
189
Now i tried to minimalist-mobile but still not working…
andyblac
(Andy Blackburn)
December 7, 2023, 11:26am
190
hmm, can you view the java console, do you see any errors ?
andyblac
(Andy Blackburn)
December 7, 2023, 11:29am
191
you also have ulm_custom_card_andyblac_room_color_on: true, but you have not supplied an entity, try removing this line if not needed.
DanySilvaa
(Daniel Silva)
December 7, 2023, 11:35am
192
Ok, i tried to remove it too but still not working
DanySilvaa
(Daniel Silva)
December 11, 2023, 9:28am
194
I would like to say a big thank you @andyblac for this help and support!
All issues are now corrected.
radekD
(Radek Dohnal)
December 12, 2023, 1:35pm
196
Small question about color.
When I set variable ulm_custom_card_andyblac_room_sensor_color_on: red, the icon isnt clearly red but lightly red
and when I try to definy colour in rgb style ulm_custom_card_andyblac_room_sensor_color_on: rgb(255, 255, 0) then the icon color is white.
Also tha colour of card isn same as colour of icon (card is little lighter)
view_layout:
grid-area: room108
template:
icon: mdi:bed-empty
tap_action:
action: navigate
navigation_path: loznice
variables:
ulm_custom_card_andyblac_room_color: blue
sensor_1:
entity_id: binary_sensor.mg_108_loznice
icon: mdi:window-open-variant
sensor_2:
entity_id: binary_sensor.pir_108_loznice
icon: mdi:motion-sensor
sensor_3:
entity_id: media_player.108_loznice
icon: mdi:play-pause
sensor_4:
entity_id: cover.zaluzie_jih
icon: mdi:window-shutter
ulm_custom_card_andyblac_room_sensor_color: red
ulm_custom_card_andyblac_room_sensor_color_on: blue
Whats wrong?
Theme set in HA is minimalistic-desktop.
Thanks for help!
andyblac
(Andy Blackburn)
December 12, 2023, 2:22pm
197
hi,
the red colour is from your theme chosen, and atm the card does not support a custom colour like you have tried to define. Make a feature request in my git, and I’ll see if it is possible to do.
Themes are located in /homeassistant/themes, the easiest ways to change, is to duplicate it and make a new theme, don’t just edit the theme as it will be overriden on Minimalist UI update.
here is an example of how to do it, I created a theme called minimalist-andy HA_config_files/themes/minimalist-andy/minimalist-andy.yaml at f15df9a4912e41760f7f766ae32afbbde3e4f921 · andyblac/HA_config_files · GitHub
thats by design, if you mean the room icon is lighter than the off state, but darker than the on state, it so you can clearly see the state of the entities. Remember the room icon can also have a state.
andyblac
(Andy Blackburn)
December 13, 2023, 11:50am
198
i’m in the process of adding this suoport to all my cards (beta should be in dev branch soon)
view_layout:
grid-area: room10
template:
icon: mdi:desk
tap_action:
action: navigate
navigation_path: office
variables:
ulm_custom_card_andyblac_room_color: rgb(245,90,49)
sensor_label_1: sensor.wiser_lts_temperature_office
sensor_label_2: sensor.wiser_lts_humidity_office
climate:
entity_id: climate.wiser_office
sensor_1:
entity_id: binary_sensor.office_door_contact
sensor_2:
entity_id: cover.office_window_shade
sensor_5:
entity_id: switch.office_socket_1_left
tap_action:
action: toggle
sensor_6:
entity_id: switch.office_socket_1_right
tap_action:
action: toggle
entity_3:
entity_id: light.office_dimmer
ulm_custom_card_andyblac_room_icon_color_on: amber
andyblac
(Andy Blackburn)
December 13, 2023, 3:42pm
199
this is now supported in the latest Dev branch, @radekD please test it report back if it works for you, the alpha channel (transparency) is hardcoded, it you want rgba to be supported i can add that too, but it is more work.
radekD
(Radek Dohnal)
December 13, 2023, 7:53pm
200
Hello.
Thanks for this modification. Set card color by code
ulm_custom_card_andyblac_room_color: rgb(116,216,255)
works perfect:
But is a problem with light icon - off state = dark grey (ok), on state = light grey (not ok). On state of light should be yellow, not light grey.
And one qustion about cover. Why the red color of cover is different from red color of TV (sensors).
template:
icon: mdi:sofa
tap_action:
action: navigate
navigation_path: obyvak
variables:
sensor_5:
entity_id: cover.zaluzie_vychod_zahrada
ulm_custom_card_andyblac_room_sensor_color_on: lightblue
sensor_6:
entity_id: media_player.televize_v_obyvaku
icon: mdi:television
andyblac
(Andy Blackburn)
December 13, 2023, 8:54pm
201
the light grey is from your theme, if you have not set a on colour or using ulm_custom_card_andyblac_room_use_light_color: true can you tell me what have you got set for on colour ? for example:
entity_3:
looks ok here.
can you post the full code for that room.
EDIT:
on a second look, it looks like your covers are closed ie in off state, and therfore it darker, TV is in on state therefore brighter.
as I said above if you want to also control the alpha channel (brightness) , i’ll need to add support for rgba ie rgba(255,0,0,100)
radekD
(Radek Dohnal)
December 13, 2023, 9:24pm
202
Light color - my fault. I used ulm_card_room_use_light_color: true instead of ulm_custom_card_andyblac_room_icon_color_on: amber. Now it works perfect!
Cover icon color - You are right that TV is On state and cover is Closed state. Now I understand that color difference. So each icons with on/open state is always lighter and each icon with off/closed state is alway darker - right? Its hardcoded (without possibility of change) or I can set the brightness of on/open state?
Overall it will be perfect, if you add support for rgba color. Primary I would like to use red color for all on states and closed covers and darker color (set by card color) for all icons with off states and open cover.
andyblac
(Andy Blackburn)
December 13, 2023, 9:32pm
203
correct
correct, it’s hard coded, I could add rgba support, but this will not work with theme colour names, you would have to use rgba(255,0,0,100) for example.
radekD
(Radek Dohnal)
December 14, 2023, 7:32am
204
Its ok, that theme colour names not works, when there will be rgba possibility.
andyblac
(Andy Blackburn)
December 14, 2023, 9:56am
205
ok, i’ll try to add support today, for sensors.
