another idea to avoid penalizing the length of the name would be like this! …now I’ll try to understand if I can do it with my skills
this option is way easier, but be-careful check it fits, when use only 3 or 2 entity buttons, as they change size. (entity_2, entity_3, entity_4 and entity_3, entity_4)
another option, could be, to recode so that the room card and the room button and do different actions, like I did for the status button. (the large circle button vs the outside area)
I can do it! I know how to do it!
https://github.com/mon3y78/UI-Minimalist-Custom-Cards/blob/ed647c038d3dc8ca5c1fe68d502eff36bf7f3d96/custom_cards/custom_card_andyblac_room/custom_card_andyblac_room.yaml
Thanks for getting back to me. It could not hurt to mention in the docs what clicking on each area of the card does. Originally I didn’t have it set up right for the popup, but noticed I could click on both the title and icon even though nothing happened. When I got the popup built I then for some reason just kept trying to click on the title and didn’t even think of clicking on the icon. More than anything, it was just me not making the connection.
If I have any more trouble with the cards I will definitely reach out for help. The main thing I am dealing with is just reading through all of the code to make sure I understand what everything is doing so that I can adjust it appropriately for my setup. I have many years of coding experience so the logic is easy, just takes a moment to recognize the different language format at times. Also does not help that it is a combination of yaml, java, css, etc…
Again, great job on these.cards.
@andyblac What are you using to determine your person eta zone distance? I was thinking of you the proximity sensor but I want to make sure I am returning the correct value for the person card.
I use an entity from iCloud v3 integration sensor.andys_iphone_icloudv3_zone_distance
Are you creating your own sensor using that data? If so can you share the code to create it? I looked through you git and did not find anywhere that you have that sensor defined if you did.
On another topic, I kind of ran into an issue last night when I couldn’t figure out where and what macro you had created for jinja. After a bit of searching I found it earlier in this thread the code you created and got things working. Not sure if you want to upload that to the git repo for people to more easily get the code.
Thanks a lot for taking the time to respond to all these questions.
as i explained above, no it come with the iCloud3 V3 integration.
regarding the jinja macro, i thought i had included it, if not i’ll will upload it.
EDIT:
here is the current macro file
https://github.com/andyblac/HA_config_files/blob/8947994b7eeaefb164b11ec0b79b0d4956296100/custom_templates/tools.jinja
Thanks for the updated macro. Much appreciated.
Another question. In the status sensors template file for the lights I am seeing that the browser mod screen is showing as a light entity. How do you handle filtering out the browser mod screen as a light entity or do you just accept it is there. I’ve been trying to filter it out of the list, but have had no luck so far.
Here is what I am seeing:
i just disabled the entity, as I did not use it.
this what it looks like
I’ve added the proximity integration which allows me to provide the distance from home. Hopefully it works, but I won’t know until I leave the house to find out…lol.
By the way, where did you get your avatars for the person entity?
there just apple emojis
@iPilla I am interested in how you added the camera entity to your room card. I tried to find it in you git but could not see where you made any changes. I also could not find anything in your fork of andyblac’s HA_config_files. I have currently 3 room cards I would like to add the camera to and provide a popup when clicked. If you can provide your code for the room card and let me know if there is a need to modify the custom_card_anyblac_room.yaml I would greatly apreaciate it.
you can use my Dev. if you need help I’m available. let me know if you like it
https://github.com/mon3y78/UI-Minimalist-Custom-Cards/tree/dev
I simply added 2 sections to the file which you can find by searching for “video:”.
then you will have to add to the variables:
video:
entity_id: camera.example
icon: mdi:cctv
as you can see you can customize the icon.
Perfect, that is exactly what I was looking for. Thank you very much. Now I can slowly work through adding the rest of the room cards. I also realize I need to get my hands on a lot more smart switches, outlets, and multi sensors.
It is sad that the further I get into HA the more I realize I need to purchase to be able to automate things.
I find it very convenient to use entities with @andblac’s pop-up cards. inside these I exploit auto-entities so if I add/remove decices I don’t have to touch the code.
entity_2:
entity_id: sensor.camera_luci_on
popup_content: !include popups/rooms/camera/camera-luci.yaml
templates:
- custom_popup_andyblac_hold
- custom_popup_andyblac_tap
type: custom:auto-entities
card:
type: entities
title: luci camera
show_header_toggle: true
filter:
include:
- domain: light
area: camera_da_letto
exclude:
- name: /[Dd][Nn][Dd]/
sort:
method: state
Hello.
Is it possible to have sensor for cover that change color when cover are in state ‘closed’?
I try this code, but it doesn change the color from blue to red when cover are closed…
For other sensors (magnetic contats, motion sensor) in works ok.
- type: custom:button-card
view_layout:
grid-area: room109
template:
- custom_card_andyblac_room
icon: mdi:faucet
tap_action:
action: navigate
navigation_path: kuchyne
variables:
ulm_custom_card_andyblac_room_color: blue
sensor_label_1: sensor.teplota_kuchyne
sensor_1:
entity_id: binary_sensor.mg_109_kuchyne
icon: mdi:window-open-variant
ulm_custom_card_andyblac_room_sensor_color_on: red
sensor_2:
entity_id: binary_sensor.pir_109_kuchyne
icon: mdi:motion-sensor
sensor_3:
entity_id: media_player.109_kuchyne
icon: mdi:play-pause
sensor_4:
entity_id: cover.109_zaluzie_jih_zahony
icon: mdi:window-shutter
hi, for covers on is treated as open, so if you want red for close and blue to be open
try this:
sensor_4:
ulm_custom_card_andyblac_room_sensor_color: red
ulm_custom_card_andyblac_room_sensor_color_on: blue
